展讯 SC9830A+SC2342A 做的4G 智能手机PCB文件
NamePart TypePCB DecalValueANT0400CON-SPRING-T105-11F2RCON-SPRING-T105-11F2RAAANT0401CON-SPRING-T105-11F2RCON-SPRING-T105-11F2RBANT0600NC-PAD-RFANTNC-PAD-RFANTAAAAANT0601NC-PAD-RFANTNC-PAD-RFANTAAAAANT1900NC-PAD-RFANTNC-PAD-RFANTAAAAANT1902NC-PAD-RFANTNC-PAD-RFANTAAAACON1BAT-SMD-7PINBAT-SMDkey_resetCON3CON_8PIN_1.0FPC-8P_0.8CAP_KEYD1D-MBR0530TXSOD-123MBR0540/B5819W SLD331LTPL-C062WDYF-WAOXW2016D4100D-MBR0530TXSOD-123MBR0540/B5819W SLD4102DIODE-SWITCH-LBAT54SLT1GSOT23BAT54SD4103DIODE-SWITCH-LMBR140T1GSOD-123FLMBR140/B5819W SLD4104DIODE-ZENER-UDZS18BUMD2ZENER-UDZS18B/18VD4105DIODE-SWITCH-LBAT54SLT1GSOT23BAT54SD4107DIODE-ZENER-UDZV8.2BUMD2ZENER-UDZS8.2B/8.2VD5100DIODE-LED-LTPL-C064WD-WADIODE-LED-LTPL-C064WD-WAD6100DIODE-ZENER-PZ3D4V2HSOD-323-PRISEMIZENER-PZ3D4V2HF1002BL1608-05K2450_1DIPLEXER/6P/SMD/DP1608BL1608-05K2450FB1BEAD-1K-OHM-100MHZ-250MA-0402SL04021Kohm@100MHzFB2BEAD-1K-OHM-100MHZ-250MA-0402SL04021Kohm@100MHzFB3BEAD-1K-OHM-100MHZ-250MA-0402SL04021Kohm@100MHzFB4BEAD-600-OHM-100MHZ-0603SL0603-S600ohm@100MHzFB5BEAD-1K-OHM-100MHZ-250MA-0402SL04021Kohm@100MHzFB6BEAD-1K-OHM-100MHZ-250MA-0402SL04021Kohm@100MHzFB7BEAD-1K-OHM-100MHZ-250MA-0402SL04021Kohm@100MHzFB4100BEAD-470-OHM-100MHZ-0.5A-0603SL0603-S470ohm@100MHz 500mAFD1401NC-FIDUCIALMARKPAD-FIDFD1402NC-FIDUCIALMARKPAD-FIDFD1403NC-FIDUCIALMARKPAD-FIDFD1404NC-FIDUCIALMARKPAD-FIDJ1CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703BJ2CON-EAR-PJ-3241-5PCON-EAR-PJ-3241-5PPJ-3588J12CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703BJ13CON_6PINFP243H-RJ14RF-CONRF-CONRFJ15RF-TESTKEY_4MM_1.7MMAAAAAAJ16RF-CONRF-CONRFJ18CON45-ZIFFP270-45-0.3FH26-51S-0.3SHWJ19FPC_30PIN_MIPICON-FPC-FPC30-T1T12021-AFPC-30PIN_0.5_H=2.0MMJ20SOCKET-SIM-SIM25-16M03-TP300SOCKET-SIM-SIM25-16M03-TP300SOCKET-SIM-SIM25-16M03-TP300J100CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1J101CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1J501RF-TESTKEY_4MM_1.7MMAAAAJ5100CON-FPC-FPC24CON-FPC-FPC24FPC-24PIN_0.5_H=2.0MMJ6201CON-USB-MICRO-CBCON-USB-MICRO-CBmicor usb UAF95-05254-S113J6202CON-CLIP-SHIELD-PTC0703BCON-CLIP-SHIELD-PTC0703BJ6500SOCKET-T-CARDSD_F03TF-CARDL1IND-POWER-1.0UH-MLP2520W1R0MSL1008(2520)4.7uHL2IND-POWER-1.0UH-MLP2520W1R0MSL1008(2520)10uHL0003IND-CER-3.9NH-0.1-0201-LQP03TN-00SL0201AANCL0004IND-NF-0201IND-NF-0201NFL0005IND-CER-8.2NH-5%-0201-LQP03TN-02SL0201BNCL0006CAP-2.7PF-0201SC0201AAAANCL0007CAP-1.2PF-0201SC0201AAAANCL0008IND-CER-8.2NH-3%-0201-LQP03TN-00SL0201AA8.2nHL0009IND-CER-2.7NH-0.1-0201-LQP03TN-00SL0201AA2.7nHL0010IND-CER-6.8NH-3%-0201-LQP03TN-00SL0201AA6.8nHL0011IND-CER-3.9NH-0.1-0201-LQP03TN-00SL0201AA3.9nHL0013IND-NF-0201IND-NF-0201NFL0014IND-NF-0201IND-NF-0201NFL0015IND-NF-0201IND-NF-0201NFL0016IND-NF-0201IND-NF-0201NFL0018IND-NF-0201IND-NF-0201NFL201IND-POWER-0.68UH-WPN201610HR68MTIND-POWER-WPN20160.68uHL202IND-POWER-0.47UH-WPN252010HR47MTIND-POWER-WPN25200.47uHL203IND-POWER-1.0UH-SPH252012H1R0MTY03IND-POWER-1.0UH-SPH252012H1R0MTY031.0uHL204IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-2.2UH-SPH252012H2R2MT2.2uHL205IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-2.2UH-SPH252012H2R2MT2.2uHL206IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-2.2UH-SPH252012H2R2MT2.2uHL207IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-2.2UH-SPH252012H2R2MT2.2uHL0400IND-NF-0201IND-NF-0201NCL0401CAP-2PF-0.25-50V-0201-GRM0335C-CSC0201AAAA2pF(NF)L0402CAP-0.5PF-0201SC0201H0.5pFL0403CAP-1.5PF-0201SC0201AAAA1.5pFL0404IND-CER-2.7NH-0.1-0201-LQP03TN-00SL0201AANCL0405IND-CER-18NH-3%-0201-LQP03TN-00SL0201AA18nHL0406CAP-3.9PF-0201SC0201AAAANCL0407IND-NF-0201IND-NF-0201NCL0408IND-NF-0201IND-NF-0201NFL0409IND-NF-0201IND-NF-0201NCL0410CAP-1PF-0201SC0201AAAANCL0412IND-CER-2.4NH-0.2-0201-LQP03TN-02SL0201AA2.4nHL0413IND-NF-0201IND-NF-0201NFL0414CAP-1PF-0201SC0201AAAA1.0pFL0415CAP-3.9PF-0201SC0201AAAA3.9pFL0416CAP-1.5PF-0201SC0201AAAA1.5pFL0417IND-NF-0201IND-NF-0201NCL0419IND-CER-12NH-5%-0201-SDCL0603Q-02SL0201AA12nHL0420IND-CER-3.6NH-0.2-0201-LQP03TN-02SL0201AA3.6nHL0421IND-CER-9.1NH-5%-0201-LQP03TN-02SL0201B9.1nH(NF)L0422IND-CER-9.1NH-0.3-0201-SDCL0603Q-02SL0201AA9.1nH(NF)L0423IND-CER-12NH-5%-0201-LQP03TN-02SL0201B12nHL0424IND-NF-0201IND-NF-0201NCL0425CAP-1.2PF-0201SC0201AAAANCL0426IND-CER-8.2NH-3%-0201-LQP03TN-00SL0201AA8.2nHL0427IND-CER-2.7NH-0.1-0201-LQP03TN-00SL0201AA2.7nHL0429IND-CER-3.0NH-0.1-0201-LQP03TG-02SL0201AA3.0nHL0432IND-CER-3.0NH-0.1-0201-LQP03TG-02SL0201AA3.0nHL0433IND-NF-0201IND-NF-0201NFL0435IND-CER-2.7NH-0.1-0201-LQP03TN-00SL0201AA2.7nHL0436CAP-3.9PF-0201SC0201AAAANCL0437IND-CER-4.3NH-3%-0201-LQP03TN-02SL0201AA4.3nHL0438CAP-3.9PF-0201SC0201AAAANCL0440IND-CER-1.5NH-0.3-0201-SDCL0603Q-02SL0201AANCL0441IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL0201AANCL0442CAP-3.9PF-0201SC0201AAAANCL0444IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL0201AANCL0446IND-NF-0201IND-NF-0201NCL0449IND-NF-0201IND-NF-0201NFL0451IND-NF-0201IND-NF-0201NFL0452IND-CER-8.2NH-3%-0201-LQP03TN-00SL0201AA8.2nHL0453CAP-1PF-0201SC0201AAAANCL0454CAP-6.8PF-0201SC0201AAAANCL0455IND-NF-0201IND-NF-0201NFL0462IND-CER-6.2NH-0.3-0201-SDCL0603Q-02SL0201AA6.2nHL0463IND-CER-3.9NH-0.1-0201-LQP03TN-00SL0201AA3.9nHL0464IND-CER-12NH-5%-0201-SDCL0603Q-02SL0201AA12nH(NF)L0465IND-CER-2.4NH-0.2-0201-LQP03TN-02SL0201AA2.4nHL0466IND-NF-0201IND-NF-0201NFL0467CAP-2.2PF-0201SC0201AAAA2.2pFL0468IND-CER-8.2NH-3%-0201-LQP03TN-00SL0201AA8.2nHL0471IND-NF-0201IND-NF-0201NFL0473IND-CER-12NH-5%-0201-LQP03TN-02SL0201B12nHL0474IND-CER-12NH-5%-0201-SDCL0603Q-02SL0201AA12nHL0476IND-CER-9.1NH-5%-0201-LQP03TN-02SL0201B9.1nHL0477CAP-3.9PF-0201SC0201AAAA3.9pF(NF)L0478IND-CER-4.7NH-0.3-0201-SDCL0603Q-02B01SL0201AA4.7nHL0479IND-CER-1.5NH-0.3-0201-SDCL0603Q-02SL0201AA1.5nHL0480IND-CER-6.8NH-3%-0201-LQP03TN-00SL0201AA6.8nHL0481IND-CER-3.9NH-0.1-0201-LQP03TN-00SL0201AA3.9nHL0485CAP-2.2PF-0201SC0201AAAANCL0486IND-CER-8.2NH-3%-0201-LQP03TN-00SL0201AA8.2nHL0487IND-CER-18NH-3%-0201-LQP03TN-00SL0201AA18nHL0494IND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01SL0201AANCL0499IND-CER-2.4NH-0.2-0201-LQP03TN-02SL0201AA2.4nHL0600IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL0201AA3.9nHL0601CAP-2.7PF-0201SC0201AAAANCL0602IND-NF-0201IND-NF-0201NFL0603IND-CER-9.1NH-0.3-0201-SDCL0603Q-02SL0201AANCL0604IND-CER-18NH-3%-0201-LQP03TN-00SL0201AANCL0606CAP-2.2PF-0201SC0201AAAANCL0607IND-CER-4.7NH-0.3-0201-SDCL0603Q-02B01SL0201AANCL0608IND-NF-0201IND-NF-0201NCL0610IND-CER-3.9NH-0.1-0201-LQP03TN-00SL0201AA3.9nHL0611IND-CER-8.2NH-5%-0201-LQP03TN-02SL0201B8.2nHL0613CAP-4.7PF-0201SC0201AAAA4.7pF(NF)L0614IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL0201AANCL0616CAP-2.7PF-0201SC0201AAAANCL0617IND-NF-0201IND-NF-0201NFL0618CAP-2.2PF-0201SC0201AAAANCL0619IND-CER-7.5NH-3%-0201-LQP03TN-00SL0201AANCL0620IND-NF-0201IND-NF-0201NCL0621IND-CER-47NH-5%-0201-SDCL0603Q-02B01SL0201B47nHL0622IND-CER-47NH-5%-0201-SDCL0603Q-02B01SL0201B47nHL0623IND-CER-47NH-5%-0201-SDCL0603Q-02B01SL0201B47nHL0627CAP-1.2PF-0201SC0201AAAA1.2pFL0628IND-CER-9.1NH-0.3-0201-SDCL0603Q-02SL0201AA9.1nHL0629IND-NF-0201IND-NF-0201NCL0630IND-CER-47NH-5%-0201-SDCL0603Q-02B01SL0201B47nHL0631CAP-4.7PF-0201SC0201AAAANCL0632IND-CER-47NH-5%-0201-SDCL0603Q-02B01SL0201B47nHL0633CAP-4.7PF-0201SC0201AAAA4.7pF(NF)L0634IND-CER-47NH-5%-0201-SDCL0603Q-02B01SL0201B47nHL0635IND-CER-47NH-5%-0201-SDCL0603Q-02B01SL0201B47nHL0636IND-CER-47NH-5%-0201-SDCL0603Q-02B01SL0201B47nHL0639IND-CER-3.6NH-0.1-0201-LQP03TN-02SL0201AA3.6nHL0641CAP-3PF-0201SC0201AAAA3pFL0647CAP-1.3PF-0.1-50V-0201-GRM0335C-BSC0201AAAANCL0651CAP-2.7PF-0201SC0201AAAA2.7pF(NF)L1900IND-CER-NF-0201SL0201NCL1901IND-CER-NF-0201SL0201NCL4102IND-POWER-10UH-SWPA4020S100MIND-POWER-SWPA4010uHL7202IND-CER-1.0NH-0201SL02011.0NHL7203IND-CER-NF-0201SL0201NFL7204IND-CER-3.3NH-0201SL0201D3.3NHL7206IND-CER-4.3NH-0201SL02014.3NHL7207IND-CER-2.0NH-0201SL02012.0NHL7208IND-CER-4.7NH-0201SL02014.7NHL7209IND-CER-NF-0201SL0201NFL7210IND-CER-3.3NH-0201SL0201D3.3NHL7211IND-CER-NF-0201SL0201ANCL7212IND-CER-NF-0201SL0201ANCL7213IND-CER-8.2NH-0201SL0201A8.2NHL7214IND-CER-4.7NH-0201SL0201NCL7215IND-CER-27NH-0201SL020127NHMLV1MLV-AVLC5S02050SMLV0402NCQ2TRIODE-NPN-2SC5658-ASOT23MMBT2222Q1300TRIODE-PNP-PBSS5320XSOT-89Q1301FET-N-2SK3019SOT-416REC3100AUDIO-RECEIVER-SDRP0612KJ02-F1-GAUDIO-RECEIVER-SDRP0612KJ02-F1-GSDRP0612KJ02-F1-GS6300SWITCH-PUSH-TS-1100ASWITCH-PUSH-TS-1100ABkey_powerS6301SWITCH-PUSH-TS-1100ASWITCH-PUSH-TS-1100Akey_vol+S6302SWITCH-PUSH-TS-1100ASWITCH-PUSH-TS-1100Akey_vol-S6303SWITCH-PUSH-TS-1100ASWITCH-PUSH-TS-1100ABAkey_resetSP0601RF-SWITCH-SKY13418-485LFPQFN_14_P045X040_200X200_T100_H060_485LFT0030NC-PADNC-PAD-0.5X0.5T0031NC-PADNC-PAD-0.5X0.5T32TPTPT0033NC-PADNC-PAD-0.5X0.5T0034NC-PADNC-PAD-0.5X0.5T35NC-TP-1.5NC-TP-1.5T36NC-TP-1.5NC-TP-1.5T0102NC-PADNC-PAD-0.5X0.5T0103NC-PADNC-PAD-0.5X0.5T107NC-TP-1.5NC-TP-1.5T108NC-TP-1.5NC-TP-1.5T0115NC-PADNC-PAD-0.5X0.5TVS4TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5GESD9L5.0ST5G/AU0511P1 5V 7PFTVS6100TVS-ESD5Z3.3T1G-3.3V-105PF-SOD-523SOD-523NFTVS6200TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5GAU0561BP 5V 2.5PF/ESD9B5VL-2/TRTVS6201TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5GAU0561BP 5V 2.5PF/ESD9B5VL-2/TRTVS6202TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5GAU0561BP 5V 2.5PF/ESD9B5VL-2/TRTVS6205TVS-PTVS3V3S1URTVS-PTVS3V3S1URPDZ5.6/0.5WU0001RF-SAW-SAFFB881MAN0F0ARF-SAW-1.1X0.9SF-0881T4-C13/SFH881AA002U2BGA11.5X13-221-0.5MMBGA11.5X13-221-0.5MMABGA11.5X13-221-0.5MMU0002RF-SAW-SAFFB942MAN0F0ARF-SAW-1.1X0.9SF-0942T4-C13/SFH942AA002U3GSL168X_1QFN_5X5MM_40_0D4GSL1680U4FET-P-SI2301CDS-T1-GE3SOT23SI2301U0005RF-SAW-SAFFB2G65AA0F0ARF-SAW-1.1X0.9SF-2140T4-C13U6MT8377SOT23-6TCS9300/LP6218U0007RF-SAW-SAFFB2G65AA0F0ARF-SAW-1.1X0.9SF-1842T2-C13U0008RF-SAW-SAFFB881MAN0F0ARF-SAW-1.1X0.9SF-1960T4-C13/SFHG60CA002U0009RF-SAW-SAFFB881MAN0F0ARF-SAW-1.1X0.9NCU0010RF-SAW-SAFFB2G35AA0F0ARF-SAW-1.1X0.9NCU0011RF-SAW-SAFEA2G35MF0F0ARF-SAW-1.35X1.05NCU12POWER-LDO-WL2801E33-5/TRSOT23-5WL2801E18-5/XC6221B18MRU13IC_SL3670_QFN52PINIC_SL3670_QFN52PINGSL3670U40MMA7660FC_1MMA7660FCM3236AF/STK8312U100ASIC-SC2723-170-0.4BGA6.2X6.6-170-0.4-SC2723U0400RF-PAM-SKY77643-11PQFN_42_P044_680X400_T205X240X2_H080U0401RF-SW+PA-SKY77916-11PQFN_48_P048_550X530_T390X370_H080VC7910U0403RF-SAW-SAFEA2G35MF0F0ARF-SAW-1.35X1.052350MHzU0405RF-SAW-DUPLEX-SAYEY2G53BA0F0AFILTER_8_180X140_H060B8674U0406RF-SAW-DUPLEX-SAYEY1G95GA0F0AFILTER_8_180X140_H060B8651U0407RF-SAW-DUPLEX-SAYEY1G88BA0B0AFILTER_8_180X140_H060NCU0408RF-SAW-DUPLEX-SAYEY1G73BA0F0AFILTER_8_180X140_H060NCU0409RF-SAW-DUPLEX-SAYEY897MGA0F0AFILTER_8_180X140_H060NCU0412RF-SAW-DUPLEX-SAYEY1G74BC0B0AFILTER_8_180X140_H060B8680U0413RF-SAW-DUPLEX-SAYEY836MBA0F0AFILTER_8_180X140_H060NCU0414RF-SAW-DUPLEX-SAYEY806MBA0F0AFILTER_8_180X140_H060B8677U0502MEM-EMMC-KLM4G1YE4C-B001BGA11.5X13-153EMMC-KLM4G1YE4C-B001U600ASIC-SC9830A-492-0.4BGA11.7X11.7-492-0.4-SC9830AU0601RF-SAW-SAFFB942MAN0F0ARF-SAW-1.1X0.9NCU0602RF-SAW-SAFFB2G35AA0F0ARF-SAW-1.1X0.92350MHzU0604RF-SAW-SAFFB2G65AA0F0ARF-SAW-1.1X0.9SF-2655T5-C13U0605RF-SAW-SAFFB1G96AB0F0ARF-SAW-1.1X0.9NCU0607RF-SAW-SAFFB806MAA0F0ARF-SAW-1.1X0.9SFH806AA002U0609RF-SAW-SAFFB881MAN0F0ARF-SAW-1.1X0.9NCU0610RF-TRANSCEIVER-SR3593GBGAS_84_P040_475X475_H085_SR3593GU701POWER-DC2DC-AW3641EPOWER-DC2DC-SGM3140NCU1202SENSOR-LIGHT+PROX-LTR-558ALS-WASENSOR-LIGHT+PROX-LTR-558ALS-WAU4108POWER-DC2DC-KTD257EHD-TRSOT23-6ATCS3356/LP3301U7201BWFG-SC2342A-175-0.4BGA7.5X5.3-175-0.4-SC2342AU7202RF-SAW-SAFEA2G45MC0F0ARF-SAW-SAFEA2G45MC0F0AU7206RF-SAW-SAFFB1G58KA0F0ARF-SAW-SAFFB1G58KA0F0AU7207RF-LNA-AR8159RF-LNA-AR8159UD1TCS5515SOT23_6TCS5515/LP3302AUF4BGA_EMMC_169BGA_EMMC_169UG2BMA220-222-250BMA222BMA220UU4SY6280SOT23-5TCS9708/LPW5206B5FX0600XTAL-TCXO-26MHZ-1XXB26000MABOSC_CC_250X200_H090_KDSNCX7200XTAL-TCXO-1XXB26000CTBXTAL-TCXO-1XXB26000CTBY1CRYSTALA_4PINCRY32768_1MC-1467pf +/-20ppm PCB文件。回复可见下载。
**** Hidden Message ***** 支持 谢谢分享
回 电子小跑腿 的帖子
电子小跑腿:PCB文件。回复可见下载。[内容隐藏]
(2021-09-26 12:31) images/back.gif
