老吴 发表于 2019-9-9 17:06:14
10层1介盲埋孔MTK6735 手机PCB和原理图共享下载
NamePart TypePCB DecalValueANT3601ANTENNA_11PAD/1P/R1.3ANT / 92138100010FBEAD5001FB_/_BLM15AG121SN1BEAD0402FB / BLM15AG601SN1BEAD6001FB_/_BLM18BD252SN1BEAD0603FB / BLM18BD102SN1 / 0603BEAD6002FB_/_BLM18BD252SN1BEAD0603FB / BLM18BD102SN1 / 0603BEAD6003FB_/_BLM18BD252SN1BEAD0603FB / BLM18BD102SN1 / 0603BEAD6701FB_/_BLM18BD252SN1BEAD0603FB / BLM18BD102SN1 / 0603BEAD6702FB_/_BLM18BD252SN1BEAD0603FB / BLM18BD102SN1 / 0603CON3301CAR_KIT_/_MM8130-2600MM8130-2602Car_Kit / MM8130-2600CON3401CAR_KIT_/_MM8130-2600MM8130-2602Car_Kit / MM8130-2600CON5001TST_PORT_0MM8130-2602Car_Kit / MM8130-2600CON6304CON/SIM/LUS62-90006-0135_4SIM-CAF99-06134-0103CON/SIM/LUS62-90006-0135CON6306CON/SIM/LUS62-90006-0135_3QFN8/SMD/P1.27/64K-M2M-MS0M2M MS0 SIMCON6700CON_/_12_/_TA-M017-012-07-811_1TF-CAF11-08134-0512DIPCON / 12 / TA-M017-012-07-811CON6702TMP_1OK-06F030-04OK-06F030-04D2103D_/_MMSZ5231BT1GD_BZX584C5V1_SOD-523SIG5V1T1GD6701DIODE_DIP_SCHOTTKYRB160M-40RB160M-40D6710BZX584C5V1D_BZX584C5V1_SOD-523BZX584C4V3EMI6702EMI_/_TCM0806G-350-2PFILTER/SMD/TCM0806GEMI / TCM0806G-350-2PEMI6703EMI_/_TCM0806G-350-2PFILTER/SMD/TCM0806GEMI / TCM0806G-350-2PEMI6704EMI_/_TCM0806G-350-2PFILTER/SMD/TCM0806GEMI / TCM0806G-350-2PEMI6705EMI_/_TCM0806G-350-2PFILTER/SMD/TCM0806GEMI / TCM0806G-350-2PEMI6706EMI_/_TCM0806G-350-2PFILTER/SMD/TCM0806GEMI / TCM0806G-350-2PF5001BL1608-05K2450_0FILTER/SMD/LFD211G57ME3TRPX / TDK TPX205950MT-7110A1FB6701PZ1005U601-R45TFLB0402600@100MHZFD9101TP_R_1MMFDTP / 40 / milFD9102TP_R_1MMFDTP / 40 / milFD9103TP_R_1MMFDTP / 40 / milFD9104TP_R_1MMFDTP / 40 / milJ101CON10X2/SMD/P1.27/2_0.0MMCON10X2/SMD/P1.27/2.0MM-2CON10*2/SMD/P1.27/2.0MMJ102CON10X2/SMD/P1.27/2_0.0MMCON10X2/SMD/P1.27/2.0MM-2CON10*2/SMD/P1.27/2.0MMJ3603RF_CONN_20279C8_0ECT818000157ECT818000157(NC)J3604RF_CONN_20279C8_0ECT818000157ECT818000157(NC)J5002RF_CONN_20279C8_0ECT818000157ECT818000157J5003RF_CONN_20279C8_0ECT818000157ECT818000157(NC)J6701REC22_DUALROW_0CON12X2/SMD/P1.27/2.0MM-1REC22_DUALROW_01-220012-211SJ6702REC22_DUALROW_0CON12X2/SMD/P1.27/2.0MM-1REC22_DUALROW_01-220012-211SJ6703B37.12_1.00031CON_FPC_AFC30-30FCA-HFYXT-BB10-24S-02L2001L_/_MDMK2020TR68MM_/_SMD2520L/IND/SMD/2520PL / 0.33 / uH / 2520L2003L_/_MDMK2020TR68MM_/_SMD2520L/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L2006L_/_MDMK2020T1R0MM_/_SMD2520L/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L2008L_/_MDMK2020T1R0MM_/_SMD2520L/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L2009L_/_MDMK2020T1R0MM_/_SMD2520L/IND/SMD/VLS201610EPL / 2.2 / uH / 2016L3206L_/_3.3_/_NH_/_0201L0201C / 1.3 / pF / 0201L6701INDUCTORL_3X3X1.2MMLQH3NPN220MJ0L(22UH)L6707B29.01_0.00021L0806MAKK2016T2R2MMIC1CAP_ARRAY_0CON_WF12502-022000CON2PINNTC3201NTC_/_NCP15WF104F03RC_/_0402_R0201NTC / NTCG064EF104F / 0201NTC6001NTC_/_NCP15WF104F03RC_/_0402_R0201NTC / NTCG064EF104F / 0201Q7DTC143TMT_NPN_DTC114TM_SOT-723DTC143TMQ6701P-MOS_CJ3415T_MOSFET_P_CJ3415-SOT23P-MOS CJ3415(NC)Q6702DTC143TMT_NPN_DTC114TM_SOT-723DTC143TMQ6703DTC143TMT_NPN_DTC114TM_SOT-723DTC143TMSH1001NO_PAD_0402_SMD_1NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MILSH4101R_/_0_/_OHM_/_0402_1R0402R / 0 / ohm / 0402SH5001R_/_SHORT_/_OHM_/_0402R0402SHORT / 0402SH5002R_/_SHORT_/_OHM_/_0402R0402SHORT / 0402SH9101CON10_0SHD_MT6735_BBSC / PTV0703BSH9102CON10_0SHD_MT6735_PMUSC / PTV0703BSH9103NO_PAD_0402_SMD_1NC/MMD/4MILSHORT / NC-MMD-L9-4MILSH9104NO_PAD_0402_SMD_1NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MILU1001IC-MT6735-LP3-E1-SBS_MAP0827MT6735/VFBGA641/P0.4/B0.25/12.6X12.6U / IC-MT6735-LP3-E1-SBS_MAP0827U1003RT9284A_0LDO_SGM2019-3.3YC5G/TR_SC70-5SGM2019-3.3YC5G/TRU2001IC/MT6328-E1/XXXMM_0MT6328/VFBGA206/P0.4/B0.25/6.6X6.6U / MT6328E1U310160118A_22MT6169/VFBGA175/P0.4/B0.25/6.2X5.4U / MT6169U3102KT2520F26000DCW28QAKTCXO/SMD/2.5X2.0/KT2520FVTCXO / 26 / MHz / KT2520F26000DCW28QAKU3203PA_/_SKY77590_8SKY77643SKY77643/HRSMAC001/RF5410U3210LF1608-B2R5KCBBALUN/SMD/HHM22112A2LPF / LF1608-B2R5KCBU3215SAW_3FILTER/SMD/885049SAW / SAFEA2G35MF0F0AU3216DEA102700LT-6307_0FILTER/SMD/LFB212G49CG7D755LPF / LF2012-L1R4NAA / NCU3220BPF_/_ACPF-7141ACPF-7141/SMDBPF / SAFRG2G62MA0F0AU3301SAW-DPX-RX-BAL_2DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY1G88BA0B0AU3302SPDT_/_BGS12SL6_2RF1628SPDT / RF1628AU3305SAWFD1G90BH0F0A_0SAWFILTER/SMD/SAWFD1G90BH0F0ADIPX / SAWFD1G90BK0F0AU3306SAW-DPX-RX-BAL_1DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY1G95HA0F0AU3307ASM_/_SKY13492_6SKY77910SKY77916/HRTXAB005/RF5216U3308SAW-DPX-RX-BAL_1DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY2G53CA0F0U3309SAW-DPX-RX-BAL_2DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY1G74BC0B0AU3313SAW-DPX-RX-BAL_1DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY836MCA0F0AU3317BAL_/_TFSZ06051897-3317A1BALUN/SMD/TFSZ06051897-3317A1BAL / TFSZ06051897-3317A1U3322SAW_0SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / B8809U3323TDK-BALUN_0BALUN/SMD/TFSZ06052460-3310A2BAL / TDK-TFSZ06052460-3310A2U3401SPDT_/_BGS12SL6_2RF1628SPDT / RF1628AU3402IC/SP6T/SKY13416_0SKY13414SP6T / SKY13416U3403BAL_/_TFSZ06051897-3317A1BALUN/SMD/TFSZ06052460-3310A2BAL / TDK-TFSZ06052460-3310A2U3404SAW_3SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / EPCOS_AG07BU3406SAW_0SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0AU3407SAW_0SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G90FB0F0A U3408SAW_0SAWFILTER/SMD/F6QB2G595P2BSSAW / B9898U3410BAL_/_TFSZ06051897-3317A1BALUN/SMD/TFSZ06052460-3310A2BAL / TDK-TFSZ06052460-3310A2U3411SAW_0SAWFILTER/SMD/F6QB2G595P2BSSAW / SAFFB2G53AA1F0AU3412SAW_0SAWFILTER/SMD/F6QB2G595P2BSSAW / SAFFB2G60AA1F0AU4102LP_DDR2(JEDEC_162B)_0FBGA221/P0.5/B0.27/11.5X13/SAMSUNGU / H9TP32A4GDCCPR-KGMxU5001MT6611_SMD_WLCSP-61_0MT6625/SQFN40/SMD/P0.4/5X5U / MT6625L / QFN40U5002TCXO_RAKON_SMD_4P_0TCXO/SMD/2.5X2.0/IT2205BETCXO / 26 / MHz / IT2205AEU5003SAFEB1G57KA0F00SAW/SMD/1.05X1.35GNSS SAW / B8313U5004NJG1107HB3_0TSLP6/SMD/P0.4/BGA725L6/SU / BGA725L6U5005SAFEB1G57KA0F00FILTER/SMD/ACPF-7124FBAR / ACPF-7124U5006EMI_ICVE10184E150R101FREMI_ICVE10184E150R101FREMI_ICVE10184E150R101FRU5007EMI_ICVE10184E150R101FREMI_ICVE10184E150R101FREMI_ICVE10184E150R101FRU5008ICMEF112P900MFRCOMMON_ICMEF112P900MFRICMEF112P900MFRU5009EMI_ICVE10184E150R101FREMI_ICVE10184E150R101FREMI_ICVE10184E150R101FRU6700B33.01.00021QFN_BST-BMA222MC3433U6701SGM2019-3_0.3YC5G/TRSOT-23-5SGM6013-ADJYTN5G/TRU6703AK09911SENSOR_AK09911AK09911U6705MP1518-TSOT23-6SOT23_6CP2123ST-A2VR6715VR0402VR0402AVLC18S02015X2001CRYSTAL_2CRYS/SMD/3.2X1.5/9H032000XX/TXCX / 32 / KHz / CM7V-T1A
老吴 发表于 2019-9-9 17:10:22
PCB 和原理图一起打包。
**** Hidden Message *****
西城男孩 发表于 2019-9-9 17:27:43
love欣 发表于 2019-9-9 17:32:50
翻身的闲鱼 发表于 2019-9-9 18:44:46
zhao_siqing 发表于 2019-9-9 19:40:07
谢谢楼主分享
单枪舞九州 发表于 2019-9-9 20:05:56
支持
yangxf0120 发表于 2019-9-9 20:13:13
谢谢分享10层1介盲埋孔MTK6735 手机PCB和原理图
hbjsss 发表于 2019-9-9 20:18:27
shaoeli1224 发表于 2019-9-9 20:29:30
看看
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 10层1介盲埋孔MTK6735 手机PCB和原理图共享下载
