电子小跑腿 发表于 2020-2-22 13:53:43
AD  PADS  ALLEGRO通用的3D PCB封装库
很多3D STEP 通用的模型封装。PADS ALLEGRO AD 都可以用的。太多太多,没办法全部截图。下面有详细列表。有需要的下载。
详细封装列表。
\050-2.STEP
\050-3.STEP
\050-4.STEP
\050-5.STEP
\050-6.STEP
\050-7.STEP
\050-8.STEP
\050-9
\050-9.STEP
\1001-1
\1001-2
\1001-3
\1001-4
\1001-5
\1001-6
\1001-7
\1001-8
\10uF.STEP
\22-27-2021
\22-27-2031
\22-27-2041
\22-27-2051
\22-27-2061
\22-27-2071
\22-27-2081
\3SMG_atd-036ab.step
\4.7uF.STEP
\4pin_TS-1143-WP.STEP
\5MM LED RED.step
\5w wid.step
\7 Segment LED Module.step
\8x12 display.step
\9脚电子管座.STEP
\A1191.STEP
\A992.STEP
\axial-0.2-0.125w
\AXIAL-0.2-0.125W.STEP
\AXIAL-0.4-0.25W
\AXIAL-0.4-0.25W.STEP
\axial-0.6-2w
\axial-0.6-2W.STEP
\axial-8.60-3W.STEP
\AXIAL0_4_10K.step
\AXIAL0_4_1K.step
\AXIAL0_4_3K3.step
\AXIAL0_4_47K.step
\AXIAL0_4_4K7.step
\AXIAL_RESISTOR(0_25W).step
\AXIAL_RESISTOR(3W).step
\B649A.STEP
\BS-114_T.STEP
\Buzzer D7-12
\C06x18
\C06x18..STEP
\C06x18.STEP
\C10x26.STEP
\C10x26R.STEP
\C14x26.STEP
\C17x32.STEP
\C1845.STEP
\C2856.STEP
\CAP   天蓝.STEP
\CAP   粉紫.STEP
\CAP   绿.STEP
\CAP   蓝.STEP
\CAP 10.STEP
\CAP 101.STEP
\CAP0.2.STEP
\CAP0.3.STEP
\Capacitor 0603 SMD.step
\Capacitor 0805 SMD.step
\Capacitor 0805 SMD1.step
\Capacitor 100nF.step
\Capacitor 10n - 630V.step
\Capacitor 1206 SMD.step
\Capacitor 1206 SMD1.step
\Capacitor 1812 SMD.step
\Capacitor 2200uF, 25V.step
\Capacitor array.step
\Capacitor Electrolytic (Vertical).step
\Capacitor Radial Electrolitic.step
\Capacitor RB_3_6.step
\Capacitor RB_4__8.step
\Capacitor RB_5_1_0.step
\CERMET TRIMMER SINGLE TURN 10MM 500MW SIDE ADJUST 3386W.step
\CERMET TRIMMER SINGLE TURN 10MM 500MW TOP ADJUST.step
\CES-105-01-G-S 5pin.step
\CUI-DEFAULT.step
\D-PAK
\D-PAK.STEP
\D669A.STEP
\D7_12.STEP
\DF1704E-28.STEP
\DIP20-300-metric.step
\DIP40-600.step
\DIPSWITCH-1.step
\DIPSWITCH.STEP
\DIPSWITCH_DA10.STEP
\DO-214AA
\DO-214AA.STEP
\DO-214AB
\DO-214AB.STEP
\DO-214AC
\DO-214AC.STEP
\DO-41
\DO-41.STEP
\DO-41Z
\DO-41Z.STEP
\DR9-PIN_DSUB-1.STEP
\DR9-PIN_DSUB.STEP
\ECQE(F) 0.33uf 630Vdc 250Vac RA.step
\ECQE(F) 0.47uf 630Vdc 250Vac.step
\ECQE(F) 0.68uf 630Vdc 250Vac.step
\ECQE(F) 1.5uf 630Vdc 250Vac.step
\EI-19x5.STEP
\ELECTROLITIC CAPACITOR RADIAL 10X12.step
\ELECTROLITIC CAPACITOR RADIAL 5X11.step
\ELECTROLITIC CAPACITOR RADIAL 8X12.step
\GREENLED-.step
\HJR-4102.STEP
\IPT1-105-01-S-D.step
\J74.STEP
\JP051-6P6C
\JP051-6P6C_02.STEP
\JS-1132-10
\JS-1132-11
\JS-1132-12
\JS-1132-13
\JS-1132-14
\JS-1132-15
\JS-1132-2
\JS-1132-3
\JS-1132-4
\JS-1132-5
\JS-1132-6
\JS-1132-7
\JS-1132-8
\JS-1132-9
\JS-1132R-2
\JS-1132R-3
\JS-1132R-4
\JS-1132R-5
\JS-1132R-6
\JS-1132R-7
\JS-1132R-8
\K170.STEP
\KSD-9700
\KSD-9700.STEP
\LED 1206.step
\led 5mm 3 pin.step
\LED DIP 3MM.step
\led0805green.step
\LED1206R.STEP
\LED1206Y.STEP
\LED3_BLUE.STEP
\LED3_GRE.STEP
\LED3_RED.STEP
\LED3_YEL.STEP
\LED5-BLUE
\LED5-GRE
\LED5-RED
\LED5-YEL
\LED5_BLUE.STEP
\LED5_GRE.STEP
\LED5_RED.STEP
\LED5_YEL.STEP
\LEDd3G.STEP
\LEDd5B.STEP
\LEDd5G.STEP
\LEDd5O.STEP
\LEDd5Y.STEP
\LM317CV.STEP
\LTC-3710HR DISPLAY, 4-LED.STEP
\LTMM-O5-02-G-D.step
\MJE15030.STEP
\MJE15031.STEP
\Murata TZ03Capacitor.step
\PA0630NOXOX-HA1
\PA0630NOXOX-HA1.STEP
\paizheng9pin.step
\PCM1704-20.STEP
\R0402
\R0603
\R0805
\R1206
\R1206-4R.step
\RA电阻.STEP
\RA电阻1.4W.STEP
\RA电阻1.4W10.5K.STEP
\RA电阻1.4W10K.STEP
\RA电阻1.4W12.4K.STEP
\RA电阻1.4W14.3K.STEP
\RA电阻1.4W1K.STEP
\RA电阻1.4W1M.STEP
\RA电阻1.4W2.2K.STEP
\RA电阻1.4W220R.STEP
\RA电阻1.4W2K.STEP
\RA电阻1.4W37.4K.STEP
\RA电阻1.4W470R.STEP
\RA电阻1.4W47R.STEP
\RA电阻1.4W5.6K.STEP
\RA电阻1.4W560R.STEP
\RA电阻1.4W56K.STEP
\RA电阻1.4W75R.STEP
\RA电阻1.4W76.8K.STEP
\RA电阻1.4W97.6K.STEP
\RA电阻100K.STEP
\RA电阻1W100K.STEP
\RA电阻1W220K.STEP
\RA电阻1W220R.STEP
\RA电阻2W100R.STEP
\RA电阻2W10K.STEP
\RA电阻2W140K.STEP
\RA电阻2W1K.STEP
\RA电阻2W1M.STEP
\RA电阻2W2.7K..STEP
\RA电阻2W200K.STEP
\RA电阻2W220K.STEP
\RA电阻2W240K.STEP
\RA电阻2W31.6R.STEP
\RA电阻2W464R.STEP
\RA电阻2W470R.STEP
\RA电阻2W47K.STEP
\RA电阻2W5.1K.STEP
\RA电阻2W50K.STEP
\RA电阻2W6.2K.STEP
\RA电阻4.1W2.2K.STEP
\REDLED.step
\Resistor 0805 103.step
\Resistor 0805 SMD.step
\Resistor 1812 SMD.step
\RESISTOR 7_62MM DIP.step
\Resistor array 9pin.step
\RESISTOR, 0_25 W, 0_4 IN LEAD PITCH.step
\Resistor2.step
\Res_Normal (0_25W).step
\RF12232F.STEP
\RIA_AJT10L8813-011.step
\RL-DIP12.STEP
\S302.step
\SD-105-02-G.step
\SIM300D.STEP
\SIM548Z.STEP
\SIP-2-3.96
\SIP-3-3.96
\SL-D
\SL-E
\SL-G
\SL-H
\SMG_4.step
\SMG_4_1.step
\SO-8
\SO-8.STEP
\SOD-123
\SOD-123.STEP
\SOD-323
\SOD-323.STEP
\SOD-523
\SOD-523.STEP
\SOD-723
\SOD-723.STEP
\SOD-80
\SOD-80.STEP
\SOIC-4
\SOIC-4.STEP
\SOP14
\SOP14.STEP
\SOP8
\SOT-223_MP04A
\SOT-223_MP04A.STEP
\SOT-23-3
\SOT-23-3.STEP
\SOT-23-5
\SOT-23-5.STEP
\SOT-89
\SOT-89.STEP
\SW3dPS-1N4007.STEP
\SW3dPS-1N4007_Stand.STEP
\SW3dPS-1N4148.STEP
\SW3dPS-1N4148_Stand_V2008.STEP
\SW3dPS-bridge 2.STEP
\SW3dPS-BYW98.STEP
\SW3dPS-ctb0100~2.STEP
\SW3dPS-DIP SWITCH 8 POS CTS 206.STEP
\SW3dPS-diptronics tactile dts-63k.STEP
\SW3dPS-DO-214AB SMC.STEP
\SW3dPS-DO-214AC SMA.STEP
\SW3dPS-dsp-012.STEP
\SW3dPS-e-switch - series p227 .STEP
\SW3dPS-HP49US.STEP
\SW3dPS-jm12864a.STEP
\SW3dPS-LCD module 16 X 2 backlight.STEP
\SW3dPS-Lumex_LCM-X02002DXX_2x20LCD_withBackLight.STEP
\SW3dPS-optrex_dmc16207_2linex16characterlcd.STEP
\SW3dPS-PowSO30-ST.STEP
\SW3dPS-PQ208.STEP
\SW3dPS-PUSH BUTTON-2.STEP
\SW3dPS-rapc722.STEP
\SW3dPS-srb22a2fbbnn.STEP
\SW3dPS-SSOP 20 PIN.STEP
\SW3dPS-SSOP-24.STEP
\SW3dPS-SSOP16.STEP
\SW3dPS-ssop16p500x440ls065h200.STEP
\SW3dPS-SSOP36-P08.STEP
\SW3dPS-SSOP_20.STEP
\SW3dPS-switch-tact-smt.STEP
\SW3dPS-TACT Switch - SKHUAME010.STEP
\SW3dPS-Touche DTS-6X.STEP
\SW3dPS-Touche DTSM-644.STEP
\SW3dPS-TRANSFORMER, 50VA.STEP
\SW3dPS-TSSOP-20.STEP
\SW3dPS-TSSOP-48.STEP
\SW3dPS-TSSOP20_TP.STEP
\SW3dPS-TVAU19.step
\SW3dPS-TVBU19.STEP
\SW3dPS-winstar 12864 lcd.STEP
\Switch - TL3330AF130QG (Tact Switch, SMD).step
\TAJ-A
\TAJ-B
\TAJ-C
\TAJ-D
\TAJ-E
\TAJ-R
\TANT_2M_2M-DEFAULT.step
\TCSD-05-01-X-N.step
\TL 2201.step
\TO-126
\TO-126.STEP
\toshiba_11-4c1
\TOSHIBA_11-4C1.STEP
\TOYO LED.step
\TS-1180-WP.STEP
\TSSOP-8
\TSSOP-8.STEP
\TSSOP28.STEP
\TSW-109-07-G-S 9pin.step
\UPC1237HA.STEP
\USB-A-S-F-B-TH.step
\USB-AM-S-F-B-TH.step
\USB-B-S-F-B-TH.step
\User Library-DFLS220-POWERDI-123.STEP
\User Library-Diode MELF.STEP
\User Library-DIP-Switch.STEP
\User Library-DIPSWITCH_DA12.STEP
\User Library-DIPSWITCH_DA7.STEP
\User Library-DIPSWITCH_DA8.STEP
\User Library-DIPSWITCH_DA9.STEP
\User Library-Disipador 34M8491-1.STEP
\User Library-display-alpha-numeric 20x2.STEP
\User Library-Everbouquet_MC1602X-SYL_LCD.STEP
\User Library-GeyerElectronics_KX13.STEP
\User Library-GeyerElectronics_KX5.STEP
\User Library-KCD11.STEP
\User Library-Phone Line Transformer.STEP
\User Library-PSSO-12.STEP
\User Library-PUSH BUTTON-3.STEP
\User Library-SOD-123_DiodesInc.STEP
\User Library-sop-8.STEP
\User Library-SOP14-p127-780.STEP
\User Library-ssop-16 0_0315pol.STEP
\User Library-SSOP-30.STEP
\User Library-SSOP-48.STEP
\User Library-WG12864A.STEP
\User Library-XFMR_Xicon_42TL.STEP
\XTAL1.step
\三级管1.STEP
\三级管11.STEP
\双排针-8.STEP
\双排针.STEP
\场效应管J200.STEP
\场效应管K1529.STEP
\拨码开关.STEP
\排阻.STEP
\电子管12AU7A.STEP
\电子管USA5687WB.STEP
\电容.STEP
\电解电容柠蒙黄零件72.STEP
\电解电容深绿零件72.STEP
\电解电容粉红零件72.STEP
\电解电容紫零件72.STEP
\电解电容红零件72.STEP
\电解电容绿零件721.STEP
\电解电容绿.STEP
\电解电容蓝零件72.STEP
\电解电容黄零件72.STEP
\电解电容.STEP
\编码开关.STEP
\胆电容.STEP
\零件1.STEP
\零件11.STEP
\零件2.STEP
\零件4.STEP
\零件5.STEP
\零件5V继电器.STEP
\SL-B
\050-9\050-9.STEP
\1001-1\1001-1.STEP
\1001-2\1001-2.STEP
\1001-3\1001-3.STEP
\1001-4\1001-4.STEP
\1001-5\1001-5.STEP
\1001-6\1001-6.STEP
\1001-7\1001-7.STEP
\1001-8\1001-8.STEP
\22-27-2021\molex-22-27-2021.STEP
\22-27-2031\molex-22-27-2031.STEP
\22-27-2041\molex-22-27-2041.STEP
\22-27-2051\molex-22-27-2051.STEP
\22-27-2061\molex-22-27-2061.STEP
\22-27-2071\molex-22-27-2071.STEP
\22-27-2081\molex-22-27-2081.STEP
\axial-0.2-0.125w\AXIAL-0.2-0.125W.STEP
\AXIAL-0.4-0.25W\AXIAL-0.4-0.25W.STEP
\axial-0.6-2w\axial-0.6-2W.SLDPRT
\C06x18\C06x18.STEP
\D-PAK\D-PAK.STEP
\DO-214AA\DO-214AA.STEP
\DO-214AB\DO-214AB.STEP
\DO-214AC\DO-214AC.STEP
\DO-41\DO-41.STEP
\DO-41Z\DO-41Z.STEP
\JP051-6P6C\JP051-6P6C_02.STEP
\JS-1132-10\JS-1132-10.STEP
\JS-1132-11\JS-1132-11.STEP
\JS-1132-12\JS-1132-12.STEP
\JS-1132-13\JS-1132-13.STEP
\JS-1132-14\JS-1132-14.STEP
\JS-1132-15\JS-1132-15.STEP
\JS-1132-2\JS-1132-2.STEP
\JS-1132-3\JS-1132-3.STEP
\JS-1132-4\JS-1132-4.STEP
\JS-1132-5\JS-1132-5.STEP
\JS-1132-6\JS-1132-6.STEP
\JS-1132-7\JS-1132-7.STEP
\JS-1132-8\JS-1132-8.STEP
\JS-1132-9\JS-1132-9.STEP
\JS-1132R-2\JS-1132R-2.STEP
\JS-1132R-3\JS-1132R-3.STEP
\JS-1132R-4\JS-1132R-4.STEP
\JS-1132R-5\JS-1132R-5.STEP
\JS-1132R-6\JS-1132R-6.STEP
\JS-1132R-7\JS-1132R-7.STEP
\JS-1132R-8\JS-1132R-8.STEP
\KSD-9700\KSD-9700.STEP
\LED5-BLUE\LED5_BLUE.STEP
\LED5-GRE\LED5_GRE.STEP
\LED5-RED\LED5_RED.STEP
\LED5-YEL\LED5_YEL.STEP
\PA0630NOXOX-HA1\PA0630NOXOX-HA1.STEP
\R0402\R0402.STEP
\R0603\R0603.STEP
\R0805\R0805.STEP
\R1206\R1206.STEP
\SIP-2-3.96\molex-22-27-2021.STEP
\SIP-3-3.96\SIP-3-3.96 22-27-2031.STEP
\SL-D\SL-B.STEP
\SL-D\SL-D.STEP
\SL-E\SL-E.STEP
\SL-G\SL-G.STEP
\SL-H\SL-H.STEP
\SO-8\SO-8.STEP
\SOD-123\SOD-123.STEP
\SOD-323\SOD-323.STEP
\SOD-523\SOD-523.STEP
\SOD-723\SOD-723.STEP
\SOD-80\SOD-80.STEP
\SOIC-4\SOIC-4.STEP
\SOP14\SOP14.STEP
\SOP8\SO-8.STEP
\SOT-223_MP04A\SOT-223_MP04A.STEP
\SOT-23-3\SOT-23-3.STEP
\SOT-23-5\SOT-23-5.STEP
\SOT-89\SOT-89.STEP
\TAJ-A\TAJ-A.STEP
\TAJ-B\TAJ-B.STEP
\TAJ-C\TAJ-C.STEP
\TAJ-D\TAJ-D.STEP
\TAJ-E\TAJ-E.STEP
\TAJ-R\TAJ-R.STEP
\TO-126\TO-126.STEP
\toshiba_11-4c1\TOSHIBA_11-4C1.STEP
\TSSOP-8\TSSOP-8.STEP
电子小跑腿 发表于 2020-2-22 13:58:28
一起打包。 回复可见下载。
**** Hidden Message *****
roezw 发表于 2020-2-22 14:09:48
wych131 发表于 2020-2-22 14:49:02
感谢分享!
bingo426 发表于 2020-2-22 15:19:28
kanxue_nmg 发表于 2020-2-22 17:30:02
mirage 发表于 2020-2-23 00:10:50
谢谢分享
longxuekai 发表于 2020-2-23 07:09:37
来看一下吧
andyhh 发表于 2020-2-23 08:11:55
安acp 发表于 2020-2-23 08:51:07
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: AD  PADS  ALLEGRO通用的3D PCB封装库
