英特尔 BayTrail4代凌动4核E3845 主板PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEAT_ATX1SK12D02_D90SLIDE SWITCH 1P2T_D90SK12D02_D90BAT1BH800-9_S180BATTERY HOLDERCR2032LBH800-9_S180BTB_FH1FH25X2_1D27M_S180FEMALE HEADER2X25_1.27MM_S180FH25X2_1D27M_S180BTB_PH1PH25X2_1D27M_H_S180PIN HEADER2X25_1.27MM_S180PH25X2_1D27M_H_S180BZ1BZ_250BUZZERBZ_250CFAST1CFAST_S90_PP-1CFAST SOCKET_H=8.35MMCFAST_S90_PP-1CLR_CMOS1DIP2A-300SW1X1_D180(EDS101SZ)DIP2A-300COM12_SEL1KDCON5X2_2MPIN HEADER2X5_2.0MM_D180KDCON5X2_2MCOM1_1DCON9MCOM9M_D90DCON9MCOM2_1DCON9MCOM9M_D90DCON9MCOM34_SEL1KDCON5X2_2MPIN HEADER2X5_2.0MM_D180KDCON5X2_2MCOM3_1DCON9M-TCOM9M_THIN_D90DCON9M-TCOM4_1DCON9M-TCOM9M_THIN_D90DCON9M-TD11N5817ASS14(1N5819)1N5817AD2BAT54S_132BAV99_SOT23BAT54S_132D3BAT54S_132BAV99_SOT23BAT54S_132D4BAT54S_132BAV99_SOT23BAT54S_132D5BAT54S_132BAV99_SOT23BAT54S_132D6BAT54S_132BAV99_SOT23BAT54S_132D7BAT54_132BZX84C51_SOT23BAT54_132D8SMA-LSFM1100LSSMA-LSD91N5817ASS14(1N5819)/NC1N5817AD10SOD123MMSZ5226B-TG_SOD-123SOD123D11SOD123MMSZ5226B-TG_SOD-123SOD123D12SOD123MMSZ5226B-TG_SOD-123SOD123D13SM1206D_AC1N4148WSM1206D_ACD14SM1206D_AC1N4148WSM1206D_ACD15SOD123MMSZ5226B-TG_SOD-123SOD123D16SOD123MMSZ5226B-TG_SOD-123SOD123D17BAT54S_132BAV99_SOT23BAT54S_132D18SM1206D_AC1N4148WSM1206D_ACD19SOD123MMSZ5226B-TG_SOD-123SOD123D20SOD123MMSZ5226B-TG_SOD-123SOD123D21SOD123MMSZ5226B-TG_SOD-123SOD123D22SM1206D_AC1N4148WSM1206D_ACD23BAT54C_132BAT54C_SOT23BAT54C_132D24BAT54_132BZX84C51_SOT23BAT54_132D25BAT54_132BZX84C51_SOT23BAT54_132D26BAT54_132BZX84C51_SOT23BAT54_132D27BAT54_132BZX84C51_SOT23BAT54_132D28BAT54C_132BAT54C_SOT23BAT54C_132D29SM1206D_AC1N4148WSM1206D_ACD30SM1206D_AC1N4148WSM1206D_ACD31SM1206D_AC1N4148WSM1206D_ACD32SM1206D_AC1N4148WSM1206D_ACD33BAT54C_132BAS21A_SOT23BAT54C_132D341N5817ASS14(1N5819)1N5817AD35SM1206D_AC1N4148WSM1206D_ACD36SM1206D_AC1N4148WSM1206D_ACD37SMA-LSFM1100LSSMA-LSD38SM1206D_AC1N4148WSM1206D_ACD391N5817ASS14(1N5819)1N5817AD401N5817ASS14(1N5819)1N5817AD41SM1206D_AC1N4148WSM1206D_ACD42SM1206D_AC1N4148WSM1206D_ACD43SM1206D_AC1N4148WSM1206D_ACD44SM1206D_AC1N4148WSM1206D_ACDC_IN15EHDRM-03P_5MM5EHDRM-03P_D905EHDRM-03P_5MMDEBUG1KDCON7X2_2MPIN HEADER2X7_2.0MM_D180KDCON7X2_2MDIO1ECH350R-10PECH350R-10P_D90ECH350R-10PDIO_PWR15EHDRM-03P_5MM5EHDRM-03P_D905EHDRM-03P_5MMDIO_PWR2CON2X2_165A3ATX MALE CONNECTOR2X2_4.2MM_D180CON2X2_165A3DIO_TEST1ECH350R-10PECH350R-10P_D90ECH350R-10PDP1DP_WDPE20_D90DISPLAYPORT_20H_D90DP_WDPE20_D90DVI_I1DVI30ADVI-I CONNECTORDVI30AESD1SOT23-6SESD099-04AT1_SOT23-6SOT23-6ESD2SOT23-6SESD099-04AT1_SOT23-6SOT23-6ESD3SOT23-6SESD099-04AT1_SOT23-6SOT23-6ESD4SOT23-6SESD099-04AT1_SOT23-6SOT23-6ESD5DFN4120P10EAZ1065-06F_DFN4120P10EDFN4120P10EESD6SOT23-6SESD099-04AT1_SOT23-6SOT23-6ESD7SOT23-6SESD099-04AT1_SOT23-6SOT23-6ESD8SOT23-6SESD099-04AT1_SOT23-6SOT23-6ESD9SOT23-6SESD099-04AT1_SOT23-6SOT23-6ESD10SOT23-6SESD099-04AT1_SOT23-6SOT23-6ESD11SOT23-6SESD099-04AT1_SOT23-6SOT23-6FS1FUSE_0456BRICK 125V/20A_SMDFUSE_0456FS2FUSE_SMDFUSE_13V/2.6AFUSE_SMDFS3FUSE_SMDFUSE_16V/1.25AFUSE_SMDFS4FUSE_SMDFUSE_16V/1.25AFUSE_SMDFS5FUSE_SMDFUSE_16V/1.25AFUSE_SMDH1MTH276_138138 DRILL / 276PADMTH276_138JP1JH2X4-HDPIN HEADER2X4_2.54MM_D180JH2X4-HDL1SM0603LBEAD 30SM0603LL2SM0603LBEAD 30SM0603LL3SM0603LBEAD 30SM0603LL4SM0603LBEAD 30SM0603LL5SM0603LBEAD 30SM0603LL6SM0603LBEAD 30SM0603LL7SM0603LBEAD 30SM0603LL8SM0603LBEAD 30SM0603LL9ZPWM-10400.36UH/30A_ZPWM-1040MA-R36_S180ZPWM-1040L10SER14000.3UH/49.6A_SER1408-301MED_S180/NCSER1400L11SM0603LBEAD 30SM0603LL12SM0603LBEAD 30SM0603LL13SER2900SER2915L-103KL_S180SER2900L14SLPG1307SLPG1307-100M_S180/NCSLPG1307L15APL1108P-R30M0.3UH/41A_APL1108P-R30-AX_D180/NCAPL1108P-R30ML16SER14000.3UH/49.6A_SER1408-301MED_S180SER1400L17TYL17X10GRT-CM127125-3R0N-40110_D180/NCTYL17X10L18SER14002.0UH/18.5A_SER1412-202ME_S180SER1400L19SER14000.3UH/49.6A_SER1408-301MED_S180SER1400L20APL1108P-R30M0.3UH/41A_APL1108P-R30-AX_D180/NCAPL1108P-R30ML21SER14002.0UH/18.5A_SER1412-202ME_S180SER1400L22TYL17X10GRT-CM127125-3R0N-40110_D180/NCTYL17X10L23SER14000.3UH/49.6A_SER1408-301MED_S180/NCSER1400L24ZPWM-10400.36UH/30A_ZPWM-1040MA-R36_S180ZPWM-1040L25SER14002.0UH/18.5A_SER1412-202ME_S180SER1400L26TYL17X10GRT-CM127125-3R0N-40110_D180/NCTYL17X10L39SM0805LBEAD 30(0805)SM0805LLAN1RJ45_RT7-174AAM1ARJ45+TRANSFORMERLEDRJ45_RT7-174AAM1ALAN2RJ45_RT7-174AAM1ARJ45+TRANSFORMERLEDRJ45_RT7-174AAM1ALED1A694BLEDHOLDER(GREEN/YELLOW)_3MM_D90A694BLED1_1A694BLEDHOLDER(GREEN/YELLOW)_3MM_D90A694BLED2_1A694BLEDHOLDER(GREEN/YELLOW)_3MM_D90A694BLED3_1A694BLEDHOLDER(GREEN/YELLOW)_3MM_D90A694BLED4_1A694BLEDHOLDER(GREEN/YELLOW)_3MM_D90A694BLINE_OUT1AJ_424-05211T02_D90PHONEJACK STEREOSW(GREEN)AJ_424-05211T02_D90MIC1AJ_424-05211T02_D90PHONEJACK STEREOSW(PINK)AJ_424-05211T02_D90MINIPCIE1MINIPCIE_52MINI-PCIE_5.6MMMINIPCIE_52MINIPCIE2MINIPCIE_52MINI-PCIE_5.6MMMINIPCIE_52NUT1H264P4-MTH_MTNUT_M2_5.6MMH264P4-MTH_MTNUT2H264P4-MTH_MTNUT_M2_5.6MMH264P4-MTH_MTNUT3H264P4-MTH_MTNUT_M2_5.6MMH264P4-MTH_MTNUT4H264P4-MTH_MTNUT_M2_5.6MMH264P4-MTH_MTOSC1OSC-5X3OSC-48MHZ_4P/SMDOSC-5X3POWER1CON4_BWAFER 1X4_2.0MM_D180CON4_BPS2_1CON6_BWAFER 1X6_2.0MM_D180CON6_BPWR_SW1TC006-N12AAATC006-N12AAAXXXX-3TC006-N12AAAQ1SOT23_QA2N3904/SOT23SOT23_QAQ2SOT23_QA2N3904/SOT23SOT23_QAQ32N7002B2N7002/SOT232N7002BQ42N7002B2N7002/SOT232N7002BQ52N7002B2N7002/SOT232N7002BQ62N7002B2N7002/SOT232N7002BQ72N7002B2N7002/SOT232N7002BQ82N7002B2N7002/SOT232N7002BQ9POWER56FDMS7694_POWER56POWER56Q10POWER56FDMS7694_POWER56POWER56Q11POWER56FDMS0312S_POWER56POWER56Q12POWER56FDMS0312S_POWER56POWER56Q13POWER56FDMS7694_POWER56POWER56Q14SOT23_QA2N3904/SOT23SOT23_QAQ152N7002B2N7002/SOT232N7002BQ162N7002BAO3414/SOT232N7002BQ172N7002BAO3414/SOT232N7002BQ182N7002BAO3414/SOT232N7002BQ192N7002BAO3414/SOT232N7002BQ202N7002B2N7002/SOT232N7002BQ212N7002BAO3414/SOT232N7002BQ22SOT23_QA2N3904/SOT23/NCSOT23_QAQ232N7002BAO3414/SOT232N7002BQ242N7002B2N7002/SOT232N7002BQ252N7002B2N7002/SOT232N7002BQ262N7002BAO3414/SOT232N7002BQ272N7002BAO3414/SOT232N7002BQ282N7002BAM2324N-T1-TRG_SOT232N7002BQ292N7002BAM2324N-T1-TRG_SOT232N7002BQ302N7002BAM2324N-T1-TRG_SOT232N7002BQ312N7002BAM2324N-T1-TRG_SOT232N7002BQ322N7002B2N7002/SOT232N7002BQ33POWER56FDMS86300DC_POWER56POWER56Q34POWER56FDMS8333L_POWER56POWER56Q352N7002B2N7002/SOT232N7002BQ362N7002B2N7002/SOT232N7002BQ37POWER56FDMS86103L_POWER56POWER56Q38POWER56FDMS86103L_POWER56POWER56Q392N7002B2N7002/SOT232N7002BQ402N7002B2N7002/SOT232N7002BQ412N7002B2N7002/SOT232N7002BQ422N7002BAO3414/SOT232N7002BQ43POWER56FDMS8333L_POWER56POWER56Q44POWER56FDMS86103L_POWER56POWER56Q45POWER56FDMS8333L_POWER56POWER56Q462N7002B2N7002/SOT232N7002BQ472N7002B2N7002/SOT232N7002BQ482N7002BAO3414/SOT232N7002BQ492N7002B2N7002/SOT232N7002BQ502N7002B2N7002/SOT232N7002BQ51POWER56FDMS7694_POWER56POWER56Q522N7002B2N7002/SOT232N7002BQ532N7002B2N7002/SOT232N7002BQ542N7002B2N7002/SOT232N7002BQ55POWER56FDMS7694_POWER56POWER56Q562N7002B2N7002/SOT232N7002BQ572N7002B2N7002/SOT232N7002BQ58POWER56FDMS7694_POWER56POWER56Q59POWER56FDMS0312S_POWER56POWER56Q60POWER56FDMS0312S_POWER56POWER56Q61POWER56FDMS0312S_POWER56POWER56Q622N7002BAO3414/SOT232N7002BQ632N7002BAO3414/SOT232N7002BQ642N7002BAO3414/SOT232N7002BQ65POWER56FDMS7694_POWER56POWER56Q66POWER56FDMS7694_POWER56POWER56Q67POWER56FDMS0312S_POWER56POWER56Q682N7002BAO3414/SOT232N7002BQ692N7002B2N7002/SOT232N7002BQ702N7002B2N7002/SOT232N7002BQ71POWER56FDMS7694_POWER56POWER56Q72SOT23_QA2N3904/SOT23/NCSOT23_QAQ73POWER56FDMS7694_POWER56POWER56Q74POWER56FDMS7694_POWER56POWER56Q75POWER56FDMS7694_POWER56/NCPOWER56Q76POWER56FDMS7694_POWER56POWER56Q772N7002B2N7002/SOT232N7002BQ78POWER56FDMS7694_POWER56POWER56Q79POWER56FDMS0312S_POWER56POWER56Q80SOT23_QA2N3904/SOT23SOT23_QAQ812N7002BAO3414/SOT232N7002BQ82POWER56FDMS7694_POWER56POWER56Q83SOT23_QA2N3904/SOT23SOT23_QAQ84SOT23_QA2N3904/SOT23SOT23_QAQ85MYSMDTO252_GDSAP6679GH_TO252MYSMDTO252_GDSQ862N7002B2N7002/SOT232N7002BQ872N7002BAO3414/SOT232N7002BRESET1PH1X2_2D_D180PIN HEADER1X3_2.0MM_D180/NCPH1X2_2D_D180RN1RN8SMDA4.7K(8P4R)/NCRN8SMDARN2RN8SMDA4.7K(8P4R)RN8SMDART1SM0603R10K,5% THRMSM0603RRT2SM0603R10K,5% THRMSM0603RRT3SM0603R100K,5% THRM/NCSM0603RRT4SM0603R100K,5% THRM/NCSM0603RRT5SM0603R10K,5% THRMSM0603RRT6SM0603R10K,5% THRMSM0603RS1COPPER_1COPPER/NCCOPPER_1S2COPPER_1COPPER/NCCOPPER_1S3COPPER_1COPPER/NCCOPPER_1S4COPPER_1COPPER/NCCOPPER_1S5COPPER_2COPPER/NCCOPPER_2S6COPPER_1COPPER/NCCOPPER_1S7COPPER_1COPPER/NCCOPPER_1S8COPPER_1COPPER/NCCOPPER_1S9COPPER_1COPPER/NCCOPPER_1S10COPPER_1COPPER/NCCOPPER_1S11COPPER_1COPPER/NCCOPPER_1SATA1SATA22P_F_15D15_S90SATA CONN 7+15PIN_S90SATA22P_F_15D15_S90SC1MYEC200_400470UF/16VMYEC200_400SC2MYEC200_400470UF/16VMYEC200_400SC3SC_10D3X10D3_SMD82UF/50V_S180SC_10D3X10D3_SMDSC4MYEC138_350270UF/16VMYEC138_350SC5MYEC138_350270UF/16VMYEC138_350SC6MYEC100_250820UF/2.5VMYEC100_250SC7MYEC138_350270UF/16VMYEC138_350SC8MYEC100_250820UF/2.5VMYEC100_250SC9MYEC100_250820UF/2.5VMYEC100_250SC10MYEC138_350270UF/16VMYEC138_350SC11MYEC138_350270UF/16VMYEC138_350SC12MYEC138_350270UF/16VMYEC138_350SC13MYEC200_400470UF/16VMYEC200_400SC14MYEC200_400470UF/16VMYEC200_400SC15MYEC138_350270UF/16VMYEC138_350SIM1SIM_CON_PPSIM CARD SOCKET6P_SMDSIM_CON_PPSODIMM1DDR3_SODIMM_R_S90_HLDDR3 SODIMM REVERSE204P 1.5V 9.2MM_S90DDR3_SODIMM_R_S90_HLTC1TAND_7343330UF/2VTAND_7343TVS11N5817ASMAJ33CA_DO214AC(SMA)1N5817ATVS21N5817ASMAJ33CA_DO214AC(SMA)1N5817ATVS31N5817ASMAJ33CA_DO214AC(SMA)1N5817ATVS41N5817ASMAJ33CA_DO214AC(SMA)1N5817ATVS5SMCSMDJ58CA_SMCSMCU1EL357N-GEL357N(C)(TA)-GEL357N-GU2EL357N-GEL357N(C)(TA)-GEL357N-GU3EL357N-GEL357N(C)(TA)-GEL357N-GU4EL357N-GEL357N(C)(TA)-GEL357N-GU5QFN40-T_6X6SP339EER1-L_QFN40-T_6X6QFN40-T_6X6U6QFN40-T_6X6SP339EER1-L_QFN40-T_6X6QFN40-T_6X6U7EL357N-GEL357N(C)(TA)-GEL357N-GU8EL357N-GEL357N(C)(TA)-GEL357N-GU9EL357N-GEL357N(C)(TA)-GEL357N-GU10EL357N-GEL357N(C)(TA)-GEL357N-GU11SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U12SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U13MSOP8F75909M_MSOP8MSOP8U14SOT23-5SN74AHCT1G125DBVR_SOT23-5SOT23-5U15ISL6262ACRZ-QFN48CH7318C-BFISL6262ACRZ-QFN48U16QFN64-T_9X9WGI210-AT_QFN64-TQFN64-T_9X9U17QFN64-T_9X9WGI210-AT_QFN64-TQFN64-T_9X9U18PQFN34-3T_5D5X5FAN2356MPX_PQFN34-3T_5D5X5PQFN34-3T_5D5X5U19MSOP8F75909M_MSOP8MSOP8U20FCBGA1170E3845_FCBGA1170FCBGA1170U21SOT23-5SN74LVC1G32DBVR_SOT23-5SOT23-5U22WQFN-20L-T_3X3RT8207MZQW_WQFN-20L-T_3X3WQFN-20L-T_3X3U23SOT23-6RT9194_SOT23-6SOT23-6U24SOT23-5SN74LVC1G32DBVR_SOT23-5SOT23-5U25SOT23-6RT9194_SOT23-6SOT23-6U26QFN40-T_5X5ISL95837HRZ-HF_QFN40-T_5X5QFN40-T_5X5U27SOP8B-209W25Q64FWSSIG-HF_SOIC8-209SOP8B-209U28SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U29SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U30QFN40-T_6X6SP339EER1-L_QFN40-T_6X6QFN40-T_6X6U31MSOP8F75909M_MSOP8MSOP8U32SOT23-5SN74AHC1G08DBVR_SOT23-5/NCSOT23-5U33SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U34SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U35SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U36SOP14B-300LM1877M-9_SOP14B-300SOP14B-300U37LQFP48ALC886-GR_LQFP48LQFP48U38SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U39SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U40SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U41SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U42SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U43DFN2X3-6TLTC4357CDCB_DFN2X3-6TDFN2X3-6TU44SOT23-5SN74AHCT1G125DBVR_SOT23-5SOT23-5U45SOP8B-209W25Q16DVSSIG-HF_SOIC8-209SOP8B-209U46MSOP8F75909M_MSOP8MSOP8U47TSSOP38-TLT3791-1_TSSOP38-TTSSOP38-TU48SOP8B-209W25Q16DVSSIG-HF_SOIC8-209SOP8B-209U49MSOP8F75909M_MSOP8MSOP8U50MSOP8F75909M_MSOP8MSOP8U51SOT23-6RT9194_SOT23-6SOT23-6U52LQFP128_14X14F81866AD_LQFP128_14X14LQFP128_14X14U53SOIC8APW7120KE-TRL_SOIC8SOIC8U54SOT23-5SN74AHC1G08DBVR_SOT23-5SOT23-5U55SOT23-5SN74AHC1G08DBVR_SOT23-5/NCSOT23-5U56MSOP8F75909M_MSOP8MSOP8U57QFN36-T_6X6USB2514B-AEZC_QFN36-T_6X6QFN36-T_6X6U58PQFN34-3T_5D5X5FAN2356MPX_PQFN34-3T_5D5X5PQFN34-3T_5D5X5U59SOIC8APW7120KE-TRL_SOIC8SOIC8U60QFN40-T_6X6SP339EER1-L_QFN40-T_6X6QFN40-T_6X6U61MSOP8F75909M_MSOP8MSOP8U62SOT23-5SN74AHC1G08DBVR_SOT23-5/NCSOT23-5USB2_1USB2_L_UA04FSXL1930USB2.0_L_D90USB2_L_UA04FSXL1930USB2_2USB2_L_UA04FWS-ACUSB2.0_S90USB2_L_UA04FWS-ACUSB2_3USB2_L_UA04FWS-ACUSB2.0_S90USB2_L_UA04FWS-ACUSB3_1USB3_L_124-0921NUSB3.0_L_D90USB3_L_124-0921NX1XTL_4P_5X3D2_S18025MHZ_4P/SMDXTL_4P_5X3D2_S180X2CM315D32.768KHZ/SMDCM315DX3XTL_4P_5X3D2_S18025MHZ_4P/SMDXTL_4P_5X3D2_S180X4XTL_4P_5X3D2_S18025MHZ_4P/SMDXTL_4P_5X3D2_S180X5XTL_4P_5X3D2_S18024MHZ_4P/SMDXTL_4P_5X3D2_S180 服务器卡了几天。。 忍不住了,大半夜升级, 发个作品测试一下发帖功能有没有问题
PCB文件回复可见下载。
**** Hidden Message ***** 收藏,谢谢分享。 高级货,学习了。谢谢!!
