发一个PADS AD ALLEGRO 通用 3D元件
有以下3D 元件模型。需要的自己下载。
1101M2S3ABE2.STEP
3225-1.STEP
35ZLH1000MEFC12_5X20.STEP
3DC15-1000J.STEP
5MM-LED-RG.STEP
750313102.STEP
Audio jack 4.step
BU2032SM-HD-G(CR2032 Battery Holder).STEP
C0402-1.STEP
C0603 (1608)_CH.STEP
C0805(2012M) Cap.STEP
C1206 (3216)_EH.STEP
C1210 (3225)_FJ.STEP
C1812 (4532)_GC.STEP
C1825 (4564)_HG.STEP
C2225 (5664)_KD.STEP
C3216-18_A_case.STEP
C3216_1206.STEP
C3528.STEP
C6032-28_y.STEP
C7343-20.STEP
C7343-31.STEP
C7343-40.STEP
C7343-43.STEP
C7343.STEP
Cap-EL(10x16-5).STEP
Cap-EL(10x20-5).STEP
Cap-EL(10x25-5).STEP
Cap-EL(10x30-5)T.STEP
Cap-EL(12_5x20-5)T.STEP
Cap-EL(12_5x25-5).STEP
Cap-EL(12_5x25-5)T.STEP
Cap-EL(13x25-5).STEP
Cap-EL(16x26-7_5).STEP
Cap-EL(16x31_5-7_5)T.STEP
Cap-EL(18x26-7_5)T.STEP
Cap-EL(18x36-7_5)T.STEP
Cap-EL(18x40-7_5)T.STEP
Cap-EL(8x12-3_5)T.STEP
CAP-EL_K21.STEP
CAP120X100M.step
CAPF.STEP
CAPG.STEP
CAPML200 (2_5x6_6).STEP
CDPH4D19FNP-100MC.step
CDPH4D19FNP-6R8MC.step
CDRH3D18.STEP
CDRH4D18.STEP
cdrh4d18c.STEP
CR1005-0402.STEP
CR1608-0603.STEP
CR2012-0805.STEP
CR3216-1206.STEP
D0805.STEP
DIOD SMD 10BF10.STEP
DIOD SMD CILINDRIC SMALL.STEP
DIODE_SOD-923.STEP
DIP4-7_62-2_54.STEP
DO-214AA SMB.STEP
DO-214AB SMC.STEP
DO-214AC SMA.STEP
DPAK-1.step
DPAK-5-1.step
DPAK_TO-252AA.step
DT-26-1.STEP
DT-26.STEP
E-Switch - TL3330AF130QG (Tact Switch, SMD).step
EL817-SOP.step
FILESLIST111.TXT
FUSER_nanoSMD.STEP
GREENLED.STEP
HC-49-1.step
HC-49.step
HC-49S.step
HC-49SM-1.step
HC-49_LT_THT.step
HC-49_LT_THT_16MHz.step
HC49-SMD.STEP
HC49.step
HC49U-2.step
HC49US.STEP
HC49_cystal.STEP
HC49_SMD.STEP
HC49_US-SM.STEP
Header_Male_2Pin.STEP
Header_Male_40Pin.STEP
Header_Male_RA_Low_3Pin.STEP
Header_Male_RA_Low_40Pin.STEP
Header_Male_RA_Low_4Pin.STEP
Header_Male_RA_Low_5Pin.STEP
Header_Male_RA_Low_6Pin.STEP
Header_Male_RA_Low_7Pin.STEP
Header_Male_RA_Low_8Pin.STEP
Header_Male_RA_Low_9Pin.STEP
IND_0805.STEP
KCSA56-104.step
LED 0805.STEP
LED 1206 BLUE.STEP
LED 1206.STEP
LED DIP 3MM.STEP
LED SMD0603.STEP
LED SMD0805.STEP
LED-0402.STEP
LED0603(G).STEP
LED0805(B).STEP
LED0805(G).STEP
LED0805(R).STEP
LED0805(Y).STEP
LED1206G.STEP
LED1206R.STEP
LED1206Y.STEP
LED_0603_B.STEP
LED_0603_G.STEP
LED_0603_R.STEP
LED_0603_Y.STEP
LED_SMLK34.step
melf-2.STEP
MEM2055-00-190-01-A_revG.STEP
MiniMelf-2.STEP
Molex - 15-91-0100 (Pin Header 2_54mm 10 Pin).STEP
PC817_Gullwing.STEP
PG-SOT223.STEP
QFN 24 4x4.step
QSOP16-1.step
R1206.step
REDLED.STEP
RES0201.STEP
RES0402-2.STEP
RES0603-3.STEP
RES0805-2.STEP
RES1206-2.STEP
RESC3216X06N.STEP
RESISTOR 2512.STEP
RESISTOR 7_62MM DIP.STEP
RES_OARS1-R003.STEP
RS-101(RCA-107).STEP
SC-88A.step
SC70-3.step
SDIP.STEP
SF56S006V4BR2000.STEP
SIM5060-6-0-26-01-A.STEP
SIMID 1210-H.STEP
SM-Cap_0201 (0603)_AB.STEP
SMA(T)-21 SMD.STEP
SMD 8x10.step
SMT DO3316.STEP
SOD-323.STEP
SOD-323F.STEP
SOD-723.STEP
SOD-923.STEP
SOD123.STEP
SOD523.STEP
sod80-1.STEP
SOD80-3.STEP
SOD80C-1.STEP
SOIC-14.STEP
SOIC-16-1.STEP
SOIC-7.STEP
SOP-6.step
SOP50P310X110-8N.step
SOT 143.STEP
SOT-223-1.STEP
SOT-223-6.STEP
SOT-223.STEP
SOT-23-5.STEP
SOT-23-5L.step
sot-23-6-5.STEP
SOT-23-6.STEP
SOT-23-8-Thin.step
SOT-23.STEP
SOT-323-5L.step
SOT-343N.step
SOT-523.step
sot-553.STEP
SOT-563.step
SOT-723.step
SOT-82.STEP
SOT-89-5.step
SOT-89.STEP
SOT-923f.step
SOT143-1.STEP
SOT143_1.STEP
SOT223-3.STEP
SOT223-5.STEP
SOT23 5.STEP
SOT23-6-1.STEP
SOT233.STEP
SOT238.step
SOT323 (SC70-3)-1.STEP
SOT343-1.step
SOT343F.step
SOT343N.STEP
SOT353-1-1.step
SOT353-1.step
SOT353.step
SOT50P160X60-5.STEP
SOT50P160X60-6.STEP
SOT89-5-1.step
SOT89-5.step
SOT89.STEP
SOT895-A-PKG.STEP
SRN6045 Series.STEP
SS22F07G7-G.STEP
SW3dPS-SOT363.STEP
switch 6x6x9_5mm.STEP
TACT SMD 6X6.STEP
TCLT100-SOP4L.step
TI_LPG0002A_TO-92_Temp_Sensor.step
TO-220AB-7 SMD.step
TO-252-3.step
TO-252.step
TO-255AA-1.step
TO-92-6.step
TO220AB.STEP
TO252-2.STEP
TO252AA.step
tsot-23-5.STEP
TSOT-23-6(S6).STEP
TSOT-23-8-1.STEP
TSOT-23-8.STEP
TSOT-23.STEP
TSOT23-5.STEP
UFL-R-SMD.STEP
Varistor_20mm.STEP
VL-3032 HF5N.STEP
