老吴 发表于 2019-10-24 11:05:33
英特尔intel Bay trail WIN平板电脑PCB和原理图共享【ALC5640+TUSB1
NamePCB DecalValuePart TypeBAT+1.5DATEST_POINT1.5BAT-1.5FTEST_POINT1.5CON3FPC6PINCONN6FPC6PINCR7005CMP_419_3ESD9N5BM-2/TRCMP_419CR7008SMCR_P6X1P0_P40HESDSMCR_P6X1P0_P40HCR7009SMCR_P6X1P0_P40HESDSMCR_P6X1P0_P40HCR7010CMP_419_3ESD9N5BM-2/TRCMP_419CR7012SMCR_P6X1P0_P40HESDSMCR_P6X1P0_P40HCR7013SMCR_P6X1P0_P40HESDSMCR_P6X1P0_P40HCR8200D1206WSB5502WD1206CR9401CMP_419_3ESD9N5BM-2/TRCMP_419CR9402CMP_419_3ESD9N5BM-2/TRCMP_419CR9403CMP_419_3ESD9N5BM-2/TRCMP_419D1D1206B5819WD1206D2SOT23BAT54SSOT23D3D12065.6VD1206D903D1206B5819W/SOD123D1206F9400R1206FUSER1206FB4002R0402FERRITE_ALTSIZER0402J3501TFABCCON12_MICROSD_MTG4TFABCJ4002SIM12PINCON8_MICRO_SIM_MTG4SIM12PINJ4101CMP_395_1CON4_COAX_2X2_MM4829_2702CMP_395J6401CMP_395_1CON4_COAX_2X2_MM4829_2702CMP_395J8504CON24CON24_RCPT_CAM_BYT_CRCON24J8505CON24CON24_RCPT_CAM_BYT_CRCON24J9400USB-ST-01H5-CACON5_USB_MICRO_AB_MTG4USB-ST-01H5-CAL1SML2520_1P0H_14.7UH/2ASML2520_1P0HL2009SML2520_1P0H_14.7UHSML2520_1P0HL4000R02014.7NHR0201L4001R02014.7NHR0201L6010CMP_4186.8NHCMP_418L8205IND-4X44.7UHIND-4X4L8404SML_4P_43X53_CM_P35H80OHM_100MHZSML_4P_43X53_CM_P35HL8405SML_4P_43X53_CM_P35H80OHM_100MHZSML_4P_43X53_CM_P35HL8406SML_4P_43X53_CM_P35H80OHM_100MHZSML_4P_43X53_CM_P35HL8407SML_4P_43X53_CM_P35H80OHM_100MHZSML_4P_43X53_CM_P35HL8408SML_4P_43X53_CM_P35H80OHM_100MHZSML_4P_43X53_CM_P35HL9000CMP_521_180OHM_100MHZCMP_521NTC1.5ETEST_POINT1.5PT11C-DIPICSRC-5210SFRC-DIPQ1SOT723WNM2030SOT723Q11SOT23WPM2026SOT23Q12SOT23WPM2026SOT23Q104SOT23NC/WNM2030SOT23Q2000CMP_456_1WPM1481CMP_456Q8400BSOT723WNM2030SOT723Q8401LCC6_P65MM_SQ2P05MM_NSWPM1481LCC6_P65MM_SQ2P05MM_NSQ9503ASOT723WNM2030SOT723Q9503BSOT723WNM2030SOT723SH2003SHUNT_0402SHUNT_BYT_CR_MRDSHUNT_0402SH2004SHUNT_0402SHUNT_BYT_CR_MRDSHUNT_0402SH2005SHUNT_0402SHUNT_BYT_CR_MRDSHUNT_0402SH2006SHUNT_0402SHUNT_BYT_CR_MRDSHUNT_0402SH2007SHUNT_0402SHUNT_BYT_CR_MRDSHUNT_0402SH2008SHUNT_0402SHUNT_BYT_CR_MRDSHUNT_0402SH4001R0201SHUNT_LOCALR0201SH4002R0201SHUNT_LOCALR0201U4SOT26TCS3358SOT26U16SOT25ATCS9322SOT25U17SOT-25RT9193-28GBSOT-25U18SOT-25TCS2109-1V2SOT-25U23SOT23-6WD3126SOT23-6U704UART-2UARTUART-2U1000CMP_4SOC_VLV2_CR_CONCEPT_CUST_WW3CMP_4U2003CMP_404AXP288_1P04CMP_404U3005BGA96_P8MM_9P1X14P1MT41K256M16BGA96_P8MM_9P1X14P1U3006BGA96_P8MM_9P1X14P1MT41K256M16BGA96_P8MM_9P1X14P1U3500SOP8MX25U1635ESOP8U3501CMP_406KLM8G1WEMB_B031CMP_406U4000CMP_409H350_A50_10CMP_409U6013CMP_455SAFFB1G58KA0F0CMP_455U6014CMP_451BCM4752IFBG_P12CMP_451U6206CMP_405RL_SM02BD_8723BSCMP_405U6400LFD181LFD211G58DPFC268LFD181U7001QFN48ALC5640_VBCMP_518U7002SOT25AA74LVC1G126SOT25U7086FPC6PINCON2FPC6PINU7087FPC6PINCON2FPC6PINU8000LTR-533JSA1213LTR-533U8001CMP_513KXCJK_1013CMP_513U8200SOT26KTD2511CEHDSOT26U9001CMP_512TUSB1210CMP_512U9009CMP_51174AVC1T45YZPCMP_511U9010CMP_377AOZ6184_DPDTCMP_377U9012FPC32PIN40PINFPC32PINY1000CMP_51625.0MHZCMP_516Y1001SMY2P_49X8332.768KHZSMY2P_49X83Y6001CMP_45326MHZCMP_453
老吴 发表于 2019-10-24 11:07:13
PCB 和原理图。回复可见下载。
**** Hidden Message *****
kanxue_nmg 发表于 2019-10-24 11:22:58
yfchen1003 发表于 2019-10-24 11:49:36
最近老大又送福利了
love欣 发表于 2019-10-24 13:48:23
ming315578376 发表于 2019-10-24 14:31:37
谢谢楼主分享,学习一下
shuszhao 发表于 2019-10-24 15:21:24
谢谢楼主分享,学习一下
mercyme 发表于 2019-10-24 15:49:23
君夕 发表于 2019-10-24 16:13:21
aokema124 发表于 2019-10-24 19:24:47
看看好不好
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 英特尔intel Bay trail WIN平板电脑PCB和原理图共享【ALC5640+TUSB1
