pads logic offpage 标签对齐方法
打开原理图,点击“file”,“export”
输出ASCII文件到指定位置,跳出设置框,点击“select all”,“OK”
用notepad++或editplus等记事本软件打开,搜索netnames,尽量不要选择记事本,因为notepad++有一个很重要的技巧,能够同时操作多行,详见经验“怎样在Notepad++中列选”
26怎样在Notepad++中列选(竖选)
每行各项所对应含义为,netname itemname x y ori just shx shy shori shjust shn fontinfo,
其中Justification of the text string
The value is a bit string as follows:
Bit 0 = 0 Left justified or center (X direction) justified Bit 0 = 1 Right justified
Bit 1 = 0 Bottom justified or middle (Y direction) justified Bit 1 = 1 Top justified
Bit 2 = 0 Left or right justified Bit 2 = 1 Center justified
Bit 3 = 0 Bottom or top justified Bit 3 = 1 Middle justified.
When text is rotated the definitions for bits 0 and 1 are interchanged.
把对应值改为相同的值,在pads logic新建一个空的原理图,点击“file”,“import”
offpage分成四种朝向,要根据rotation,orientation区分对待
如果rotation为90,注意取值为旋转之前所对应的位移值 多谢楼主分享
