用STM32F4的库函数RCC_PLLConfig()代替SystemInit()手动初始化
STM32上电复位后首先执行Reset_Handler,然后调用SystemInit()函数完成时钟等基本初始化,再执行main函数。; Reset handler
Reset_Handler PROC
EXPORTReset_Handler
IMPORTSystemInit
IMPORT__main
LDR R0, =SystemInit
BLX R0
LDR R0, =__main
BX R0
ENDP
SystemInit()函数在文件system_stm32f4xx.c中。由于该函数中宏定义较多,所以可读性不高,该函数并不能一目了然的看懂STM32F4的各个时钟都配置成了什么样子,笔者归纳总结了库函数和网上的一些资料,自己写了个手动配置RCC时钟的函数如下:
* .@1 - 复位 RCC 时钟配置为系统上电复位后的状态
* 系统上电复位后的时钟状态定义如下 - HSI ON and used as system clock source
* - HSE, PLL and PLLI2S OFF
* - AHB, APB1 and APB2 prescaler set to 1
* - CSS, MCO1 and MCO2 OFF
* - All interrupts disabled
* 该函数不改变如下配置:- Peripheral clocks
* - LSI, LSE and RTC clocks
* .RCC_PLLConfig(RCC_PLLSource, PLLM, PLLN, PLLP, PLLQ)
* RCC_PLLSource - PLL输入时钟源:RCC_PLLSource_HSI/RCC_PLLSource_HSE 之一
* PLLM - 分频因数,用来生成PLL VCO输入时钟,该时钟范围:1~2M
* RCC_PLLSource/PLLM = PLL VCO输入时钟
* 该分频因数的范围:2~63
* PLLN - 倍频因数,PLL VCO输入时钟*PLLN = PLL VCO输出时钟
* PLL VCO输出时钟范围:192~432M
* PLLP - 分频因数,用于生成SYSCLK
* PLL VCO输出时钟/PLLP = SYSCLK
* 该分频因数的范围:2,4,6 OR 8
* PLLQ - USB OTG FS, SDIO and RNG(随机数发生器)时钟的分频因数
* USB OTG FS需要48M的时钟以正常工作
* SDIO and RNG(随机数发生器)时钟 <= 48M
* 该分频因数的范围:2~15
* PLL_VCO =(RCC_PLLSource/PLLM)*PLLN
* SYSCLK = ((RCC_PLLSource/PLLM)*PLLN) / PLLP
* USB OTG FS, SDIO and RNG Clock = ((RCC_PLLSource/PLLM)*PLLN) / PLLQ
* 2018-01-27
void RCC_MyConfig(void)
RCC_DeInit(); //@1
RCC_HSEConfig(RCC_HSE_ON); //打开外部时钟
if(RCC_WaitForHseStartUp() == SUCCESS) //等待外部时钟成功启动
//RCC_PLLCmd(DISABLE); //配置PLL前应先关闭主PLL
RCC_SYSCLKConfig(RCC_SYSCLKSOURCE_PLLCLK); //选择PLL时钟为系统时钟
RCC_HCLKConfig(RCC_SYSCLK_Div1); //HCLK(AHB)时钟为系统时钟1分频
RCC_PCLK1Config(RCC_HCLK_Div4); //PCLK(APB1)时钟为HCLK时钟8分频
RCC_PCLK2Config(RCC_HCLK_Div2); //PCLK(APB2)时钟为HCLK时钟2分频
RCC_PLLConfig(RCC_PLLSource_HSE, 25, 336, 2, 7); //PLL时钟配置,外部晶振为25MHz,系统配置为168MHz
RCC_PLLCmd(ENABLE); //开启PLL时钟,并等待PLL时钟准备好
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
while(RCC_GetSYSCLKSource() != 0x08); //Wait till PLL is used as system clock source
看过上面的文章,读者可能有不懂的一个地方就是PLL VCO,那么,PLL,是倍频电路,我们把PLL倍频电路看作一个黑匣子,它是有输入和输出的,RCC_PLLSource经过PLLM分频后,就得到了这个黑匣子的输入时钟,这个输入时钟经过PLLN倍频后,就得到了黑匣子的输出时钟,OK,这个时钟就叫做PLL VCO
关键字:STM32F4库函数RCC_PLLConfig()SystemInit()手动初始化 加油加油加油呦
