想学一下genesis2000脚本!那位高手能帮我看一下这是什么意
DO_INFO -t matrix -e $JOB/matrix -d ROWset matrix_counter = 0set L_NUM = 0set OUTER_LAYERS = ( )set INN_LAYERS = ( )set SM_LAYERS = ( )set SS_LAYERS = ( )set DRL_LAYERS = ( )set layers_no = ( )set SIGNAL_LAYERS = ( )set NEGATIVE_LAYERS = ( )set TOP_LAYERS = ( )set BOT_LAYERS = ( )set outer_top = ( )set outer_bot = ( )set posi_top = ( )set posi_bot = ( )set nega_top = ( )set nega_bot = ( )........ 我也想学,哪里有教程啊 DO_INFO -t matrix -e $JOB/matrix -d ROW 这里是获取层数
