关于alegro网表错误饿问题
{ Using PSTWRITER 16.6.0 d001Jul-10-2020 at 16:24:03 }#1 ERROR(ORCAP-36071): Illegal character "Dot(.)" found in "PCB Footprint" property for component instance U4: SCHEMATIC1, PAGE1 (238.76, 114.30) .
#2 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance E1: SCHEMATIC1, PAGE1 (13.46, 6.60).
#3 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number E5: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
#4 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number F2: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
#5 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number D7: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
#6 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number E7: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
#7 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number D6: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
#8 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number E6: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
#9 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , RST_N1: SCHEMATIC1, PAGE1 (40.39, 86.36). All pins should be numbered.
#10 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , UART_RX1: SCHEMATIC1, PAGE1 (19.56, 109.22). All pins should be numbered.
#11 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , BATP1: SCHEMATIC1, PAGE1 (20.07, 86.36). All pins should be numbered.
#12 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , UART_TX1: SCHEMATIC1, PAGE1 (18.03, 99.06). All pins should be numbered.
#13 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , GND1: SCHEMATIC1, PAGE1 (40.13, 109.22). All pins should be numbered.
#14 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , REGEN1: SCHEMATIC1, PAGE1 (40.64, 99.31). All pins should be numbered.
#15 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , OD_GPIO1: SCHEMATIC1, PAGE1 (19.81, 119.38). All pins should be numbered.
#16 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package TP_1 , L-1: SCHEMATIC1, PAGE1 (241.81, 4.83). All pins should be numbered.
#17 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , PIO1: SCHEMATIC1, PAGE1 (40.64, 119.38). All pins should be numbered.
#18 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package TP_1 , L+1: SCHEMATIC1, PAGE1 (238.51, 27.69). All pins should be numbered.
#19 INFO(ORCAP-36107):PCB Editor does not support Dots(.), Forward Slash(/) and White space in footprint names. The supported characters include Alphabets, Numerics,
Underscore(_) and Hyphen(-).
#20 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
请问大家这么多的错误,除了红色部分外,应该如何更改?
第一,做元件的时候说GND告警可以忽略,这里警告改如何修改?我通过把GND加数字办法已经修改成功,请问高手还没有其他办法?
第二,那些焊点的错误,因为是要做测试夹具,程序下载口可以随便放置,因此做的是一个焊点算是一个封装,这里是我最不明白的,希望能得到大神的指导。
希望有大神不吝赐教,谢谢了! 第一个问题放置引脚的时候选择为power引脚就不会提示了,只有power引脚才能重名。比如VCC和GND 各位大神,第二个问题我刚才试出来把我原来做的单点焊盘封装有贴片改为加过空方式就不报错了,请问这又是什么原因呢? 好好学习,天天向上 没有人指导一下吗
