老吴 发表于 2020-10-22 10:52:46
MTK6735/MT6735 方案智能手机PCB和原理图共享
NamePart TypePCB DecalValueANT2ELJ_SOLDERING_ANTPADELJ_SOLDERING_ANTPADANT3301ELJ_SOLDERING_ANTPADELJ_SOLDERING_ANTPADANT3401ELJ_SOLDERING_ANTPADELJ_SOLDERING_ANTPADB6000B0603-2500RL0603BLM18BD252SN1CON3301CON-RF-TEST-MM4829-2702B-MURATAMM4829-2702BMHC-310CON3302ELJ_RF_MM8030-2610RK0_2X2X1MMELJ_RF_MM8030-2610RK0_2X2X1MMKLJ_RF_818000291_2X2X1CON3401ELJ_RF_MM8030-2610RK0_2X2X1MMELJ_RF_MM8030-2610RK0_2X2X1MMNC KLJ_RF_818000291_2X2X1D1DIODE_SCHOTTKY_6RB551V-30(UMD2)BAT54WSD2000TVS-6V2-PZ3D4V2H-ROHMSOD323/SMD/MM3Z2V4T1PZ3D4V2H (PRISEMI)D6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45D6101DIODE_SCHOTTKY_2SOD123MM1Z5VD6102BAT54SSOT23_3BAT54SD6103DIODE_SCHOTTKY_2SOD123MM1Z20VD6108BAT54SSOT23_3BAT54SD6109DIODE_SCHOTTKY_2SOD1231N5819D6110DIODE_SCHOTTKY_2SOD1231N5819EMI1302EMIX21A390FNPE_1FILTER/SMD/TCM0806GNCF5002BL1608-05K2450BALUN/SMD/BL1608/ACX BL1608-05K2450H1PTH_HOLE_3.5/2.8MMPTH_HOLE_3.5/2.8MMDNIH2PTH_HOLE_3.5/2.8MMPTH_HOLE_3.5/2.8MMDNIH1000PTH_HOLE_1.6/2.8MMNC_PTH_HOLE_1.6/2.8MMDNIH1001PTH_HOLE_1.6/2.8MMNC_PTH_HOLE_1.6/2.8MMDNIH1002PTH_HOLE_1.6/2.8MMNC_PTH_HOLE_1.6/2.8MMDNIHDMI6301ELJ_HD-04B-A-A4_HDMI-4DIPELJ_HD-04B-A-A4_HDMI-4DIPELJ_HD-04B-A-A4_HDMI-4DIPJ801ELJ_HC301-13RL-GF_ZIF-H1.0ELJ_HC301-13RL-GF_ZIF-H1.0ELJ_HC301-13RL-GF_ZIF-H1.0J901ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3AXK7L30227GJ1302ELJ_FPCXG0512_H15_ZIF_12PIN_H1.5ELJ_FPCXG0512_H15_ZIF_12PIN_H1.5ELJ_FPCXG0512_H15_ZIF_12PIN_H1.5J2001NC_BAT_CON_3NC_BAT_CON_3NCJ2002ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9BAT-5PIN-1.25JP-H1.9J5101CON-RF-TEST-MM4829-2702B-MURATAMM4829-2702BMHC-310J6001ELJ_MCD-HXQK5F-LJ04B_5PIN_USB_4DIP_WELJ_MCD-HXQK5F-LJ04B_5PIN_USB_4DIP_WELJ_MCD-HXQK5F-LJ04B_5PIN_USB_4DIP_WJ6003NC-PAD_2PIN_1.3X1.8C0805NCJ6004NC-PAD_2PIN_1.3X1.8C0805NCJ6005NC-PAD_2PIN_1.3X1.8C0805NCJ6006NC-PAD_2PIN_1.3X1.8C0805NCJ6007ELJ_HXQKDC-085B_DC_3PELJ_HXQKDC-085B_DC_3PELJ_HXQKDC-085B_DC-3PJ6008ELJ_ADJ-312-P15-39XF_EAR-FCB1.4ELJ_ADJ-312-P15-39XF_EAR-FCB1.4J6101ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_YHHDMI-7519-C3.5_H3.3ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5J6201NC_FLASH-LED-FPC_PADNC_FLASH-LED-FPC_PADNCJ6501ELJ_L50124_24PIN_0.5PJ_H2.0ELJ_L50124_24PIN_0.5PJ_H2.0AXK7L30227GJ6503ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5J6601NC-PAD_2PIN_1.3X1.8C0805NCJ6701ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3FPC51P-0.3MML1L0201L0201C / 1.2 / pF / 0201L17L0201_5.6NHL02013.3NH +-0.1NHL402IND-CD43CD43SWPA4018S1R5NTL2000L2520-22UL25200.33uH_252012L2001L/IND/SMD/VLS201610EL/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L2002L/IND/SMD/VLS201610EL/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L2003L/IND/SMD/VLS201610EL/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L2004L2520-22UL25202.2uH_201610L2020L/IND/SMD/2520L/IND/SMD/25201uHL6101ELLVFG-C_1.4_3.2ELLVFG-C_1.4_3.210uHL6103IND-CD43CD4310uHL6105MPH252012MPH252012NRH2410T4R7MNMARK1000MARK_ALL_AMARK_ALLDNIMARK1001MARK_ALL_AMARK_ALLDNIMARK1002MARK_ALL_AMARK_ALLDNIMARK1003MARK_ALL_AMARK_ALLDNINC37NC_PAD_1206_SMDNC0402/SMDNC PADNC112NC_PAD_1206_SMDNC0201/SMDNC PADNTC2000RES0402R0402NTCG104EF104FNTC3201R0402-0RR0402NTC / NTCG064EF104FPL5002VLS201610EL/IND/SMD/VLS201610EMPH201610S2R2Q1309LNTK3043NT5GSOT-723-123LNTK3043NT5GQ6101SC-75_SOT-416_DTC114EET1-DSC-75_SOT-416_DTC114EET1-DNC DTC114YET1Q6102SC-75_SOT-416_DTC114EET1-DSC-75_SOT-416_DTC114EET1-DNC DTC114YET1Q6103IRF5210/TO_6SOT23_3WPM2026Q6104NPN_BECSOT23_3MMBT3904Q6201SC-75_SOT-416_DTC114EET1-DSC-75_SOT-416_DTC114EET1-DNC DTC114YET1Q6301IRF5210/TO_6SOT23_3WPM2026Q6302NPN_BECSOT23_3MMBT3904Q6601WNM4002_SOT-523/723WNM4002_SOT-523/723WNM4002Q6602LNTK3043NT5GSOT-723-123WNM2030Q6801WNM4002_SOT-523/723WNM4002_SOT-523/723 NC WNM4002Q6804WNM4002_SOT-523/723WNM4002_SOT-523/723 NC WNM4002SH2100KLINK_NO_PAD_0.1MM_LAYER7KLINK_NO_PAD_0.1MM_TOPSHORT / NC-MMD-L9-4MILSH5001NO_PAD_0402_SMD_1NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MILSH5002NO_PAD_0402_SMD_1NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MILSH5003NO_PAD_0402_SMD_1NC/MMD/L1/4MILSHORT / NC-MMD-L9-4MILSH6100NC_SHORT_0402NC_SHORT_0402SH6101NC_SHORT_0402NC_SHORT_0402SHORT1KLINK_NO_PAD_0.1MM_LAYER7KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILU1WL2003ESOT23-5WL2003E33U2DUPLEXER/8P/SMD/SAYEY710MBA0F0ADUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY1G74BC0B0AU3MT8193/VFBGA150/P0.4/B0.25/6.2X6.2MT8193/VFBGA150/P0.4/B0.25/6.2X6.2MT8193U4WL2003ESOT23-5WL2003E33U23WL2003ESOT23-5WL2003E12U105WS4603ESOT23-5WS4603EU106WS4603ESOT23-5WS4603EU210WS4603ESOT23-5NC/WS4603EU402SY7088DGCSY7088DGCSY7088DGCU1000MT6735/VFBGA641/P0.4/B0.25/12.6X12.6MT6735/VFBGA641/P0.4/B0.25/12.6X12.6MT6735MU1201MMC3630KJMMC3630KJU1302SSOP28_FE11SSSOP28_FE11SFE1_1s_SSOP28U2001FAN54015FAN54015HL7007U2002MT6328/VFBGA206/P0.4/B0.25/6.6X6.6MT6328/VFBGA206/P0.4/B0.25/6.6X6.6MT6328V/AU3001FBGA178/SMD/B0.4/3-IN-1FBGA178/SMD/B0.4/3-IN-1LPDDR3 178bU3002BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBABGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBASamsung KLM2G1HE3F-B001U3101MT6169/VFBGA175/P0.4/B0.25/6.2X5.4MT6169/VFBGA175/P0.4/B0.25/6.2X5.4U / MT6169U310226M_VTCXO_2520_2016_T_V26M_VTCXO_2520_2016_T_VVTCXO / 26 / MHz / KT2520F26000DCW28QAKU3203SKY77643SKY77643SKY77643/HRSMAC001/RF5410U3215BALUN/SMD/HHM22112A2BALUN/SMD/HHM22112A2LPF / LF1608-B2R5KCBU3302RF1628RF1628SPDT / RF1628AU3303SPDT_/_BGS12SL6_2RF1628SPDT / RF1628AU3304SAW-DPX-RX-BAL_2DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY806MBA0F0AU3306SAW-SAYRF1G73CA0F0A-2016-1814SAW-SAYRF1G73CA0F0A-2016-1814DPX / SAYRF1G95CA0B0AR05U3307SKY77910SKY77910SKY77910/HRTXAB008/RF5210U3308SAW-SAYRF1G73CA0F0A-2016-1814SAW-SAYRF1G73CA0F0A-2016-1814DPX / SAYFH2G53CCOFOA U3309SAW-DPX-RX-BAL_2DUPLEXER/8P/SMD/SAYEY710MBA0F0ANC SAYEY1G74BC0B0AU3311SAW-DPX-RX-BAL_2DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY710MBA0F0AU3312SAW-DPX-RX-BAL_2DUPLEXER/8P/SMD/SAYEY710MBA0F0ASAYEY1G88BA0B0AU3315SAFEA2G60MA0F0ASAFEA2G60MA0F0ASAW / SAFEA2G60MA1F0AU3316SAW-SAYRF1G73CA0F0A-2016-1814SAW-SAYRF1G73CA0F0A-2016-1814SAYEY897MCA0B0AU3318BAL_/_TFSZ06051897-3317A1_2BALUN/SMD/TFSZ06052460-3310A2BAL / TFSZ06050775-3338A1U3329SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0AU3338BALUN/SMD/TFSZ06052460-3310A2BALUN/SMD/TFSZ06052460-3310A2TFSZ06051897-3317A1U3339BALUN/SMD/TFSZ06052460-3310A2BALUN/SMD/TFSZ06052460-3310A2TFSZ06051897-3317A1U3401SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB2G14FA0F0AU3402IC/SP6T/SKY13416_0SKY13414SP5T / SKY13416U3408SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/F6QB2G595P2BSSAW / B9898U3410BALUN/SMD/TFSZ06052460-3310A2BALUN/SMD/TFSZ06052460-3310A2BAL / TDK-TFSZ06052460-3310A2U3412SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB710MAA0F0AU3413SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB806MAA0F0AU3420SAWFILTER/SMD/F6QB2G595P2BSSAWFILTER/SMD/F6QB2G595P2BSSAW / SAFFB2G60AA1F0AU3468BAL_/_TFSZ06051897-3317A1_1BALUN/SMD/TFSZ06052460-3310A2BAL / TFSZ06050775-3338A1U3474SPDT_/_BGS12SL6_2RF1628SPDT / RF1628AU5001MT6630_WLCSPMT6630/WLCSP113/P0.4/B0.25/5.013X5.013U / MT6630-WLCSPU5002IC-GPS-TPX205950MT-7110A1IC-GPS-TPX205950MT-7110A1TPX205950MT-7010A1_8U5003IC-SAW-SAFEB1G57KE0F00-MURATASAFEB1G57KE0F00NC/SAFEB1G57KE0F00U5103IC-GPS-LNAP-MAX2659-MAXIMMAX2659MAX2659ELTU5105SAFEB1G57KA0F00SAW-1411FBAR / ACPF-7124U6001MSOP8MSOP8NC TCS7190( LM4890MM)U6002MSOP8MSOP8NC TCS7190( LM4890MM)U6103AP3031_0SOT23_6CP2121ST-B2/TCS23352U6105TCS4150-ESOT23_5WD1013EA/TCS4150-EU6109AP3031_0SOT23_6EUP2530/CP2123ST-B1U6201CP2155CP2155CP2155DN10-A1U6305CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMCLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMU6403TLE4917OCH167TWADU6404IC-3-A-ACCELEROMETER-BMA250-BOSCHBMA250BMA223U6601WLCSP16/SMD/P0.4/B0.2/FPF3040CSP16/SMD/P0.4/B0.25/TPS6128X/SFPF3042U6701ELI_GSL3676_QFN56_7X7X1_TPICELI_GSL3676_QFN56_7X7X1_TPICELI_GSL3676_QFN56_7X7X1_TPICU7101FSUSB42UMXFSUSB30UMXFSUSB42UMXU7102FSUSB42UMXFSUSB30UMXFSUSB42UMXVR1307VAR_0402MLV0402ESD9B5V-2/TRVR1308ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ESD9X5VL-2/TRVR1309ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ESD9X5VL-2/TRVR1310VAR_0402MLV0402ESD9B5V-2/TRVR1311VAR_0402MLV0402NC/ESD9B5V-2/TRVR2001VR0402R0402SFI0402-180E10RPP-LFVR2002VR0402R0402SFI0402-180E10RPP-LFVR2003PTVSHC3D4V5BSOD-323NC ESD56131WVR6000VAR_0402MLV0402ESD9B5V-2/TRVR6001VAR_0402MLV0402ESD9B5V-2/TRVR6002ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45VR6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45VR6017ESD5641D07ESD5641D07NC ESD5641D07VR6018VAR_0402MLV0402ESD9B5V-2/TRVR6022ESD5641D07ESD5641D07NC ESD5641D07VR6301VARISTOR-5V-50PF-AVLC5S02050-AMOTECHR0402SFI0402-180E10RPP-LFX2XTAL-3225-4PXTAL-3225-4PXTAL_12MHzX60226M_TCXO3225_2520_7M26000028_DSA26M_TCXO3225_2520_7M26000028_DSA26MHz/ 7M26000028X2000CRYS/SMD/3.2X1.5/9H032000XX/TXCCRYS/SMD/3.2X1.5/9H032000XX/TXCNCX510126M_TCXO_2520TC7L26002015_2016L2642126M_TCXO_2520TC7L26002015_2016L26421NC/TCXO / 26 / MHz / IT2205AEZ1BAL_/_RFBLN2012090BM5T25BALUN/10P/SMD/BD2012RFBLN2012090BM6T16Z3101BAL_/_RFBLN2012090BM5T25BALUN/10P/SMD/BD2012RFBLN2012090BM6T16
老吴 发表于 2020-10-22 10:54:30
PCB 原理图一起打包。回复可见。
**** Hidden Message *****
yfchen1003 发表于 2020-10-22 11:27:57
精品!
roezw 发表于 2020-10-22 11:30:53
hhbin634 发表于 2020-10-22 13:07:30
pcbaihaozhe 发表于 2020-10-22 13:39:42
jass2008 发表于 2020-10-22 13:43:59
什么格式?
木子健518 发表于 2020-10-22 14:15:41
sym21ic 发表于 2020-10-22 15:09:49
love欣 发表于 2020-10-22 16:37:33
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: MTK6735/MT6735 方案智能手机PCB和原理图共享
