君正 JZ4775参考板PCB和原理图(LAN8720+AP6212)
NamePart TypePCB DecalValueBT2BATTERYSIP_2P_2D0Battery SocketD11/4M11Z10_1D0805_A1BZT52C5V1SD35655F_2D0805_A1LEDD45655F_1D0805_A1LEDD7DIODE_PIN_0D0805_A1WSB5543WD8DIODE_PIN_0D0805_A1WSB5543WD95655FD0805_A1PHOTO_DESD11/4M11Z10_0ESD0402_A2ESD9X5VUESD331/4M11Z10_0ESD0402_A2ESD9X5VUF1FUSE_1L18120.5AH4TEST_1_2ZKHOLEMOUNT HOLEJ4EARPHONE_0_2PJ-382EARPHONEJ6CON-I/O_MICROUSB_0MICROUSB_DIPCON-I/O_MICROUSB_5PINJ7CON3_1RAPC712_1MM+5V DC SOCKETJ8CON-I/O_MICROUSB_0MICROUSB_DIPCON-I/O_MICROUSB_5PINJ9USBX1_0USB_AF90USB_HOSTJ11HR911105A_2RJ45_LED_8PIN_AHR911105AJ13MMC-SD_3TFCARDT-FLASHJ20FPC60FPC60_0D5_L1FPC60J23CON20_1FPC24_0D524-PIN-0.5 CONNECTORJ24CON20_1FPC24_0D524-PIN-0.5 CONNECTORL1INDUCTOR_0DLM11SDLM11SN900HY2LL8INDUCTORL25204.7uH/1AL9INDUCTORL25204.7uH/1AL10INDUCTORL25204.7uH/1AL12INDUCTORL20162.2uHL13INDUCTORL20162.2uHL14INDUCTORL20162.2uHLINEIN_LTEST_1TEST_SMDTESTLINEIN_RTEST_1TEST_SMDTESTM1MICMIC6M_DIPMICQ1PNP_BCE_0SOT23MMBT3906LQ2P-CHANNELSOT23WPM3401Q3P-CHANNELSOT23WPM3401Q4P-CHANNELSOT23WPM3401Q52N7002/SOT_1SOT23WNM2016Q8P-CHANNELSOT23WPM3401Q92N706A_0SOT23WNT2F04Q102N706A_0SOT23WNT2F04Q11P-CHANNELSOT23WPM3401Q142N706A_0SOT23WNT2F04Q15P-CHANNELSOT23WPM3401Q50P-CHANNEL_2SOT23BAT54CR1R_10_2R0402240 1%R4R_2R0402100KSPK1SPKSIP_2P_2D08 OHMSW2SW_PUSHBUTTONSW-5PPUSHBUTTONTP19TEST_1TEST_SMDTESTU1JZ4775_V1.8BGA314_0D65JZ4775_V1.8U2FT232RLFPC-SSOP28-26-209FT232RLU3SST25VF016B_0SOP8GD25Q127CS1GU4SGM4064TDFN-2X2-8LSGM4064YDE8G/TRU9KB4898_4MSOP8SGM4996U11HY5S7B2ALF_29BGA96_0D8MMH5TQ2G63GFRU13K9F2808U0B_2FBGA153_0D5H26M41208HPRU14LNA8720_0LAN8720LAN8720U16HY5S7B2ALF_29BGA96_0D8MMH5TQ2G63GFRU17AP6493_0AP6212AP6212U19SGM4056_0_2TDFN_2_2_8LSGM4056-6.8YTDE8G/TRU20DCDC_RT8096C_0DCDC_SOT23-5RT8059GJ5U21DCDC_RT8096C_0DCDC_SOT23-5RT8059GJ5U22LDO_RT9073AUTDFN_1X1_4LRT9073A-33GQZU23DCDC_RT8096C_0DCDC_SOT23-5RT8059GJ5U24SGM6014_2SOT23_5SGM2036-2.5YN5G/TRU25SP6641_0SOT23-6SGM6603-5.0YN6G/TRU26MP62055_0SOT23_5RT9711AGBU27MP62055_1SOT23_5RT9711BGBU28MAX811_0SOT143_4SGM811-TXKA4/TRU30SP6641_0SOT23-6SGM6603-5.0YN6G/TRU31SGM6014_2SOT23_5SGM2036-3.3YN5G/TRU32SGM6014_2SOT23_5SGM2036-1.8YN5G/TRU33SGM6014_2SOT23_5SGM2036-3.0YN5G/TRU34SGM6014_2SOT23_5SGM2036-2.8YN5G/TRY3CRYSTAL_4CRY_2D0X1D624M_20PPMY4CRYSTAL_4CRY_2D0X1D626M_10PPMY5CRYSTAL_0CRY_3_2X1_5NX3215SA-32.768KHZ-STD-MUA-8Y6CRYSTAL_4CRY_2D5X2D025M_10PPM 板子画的一般,PCB原理图一起打包。回复可见
**** Hidden Message ***** 谢谢分享 谢谢分享
