MT7621+MT7975+MT7915 做的wifi6全千兆高性能网关路由器 PCB文件
NamePart TypePCB DecalANT1ANT/3P/MT7658/BT1ANT/3P/MT7658/BT1BC1BARCODE-33X7BARCODE-33X7CON1COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEXCON2COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEXCON5COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEXCON6COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEXD7LED/SMD/0603LED/SMD/0603D9LED/SMD/0603LED/SMD/0603D11D/SMD/P3.325/SOD-123/1N4148D/SMD/P3.325/SOD-123/1N4148D12D/SMD/P6.61/B540CD/SMD/P6.61/B540CH12HOLE/PTH/R0.762X1.6D0.508X1.3HOLE/PTH/R0.762X1.6D0.508X1.3H13TOOLING_HOLE/3.5MMTOOLING_HOLE/3.5MMH14HOLE/PTH/R0.762X1.6D0.508X1.3HOLE/PTH/R0.762X1.6D0.508X1.3H15HOLE/PTH/R0.762X1.6D0.508X1.3HOLE/PTH/R0.762X1.6D0.508X1.3J4DIP4/P2.54DIP4/P2.54J6CON\DC-JACK\4.7CON\DC-JACK\4.7L29L/SMD/GNR6045PM-2R2ML/SMD/GNR6045PM-2R2ML30L/SMD/GNR6045PM-2R2ML/SMD/GNR6045PM-2R2ML360L0603L0603L361L0402L0402L1323L/SMD/GNR6045PM-2R2ML/SMD/GNR6045PM-2R2ML1324L/SMD/GNR6045PM-2R2ML/SMD/GNR6045PM-2R2ML1325L/SMD/GNR6045PM-2R2ML/SMD/GNR6045PM-2R2MP1RJ45/8P/DIP/R/8208C-B01RJ45/8P/DIP/R/8208C-B01P1202PHJ8X4_NPHJ8X4_NS4SW-2P2T-6.3SW-2P2T-6.3S5SW-TACT\4.5MMSW-TACT\4.5MMSH3HOLE/PTH/R0.8128X1.6D0.508X1.35HOLE/PTH/R0.8128X1.6D0.508X1.35SH5HOLE/PTH/R0.8128X1.6D0.508X1.35HOLE/PTH/R0.8128X1.6D0.508X1.35SH7HOLE/PTH/R0.8128X1.6D0.508X1.35HOLE/PTH/R0.8128X1.6D0.508X1.35T300TRANSFORMER/48P/SMD/GS5014LFTRANSFORMER/48P/SMD/GS5014LFT301TRANSFORMER/48P/SMD/GS5014LFTRANSFORMER/48P/SMD/GS5014LFT302TRANSFORMER/24P/SMD/HN2429CGTRANSFORMER/24P/SMD/HN2429CGU6MT7621/LFBGA346/P0.65/B0.3/11.7X13.6MT7621/LFBGA346/P0.65/B0.3/11.7X13.6U8SOP8/SMD/P1.27/MX25L3206ESOP8/SMD/P1.27/MX25L3206EU9DIPLEXER/6P/SMD/DPX165900DT-8025A1/TDKDIPLEXER/6P/SMD/DPX165900DT-8025A1/TDKU10SOT23-6SOT23-6U23XTAL-SMD/3.2X2.5XTAL-SMD/3.2X2.5U24FBGA96/SMD/P0.8/MICRONFBGA96/SMD/P0.8/MICRONU83SOT-143/SMD/G693SOT-143/SMD/G693U450TSOP48/SMDTSOP48/SMDU1257SOT23-6SOT23-6U1260SOT23-5SOT23-5U1263SOT23-6SOT23-6U1264SOT23-6SOT23-6U1302SOT223-3/SMD/P2.3/AX1007SOT223-3/SMD/P2.3/AX1007U1305FILTER/3P/SMD/RFBPF1608060K98Q1CFILTER/3P/SMD/RFBPF1608060K98Q1CU1308MT7975/DRQFN111/SMD/10.5X9MT7975/DRQFN111/SMD/10.5X9U1309MT7915/DR-QFN164/SMD/P0.5/12X12MT7915/DR-QFN164/SMD/P0.5/12X12U1310SOT23-6SOT23-6U1312FILTER/3P/SMD/RFBPF1608060K98Q1CFILTER/3P/SMD/RFBPF1608060K98Q1CU1313QFN6/SMD/P0.35/RTC6608OSPQFN6/SMD/P0.35/RTC6608OSPWCON24COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEXWCON25COAXIAL/SMD/CON/V/I-PEXCOAXIAL/SMD/CON/V/I-PEXWU4CRYS/SMD/D3.2X2.5/E3SB40/HOSONICCRYS/SMD/D3.2X2.5/E3SB40/HOSONIC PCB 来了。赚5个金币
支持WiFi6吗?
