18层经典PCB XILINX XCVC1902-2MSEVSVA2197-ES9780+XCZU4 PCB原理图
B1BATTERY_BAT_TS518_TS621_DUAL_TSTS621E-FL11EBAT_TS518_TS621_DUAL
J5HDR_2X4_HDR_2X4_HDR_2X4HDR_2X4HDR_2X4
J8TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J10TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J11HDR_2X6_HDR_2X6_HDR_2X6HDR_2X6HDR_2X6
J12HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J1612V_RT_ANGLE_MINI_FIT_JACK_CON_39-30-1060CON_MOL_5569_6P
J17TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J26HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J29TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J34HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J36HDR_2X7_87832_1420_87832-142087832-142087832_1420
J37HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J45DDR4_1V2_288P_SMT_SKT_0_SOC_FCI10124677-0001001LFSOC_FCI_DDR4_288_DIMM
J51ASP_184329_01_ASP_184329_01_ASPASP_184329_01ASP_184329_01
J53ASP_184329_01_ASP_184329_01_ASPASP_184329_01ASP_184329_01
J60HDR_2X3_HDR_2X3_HDR_2X3HDR_2X3HDR_2X3
J63TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J64TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J72TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J77TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J112TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J117TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J202HDR_2X7_87832_1420_87832-142087832-142087832_1420
J203HDR_1X2_HDR_1X2_HDR_1X2HDR_1X2HDR_1X2
J204HFJ11_1G01E_L12RL_CON_ETH_HFJ11RJ45CON_ETH_HFJ111G01E_L12RL
J205HDR_2X4_HDR_2X4_HDR_2X4HDR_2X4HDR_2X4
J2065025700893_CON_MOL_10P_50257008CON_MOL_10P_5025700893CON_MOL_10P_5025700893
J207CONN_USB_C_CON_AMP_12401598E4_212401598E4#2ACON_AMP_12401598E4_2A
J209TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J212SEAF-30-05P0-L-08-1-A-K_SAMTEC_SAMTEC_SEAF_08X30SAMTEC_SEAF_30X8
J233FANHDR4_HDR_1X4_LOCK_MOLEX_0470470533000HDR_1X4_LOCK_MOLEX
J234HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J249TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J275TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J288FS1-Z38-20Z6-10_CON_TE_1551920_1551920-2CON_TE_1551920_2
J290TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J291TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J295TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINI
J296TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J297TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J300HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J301HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J3025025700893_CON_MOL_10P_50257008CON_MOL_10P_5025700893CON_MOL_10P_5025700893
J306HDR_1X2_HDR_1X2_HDR_1X2HDR_1X2HDR_1X2
J3072301997-7_RJ45_28P_1O27MM_PTH_RRJ45RJ45_28P_1O27MM_PTH_RA_H27O24_TYCO
J308629104190121_WURTH_6291041901216.29104E+11WURTH_629104190121
J309CONN_JACK_RCA_CUI_RCJ_021_RCAJRCAJACKCUI_RCJ_021
J310HDR_2X9_HDR_MOLEX_87832_1820_08878321820HDR_MOLEX_87832_1820
J313HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J324TP-HOOK_TP_KEY_MINI_BLACK_TP_KEBLACKTP_KEY_MINI
J325HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3
J326HDR_2X4_HDR_2X4_HDR_2X4HDR_2X4HDR_2X4
J328SMA-5PIN_CONN_CARLISE_TM14_0084TM14-0084-00CONN_CARLISE_TM14_0084_00
J329SMA-5PIN_CONN_CARLISE_TM14_0084TM14-0084-00CONN_CARLISE_TM14_0084_00
J330SMA-5PIN_CONN_CARLISE_TM14_0084TM14-0084-00CONN_CARLISE_TM14_0084_00
J331SMA-5PIN_CONN_CARLISE_TM14_0084TM14-0084-00CONN_CARLISE_TM14_0084_00
J332QSFP_PLUS_CAGE_TYCO_1551892_1_11551892_1TYCO_1551892_1
J366DDR4_RDIMM_FENCE_DDR4_RDIMM_FENSL-13621FDDR4_RDIMM_FENCE
J367MECH_ZSFP_PLUS_1X2_CAGE_CAGE_192227728-1CAGE_19P_PTH_RA_1X2_ZSFP_2227728_TE
J368ZSFP_PLUS_CONNECTOR_NO_CAGE_CON2170088-2CON20_08MM_SMT_ZSFP_RA_2170088-2_TE
J369ZSFP_PLUS_CONNECTOR_NO_CAGE_CON2170088-2CON20_08MM_SMT_ZSFP_RA_2170088-2_TE
JP1PCIE_PWR_2X4_ASTRON_6652208-T006652208-T0003T-HASTRON_6652208-T0003T-H_A
L1IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L2IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L3IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L4IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L5IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L6IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L7IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L8IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L18IND_BEADC100X50X55L25N_FERRITE-FERRITE-120BEADC100X50X55L25N
L19IND_BEADC100X50X55L25N_FERRITE-FERRITE-120BEADC100X50X55L25N
L20IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L21IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L22IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L23IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L24IND_IND_COIL_SCL7649_36NH36NHIND_COIL_SCL7649
L31IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L32IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L39IND_IND_WURTH_744355047_470NH470NHIND_WURTH_744355047
L41IND_IND_BOURNS_SRN2512_0.68UH0.68UHIND_BOURNS_SRN2512
L54IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L55IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L56IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L57IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110
L58IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65
L60IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L61IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L62IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L65IND_IND_MUR_2520_470NH470NHIND_MUR_2520
L66IND_IND_MUR_2520_470NH470NHIND_MUR_2520
L67IND_IND_MUR_2520_1.0UH1.0UHIND_MUR_2520
L68IND_IND_MUR_2520_1.0UH1.0UHIND_MUR_2520
L69IND_IND_MUR_2520_1.0UH1.0UHIND_MUR_2520
L71IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L72IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L73IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L74IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L75IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L76IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L77IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3
L78IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L79IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L81IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L82IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L83IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L84IND_IND_SRP4020TA_2.2UH2.2UHIND_SRP4020TA
L87IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L88IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TA
L89IND_IND_SRP4020TA_2.2UH2.2UHIND_SRP4020TA
L90IND_IND_SRP4020TA_2.2UH2.2UHIND_SRP4020TA
L93IND_IND_SRP7050TA_680NH680NHIND_SRP7050TA
L94IND_IND_SRP7050TA_680NH680NHIND_SRP7050TA
L95IND_IND_SRP7050TA_680NH680NHIND_SRP7050TA
L96IND_INDC1050X1020X470_720NH720nHINDC1050X1020X470
L97IND_IND_IHLP2020BZ_ER_4.7UH4.7UHIND_IHLP2020BZ_ER
L98IND_IND_IHLP2020BZ_ER_4.7UH4.7UHIND_IHLP2020BZ_ER
L99IND_IND_IHLP2020BZ_ER_4.7UH4.7UHIND_IHLP2020BZ_ER
L100IND_IND_IHLP2020BZ_ER_4.7UH4.7UHIND_IHLP2020BZ_ER
L101IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L102IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L103IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L108IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L109IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95
L112IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L113IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L114IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L115IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L118IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L127IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L128IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L132IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L133IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L134IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L135IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L136IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L137IND_IND_COIL_1008AF_5.8UH5.8UHIND_COIL_1008AF
L138IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AF
L139IND_IND_COIL_1008AF_6.8UH6.8uHIND_COIL_1008AF
L140IND_IND_COIL_1008AF_6.8UH6.8uHIND_COIL_1008AF
L141IND_IND_COIL_1008AF_6.8UH6.8uHIND_COIL_1008AF
MH11HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
MH12HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
MH14HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
MH23HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
MH26HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125
P2HDMI_DUAL_STACKED_CON_TE_1888811888811-1CON_TE_1888811_1
P3CON_PCI_EXPRESS_X8_PCIE_8LANE_EPCIE_8LANE_EDGEGen4PCIE_8LANE_EDGE_GEN4
Q1FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q2FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q3FET-3PIN_SOT_23_2N7002_2152N7002_215SOT_23
Q4FET-3PIN_SOT_23_2N7002_2152N7002_215SOT_23
Q5FET-3PIN_SOT_23_2N7002_2152N7002_215SOT_23
Q8FET-3PIN_SOT_23_SI2300DSSI2300DSSOT_23
Q13FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q33FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q34FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q35FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q36FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q37FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q38FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
Q39SI7157DP_PWR_56_V02_SI7157DPSI7157DPPWR_56_V02
Q40SI7157DP_PWR_56_V02_SI7157DPSI7157DPPWR_56_V02
Q41RUM001L02T2CL_SOT_723_RUM001L02RUM001L02T2CLSOT_723
Q42NDS336P_SOT_23_FDN336PFDN336PSOT_23
Q43FET-3PIN_SOT_23_NDS331NNDS331NSOT_23
SHIELD1FF-VCK190-1588-SHIELD_FF-VCK190FF-VCK190-1588-SHIELDFF-VCK190-1588-SHIELD
SW1SW_DIP_4_SW_SDA_8P_SDA04H1SBDSDA04H1SBDSW_SDA_8P
SW2PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW3SW_DIP_2_SW_SDA_4P_SDA02H1SBDSDA02H1SBDSW_SDA_4P
SW4PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW5PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW6SW_DIP_4_SW_SDA_8P_SDA04H1SBDSDA04H1SBDSW_SDA_8P
SW7PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW11SW_DIP_4_SW_SDA_8P_SDA04H1SBDSDA04H1SBDSW_SDA_8P
SW12PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW13SW_SLIDE_SPDT_SW_102_1261_EV_111101M2S3AQE2SW_102_1261_EV
SW14PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW15PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
SW16PUSHBUTTON-4_SW_TL3301_G_4P_TL3TL3301EF100QGSW_TL3301_G_4P
U1XCVC1902VSVA2197_C_SOC_2197_092XCVC1902-2MSEVSVA2197-ES9780SOC_2197_092MM_IRON_IDI_HEAD
U2SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U3SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U4SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U5SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U6REF3012_SOT23_3_ISL60002DIH310ZISL60002DIH310Z-TKSOT23_3
U7SN74LVC07A_TSSOP_14_SN74LVC07ASN74LVC07ATSSOP_14
U8LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U10TPS3890_WSON_6_155X155X80_TPS38TPS389001DSERWSON_6_155X155X80
U14SN74CB3Q3253_TSSOP065P620X120_1SN74CB3Q3253PWRTSSOP065P620X120_16
U15SN74CB3Q3253_TSSOP065P620X120_1SN74CB3Q3253PWRTSSOP065P620X120_16
U16SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U17TL1963A_33DCYR_DCY_R_DPSO_G4_TLTL1963A_33DCYRDCY_R_DPSO_G4
U18SN74AVC2T245_QFN40P140X180X55-1SN74AVC2T245QFN40P140X180X55-10
U20FT4232HL_LQFP_64_FT4232HL_LQFP6FT4232HL_LQFP64LQFP_64
U21SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U2293LC56B_SOIC8P127W390_93LC56B93LC56BSOIC8P127W390
U23SN74AVC2T245_QFN40P140X180X55-1SN74AVC2T245QFN40P140X180X55-10
U24MAX9100_SOP095P280X145_5_MAX910MAX9100SOP095P280X145_5
U25K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U26K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U27SBSMC_FILTER_SYFER_SBSM_2220_0.0.33UFFILTER_SYFER_SBSM_2220
U32SI570_SINGLE_SI570_10MHZ-160MHZ10MHZ-160MHZSI570
U33TCA9548A_TSSOP_24_TCA9548APWRTCA9548APWRTSSOP_24
U34M24128-BR_TSSOP65P640X120_8_M24M24128-BRTSSOP65P640X120_8
U35TCA9548A_TSSOP_24_TCA9548APWRTCA9548APWRTSSOP_24
U40TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U41TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U42TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U43SN65DP159RGZ_VQFN05P700X700X100SN65DP159RGZVQFN05P700X700X100_48_408EP
U44TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U45TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U46TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U47TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U48TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U49TPD12S016_UQFN04P210X410X55_24PTPD12S016RKTRUQFN04P210X410X55_24P
U50M24C64_TSSOP65P640X120_8_M24C64M24C64-WTSSOP65P640X120_8
U51TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U52TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U53TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U54TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U55TMDS181IRGZT_VQFN05P700X700X100TMDS181VQFN05P700X700X100_48_408EP
U56TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U57TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U58TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U59TPD1E05U06DPYT_SON_65P60X10X45_TPD1E05U06DPYTSON_65P60X10X45_2
U60TCA9406DCUR_SOIC50P320X90X8_TCATCA9406DCURSOIC50P320X90X8
U61TPD4E05U06DQAR_DQA_R_PSON_N10_TTPD4E05U06DQARDQA_R_PSON_N10
U628T49N241_VFQFPN05P6X6X10_40_4658T49N241VFQFPN05P6X6X10_40_465EP
U63SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U64MAX6643_QSOP16_MAX_E16_1_MAX664MAX6643QSOP16_MAX_E16_1
U65INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U80IR3897_PWR_QFN_IR3897_17_IR3897IR3897PWR_QFN_IR3897_17
U99USB3320_QFN32_QFN05P500X500X100USB3320QFN05P500X500X100_32P_330EP
U100MIC2544A_1YM_SOIC_8_MIC2544A-1YMIC2544A-1YMSOIC_8
U101TPD2EUSB30_DRT_R_PDSO_N3_TPD2EUTPD2EUSB30DRTRDRT_R_PDSO_N3
U103SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6
U104X-SDM-01_IP4856CX25_SHIFTER_ADAX-SDM-01IP4856CX25_SHIFTER_ADAPTER
U105SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6
U107SN74AVC2T244_SON35P145X105X40_SSN74AVC2T244SON35P145X105X40
U109SN74AVC2T244_SON35P145X105X40_SSN74AVC2T244SON35P145X105X40
U110TJA1057_SOIC_8_TJA1057GT/3JTJA1057GT/3JSOIC_8
U122SN74AVC8T245_TSSOP_24_SN74AVC8TSN74AVC8T245TSSOP_24
U123SN74AVC8T245_TSSOP_24_SN74AVC8TSN74AVC8T245TSSOP_24
U124SN74AVC8T245_TSSOP_24_SN74AVC8TSN74AVC8T245TSSOP_24
U125XCZU4EGSFVC784_BGA784C08P28X8_2XCZU4-SFVC784BGA784C08P28X8_230X230X312
U128SN74AVC1T45_SC70_6_SN74AVC1T45SN74AVC1T45SC70_6
U129TPS3890_WSON_6_155X155X80_TPS38TPS389001DSERWSON_6_155X155X80
U130AND_GATE_SINGLE_SC70_5_SN74LVC1SN74LVC1G08SC70_5
U13188E1512_QFN56_QFN05P800X800X100M88E1512QFN05P800X800X100_56_437EP
U132K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U134DP83867ISRGZ_VQFN05P700X700X100DP83867ISRGZVQFN05P700X700X100_48_408EP
U135TPD4E05U06DQAR_DQA_R_PSON_N10_TTPD4E05U06DQARDQA_R_PSON_N10
U142SI5332F_PQFN05P500X500X100_32P_Si5332FD10259-GM1PQFN05P500X500X100_32P_220EP
U143TPS62480_VQFN05P260X310X100_16_TPS62480RNCRVQFN05P260X310X100_16
U144TPS62097_VQFN05P210X210X100_11_TPS62097RWKRVQFN05P210X210X100_11
U145TPS7A83A_PVQFN05P365X365X100_20TPS7A8300ARGRRPVQFN05P365X365X100_20_200EP
U146TPS62097_VQFN05P210X210X100_11_TPS62097RWKRVQFN05P210X210X100_11
U147TPS62097_VQFN05P210X210X100_11_TPS62097RWKRVQFN05P210X210X100_11
U150K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U151K4F8E304HA_R044_WFBGA_200_10X14MT53D512M32D2DS-046WFBGA_200_10X14_5MM
U152IR35215_QFN04P500X500X85_40_370IR35215QFN04P500X500X85_40_370
U153TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U154TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U155TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U156TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U157TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U158TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U159TDA21472_PQFN_TDA21472_41_TDA21TDA21472PQFN_TDA21472_41
U160IRPS5401_IRPS5401MTRPBF_IRPS540IRPS5401IRPS5401MTRPBF
U161INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U162INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U163INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U164INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U165INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U166INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U167IRPS5401_IRPS5401MTRPBF_IRPS540IRPS5401IRPS5401MTRPBF
U168INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U172INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U173INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U174INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U175IRPS5401_IRPS5401MTRPBF_IRPS540IRPS5401IRPS5401MTRPBF
U176INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U177INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U184INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U185IR38164_QFN_IR38164_26_IR38164IR38164QFN_IR38164_26
U186INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U187IR38164_QFN_IR38164_26_IR38164IR38164QFN_IR38164_26
U188INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U189IR38164_QFN_IR38164_26_IR38164IR38164QFN_IR38164_26
U190IR3889_QFN_IR3889_36_IR3889IR3889QFN_IR3889_36
U191IR3889_QFN_IR3889_36_IR3889IR3889QFN_IR3889_36
U192SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570
U198DP83867ISRGZ_VQFN05P700X700X100DP83867ISRGZVQFN05P700X700X100_48_408EP
U199SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6
U200SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U201MAX8869EUE18_TSSOP_16_EP_MAX886MAX8869EUE18+TSSOP_16_EP
U203SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6
U204SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U205SI570_SI570_10_TO_810MHZ10_TO_810MHZSI570
U206SI53340_QFN16_SI_3X3MM_SI53340-SI53340-B-GMQFN16_SI_3X3MM
U210PCA9306DCTR_DCT_R_PDSO_G8_PCA93PCA9306DCTRDCT_R_PDSO_G8
U211PCA9306DCTR_DCT_R_PDSO_G8_PCA93PCA9306DCTRDCT_R_PDSO_G8
U212PCA9306DCTR_DCT_R_PDSO_G8_PCA93PCA9306DCTRDCT_R_PDSO_G8
U213PCA9306DCTR_DCT_R_PDSO_G8_PCA93PCA9306DCTRDCT_R_PDSO_G8
U214TCA9548A_TSSOP_24_TCA9548APWRTCA9548APWRTSSOP_24
U216SN74AVC1T45_SC70_6_SN74AVC1T45SN74AVC1T45SC70_6
U217U7836LF_OSC_RAKON_U7836LF_38.4M38.4MHZOSC_RAKON_U7836LF
U218TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20
U2198A34001_CABGA_144P80_(S1+S2+S3)8A34001CABGA_144P80
U220TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20
U221AND_GATE_SINGLE_SC70_5_SN74LVC1SN74LVC1G08SC70_5
U22224LC64_SOIC127P600X175_8_24FC1024FC1025T-I/SNSOIC127P600X175_8
U223LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U225LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U226LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U227LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U228LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U229LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U230LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U231LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U232LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U233TCA6416A_TSSOP_24_TCA6416ATCA6416ATSSOP_24
U234INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10
U235SN74LVC07A_TSSOP_14_SN74LVC07ASN74LVC07ATSSOP_14
U236LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U238SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U239SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U240NC7SZ66_SC70_5_SC70_5_NC7SZ66P5NC7SZ66P5XSC70_5
U241NC7SZ66_SC70_5_SC70_5_NC7SZ66P5NC7SZ66P5XSC70_5
U242SN74AVC4T245_QFN_RSV_16_SN74AVCSN74AVC4T245QFN_RSV_16
U243LP38798_WSON05PX400X400X100_12_LP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300
U244SIT5358AN-FR-33E0_OSC_SIT5358_554.000000MHzOSC_SIT5358_500X320X095
U245ICS85411AMLF_SOIC_8_ICS85411AMLICS85411AMLFSOIC_8
X1FC-13A_XTAL_XTAL_FC13A_32.768KH32.768KHZXTAL_FC13A
X2TPD4S012_DRY_6_SON_TPD4S012TPD4S012DRY_6_SON
X3FA238_XTAL_EPSON_FA238_12.00MHZ12.00MHZXTAL_EPSON_FA238
X5XTAL_40MHZ_XTAL4P_320X250X60_4040.00MHZXTAL4P_320X250X60
X7MA506_XTAL_MA506_25.00MHZ25.00MHZXTAL_MA506
X8CRYS_2_XTAL_HCM49_24.000MHZ24.000MHZXTAL_HCM49
X9ABM8_XTAL_XTAL_ABM8_25.00MHZ25.00MHZXTAL_ABM8
X10ABM8_XTAL_XTAL_ABM8_25.00MHZ25.00MHZXTAL_ABM8
文件解压出来差不多 80M 。 回复可见
**** Hidden Message *****
学习学习了 学习了
