新唐 NUC970 +NCU8822L+IP101GR+TS8121C 做的开发板PCB和原理图
NamePart TypePCB DecalValueBT1BATTERY_ELEMBAT\CR2032-4-2CR2032CON1HEADER_2X20_0HEADER10X2\BOXJTAG ICECON2POWER_JACKPOWRJACK\3PDC-PLUGCON3AXA2R63061_0AXA2R63021eMMC CardCON4AXA2R63061_1AXA2R63021SD CardCON5CON2HEADER_2X1_2.54MMIIC ModeCON6CON2HEADER_2X1_2.54MMAUXiCON7CON2HEADER_2X1_2.54MMNANDMLCCON8CON2HEADER_2X1_2.54MMSpkoCON9CON2HEADER_2X1_2.54MMAUXoCON10CON4AHEADER_2X2_2.54MMCAN0/1CON11PJK-691_0PJK-691EARPhoneCON12CON12AHEADER_2X6_2.54MMPDCON13CON20AHEADER_2X10_2.54MMPCCON14CON20AHEADER_2X10_2.54MMPBCON15CON24AHEADER_2X12_2.54MMCMOS SensorCON16CON10AHEADER_2X5_2.54MMPJCON17CON6A_1HEADER_2X3_2.54MMPGCON18RJ45_SHLD_0RJ45\8P\JA\LEDRJ-45 8P8C_LED R/ACON19CON8AHEADER_2X4_2.54MMPHCON20CON4USB4P_ATYPEUSBCON21CON20AHEADER_2X10_2.54MMPECON22CON20AHEADER_2X10_2.54MMPICON23CON40A_0M_DIN_32X2/2.54ALCDCON24USB_TYPE_B_3MINI_5P_B_TYPEUSB miniAB RECEP.CON25CON16AHEADER_2X8_2.54MMPHCON26CON40AHEADER_2X20_2.54MMEBICON27CON16AHEADER_2X8_2.54MMPFCON28CON8A_2HEADER_2X4_2.54MMPGCON29CON8AHEADER_2X4_2.54MMADCCON30CON8AHEADER_2X4_2.54MMPFCON31HEADER_6_0SIM-CARDSIM CARD SLOTCON32CON12AHEADER_2X6_2.54MMPDCON33CON20AHEADER_2X10_2.54MMPACON34CON10A_1HEADER_2X5_2.54MMPGCON35CON8A_3HEADER_2X4_2.54MMPGCON36CON4AHEADER_2X2_2.54MMCON4ACON37CONNECTOR_DB9_0DB9_FMALEUART1CON38CONNECTOR_DB9_0DB9_FMALEUART2CON39CONNECTOR_DB9_0DB9_FMALEUART0CON40CONNECTOR_DB9_0DB9_FMALEUART3CON41CONNECTOR_DB9_0DB9_FMALEUART4CT1CAP_NPC060310uFD2ZENAR_0SOD-523RB521S-30J2CON2HEADER_2X1_2.54MMVinK6SW-SSTS-B5EnterL1INDUCTOR_IRONSMTDR434.7uHL2INDUCTOR_IRONSMTDR434.7uHL3INDUCTORL06031608-221TL4INDUCTOR_IRONSMTDR434.7uHL5INDUCTORL06031608-221TLED10LEDLED_0603LED_RM1MICROPHONE_09.7D2.54MMMICM2MICROPHONE_09.7D2.54MMMICPAD11PAD1PAD_1.25X1.25MMeMWPPAD21PAD1PAD_1.25X1.25MMSDWPPAD31PAD1PAD_1.25X1.25MMN_PreQ1NPN_1SOT23-BEC2N3904Q2NPN_1SOT23-BEC2N3904Q3SI2303CDS_1SOT23-GSDSI2303CDSQ4NPN_1SOT23-BEC2N3904Q5NPN_1SOT23-BEC2N3904Q6SI2303CDS_1SOT23-GSDSI2303CDSQ7SI2303CDS_1SOT23-GSDSI2303CDSSW2SW-SSTS-B5RTC KeySW3SW_DIP-5DIPSWX5_2.54MMNANDDSW4SW-SSTS-B5WDTRstSW5SW-3PAD23P-1.2MMPSLSW6SW_DIP-5DIPSWX5_2.54MMICESW7SW_DIP-5DIPSWX5_2.54MMNANDD/CtrlSW8SW_DIP-6DIPSWX6_2.54MMSPISW9SW2PHS2P-1.2MMVD33SW10SW2PHS2P-1.2MMVD18SW11SW_DIP-6_1DIPSWX6_2.54MMeMMCSW12SW2PHS2P-1.2MMVD12SW13SW_DIP-5DIPSWX5_2.54MMNANDCtrlSW14SW_DIP-8DIPSWX8_2.54MMSDSW15SW_DIP-8DIPSWX8_2.54MMIISSW17SW_DIP-4_0DIPSWX4_2.54MMCAN Bus0/1SW18SW_DIP-4_0DIPSWX4_2.54MMPWMSW19SW_DIP-6_1DIPSWX6_2.54MMCAN 0/1 CfgSW20SW_DIP-6_1DIPSWX6_2.54MMLCDCtrlSW21SW_DIP-5_0DIPSWX5_2.54MMEthernetSW22SW_DIP-8_0DIPSWX8_2.54MMCMOSD/IICSW23SW_DIP-8_0DIPSWX8_2.54MMLCDDSW24SW_DIP-8_0DIPSWX8_2.54MMCMOSCtrl/DSW25SW_DIP-8_0DIPSWX8_2.54MMLCDDSW26SW_DIP-5_0DIPSWX5_2.54MMKPISW27SW_DIP-4_0DIPSWX4_2.54MMEBIAdd/CtrlSW28SW_DIP-8_0DIPSWX8_2.54MMEBICtrlSW29SW_DIP-8_0DIPSWX8_2.54MMLCDDSW30SW_DIP-4DIPSWX4_2.54MMUSB P_CtrlSW31SW_DIP-5DIPSWX5_2.54MMCfgSW32SW_DIP-8_0DIPSWX8_2.54MMEBIDSW33SW_DIP-8_0DIPSWX8_2.54MMEBIAddSW34SW_DIP-4DIPSWX4_2.54MMUSB P_IndSW35SW_DIP-5DIPSWX5_2.54MMCfgSW36SW_DIP-5_0DIPSWX5_2.54MMLCD TouchSW37SW_DIP-5DIPSWX5_2.54MMSIM CardSW38SW_DIP-5_0DIPSWX5_2.54MMEthernetSW39SW_DIP-8_0DIPSWX8_2.54MMEBIDSW40SW_DIP-4_0SDS-8UART1SW41SW_DIP-4_0SDS-8UART2SW42SW_DIP-4_0DIPSWX4_2.54MMUART0SW43SW_DIP-4_0SDS-8UART3SW44SW_DIP-4_0SDS-8UART4U1APL3203A_1TDFN2X2-8APL3203AU3ZT7103S_0TSOT-25ZT7103TU4ZT7103S_0TSOT-25ZT7103TU6W55X10_2SOIC8_208W55X16U7W25Q128BV_4SOIC16_300W25Q128BVU8ZT7103S_0TSOT-25ZT7103TU9NAND_4-8G_0TSOP48-0.5MMNAND FlashU10NAU8501QFN32L_5X5MM\0.5MM_PITCHNCU8822LU11SN65HVD230SO-8-1.27X5.4MSN65HVD230U12SN65HVD230SO-8-1.27X5.4MSN65HVD230U13PE-68515_1ST6200TTS8121CU14IP101GA_0QFN32IP101GRU15NUC970_1LQFP-216NUC970U16NCT3520W-H10MSOP-8NCT3520W-H10U17NCT3520W-H10MSOP-8NCT3520W-H10U18ADM232_1SOP16/150TRS3232ECU19ADM232_1SOP16/150TRS3232ECU20ADM232_1SOP16/150TRS3232ECU21ADM232_1SOP16/150TRS3232ECU22ADM232_1SOP16/150TRS3232ECUX?TPS61161_0SOT23-5NCT3705U-AX1CRYSTAL_SMD_2SOT-14325MHzX2CRYSTAL_SMD_2TXC7M-3.2X2.5MM12MHzX3MA306/SM_2XTAL_2P/1.5MMTXC-9H T9 SMD 32.768KHz 30ppm PCB文件,原理图,用户手册等。
谢谢楼主的分享 学习一下。
