BCM96332 做的电信ADSL 拨号猫 PCB和原理图
NamePart TypePCB DecalValueD1LEDLED-2.54LEDD2DIO-LEDLED-2.54GREEN-R/AD6LEDLED-2.54LEDD7DIO-SCHOTTKYDO-214SS24D8DIO-SCHOTTKYDO-214SS24D9DIODEIN4148IN4004D10DIODEIN4148IN4004D11DIODE603NCJ1RES-OPT-A+BMY-0603-3PAC=75RJ2RES-OPT-A+BMY-0603-3PAC=0RJ3B2S_1JUMPNC/2PJ4RES-OPT-A+BMY-0603-3PBC=0RJP24_HEADERSIP44 HEADERL1IND603330nHL2IND341268uHL3IND341268uHL6INDL-22UH/2A22UH/2AL7IND341268uHL8IND341268uHL9FB1210600@100MHzL10FB603600@100MHzL11FB603600@100MHzL12INDL-22UH/2A22UH/2AL13IND-FB603600@100MHzL15IND805NCP1RJ45-10+2-J_8RJ-45RJ45-1X8-RAP2CON-USB-J_0USBCON4B_DIPNC/USBP3RJ11-6-JRS-232RJ11P4CON-RCA-VERT-JPOWERJKR/A-2.5mmQ1JFET_NSOT89JFET NQ2PNP_1SOT892SB1440Q3REGULATOR_APL117-1V8_SOT223SOT-223LD1117-3.3/223Q4DIO-DUAL-ACSOT23MMBD7000LT1GQ5DIO-DUAL-ACSOT23MMBD7000LT1GQ16MMBT3904_1SOT23NCRV1DIODEIN4148ZDSW1SW-DPDT-OXC-OXC-NN_0SW-ROCKER-DPDT-VPB-DPDT-LOCKSW2SW-PB-SPST-GGSWITCH-4PDIP-4PT1XFMR-LAL0683-ALTLA2020BX2542WT2XFMR-LAN1102_0H12107DKLAN1102U1SST25VF080-FP_2SOP-8SST25VF016BU2S25FL032A_1SOP-16PS25FL032A (NC)U3MMBT3904_1SOT23ADAAU4NE5532_2SOP-8MC34063U5BCM96332_5BGABCM6332U5BCM96332BGABCM6332U6BCM6301-A0-KS-ALTSOP-8BCM6301-A0U7MT48LC4M16-NSTSOP54MT48LC4M16A2-6U8K4S161622HMY-SMT-TSOP50PK4S161622H-UC80 (NC)U9NE5532_1SOP-8MC34063X1XTALHC-49S64.000MHz PCB 和原理图共享,回复可见下载。
**** Hidden Message ***** adsl不过时吗? 支持
