2007年TCL王牌HY80彩电PCB文件和原理图(HTV180方案) BIN数据
NamePart TypePCB DecalValueCM922E-CAP-5(12.5)E-CAP-5(12.5)470u/35VD16ASMD-1N40011N40011N4001D17ASMD-1N40011N40011N4001DM1BAV99TCLSOT23bav99DM2BAV99SOT23bav99DM3D(12.5)D(12.5)1N4001DM4BAV99TCLSOT23bav99DM5BAV99SOT23bav99DM6DIO-MELFMELF1N4148DM8BAV99SOT23bav99DM9BAV99SOT23bav99DM10BAV99SOT23bav99DM11BAV99SOT23bav99DM12BAV99SOT23bav99DM13DIO-MELFMELF1N4148DM16D(12.5)D(12.5)1N4001DM17D(12.5)D(12.5)1N4001DM18D(12.5)D(12.5)1N4001DM19D(12.5)D(12.5)1N4001DM301DIO-MELFMELF1N4148DM302DIO-MELFMELF1N4148DM701DIO-MELFMELF4148/NCDM702BAV99SOT23bav99DM703BAV99TCLSOT23bav99DM704BAV99TCLSOT23bav99DM708DIO-MELFMELF1N4148/*DM709DIO-MELFMELF1N4148DM710DIO-MELFMELF1N4148DM711DIO-MELFMELF1N4148DM901D(12.5)D(12.5)1N4001DM902D(12.5)D(12.5)1N4001DM903DIO-MELFMELF1N4148ICM02ST24C16DIP8ICM03M12L16161A-7TTSOP50ICM04AMS1117AS1117AMS1117-1V8ICM06AS1117AS1117AMS1117-3.3VICM07AMS1117AS1117AMS1117-1V8ICM8SST39VF040PLCC32_50_SOCKETICM10HTV180S2300AICM11AMS1117AS1117AMS1117-3V3ICM13AMS1117AS1117AMS1117-1V8ICM301TB1307FGPQFP48ICM702TDA9881TSDIP24-1.778TDA9881TS/*ICM703HP800SOP20HP820ICM801780578057809ICM901TDA7495SSATDA7495SSATDA7495SSAICMARK2ICMARKICMARKICMARK10ICMARKICMARKICMARK11ICMARKICMARKICMARK12ICMARKICMARKICMARK14ICMARKICMARKICMARK16ICMARKICMARKLM01INDU-0805TCLFB080510UH1210LM701PK-L5(10)PK-L5(10)100UHLM702INDU-10051005MIL100UH/*LM702AINDU-10051005MIL100UH/*LM704INDU-10051005MIL100UH/*LM706INDUL100.82uH/*LM707INDU-0805TCLFB080510UH1206LM708INDU-10051005MIL100UH/*LM716INDU-0805TCLFB080551R1206LM717INDU-0805TCLFB0805FB-100R100MLM717AINDU-0805TCLFB080510UH1206LM802PK-L5(10)PK-L5(10)100UHPCBMARK1PADS-TESTPCBMARKPCBMARK2PADS-TESTPCBMARKPCBMARK3PADS-TESTPCBMARKPCBMARK4PADS-TESTPCBMARKPCBMARK5PADS-TESTPCBMARKQM01PNPSOT232SA1015QM2PNP_SMDSOT232SA1015QM3SMD_NPNTCLSOT_232SC1815QM4SMD_NPNTCLSOT_232SC1815QM5SMD_NPNTCLSOT_232SC1815QM6PNPSOT232SA1015QM7PNP_SMDSOT232SA1015QM8SMD_NPNTCLSOT_232SC1815QM9PNP_SMDSOT-23-W2SA1015QM10SMD_NPNTCLSOT-23-W2SC1815QM11SMD_NPNTCLSOT_232SC1815QM12SMD_NPNTCLSOT_232SC1815QM31PNP_SMDSOT232SA1015QM302PNPSOT232SA1015QM303PNPSOT232SA1015QM304PNPSOT232SA1015QM701SMD_NPNSOT232SC1815QM702SMD_NPNTCLSOT_232SC1815QM703SMD_NPNTCLSOT_232SC1815QM705SMD_NPNSOT232SC1815/*QM706NPNQQM708SMD_NPNTCLSOT_232SC1815QM709SMD_NPNSOT232SC1815QM710SMD_NPNSOT232SC1815/*QM717SMD_NPNTCLSOT_232SC1815QM718PNPSOT232SA1015QM719PNP_SMDSOT232SA1015QM720SMD_NPNSOT232SC1815/*QM801KTC2026YTO-220ISQM901SMD_NPNTCLSOT_232SC1815QM903PNP_SMDSOT232SA1015QMOS1SMD_NPNTCLSOT_232SC1815QMOS2SMD_NPNTCLSOT_232SC1815RNM84RARP8\4R\SMD47R*4S1SCREW_9_4SCREW_9_4TP213FID1MMTFCTTU701FS-TUNER(B)TUNER(B)VRM701VR3RDJ-3PW1H34628AH34628W6H34628AH34628XM1CON3CON\2.5MM\3PIN\AXM2CON4CON\2.5MM\4PIN\AXM3CON6CON\2.5MM\6PIN\AXM4CON3CON\2.5MM\3PIN\AXM5CON2SIP\2PXM8CON5CON\2.5MM\5PIN\AXM09CON9CON\2.5MM\9PIN\AXM11CON5CON\2.5MM\5PIN\AXM13CON15CON\VGAAAAXM706CON2SIP\2PXM712CON2SIP\2PXM714AV-12P12P_AVXM717CON11CON\2.5MM\11PIN\AXM801CON13CON\2.5MM\13PIN\AXM901CON2SIP\2PXM902CON3CON\2.5MM\3PIN\AZDM1ADIODEZ-LMLL34L3V9ZDM2BAV99TCLSOT23bav99ZDM3BAV99TCLSOT23bav99ZDM4BAV99SOT23bav99ZDM5BAV99TCLSOT23bav99ZDM6BAV99TCLSOT23bav99ZDM7BAV99SOT23bav99ZDM8BAV99SOT23bav99ZDM12DIODEZ-LMLL34L6.2VZDM29BAV99TCLSOT23bav99ZDM50BAV99TCLSOT23bav99ZDM51BAV99TCLSOT23bav99ZDM301DIODEZ-LMLL34L5V1ZDM302DIODEZ-LMLL34L3V3ZDM303DIODEZ-LMLL34L6V8ZDM304DIODEZ-LMLL34L6V8ZDM305DIODEZ-LMLL34L6V8ZDM701DIODEZ-LMLL34L5.1VZDM702DIODEZ-LMLL34L79c4v7ZDM801DIODEZ-LMLL34L5.6VZDM802KA33VZD10KA33V/NCZDM802BDIODEZ-LMLL34L33V/NCZM03CRYSTALXTAL5.024MHZZM4CRYSTAL(T)XTAL5.0-T12MHZZM704CRYSTALXTAL5.04MHZ/*ZM706SAW-SIP5COILZM707SAW-SIP5COIL 资料一起打包。回复可见。
**** Hidden Message ***** 感谢分享 谢谢分享 太厉害了
