Intel HASWELL 平台电脑主板PCB和
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEAT2TA_TEST_AUTO_P_TATATEST_AUTO_PBT1BT_BAT_R_3P-PL_BTBTBAT_R_3P-PLBUZZ1BUZZ_BUZZER_2P_P640-PL_BUZZBUZZBUZZER_2P_P640-PLCB6CB_SMD_C_P210L63H57-PL_330UF330uFSMD_C_P210L63H57-PLCD13CD_6M3_CD_6M3X12_220UF220uFCD_6M3X12CE17CE_DIP_EC_P350L80H110-PL_470UF470uFDIP_EC_P350L80H110-PLCN2GENTUSB3_0_PORT_2USB3_1RJ45_2X5GENTUSB3_0PORT_2USB3_1RJ45_2X5-PLD1BAT54C_SOT_23_BAT54CBAT54CSOT_23D4BAT54A_SOT_23_BAT54ABAT54ASOT_23D5BAT54A_SOT_23_BAT54ABAT54ASOT_23D8BAT54A_SOT_23_BAT54ABAT54ASOT_23D9BAT54A_SOT_23_BAT54ABAT54ASOT_23D10ESD_0603_SOD_323_OPT(BV03C)opt(BV03C)SOD_323D11ESD_0603_SOD_323_OPT(BV03C)opt(BV03C)SOD_323D121N4148_SOD_123_1N41481N4148SOD_123D17ESD_0603_SOD_523_OPT(ESD5B5)OPT(ESD5B5)SOD_523D18ESD_0603_SOD_523_OPT(ESD5B5)OPT(ESD5B5)SOD_523D23ESD_0603_SOD_323_OPT(BV03C)opt(BV03C)SOD_323D241N4148_SOD_123_1N41481N4148SOD_123D25BAT54A_SOT_23_BAT54ABAT54ASOT_23D26BAT54A_SOT_23_BAT54ABAT54ASOT_23D36ESD_0603_SOD_523_OPT(ESD5B5)OPT(ESD5B5)SOD_523D37ESD_0603_SOD_523_OPT(ESD5B5)OPT(ESD5B5)SOD_523D38BAT54A_SOT_23_BAT54ABAT54ASOT_23D40D_DO214_FM5819_FM5817FM5817FM5819D48ESD_0603_SOD_523_ESD5B5ESD5B5SOD_523D49ESD_0603_ESD_0603_NP_PESD0603-2PESD0603-240ESD_0603_NPD50ESD_0603_ESD_0603_NP_PESD0603-2PESD0603-240ESD_0603_NPD80DUALDIODE_SOT_23_BAV99BAV99SOT_23D81ESD_0603_SOD_523_OPT(ESD5B5)OPT(ESD5B5)SOD_523D82DUALDIODE_SOT_23_BAV99BAV99SOT_23D83ESD_0603_SOD_523_OPT(ESD5B5)OPT(ESD5B5)SOD_523D1041N4148_0805_SOD_123_J_1N4148W1N4148WSOD_123_JD1051N4148_0805_SOD_123_J_1N4148W1N4148WSOD_123_JD1061N4148_0805_SOD_123_J_1N4148W1N4148WSOD_123_JD1071N4148_0805_SOD_123_J_1N4148W1N4148WSOD_123_JFAN1FAN_0_DIP_2510_1X4_P254-PL_CPUFCPUFANDIP_2510_1X4_P254-PLFB1FB_SMD_L_0402-PL_220/500MA-02220/500mA-02SMD_L_0402-PLFB2FB_SMD_L_0402-PL_220/500MA-02220/500mA-02SMD_L_0402-PLFB3FB_SMD_L_0805-PL_200/1.5A-05200/1.5A-05SMD_L_0805-PLFB4FB_SMD_L_0402-PL_220/500MA-02220/500mA-02SMD_L_0402-PLFB5FB_SMD_L_0402-PL_220/500MA-02220/500mA-02SMD_L_0402-PLFB6FB_SMD_L_0805-PL_200/1.5A-05200/1.5A-05SMD_L_0805-PLFB7FB_SMD_L_0805-PL_200/1.5A-05200/1.5A-05SMD_L_0805-PLFB8FB_SMD_L_0805-PL_200/1.5A-05200/1.5A-05SMD_L_0805-PLFB9FB_SMD_L_0805-PL_200/1.5A-05200/1.5A-05SMD_L_0805-PLFB10FB_SMD_L_0805-PL_200/1.5A-05200/1.5A-05SMD_L_0805-PLFB11FB_SMD_L_0805-PL_200/1.5A-05200/1.5A-05SMD_L_0805-PLFB12FB_SMD_L_0603-PL_600/200MA-03600/200mA-03SMD_L_0603-PLFB13FB_SMD_L_0603-PL_600/200MA-03600/200mA-03SMD_L_0603-PLFB15BEAD_0603_L0603_120R120RL0603FB16BEAD_0603_L0603_120R120RL0603FB17FB_SMD_L_0805-PL_200/1.5A-05200/1.5A-05SMD_L_0805-PLFB18FB_SMD_L_0603-PL_600/200MA-03600/200mA-03SMD_L_0603-PLFB19FB_SMD_L_0603-PL_600/200MA-03600/200mA-03SMD_L_0603-PLJ22X5_DIP_HEADER_2X5_P200_C-PL_2X2x5-2.0DIP_HEADER_2X5_P200_C-PLJ72M54_2510X3_2510_3_2510X32510x32510_3J82M54_2510X3_2510_3_2510X32510x32510_3J102M54_2510X3_2510_3_2510X32510x32510_3J11CON_2X5_9NC_IDD_2X5_9NC_2M54_COCON_2X5_9PIDD_2X5_9NC_2M54J12CON_2X5_8NC_IDD_2X5_8NC_2M54_COCON_2x5_9PIDD_2X5_8NC_2M54J13CON_2X5_9NC_IDD_2X5_9NC_2M54_COCON_2X5_9PIDD_2X5_9NC_2M54J17CON_POWER_2X10_ATX_PWR_2X10_4M22X10ATX_PWR_2X10_4M20J18CON_2X6_IDE_2X6_2M00_CON_2X6CON_2x6IDE_2X6_2M00J19CON_POWER_2X2_ATX_PWR_2X2_4M20_CON_2x2ATX_PWR_2X2_4M20JP11X3_DIP_HEADER_1X3_P254-PL_1X3-1x3-2.54DIP_HEADER_1X3_P254-PLJP4DB9_M_DB9_M_DB9_MDB9_MDB9_MJP12SATA_HOST_SATA_1M50_TX_SM07ABA2TX_SM07ABA2_049SATA_1M50JP13SATA_HOST_SATA_1M50_TX_SM07ABA2TX_SM07ABA2_049SATA_1M50JP14HDMI_CONNECTOR_HDMI_HDMIHDMIHDMIJP15DB15_VGA_VGASN_VGA_CONVGA_CONVGASNJP16SATA_HOST_SATA_1M50_TX_SM07ABA2TX_SM07ABA2_049SATA_1M50JP17SATA_HOST_SATA_1M50_TX_SM07ABA2TX_SM07ABA2_049SATA_1M50JP18D3M5_AUDIO_2_PHNJACK_2_D3M5_AUDD3m5_AUDIO_2PHNJACK_2JP19GNETUSB_2_RJ45_USB_1000MB_RJ45_RJ45_USB_1000MBRJ45_USB_1000MBL2L_L3010_4.7UH4.7uHL3010L3L_L3010_4.7UH4.7uHL3010L13L_SMD_L_MHCI06030-PL_0.68UH/15A0.68uH/15ASMD_L_MHCI06030-PLL15SF3216_L_CM_0805_90R90RL_CM_0805L16SF3216_L_CM_0805_90R90RL_CM_0805L17SF3216_L_CM_0805_90R90RL_CM_0805L18SF3216_L_CM_0805_90R90RL_CM_0805L19L_SMD_L_GPSR1040_0.22UH/35A0.22uH/35ASMD_L_GPSR1040L20L_SMD_L_GPSR1040_0.22UH/35A0.22uH/35ASMD_L_GPSR1040L21L_SMD_L_GPSR1040_0.22UH/35A0.22uH/35ASMD_L_GPSR1040L22SF3216_L_CM_0805_90R90RL_CM_0805L45L_SMD_L_RP0603-PL_3.3UH/6A3.3uH/6ASMD_L_RP0603-PLM8M_SMD_MASK_MMMMSMD_MASKMPCIE1MINI_PCIE_1X_SMD_SLOT_MINIPCIE_MINI_PCIE_1XSMD_SLOT_MINIPCIE_52-PLMSATA1MSATA_SMD_SLOT_MINIPCIE_52-PL_MMSATA-9.2mmSMD_SLOT_MINIPCIE_52-PLMT1MT_DRILL130N_M2-PL_MTMTDRILL130N_M2-PLMT2MT_DRILL130N_M2-PL_MTMTDRILL130N_M2-PLMT3MT_DRILL130N_M2-PL_MTMTDRILL130N_M2-PLMT4MT_DRILL130N_M2-PL_MTMTDRILL130N_M2-PLMT_MP1TPWX_0_DRILLTC220B200D120-PL_TPTPWXDRILLTC220B200D120-PLQ67002_SOT_23_GDS_70027002SOT_23_GDSQ7NPN_SOT_23_EBC_39043904SOT_23_EBCQ87002_SOT_23_GDS_70027002SOT_23_GDSQ107002_SOT_23_GDS_70027002SOT_23_GDSQ14NPN_SOT_23_EBC_39043904SOT_23_EBCQ23NMOS_0_SOIC8_SI4800SI4800SOIC8Q31NMOS_0_WDFN8_3_3X3_3_P065-PL_NTNTTFS4C10NWDFN8_3_3X3_3_P065-PLQ367002_SOT_23_GDS_70027002SOT_23_GDSQ46NMOS_0_WDFN8_3_3X3_3_P065-PL_NTNTTFS4C10NWDFN8_3_3X3_3_P065-PLQ48NPN_SOT_23_EBC_39043904SOT_23_EBCQ497002_SOT_23_GDS_70027002SOT_23_GDSRT3R_R0603_OPT(470K/K-03)opt(470K/K-03)R0603RT4R_R0603_10K/K-0310K/K-03R0603S1SHORT0805_S0805_SHORTSHORTS0805SODIMM1DDR3SODIMM_SMD_SLOT_DDR3_204W-PDDR3SMD_SLOT_DDR3_204W-PLSODIMM2DDR3SODIMM_SMD_SLOT_DDR3_204-PLDDR3SMD_SLOT_DDR3_204-PLTA1TA_TA_BOT-C16D8MB-PL_TATATA_BOT-C16D8MB-PLTP_WX1TPWX_H71D47_TP_WX-PL_TPWXTPWXH71D47_TP_WX-PLU1HASWELL_BGA_SMD_SOCKET1150_HASWHASWELLBGA_SMD_SOCKET1150U2PCH_H81_BGA708_LPT_PCH_DT_?LPT_PCH_DTBGA708U3SPI_ROM_SOIC8_200_SPIFLASHSPI FLASHSOIC8_200U4IT8622/8623E_128_LQFP_1_LQFP128IT8786ELQFP128_SU7I211-AT_QFN64_0_5_9X9_EDHS_I211I211-ATQFN64_0_5_9X9_EDHSU8I211-AT_QFN64_0_5_9X9_EDHS_I211I211-ATQFN64_0_5_9X9_EDHSU9NC7SZ08_0_SOT_23_5_74AHC1G0874AHC1G08SOT_23_5U11MAX3243_SSOP_28_0M65_MAX3243MAX3243SSOP_28_0M65U13AP3417A_SOT23_5_AP3417AKTR_G1AP3417AKTR_G1SOT23_5U14JR0322A0_QFN48_1_QFN_48_0M50_T_JMB390_QFN48QFN_48_0M50_TU18CM1213A_TSOT_23_6_CM1213ACM1213ATSOT_23_6U20TVS_AZ1045-04F_DFN2510P10E_TPD4TPD4E05U06DFN2510P10EU21TVS_AZ1045-04F_DFN2510P10E_TPD4TPD4E05U06DFN2510P10EU22ALC888_0_LQFP48_ALC662-VD0ALC662-VD0LQFP48U23CM1213A_TSOT_23_6_CM1213ACM1213ATSOT_23_6U24CM1213A_TSOT_23_6_CM1213ACM1213ATSOT_23_6U25DS28C22_TDFN_8_0M50_T_DS28C22Q+DS28C22Q+TTDFN_8_0M50_TU27CM1213A_TSOT_23_6_CM1213ACM1213ATSOT_23_6U29AP3417A_SOT23_5_AP3417AKTR_G1AP3417AKTR_G1SOT23_5U30TPS2065CDBVR_SOT23_5_TPS2065CDBTPS2065CDBVRSOT23_5U31TPS2065CDBVR_SOT23_5_TPS2065CDBTPS2065CDBVRSOT23_5U32TPS2065CDBVR_SOT23_5_TPS2065CDBTPS2065CDBVRSOT23_5U33PS8201_TQFN_40_0M40_T_PS8201PS8201TQFN_40_0M40_TU34CM1213A_TSOT_23_6_SRV05_4SRV05_4TSOT_23_6U35PI5PD2069_SOIC_8_1M27_PI5PD2069PI5PD2069SOIC_8_1M27U36DS28C22_0_TDFN_8_0M50_T_ATSHA20ATSHA204ATDFN_8_0M50_TU4074AHC1G08_SOT23_5_74AHC1G0874AHC1G08SOT23_5U42P_ISL6236IRZA_QFN32~D_1_QFN32_0ISL95812HRZ-TQFN32_0_4_4X4-EDHSU45P_ISL6208CRZ-T_QFN8~D_0_DFN8_2XISL6208BCRZ-TDFN8_2X2_EDHSU4774AHC1G08_SOT23_5_74AHC1G0874AHC1G08SOT23_5U48SN74LV244A_TSSOP_20_0M65_SN74LVSN74LV244ATSSOP_20_0M65U49NB634_2_QFN21_0_4_3X4_NB675NB675QFN21_0_4_3X4U54NB634_0_QFN16_0_4_3X3_NB671ANB671AQFN16_0_4_3X3U69IMP809_0_SOT_23_OPT(IMP809)opt(IMP809)SOT_23U70IMP809_0_SOT_23_OPT(IMP809)opt(IMP809)SOT_23U520SN74ABT125DR_SOIC_14_1M27_SN74ASN74ABT125DRSOIC_14_1M27U522SGM9132YPS8G_SOIC_8_1M27_T_SGM9SGM9132YPS8G-TRSOIC_8_1M27_TU523MX25L512EMI_SOP_8_1M27_MX25L512MX25L512EMI_12GSOP_8_1M27X1CRYSTAL1_SMD_XTAL_4P_32K768-PL_32.768KHzSMD_XTAL_4P_32K768-PLX2CRYSTAL4_SMD_XTAL_4P_3_2X2_5-PL25MHzSMD_XTAL_4P_3_2X2_5-PLX3CRYSTAL2_SMD_XTAL_2P_HCM49-PL_225MHzSMD_XTAL_2P_HCM49-PLX4CRYSTAL2_SMD_XTAL_2P_HCM49-PL_225MHzSMD_XTAL_2P_HCM49-PLY5CRYSTAL_SMD_4P_CRYSTAL_SMD3225_25MHzCRYSTAL_SMD3225_H0M80 改版,没画完。 有配套原理图。有兴趣的朋友可以下载去练习。。
PCB原理图一起打包。回复下载。
**** Hidden Message ***** 这个是平板用的吗 谢谢分享! 谢谢分享
