TW8836 SCH PCB
以下内容由管理员编辑补充
NamePCB DecalPart TypeValueC162SIZE_CODE_FDCAPE_1100uF/25VCN1CON-RCJ-04XRCA_JACK_1RCJ-044 YellowCN2CON\MDIN4SVCON_1MINI DIN4CN3CON-VGA-15PVGA-CON15_1DSUB-15PCN4CON_RCA5RCA_JACK_0RCJ-022 RedCN5CON_RCA5RCA_JACK_0RCJ-026 GreenCN6CON_RCA5RCA_JACK_0RCJ-025 BlueCN7CON-DIP-40P-2M-2CON40_5PPPN202FJFN-RCCN853261-0571HEADER_553261-0571CN9CON-DIP-40P-2M-2CON40_0PPPN202FJFN-RCCN10CON-DIP-10P-2M-2CON40_2PPPN052FJFN-RCCN11CON_RCA5RCA_JACK_0RCJ-024 YellowCN12CON-DB9HMCONNECTOR_DB9_5DB9 MALECN14HDMI_TYPEAHDMI_TYPE-A_0HDMI Type ACN15JACK\PJ-20DC_SOCKET_012V/3AD1SOD-923SESD0402S-005-054SESD0402SD2SOD-923SESD0402S-005-054SESD0402SD3SOD-923SESD0402S-005-054SESD0402SD4SOD-923SESD0402S-005-054SESD0402SD5SOT-353CPDV5-3V3UP(D)D7MBRA1201N4001_0MBRA120D8SOD-3231N4001_0BAT54HD9SOD-3231N4001_0BAT54HD10SOD-3231N4001_0BAT54HF1L1206FUSETR/3216FF-4AFB40L0603INDUCTORBLM18FB41L0603INDUCTOR(BLM18)FL2MSOP10-0524RCLAMP0504_1Rclamp0524FL3MSOP10-0524RCLAMP0504_1Rclamp0524FL4MSOP10-0524RCLAMP0504_1Rclamp0524IR1IRHEADER_3_1HEADER 3IR2IRHEADER_3_1HEADER 3J1CON-SIP-4PCON5_0(CON-SIP-4P)J2CON-SIP-3PHEADER_3(CON-SIP-3P)J3HEADER160-1HEADER160_4(SOCKET)J4CON-SIP-2PCON2_00 ohmJ5CON-SIP-2PCON2_00 ohmJ6CON-SIP-2PCON2_00 ohmJ7CON-SIP-2PCON2_00 ohmJ8CON-SIP-2PCON2_00 ohmJ9CON-SIP-2PCON2_00 ohmJ10CON-SIP-2PCON2_0(0 ohm)J11CON-SIP-2PCON2_00 ohmJ12CON-DIP-6PHEADER_3X2HEADER 3X2J13CON-DIP-4PHEADER_2X2HEADER 2X2J14CON-SIP-5PCON5(HEADER 5)J1553261-0471HEADER_453261-0471J16CON-SIP-4PCON5_0(CON-SIP-4P)J17SW\KN11BSW_PUSHBUTTON_1KN11BJ18CON-SIP-2PCON2_1(HEADER 2)J19CON-SIP-2PCON2_1(HEADER 2)J20CON-SIP-5PHEADER_5(HEADER 5)J21CON-SIP-5PHEADER_5(HEADER 5)J22CON-SIP-4PCON5_0(CON-SIP-4P)J23CON-SIP-5PHEADER_5(HEADER 5)JP1CON-SIP-2PCON2_0HEADER 2L1L0805INDUCTOR_010uHL2DR1040INDUCTOR7uHL3DR1040INDUCTOR7uHLED1D\SML1206SLED_0LED-GreenLED2D\SML1206SLED_0LED-GreenLED3D\SML1206SLED_0LED-GreenLED4D\SML1206SLED_0LED-RedM1M1CON1_0(3.5MM)M2M1CON1_0(3.5MM)M3M1CON1_0(3.5MM)M4M1CON1_0(3.5MM)M5M1CON1_0(3.5MM)M6M1CON1_0(3.5MM)M7M1CON1_0(3.5MM)Q1SO8MOSFET_P_DUAL_SOIRF7314Q2SOT23NPN2N3904Q3SOT23NPN2N3904Q4SO8MOSFET_P_DUAL_SOIRF7314Q5SOT23_2N70022N3797_02N7002AQ6SOT23_2N7002ON-MOSFET-NTR4502_0NTR4502PT1GQ7SOT23NPN2N3904S9SW\KN11BSW_PUSHBUTTON_1KN11BS10SW\7101MD9AV2BESW_SPDT_0SW SPDTSD1SOT23BAS70-05_1BAS70-05SD2SOT23BAS70-05_1BAS70-05SD3B320B-B360BDIODE_SCHOTTKY_0B340B-13-FSD4B320B-B360BDIODE_SCHOTTKY_0B340B-13-FSW1DIP8SW_DIP-4SW DIP-4SW2DIP8SW_DIP-4SW DIP-4U1SO8AT24C21_2AT24C16U2LQFP128-EPTW8836_23TW8836U3DFN-L10-3X3ISL80101_3ISL80101_ADJU4DFN-L10-3X3ISL80101_3ISL80101_ADJU5SOT-353NC7SV14NL17SZ04DFT2U6SOT-353NC7SV14NL17SZ04DFT2U7TSSOP56DS90C385_0SN65LVDS93AU8ADV7390-32LFCSPADV7390_0ADV7390U9DFN-L8-2X3ISL9001A_0ISL9001A-1.8VU10SO16-300AT24C02_P_1EN25Q128-104FIPU11SO8-200AT24C02_P_2(MX25L1635D)U12M16_15MAX232ICL3232CBNZU1320-UFQFN_EXPOSED_PADGPIO_EXPANDER_4SX1505I087TRTU15SOT25AP2171WG_0AP2171WGU16SO824CXX_024C02U178_LD_MSOPISL33003_1ISL33003U18SN74AVC1T45DBVRSN74AVC1T45SN74AVC1T45U19EP9553E-LQFP128EP9553E_LQFP128HDMI_Rx_LQFP128U20DFN-L10-3X3ISL80101_3ISL80101_ADJU21DFN-L10-3X3ISL80101_3(ISL80101_ADJ)U22DFN-L10-3X3ISL80101_3ISL80101_ADJU2528_LD_TQFNISL85033_2ISL85033VR1CON-SIP-3PRESISTOR_VAR(VR)Y1OSCDIPCRYSTAL_027MHzY2ABM3CRYSTAL24MHzZD7SOT23BAS70-05_10RD6.2 补上图片。。图片 收藏谢谢分享 TW8836 SCH PCB 学习了
