老吴 发表于 2020-12-10 23:57:58
MT8135+MT6397+MT6280NS 做的平板电脑PCB和原理图
NamePCB DecalPart TypeValue3G_C1C0603C_/_2200_/_NF_/_0603_/_X5RC / 2200 / nF / 0603 / X5R3G_CON701MM8430-2610BTST_PORT_1MM8430-2610B_RA1_RB33G_CP1C0603C080522uF/10V/X5R3G_CP6C0603C080522uF/10V/X5R3G_D900LED190LED_1LED_13G_D901LED190LED_1LED_13G_E702ANT/DIP/101266-1ANTENNA_15ANTENNA1PIN3G_E703ANT/DIP/101266-1ANTENNA_15ANTENNA1PIN3G_L207L/IND/SMD/CKP20164R7MINDUCTORCKP25202R2M-T3G_L208L/IND/SMD/CKP20164R7MINDUCTORCKP25202R2M-T3G_L217L0402EMIFILTER0R3G_L613L0402L_/_NC_/_0402L / NC / 04023G_Q2022-1L1B/SMD/SSM3K35MFVMOSFET_N_2SSM3K35MFV3G_U3MLPQ16/SMD/P0.5/SC187_____________________G5627_5Semtech_SC1873G_U101MT6280NS/TFBGA288/P0.4/B0.25/8.8X8.8MT6280_69MT6280NS3G_U201MT6327/MQFN20/SMD/P0.4/3X3MT6280_64MT63273G_U401TFBGA130/P0.65/B0.3/8X9/TOSHIBAK5D1257DCA-D090_0MT29C1G12MAADVAMD_5IT3G_U609QCS5FSAW_1SAFEA1G84FA0F00R143G_U611SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYRF1G95HQ0F0A3G_U612SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYFH836MCA0F003G_U613SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALB80783G_U614SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYFH897MHA0F003G_U705XM0860SH-DL0601XM0860SH-DL0601XM0860SH-DL06723G_U706SKY77186SKY77701_0RF72453G_U707SKY77186SKY77701_0_2RF72413G_U708SKY77186SKY77701_2RF72483G_U709SKY77186SKY77701_1RF72423G_U901RF3235RF3232DS_1RF32363G_X603CRYS/SMD/D3.2X2.5/7M26000010TCVCXO_0TXC 7M26000028 X'tal 26MHz ANT1002GPS/ANT/CON1ANTENNA_0101266-1BEAD414BEAD/SMD/0603BEADBLM18BD252SN1CON401PHONEJACK/SMD/PJ-S3142/MD0840CXJC-PJ2_0PJ-S3142CON402USB_NOKIAMINI_10PIN_0Wisky USB connectorCON804FPC_24P-0.5MOV7645FB_6Wisky camera connectorCON805FPC_24P-0.5MOV7645FB_6Wisky camera connectorCON806FPC_6P-0.5MOV7645FB_10Wisky sidekey connecotrCON807H3/SMD/P1.27OV7645FB_9H3/SMD/P1.27CON1001MM8430-2600BCAR_KIT_/_MM8430-2610BMM8430-2610BCON1404TF_CARDMMC_CONN_6SD-47352-101CON1503SIM-CARDSIM_SOCKET_0_2Wisky SIM-cardCON1711H40S/P0.5IPEX-20455-040E_140P-0.5PITCH, BOTTOMCON1712CON20X2/SMD/M/AXT440124HEADER_1AXT440124CON17137-ITO-CON/SCON8P_3.5PWisky CTP controller CON1714H6S/P1.0CON8P_0.5PFH12-6S-1SHD1SOT23DIODE_DUAL_RS_AJK_3BAV-99D2SOT23DIODE_DUAL_RS_AJK_2BAV-99D3RB551V-30(UMD2)DIODE_SCHOTTKY_6RB551V-30D4RB551V-30(UMD2)DIODE_SCHOTTKY_6RB551V-30D6RCLAMP0524P/10P/SMDRCLAMP0524PRclamp0524PD7RCLAMP0524P/10P/SMDRCLAMP0524PRclamp0524PD8ESD0603/SMDDIODE_DIACESD0603/SMD/NCD9ESD0603/SMDDIODE_DIACESD0603/SMD/NCD10RB551V-30(UMD2)DIODE_SCHOTTKY_6RB551V-30D11RCLAMP0524P/10P/SMDRCLAMP0524PRclamp0524P/NCD12RCLAMP0524P/10P/SMDRCLAMP0524PRclamp0524P/NCD13RCLAMP0524P/10P/SMDRCLAMP0524PRclamp0524P/NCD300RB551V-30(UMD2)DIODE_SCHOTTKY_6RB551V-30D303DIODE/SMD/MMSZ5221BDIODE/ZENERMMSZ5231BT1GD401SOD923/SMDPG05BSESC_0ESD9L5.0ST5GD402D/SMD/UMD2DIODE_SCHOTTKY_0UDZV 5.6BEMI823FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FRGND1TP/SMD/D0.6TEST_POINT_DIP0.6TEST POINTH5HOLE/NPTH/D2.2/WS1962SCREW_HOLE_3_0.5MMHOLE/NPTH/D2.2/WS1962/NCJ300HDMI/SMD/CON/APORT_HDMI_TYPE-AHDMI_TYPE-A/NCJ301MICROHDMI/19P/SMD/ATOMO10130010031PORT_HDMI_TYPE-AHDMI_TYPE-DJ505DIP4/W/H/P2.0CONN_4_W/HOUSING_DIP_2.0Wafer_2.0_4L2L/IND/SMD/LVS252010-2R2INDUCTORVLS252010T-4R7M (4.7uH)L4L/IND/SMD/LVS252010-2R2INDUCTORVLS252010T-4R7M (4.7uH)L6L/IND/SMD/IHLP-2020AB-01INDUCTORVishay IHLP2020ABER2R2M01 (2.2uH)L212BEAD/SMD/0603INDUCTORBLM18PG221SH1L402BEAD/SMD/0603BEADLQM18NN82NM00L1001L/IND/SMD/LQM2HP-1008INDUCTORLQM2HPN2R2MG0 (2.2uH)L1003L0603INDUCTOR_3LQW18ANR10G00L1004L0402L_/_39_/_NH_/_040239nH/NCL1007L0402FERRITE_BEAD_SMD_04028.2nH/LQG15HS/MurataL1008L0402INDUCTOR_3NCL1009L0402INDUCTOR_327nH/LQG15HS/MurataLED10LED/SMD/0603LED_DIP2.54Green/NCLED301LED/6P/SMD/SMLP36DIODE_8ROHM SMLP36RGB1WLED302LED/6P/SMD/SMLV36LED_0SMLV36WBFCW/NCM5SCREW_HOLE/PTH/R6.5D3.3SCREW_HOLE_3_0.5MMSCREW_1MM/NCMIC403EAO-4015-PFAAUDIO_JACK_0EAO-4015-PFANFC_ANT1201PAD/1P/2.2X3ANTENNAANT / R2.2NFC_ANT1202PAD/1P/2.2X3ANTENNAANT / R2.2NFC_C1201C0402C_/_2200_/_NF_/_0402_/_X5R2.2uF/6.3V/X5RNFC_L1201L0603FERRITE_BEAD_SMD_0402560nH/MLF1608DR56JNFC_L1202L0603FERRITE_BEAD_SMD_0402560nH/MLF1608DR56JNFC_R1201R0402R_/_0_/_OHM_/_04020NFC_R1202R0402R_/_0_/_OHM_/_0402_30NFC_R1203R0402R_/_0_/_OHM_/_04020NFC_R1204R0402R04026K_1%NFC_R1205R0402R0402NCNFC_R1206R0402R_/_0_/_OHM_/_040210K/NCNFC_R1207R0402R04020NFC_U1201MT6605/MQFN32/SMD/P0.4/4X4/SMT3301-140_SMD_PBGA-140_0MT6605 QFN (32 Pins, 0.4mm pitch)NFC_X1201CRYS/SMD/FA-128QUARTZ_IQX0_1QUARTZ 27.12 MhzRD4R0402R0603_856_1%SW2SWITCH/SMD/STS-A85SNSSW_PUSHBUTTON_FLAT_TYPE_0STS-A85SNSU5FBGA96/SMD/P0.8/MICRONIC_DDR3_X16_FBGA-96IC DDR3 x16 FBGA-96U6FBGA96/SMD/P0.8/MICRONIC_DDR3_X16_FBGA-96IC DDR3 x16 FBGA-96U7MT8135/VFBGA398/P0.65/B0.3/15X15MT8130_14.9X14.9_0.65P_0904MT8135/VFBGA398/P0.65/B0.3/15X15U11QFN16/SMD/P0.5/HA526610109_0HA5266ADDU12TSOT-23-6/SMD/P0.95/AT1316/SAPL5151_1TPS61165DBVTU22TSOP48/SMDAM29PL160C_3NAND08GW3B2CN6E/NCU406SOT23-6/SMDTEA1206T_0Onsemi CAT3200TDI-T3U407SW/10P/SMD/FSA3000/FAIRCHILDSIM_SOCKET_0FSA3000U408SW/10P/SMD/FSA3000/FAIRCHILDSIM_SOCKET_0FSA3000U502BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA169_BALL_EMMCSamsung KLM2G1HE3F-B001U1001MODULE/MT6620/56P/SMDS500_0S501U1002PCTCXO/SMD/2.5X2/IT2200MV/RAKONTCXO_RAKON_SMD_4P_0RAKON/TX6217U1006DFN6/SMD/DALLAS/MAX2659NJG1107HB3_2MAXIM_2659U1007SAW/SMD/DGLT36M07/SDGLT36M07_0TDK DPX252500DT-5217A1U1602WLCSP14/SMD/P0.4/B0.23/AK8963ADXL345_2AK8963CU1604VDFN10/SMD/P0.5/MC3200ADXL345_1MC3210U1607OPLGA6/SMD/P0.6/CM3623CM3623_1STK2203U1609QFN30/SMD/MPU-300074ALVC74PW_1MPU-3050U1613NLSX3378/12P/P0.5/B0.27/2.02X1.54/ONNLSX3378NLSX4378U1901DSBGA4/SMD/P0.4/B0.25/TMP103TMP103AYFFTTMP103AYFFTU1904VQFN24/SMD/P0.5/BQ24196BQ24196_0bq24196U1907MT6397/TFBGA211/P0.65/B0.3/11.7X11MT6397_17X18_FINALMT6397/TFBGA211/P0.65/B0.3/11.7X11VBAT_SUPPLY1TP/SMD/D0.6TEST_POINT_DIP0.6TEST POINTVR1527R0402VR0402EZJZ0V500AAX302CRYS/SMD/MS3V-T1RCRYSTAL_132K (MS3V-T1R)X601CRYS/SMD/D2.5X2.0/RXT2520AT/RAKONTCVCXO_2XTAL / RAKON / RXT2520AT / SMD/11.5pFX602PCTCXO/SMD/2.5X2/IT2200MV/RAKONTCXO_RAKON_SMD_4P_0RAKON/TX6217
老吴 发表于 2020-12-10 23:59:41
PCB文件和原理图 回复可见下载。
**** Hidden Message *****
lc601257251 发表于 2020-12-11 05:08:51
longxuekai 发表于 2020-12-11 06:06:09
学习学习了
luchonghui74 发表于 2020-12-11 08:15:17
感谢你的分享!
wangy2000 发表于 2020-12-11 08:17:36
小小路人甲 发表于 2020-12-11 08:18:06
yushibin 发表于 2020-12-11 08:28:20
kanxue_nmg 发表于 2020-12-11 08:34:52
roezw 发表于 2020-12-11 08:43:02
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: MT8135+MT6397+MT6280NS 做的平板电脑PCB和原理图
