老吴 发表于 2020-7-12 11:04:08
杰微采用intel N2930,J1900,J1800,E3815 做的电脑主板PCB 原理图 BIO
NamePCB DecalPart TypeValueATX_12VDC_63100015DC_JACK_3P_63100015DC JACK 63100015-2.5MMBIOS1IC8_208SPI_FLASH_SOP_8PW25Q64FWSSIG SOIC208BUZZER1SPEAKER_9MMSPEAKERAC-905G-PD 5V 2PINCFAN1HEADER4_HFAN1X4_0FAN1X4CMC1LR4_0805LR4_0805FB 120 400mA EMI 0805CMC2LR4_0805LR4_0805FB 120 400mA EMI 0805CMC3LR4_0805LR4_0805FB 120 400mA EMI 0805CMC4LR4_0805LR4_0805FB 120 400mA EMI 0805COM1COM_ATXBCOM_PORT_TDB09 THIN MALECOP1SHORTCOPCOP/XCOP2SHORTCOPCOP/XCOP3SHORTCOPCOP/XCOP4SHORTCOPCOP/XCPU1BGA1170_27X25BYT_I_SOC_R1P1N2930,J1900,J1800,E3815D1SOD323DIODE1N4148WS SOD323D2SOD323DIODE1N4148WS SOD323D4SOT_23ABAT54CBAT54C SOT23D5SOD323DIODE1N4148WS SOD323/XD6SOD323DIODE1N4148WS SOD323D7SOD123DIODEB5819W SOD123D8SOD123DIODEB5819W SOD123D9SOD323DIODE1N4148WS SOD323/XD10SOD323DIODE1N4148WS SOD323D11SOD323DIODE1N4148WS SOD323DIMM1DDR3_STD_5D2DDR3_SODIMM204DDR204 STD5D2 WHITEDU3SB1USB3X2_ATXBUSBSATA_0USB3.0 X2EMMC1BGA169_0P5_12X16SDIN5C2_TFBGA_6EMMCESD1ESDPAD_R0402TVS_0ESD9B5V-2/TR 5V/XFB2FB0603FERRITE_BEADFB 30 1.5A 0603FB3FB0603FERRITE_BEADFB 600 1A 0603FB4FB0603FERRITE_BEADFB 600 1A 0603FB5FB1806LFB 60 6A 1806FB19FB0603LFB 82NH 0603FB20FB0603FERRITE_BEADFB 220 0.55A 0603FB21FB0603FERRITE_BEADFB 220 0.55A 0603FB22FB0805FERRITE_BEADFB 80 6A 0805FU1FUSE1206FUSEFUSE 7A 1206FU2FUSE_SMFUSE1812FUSE 2A 1812FU3FUSE_SMFUSE1812FUSE 2A 1812F_MIC1AUDIO6_63000346AZALIAJACK_63000348AUDIO JACK 63000347 REDF_OUT1AUDIO6_63000346AZALIAJACK_63000348AUDIO JACK 63000348 GREENF_PANEL1JP2X5CHEADER2X5N10HEADER2X5N10 2.54MMGPIO1JP2X3HEADER2X3HEADER2X3 2.54MMH1MTH200X118AHOLE_DOWELHole+DowelH2MTH200X118AHOLE_DOWEL_2STAND OFF M2.0X5.0 OD3.85H3MTHT200B250X138HOLE_DOWEL_2MTH/XH4MTHT200B250X138HOLE_DOWEL_2MTH/XH5MTHT200B250X138HOLE_DOWEL_2MTH/XHDMI1HDMI_CHDMI_AHDMI 90DINCN1HEADER6X2MMHEADER1X6WAFER 1X6 2.0MMIRQ1TP22TP_0TP/XJ1PWR_4P_90DATX12ATX 2X2 90D/XJBAT1HEADER2-2MMHEADER1X2HEADER1X2 2.0MMJBAT2HEADER2-2MMHEADER1X2HEADER1X2 2.0MMJDEBUGHEADER2HEADER1X2HEADER1X2 2.54MMJMEHEADER2HEADER1X2HEADER1X2 2.54MMJPWR_LVDS(1-2)1JUMPERJUMPER 2.54MMJPWR_LVDS1JP2X3HEADER2X3HEADER2X3 2.54MMJSATA_PWRSIP4DHEADER1X4P_WAFER1X4 2.54MMJSPKHEADER4_H-2MMHEADER1X4WAFER1X4 2.0MMJUSB1HEADER4-2MMHEADER1X4HEADER1X4 2.0MML1COIL1_0UH_SMTL_PWRIND 1.5UH 9A 6003L2COIL1_0UH_SMTL_PWRIND 1.0UH 11A 6003L3COIL1_0UH_SMTL_PWRIND 1.5UH 9A 6003L4COIL1_0UH_SMTL_PWRIND 1.0UH 11A 6003L5COIL1_0UH_SMTL_PWRIND 1.5UH 9A 6003L6LS2_6530L_PWRIND 4.7UH 5.5A 6003L7FB1210LIND 4.7UH 1.3A 3225LAN1RJ45_RB1TEST_POINT_0RJ45 RB1-2S5BAK1ALVDS1HEADER2X15X2MMHEADER2X15HEADER 2X15 2.0MMMH1MTH275X134HOLE_DOWEL_2MTH/XMH2MTH275X134HOLE_DOWEL_2MTH/XMH3MTH275X134HOLE_DOWEL_2MTH/XMH4MTH275X134HOLE_DOWEL_2MTH/XMPCIE1MINIPCIEMINI_PCIEMPCIE52 5D2MSATA1MINI_PCIEMINIPCIE 52Pin 8mmPL1LS2_6530L_PWRIND 4.7UH 5.5A 6003PQ1QFN8_6X6X1D27AON6912_0AON6912-D QFN5X6PQ2QFN8_6X6X1D27AON6912_0AON6912-D QFN5X6PQ3SOP8-50-150X70FET_NMOS_8PAO4468 SO8PQ4SOP8-50-150X70FET_NMOS_8PAO4468 SO8PR1R0402R2.55K 1% 0402PR2R0402R2.55K 1% 0402PSONSW_CMOSABUTTON_0SWITCH 4Pin 90D 6*6*5mmPWR_LED1LED5X7D7X2D54ALED_1LED GREEN 3MM 90DQ1SOT_23AMOSN_SOT_23BSS138 SOT23Q2SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q3SOT_23AMOSN_SOT_232N7002 SOT23Q4SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q5SOT_23AMOSN_SOT_23BSS138 SOT23Q6SOT_23AMOSN_SOT_23BSS138 SOT23Q7SOT_23AMOSN_SOT_23BSS138 SOT23Q10SOT_23AMOSN_SOT_23BSS138 SOT23Q11SOT_23AMOSN_SOT_23BSS138 SOT23Q12SC70_6NCT3530Y_0G2129Q13SOT_23AMOSN_SOT_232N7002 SOT23Q22SOP8-50-150X70FET_NMOS_8PAO4468 SO8Q25SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q26SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q29SOT_23AMOSN_SOT_23AO3402 SOT23Q32SOP8-50-150X70FET_PMOS_8P/1AO4413 -30V SOIC8Q33SOT_23AMOSN_SOT_232N7002 SOT23Q34TL431_SMLM431_0TL431 SOT23Q35SOP8-50-150X70FET_NMOS_8PAO4468 SO8Q36SOP8-50-150X70FET_NMOS_8PAO4468 SO8Q37SOP8-50-150X70FET_NMOS_8PAO4468 SO8Q38SOP8-50-150X70FET_NMOS_8PAO4468 SO8Q43SOP8-50-150X70FET_PMOS_8P/1AO4413 -30V SOIC8Q44SOT_23AMOSN_SOT_232N7002 SOT23Q45SOT_23AMOSN_SOT_232N7002 SOT23Q46SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q47SOT_23AMOSN_SOT_23BSS138 SOT23Q48SOT_23AMOSN_SOT_23AO3402 SOT23Q49SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q50SOT_23ATRAN_PNP_SOT_232N3906 SOT23Q51SOT_23AMOSN_SOT_23BSS138 SOT23Q52SOT_23AMOSN_SOT_232N7002 SOT23Q53SOT_23AMOSN_SOT_23BSS138 SOT23Q54SOT_23AMOSN_SOT_232N7002 SOT23Q55SOT_23AMOSN_SOT_23BSS138 SOT23Q57SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q60SOT_23AMOSN_SOT_232N7002 SOT23Q61IC8_SO_BNCT3101SNCT3101S ESOP-8Q62SOP8-50-150X70FET_PMOS_8P/1AO4447A -30A SOIC8Q63SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q64SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q65SOT_23AMOSN_SOT_232N7002 SOT23Q66SOT_23AMOSN_SOT_23AO3402 SOT23Q67SOT_23AMOSN_SOT_232N7002 SOT23Q68SOT_23AMOSN_SOT_232N7002 SOT23Q69SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q70SOT_23AMOSN_SOT_232N7002 SOT23Q71SOT_23AMOSN_SOT_232N7002 SOT23Q72SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q74SOT_23ATRAN_NPN_SOT_232N3904 SOT23Q75SOT_23AMOSN_SOT_23BSS138 SOT23Q76SOT_23AMOSN_SOT_23BSS138 SOT23Q78SOT_23AMOSN_SOT_232N7002 SOT23Q79SC70_6FET_NMOS_6P/22N7002-D SOT363Q80SC70_6DUAL_NPN_TRAN2N3904-D SOT363Q81SC70_6FET_NMOS_6P/22N7002-D SOT363Q82SC70_6DUAL_NPN_TRAN2N3904-D SOT363Q84SC70_6DUAL_NPN_TRAN2N3904-D SOT363Q85SC70_6DUAL_NPN_TRAN2N3904-D SOT363Q86SC70_6FET_NMOS_6P/22N7002-D SOT363Q87SC70_6FET_NMOS_6P/22N7002-D SOT363Q88SC70_6FET_NMOS_6P/22N7002-D SOT363Q89SC70_6FET_NMOS_6P/22N7002-D SOT363RN9SRN_0402RN_8P4R33 5% 0402 8P4RRN11SRN_0402RN_8P4R51 5% 0402 8P4RRN14LR4_0805RN_4P2R0 5% 0603 4P2RRSTSW_CMOSABUTTON_0SWITCH 4Pin 90D 6*6*5mmRT1R0603R_THERMISTOR10K 5% NTC 0603RT2R0603R_THERMISTOR10K 5% NTC 0603RTCBAT1CNS2_RCON_BAT_1X2_H2WAFER1X2 1.25MM 85204-02001RTC_BAT1RTCBATBAT CR2032 L40SATA1SATA_1_5MMSATA1SATA7PSD1SD_MMCSD_MS_12PSD CONN 12PSIM1SIM_CARD_BSIMCARD_BSIM CARDSR1R0402R4.7K 5% 0402U1QFN10_0D5_3D0X0D8NCT3530YNCT3530Y DFN10/XU2SOT23_574AHC1G08GV74AHC1G08GV SOT23_5 PHILIPSU3QFN23-0D5-4X4X1AOZ1237QIAOZ1237QI-3 QFN23LU4IC8_SO_BNCT3101SNCT3101S ESOP-8U5QFN23-0D5-4X4X1AOZ1237QIAOZ1237QI-3 QFN23LU6QFN23-0D5-4X4X1AOZ1237QIAOZ1237QI-3 QFN23LU8IC8_SO_BNCT3101SNCT3101S ESOP-8U9IC8_SO_BNCT3101SNCT3101S ESOP-8U10IC8_SO_BNCT3101SNCT3101S ESOP-8U11QFN40P_5X0D4ISL95837ISL95837HRZ QFN40U12IC8_SOAS358MTRGS358SF SO8U13QFN24TPS51125TPS51125 QFN24U14SOT457AZC099SAZC099-04S SOT23U15SOT457AZC099SAZC099-04S SOT23U16IC8_SO_BNCT3101SNCT3101S ESOP-8U17QFP_48SAUDIO_ALC892ALC662-VD LQFP48U18QFP64_7X7IT8772EFXIT8772E/FX QFP64U19SSOP16-150CM2009IP4772CZ16 SSOP16 NXPU20QFN10_20_40X24RCLAMP0524PRCLAMP0524P QFN10U21QFN10_20_40X24RCLAMP0524PRCLAMP0524P QFN10U22SSOP28-210HIN213HIN213ECAZ SSOP28U23SOT457AZC099SAZC099-04S SOT23U24SOT457AZC099SAZC099-04S SOT23U25QFN68_0D4_6X6X1MMCH7511CH7511 QFN68U26SOP8-50-150X70CH9904AMFCH9904AMF 64K SO8U27SOT457AZC099SAZC099-04S SOT23U28QFN10_20_40X24RCLAMP0524PRCLAMP0524P QFN10UA2QFN12_0D45_3X0D9ALC105ALC105 QFN12UL1QFN48_6X6X0D4RL5877_0RTL8111GN-CG QFN48USB3USB_US01USB_91_US01_0USB_91_US01_207VGA1VGA_ATXDB15DB15WIFI1JACK_SMAZYHG-2400-SMAWIFI ZYHG-2400-SMAX1XS4_5032OSC-4P24MHz OSC 5032Y1XS4_5032CRYSTAL_503225.000MHZ 20PF 5032Y2XS4_701432_0.768_SMT_4P32.768KHZ 12.5PF 8014Y3XS4_5032CRYSTAL_503225.000MHZ 20PF 5032Y4XS4_5032CRYSTAL_4P27.000MHZ 15PF 5032
老吴 发表于 2020-7-12 11:08:54
PCB 原理图 BOM 等所有资料一起打包。回复可见下载。
**** Hidden Message *****
yangxf0120 发表于 2020-7-12 11:08:07
谢谢分享intel N2930,J1900,J1800,E3815 做的电脑主板PCB 原理图
cml_l 发表于 2020-7-12 11:15:43
感谢分享
xiaoxiao 发表于 2020-7-12 11:18:04
谢谢分享
zhuming123 发表于 2020-7-12 11:26:58
shuszhao 发表于 2020-7-12 11:54:07
scitech999 发表于 2020-7-12 12:00:51
yhgwork 发表于 2020-7-12 12:46:13
看看高级的X86设计
linyuanfei 发表于 2020-7-12 12:51:44
谢谢分享
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 杰微采用intel N2930,J1900,J1800,E3815 做的电脑主板PCB 原理图 BIO
