ALLWINNER 全志H3 全志H5兼容 安卓智能电视盒PCB 和原理图
NamePart TypePCB DecalValueANT10ANT_3PINANT_3PINANT-3PIND12ESD0402ESD0402NC/ESD9B5VL-2/TRD13ESD0402ESD0402NC/ESD9B5VL-2/TRD14ESD0402ESD0402NC/ESD9B5VL-2/TRD15ESD0402ESD0402NC/ESD5451XD16ESD0402ESD0402NC/ESD5451XD17ESD0402ESD0402NC/ESD5451XD18SOD123SOD123XBS104S14D19SOD123SOD123IN4736(5.6V)D23ESD0402ESD0402NC/ESD9B5VL-2/TRD24ESD0402ESD0402NC/ESD9B5VL-2/TRD25ESD0402ESD0402NC/ESD9B5VL-2/TRD34SOD123SOD123XBS104S14D35SOD123SOD123XBS104S14D36SOD123SOD123XBS104S14D48ESD0402ESD0402NC/ESD5451XDU1FBGA96C80P9X13FBGA96C80P9X13DDR3-FBGA96DU2FBGA96C80P9X13FBGA96C80P9X13DDR3-FBGA96ESD2ESD0402ESD0402NC/ESD5451XESD3ESD0402ESD0402NC/ESD5451XESD4ESD0402ESD0402NC/ESD5451XFB7L0603L06030RFB8L0603L06030RH1VIA-M3VIA-M3H1H2VIA-M3VIA-M3H1HCON1HDMI\YKF45-7012-1HDMI\YKF45-7012-1HDMI_19PLUGJ3RCA-316RCA-316AV3-8.4-5J5PH-2.54X5PH-2.54X5PH-2.54X5J6H6-PT2_0H3_2BH6-PT2_0H3_2BNC/H6-PT2_0H3_2BJ8RJ-45BRJ-45BRJ45A_PCB-937J12DC-208DC-208DC-0003J13DC-002DC-002DC-002J21CON4_2.54CON4_2.54PH-4AJ24CON_2PIN_2.54CON_2PIN_2.54CON_2PINK1TS-026-3TS-026-3TS-026-3K2TS-026-3TS-026-3TS-026-3K4SKQG-5_2X5SKQG-5_2X5SKQG-5_2X5L4L0603L06032.2UHMASK4SMDSMDSMDP2USBDIP90CEUSBDIP90CEUSBDIP90CEP4USBDIP90CEUSBDIP90CEUSBDIP90CEQ3SOT-23SOT-23MMBT3904Q4SOT-23SOT-23MMBT3904Q6SOT-23SOT-23AO3423-PMOSQ9SOT-23SOT-23MMBT3904Q11SOT-23SOT-23NC/BSN20U1BGA347P0_65B14X14BGA347P0_65B14X14H3-BGA3XX_11U3SOT23_6SOT23_6U5QFN24-0404-.5QFN24-0404-.5RTL8189FTVU6SOT23-5SOT23-5LP3220SAB5FU7SOT23-5SOT23-5LP3218-01U10EMMCEMMCEMMC5_0_BGA169U11TSOP48TSOP48NANDU16SOT23-5SOT23-5LP3220SAB5FU22SMDTR16PSMDTR16PPM44-11BPU27RCLAMP0524PRCLAMP0524PRRCLAMP0524PU28RCLAMP0524PRCLAMP0524PRRCLAMP0524PU35SOT23-5SOT23-5AP2127K-AADJ_1.8VU398189ETV8189ETV8189ETVU49SOT23-5SOT23-5LP3987H-33B5FU50SOT23-5SOT23-5LP3987H-33B5FU53SOT23-6SOT23-6SY8113BWU2QFN40QFN40XR819X1XTAL_3225XTAL_3225NC/24MHZ_20PFX5XTAL_3225XTAL_3225NC/26MHZ_20PFX6XTAL_3225XTAL_3225NC/26MHZX8XTAL49SSMDXTAL49SSMD24MHZ_20PFXC31C0402C040222PFXC41C0402C040222PF PCB 原理图一起打包。回复可见下载。
**** Hidden Message ***** 好资料
