HI3531D+IT6801+SII9022+RTL8211EG+ES7240 做的一个PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEC1CP_1_CAPC2-98-248A_220UF220UFCAPC2-98-248AC2CP_1_SCAPC2-0808C_220UF220UFSCAPC2-0808CD1DZ3_0_SD1710A_DZ3DZ3SD1710AD2D2-3_D_0_SOT23_D2-3_DD2-3_DSOT23D10RCLAMP3346P_0_BCC7-080-0301L_RCRCLAMP3346PBCC7-080-0301LD15LED_0_SD0805-LED_LEDLEDSD0805-LEDD17LED_0_SD0805-LED_LEDLEDSD0805-LEDD22DZ3_0_SD1714D_DZ3DZ3SD1714DD24D_A_0_HSOD323A_D_AD_AHSOD323AD25D_A_0_HSOD323A_D_AD_AHSOD323AD44DZ_L_0_HSOD882_DZ_LDZ_LHSOD882D45DZ_L_0_HSOD882_DZ_LDZ_LHSOD882D49DIODEPIN_SD1710A_DIODE PINDIODE PINSD1710AD54LED_0_SD0805-LED_LEDLEDSD0805-LEDD55LED_0_SD0805-LED_LEDLEDSD0805-LEDD56LED_0_SD0805-LED_LEDLEDSD0805-LEDF1FUSE2_0_SF6127_FUSE2FUSE2SF6127FB1BEAD0805_0805-FB_220R/100MHZ220R/100MHz0805-FBID1PCB_MARKPOINTID-BOARDID-BOARDJ6USB-9S2_A_0_USB9-200-1516_USB-9USB-9S2_AUSB9-200-1516J10USB-4S4_2_CON90RS2R50-4TM_USB-4USB-4S4CON90RS2R50-4TMJ11MJ8-SL_1_MJ8-SRLFY_MJ8-SLMJ8-SLMJ8-SRLFYJ12PWC3_A_2_PWC0103-M-C_PWC3_APWC3_APWC0103-M-CJ33DB19S4_2_MOLEX_47151_DB19S4DB19S4MOLEX_47151J34DB19S4_3_MOLEX_47151_DB19S4DB19S4MOLEX_47151J35WBC1X4-M2_3_6PIN-20_6PIN-2.06PIN-2.06PIN-20J36WBC1X4-M2_3_6PIN-20_6PIN-2.06PIN-2.06PIN-20J37WBC1X4-M2_3_6PIN-20_6PIN-2.06PIN-2.06PIN-20J39CON4X1X254MM_4PIN-20_CON4X1X2MMCON4X1X2MM4PIN-20J40CON4X1X254MM_4PIN-20_CON4X1X2MMCON4X1X2MM4PIN-20J41WBC1X4-M2_3_6PIN-20_6PIN-2.06PIN-2.06PIN-20J42CON4X1X254MM_4PIN-20_CON4X1X2MMCON4X1X2MM4PIN-20J43CON4X1X254MM_4PIN-20_CON4X1X2MMCON4X1X2MM4PIN-20J45DB19S4_3_MOLEX_47151_DB19S4DB19S4MOLEX_47151J46DB19S4_3_MOLEX_47151_DB19S4DB19S4MOLEX_47151L1L_1_SPL0505H_4.7U4.7USPL0505HL2L_1_SPL0505H_4.7U4.7USPL0505HL3L_1_SPL0505H_4.7U4.7USPL0505HL4L_1_SPL0404B_1UH1UHSPL0404BL8L_1_HSL1008_2.2UH2.2UHHSL1008L9L_1_SPL0404L_2.2UH2.2UHSPL0404LL18L_1_SPL0707G_2.2UH2.2UHSPL0707GL19L_252012_2.2UH/1A2.2UH/1A252012L20L_252012_2.2UH/1A2.2UH/1A252012L21L_1_SPL0505H_4.7U4.7USPL0505HOSC125MHZ_HSX4-0302B_25MHZ25MHZHSX4-0302BQ4MOSFETP_SOT23_2N7002P2N7002PSOT23RN17RND8-4_2_SRN8-0804_2222SRN8-0804RN18RND8-4_2_SRN8-0804_2222SRN8-0804S1DSW2_0_DSW4-L_DSW2DSW2DSW4-LS2MSW4_2_SSW-PUSH_MSW4MSW4SSW-PUSHT1G2401CE_0_STFM24-40-280_G2401CEG2401CESTFM24-40-280T2RCLAMP0524P_DFN2510P10E_AZ1045_NC/RCLAMP0524PDFN2510P10E_AZ1045T3RCLAMP0524P_DFN2510P10E_AZ1045_NC/RCLAMP0524PDFN2510P10E_AZ1045T4RCLAMP0524P_DFN2510P10E_AZ1045_NC/RCLAMP0524PDFN2510P10E_AZ1045T5RCLAMP0524P_DFN2510P10E_AZ1045_NC/RCLAMP0524PDFN2510P10E_AZ1045TS1TEST_0_GND12_TESTTESTGND12U1TPS2551DRVR_0_MLF6-065-0202L_TPTPS2551DRVRMLF6-065-0202LU2TPS2551DRVR_0_MLF6-065-0202L_TPTPS2551DRVRMLF6-065-0202LU324C02_SOP8-50-150_24C0224C02SOP8-50-150U4AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045U5SPI_NAND_FLASH_0_WSON8-MX25L128NCWSON8-MX25L12835ZNU7ADM706SAR_1_SOP8-50-150_ADM706SADM706SARSOP8-50-150U10MP2316_0_QFN14-20-0302-MV_MP231MP2316QFN14-20-0302-MVU11PWR1-2_0_SBAT2-13A_PWR1-2PWR1-2SBAT2-13AU12HI3531D_M2_3_BGA805-32-3333_HI3HI3531D_M2BGA805-32-3333U13MP1494S_0_TSOT23-8_MP1494SMP1494STSOT23-8U14SII9022_0_QFN-72_SII9022SII9022QFN-72U15MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609MU16MP1494S_0_TSOT23-8_MP1494SMP1494STSOT23-8U17MP1494S_0_TSOT23-8_MP1494SMP1494STSOT23-8U18AZC199-04S_0_SOT23-6L_AZC199-04AZC199-04SSOT23-6LU19AZC199-04S_0_SOT23-6L_AZC199-04AZC199-04SSOT23-6LU21MAX3485E_0_SOP8-50-150_MAX3485EMAX3485ESOP8-50-150U22MT29F2G08ABAEAWP_0_SOP48-20-720MT29F2G08ABAEAWPSOP48-20-720U23SN74LVC1G125Q-Q1_1_HSOT-SC70-DCSN74LVC1G125Q-Q1HSOT-SC70-DCKU28AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045U31RTL8211EG_0_QFN64-050-0909LH_RTRTL8211EG_1QFN64-050-0909LHU32AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045U33AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045U37MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609MU38MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609MU39MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609MU40MP2161GJ_0_TSOT23-8_MP2161GJMP2161GJTSOT23-8U43MP2326_0_QFN14-20-0302-MV_MP232MP2326QFN14-20-0302-MVU44LT8619B_0_IT6801_IT6801IT6801IT6801U45PST597NR_3_SOT23-5_TD6817TD6817SOT23-5U46AT24C08_AT24C08_SOIC8_AT24C02/NAT24C02/NCAT24C08_SOIC8U47PST597NR_3_SOT23-5_TD6817TD6817SOT23-5U48PST597NR_0_SOT23-5_TPS2061TPS2061SOT23-5U50LT8619B_0_IT6801_IT6801IT6801IT6801U53AT24C08_AT24C08_SOIC8_AT24C02/NAT24C02/NCAT24C08_SOIC8U54AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045U55J18_1_MINI_PCIE_CONNECTOR_MINISminisataMINI_PCIE_CONNECTORU56CS5340_TSSOP16_ES7240ES7240TSSOP16U57MP1494S_0_TSOT23-8_MP1494SMP1494STSOT23-8U58CS4344_0_CS4344_TSSOP10_CS4344CS4344CS4344_TSSOP10U59PST597NR_0_SOT23-5_TPS2061TPS2061SOT23-5X2X_B_0_HSX4-0302_24MEG24MEGHSX4-0302X3X_0_HSX2-0302_32.768KHZ32.768KHZHSX2-0302Y1CRYSTAL_4PIN_CRY_3225_27MHZ27MHzCRY_3225Y2CRYSTAL_4PIN_CRY_3225_27MHZ27MHzCRY_3225 PCB文件。回复可见
**** Hidden Message ***** 支持 收藏谢谢分享 谢谢分享 看看 谢谢分享!!
