老吴 发表于 2020-10-22 09:50:26
MTK6735M / MT6735M 8层智能手机PCB和原理图共享
NamePCB DecalValuePart TypeANT3401ELJ-P-JS-29E11-ANT-H1.1POGO PINELJ-P-JS-29E11-ANT-H1.1CN6001ELJ_05-0521132-B_USB-CB0.8ELJ_05-0521132-B_USB-CB0.8ELJ_05-0521132-B_USB-CB0.8CON3302ELJ_RF_MM8030-2610RK0_2X2X1MMKLJ_RF_818000291_2X2X1ELJ_RF_MM8030-2610RK0_2X2X1MMCON3401ELJ_RF_MM8030-2610RK0_2X2X1MMNC KLJ_RF_818000291_2X2X1ELJ_RF_MM8030-2610RK0_2X2X1MMCON6001ELJ_ST-0279D00-00_AUDIOADJ-312-P2.0-3.9X(·´)ELJ_ST-0279D00-00_AUDIOCON6101ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3FH26-39S-0.3ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3D2000SOD323/SMD/MM3Z2V4T1PZ3D4V2H (PRISEMI)TVS-6V2-PZ3D4V2H-ROHMD6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45D6110SOD1231N5819DIODE_SCHOTTKY_2D6201FLASHLED_SMD_EFF-D8CA-POOTFLASH LEDFLASHLED_SMD_EFF-D8CA-POOTEMI6001FILTER/SMD/TCM0806GNCEMIX21A390FNPE_1H1000PTH_HOLE_1.6/2.8MMDNIPTH_HOLE_1.6/2.8MMH1001PTH_HOLE_1.6/2.8MMDNIPTH_HOLE_1.6/2.8MMH1002PTH_HOLE_1.6/2.8MMDNIPTH_HOLE_1.6/2.8MMJ2001ELJ_FTS09M-612-01_BTB-6P-H0.9ELJ_FTS09M-612-01_BTB-6P-H0.9ELJ_FTS09M-612-01_BTB-6P-H0.9J3401MM4829-2702BMHC-310CON-RF-TEST-MM4829-2702B-MURATAJ6001ELJ_FH26_L_25S_0.3SHW-AFH26ELJ_FH26_L_25S_0.3SHW-AJ6003REC1206NCREC_1206J6201ELJ_FH26_L_25S_0.3SHW-AFH26ELJ_FH26_L_25S_0.3SHW-AJ6202ELJ_WP7-S030VA1_BTB-30P-H0.7ELJ_WP7-S030VA1_BTB-30P-H0.7ELJ_WP7-S030VA1_BTB-30P-H0.7J6501ELJ_FH26_L_25S_0.3SHW-AFH26ELJ_FH26_L_25S_0.3SHW-AJ6502ELJ_HC503-6R-GF_PJ_0.5_H1.0NCELJ_HC503-6R-GF_PJ_0.5_H1.0J6601NC-PADX2-1X1.5NCNC-CON-2-0805J6701ELJ_HC503-6R-GF_PJ_0.5_H1.0NCELJ_HC503-6R-GF_PJ_0.5_H1.0L2000L25200.33uH_252012L2520-22UL2001L/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L/IND/SMD/VLS201610EL2002L/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L/IND/SMD/VLS201610EL2003L/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L/IND/SMD/VLS201610EL6103SWPA5012SSWPA5012S100MTSWPA5012SL6105L_NRH241010uHL2520-4U7LED2001ELE_LTST-C19GD2WT-G_RGB-LED_1.6X2.1X0.4ELE_LTST-C19GD2WT-G_RGB-LED_1.6X2.1X0.4ELE_LTST-C19GD2WT-G_RGB-LED_1.6X2.1X0.4MARK1000MARK_ALLDNIMARK_ALL_AMARK1001MARK_ALLDNIMARK_ALL_AMARK1002MARK_ALLDNIMARK_ALL_AMARK1003MARK_ALLDNIMARK_ALL_AMIC6001ELJ_(R)SOB-413S42-EM_MIC-SMTELJ_(R)SOB-413S42-EM_MIC-SMTELJ_(R)SOB-413S42-EM_MIC-SMTNTC2000R0402NTCG104EF104FRES0402NTC3201R0402NTC / NTCG064EF104FR0402-0RQ1SC-75_SOT-416_DTC114EET1-DDTC114YET1SC-75_SOT-416_DTC114EET1-DQ6101SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-DQ6102SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-DQ6103SOT23_3WPM2026IRF5210/TO_6Q6104SOT23_3MMBT3904NPN_BECSH2100KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7SH6503NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MILNO_PAD_0402_SMD_1SH6504NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MILNO_PAD_0402_SMD_1SHORT1KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7SHORT2KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7SHORT3KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7SHORT4KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7SHORT1001KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7SHORT1002KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7TP_UTXD1101TP_1.0ATP1.0MMU1000MT6735/VFBGA641/P0.4/B0.25/12.6X12.6MT6735MMT6735/VFBGA641/P0.4/B0.25/12.6X12.6U2002MT6328/VFBGA206/P0.4/B0.25/6.6X6.6MT6328V/AMT6328/VFBGA206/P0.4/B0.25/6.6X6.6U2003WDFN8/SMD/P0.5/NCP6324NCP6324CMTAATBGWDFN8/SMD/P0.5/NCP6324U2004NCP1855NCP1855NCP1855U2005NTLUS3A18PZNTLUS3A18PZNTLUS3A18PZU2305CP2155CP2155DN10-A1CP2155U3001FBGA178/SMD/B0.4/3-IN-1LPDDR3 178bFBGA178/SMD/B0.4/3-IN-1U3002BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBASamsung KLM2G1HE3F-B001BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBAU3101MT6169/VFBGA175/P0.4/B0.25/6.2X5.4U / MT6169MT6169/VFBGA175/P0.4/B0.25/6.2X5.4U3102TCXO/SMD/2.5X2.0/KT2520FVTCXO / 26 / MHz / KT2520F26000DCW28QAKKT2520F26000DCW28QAKU3203SKY77643SKY77643/HRSMAC001/RF5410SKY77643U3303RF1628SPDT / RF1628ASPDT_/_BGS12SL6_2U3304DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY806MBA0F0ASAW-DPX-RX-BAL_2U3306SAW-SAYRF1G73CA0F0A-2016DPX / SAYRF1G95CA0B0AR05SAYRF1G73CA0F0A-2016U3307SKY77910SKY77910/HRTXAB008/RF5210SKY77910U3308SAW-SAYRF1G73CA0F0A-2016DPX / SAYFH2G53CCOFOASAYRF1G73CA0F0A-2016U3309SAW-SAYRF1G73CA0F0A-2016SAYFH1G74CA0B0ASAYRF1G73CA0F0A-2016U3310FILTER/SMD/TFSL06050915-4108B1LPF / TFSL06050915-4108B1 / NCSAW_0_2U3311DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY710MBA0F0ASAW-DPX-RX-BAL_2U3312SAW-SAYRF1G73CA0F0A-2016SAYRF1G88CA0B0AR05SAYRF1G73CA0F0A-2016U3313SAW-SAYRF1G73CA0F0A-2016DPX / SAYFH836MCC0F0AR05SAYRF1G73CA0F0A-2016U3314SAW-SAYRF1G73CA0F0A-2016SAYFH1G74CA0B0ASAYRF1G73CA0F0A-2016U3316SAW-SAYRF1G73CA0F0A-2016DPX / SAYFH897MHC0F0AR05SAYRF1G73CA0F0A-2016U3318BALUN/SMD/TFSZ06052460-3310A2BAL / TFSZ06050775-3338A1BAL_/_TFSZ06051897-3317A1_2U3402SKY13414SP5T / SKY13416IC/SP6T/SKY13416_0U3403SAW/SMD/SAWEN881MCY0F00R14SAW / SAWFD881MCG0F0ASAW_/_EN881MCY0F00R14_1U3404SAW/SMD/SAWEN881MCY0F00R14SAW / SAWFD942MCA0F0ASAW_/_EN881MCY0F00R14_0_2U3406SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3408SAWFILTER/SMD/F6QB2G595P2BSSAW / B9898SAWFILTER/SMD/SAFFB1G90FB0F0AU3412SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB710MAA0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3413SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB806MAA0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3414FILTER/SMD/TFSL06050915-4108B1LPF / TFSL06050915-4108B1 / NCSAW_0_2U3468BALUN/SMD/TFSZ06052460-3310A2BAL / TFSZ06050775-3338A1BAL_/_TFSZ06051897-3317A1_1U3474RF1628SPDT / RF1628ASPDT_/_BGS12SL6_2U5101MT6625/SQFN40/SMD/P0.4/5X5U / MT6625L / QFN40MT6611_SMD_WLCSP-61_0U5102SAFEB1G57KE0F00SAFEB1G57KE0F00IC-SAW-SAFEB1G57KE0F00-MURATAU5103MAX2659MAX2659ELTIC-GPS-LNAP-MAX2659-MAXIMU5104KLJ_TPX205950MT-7110A1_1.1X2X0.9TRPX / TDK TPX205950MT-7110A1KLJ_TPX205950MT-7110A1_1.1X2X0.9U5105SAW-1411FBAR / ACPF-7124SAFEB1G57KA0F00U6001MSOP8QMYYANC TCS7190( LM4890MM)MSOP8QMYU6002MSOP8QMYYATCS7190( LM4890MM)MSOP8QMYU6105SOT23_5WD1013EA/TCS4150-ETCS4150-EU6109SOT23_6EUP2530/CP2123ST-B1AP3031_0U6303STK3171STK3171STK3171U6401M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7U6403OCH177OCH177OCH177U6404BMA250BMA223IC-3-A-ACCELEROMETER-BMA250-BOSCHVR6001MLV0402SFI0402-180E10RPP-LFVAR_0402VR6002ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45VR6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45VR6006R0402EZJZ0V500AAVR0402VR6512R0402SFI0402-180E10RPP-LFVR0402X2000CRYS/SMD/3.2X1.5/9H032000XX/TXC32.768KHz¡À20ppmCRYS/SMD/3.2X1.5/9H032000XX/TXCX5101TCXO/SMD/2.5X2.0/IT2205BETCXO / 26 / MHz / IT2205AETCXO_RAKON_SMD_4P
老吴 发表于 2020-10-22 09:52:02
PCB 原理图,回复可见下载。
**** Hidden Message *****
bidinghong 发表于 2020-10-22 10:03:05
mirage 发表于 2020-10-22 10:29:27
谢谢分享
langjitianya丶 发表于 2020-10-22 10:51:28
yfchen1003 发表于 2020-10-22 11:30:25
路过!!
roezw 发表于 2020-10-22 11:32:47
hhbin634 发表于 2020-10-22 13:06:28
yhgwork 发表于 2020-10-23 02:06:58
学习MTK手机硬件
kn1986 发表于 2020-10-23 08:43:32
学习学习,谢谢分享…
页: [1] 2 3 4 5
查看完整版本: MTK6735M / MT6735M 8层智能手机PCB和原理图共享
