MT8127原理图分享MT6611+AM29PL160C+BGU7005+MT8127E1
NamePCB DecalPart TypeValueANT9ECT818000157ECT818000071_2ECT8180000157/NCBEAD412BEAD/SMD/0603BEADBLM18BD252SN1CON1001MM8430-2600BCAR_KIT_/_MM8430-2610BMM8430-2610BD4RB551V-30(UMD2)DIODE_SCHOTTKY_6RB551V-30D8ESD0603/SMDDIODE_DIACESD0603/SMD/NCD12SOT23BAT54SBAT54SD135819DIODE_SCHOTTKY_2B5819WD14SOT23BAT54SBAT54SD300RB551V-30(UMD2)DIODE_SCHOTTKY_6BAT54WSD303DIODE/SMD/MMSZ5221BDIODE/ZENERMMSZ5231BT1GD401SOD923/SMDPG05BSESC_0ESD9L5.0ST5GD403D/SMD/UMD2DIODE_SCHOTTKY_0UDZV 5.6BD1602SOD-323/SMD/RB551V-30DIODE_SCHOTTKY_6RB551V-30EMI804FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FRFB1WCM2012-HDMIINDUCTOR-COMSDCW2012-2-900J1MS110-C10B-C13-ATF_SD_SOCKET_0TF_SD_SOCKETJ2BL125-39RL-TA3G21S45A00E_339PINJ8BL509-40G31-DWCLP097X02_080302-0401*3K3/NCJ905C-6PBSCON6CON6/NCJ1005C-24PBSOV2659_180302-0241*3K3J1105C-6PBSCON680302-0061*3K3J13BL509-40G31-DWCLP097X02_080302-0401*3K3J230205C-30PBS0.5P-30PBS80302-0301*3K3L4L/IND/SMD/LVS252010-2R2INDUCTOR_2VLS252010T-4R7M (4.7uH)L214BEAD/SMD/0402INDUCTOR_2BLM15AG601SN1L305L/IND/SMD/2520INDUCTOR_2VLS252010ET-R68NL402BEAD/SMD/0603BEADLQW18ANR10G00L802L/IND/SMD/LVS-S3016INDUCTOR_1LQH44PN4R7MPOL(4.7uH)L1601L/IND/SMD/LVS252010-2R2INDUCTOR_2LQH2HPN4R7MG0L(4.7uH)Q801SOT2340852_43904Q802SOT23P_DGS_1SI2305Q805SOT2340852_43904/NCQ1601SOT23MOSFET_P_SMD_2MI2301Q1602SOT23TRANSISTOR_NPN_SMD(B-C-E)_0LMBT3904LT1GU1SOT23/5P/SMDR1172X_1SY8089AACU2MT6627-NS/MQFN40/SMD/P0.4/5X5MT6611_SMD_WLCSP-61_0MT6627_IPD_QFN40U3SOT23/5P/SMDR1172X_1SY8088AAC/NCU5FBGA96/SMD/P0.8/10X14/DDR3L/16BIC_DDR3_X16_FBGA-96IC DDR3 x16 FBGA-96U6FBGA96/SMD/P0.8/10X14/DDR3L/16BIC_DDR3_X16_FBGA-96IC DDR3 x16 FBGA-96U11AW5306AUR3852-64TQFP_1AW5306U12SOT23-6/SMDAPL5151_0SY7200AU13SOT23-6/SMDSY7208_2SY7208U22TSOP48/SMDAM29PL160C_3NAND08GW3B2CN6E/NCU25SLP2510P8DS8008_9RClamp0524J/ESDA6V8UDU90WCSP9LM4990_0AW8010AU201MT8127/TFBGA393/P0.5/B0.27/12.1X12.6MT8127E1_DDR316_0916_RMNCMT8127U301SOT-6FDG6303_2STT818BU302MT6323L/TFBGA158/P0.5/B0.27/7.6X7.6MT6323_E1_4MT6323LU3032-1L1B/SMD/SSM3K35MFVMOSFET_N_2SSM3K35MFVU304DFN8L-3X2-H05FDG6303_3PPT8N30E2U406SOT23-6/SMDTEA1206T_0Micro Power-SGM3110U502BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA169_BALL_EMMCSamsung KLM2G1HE3F-B001U911FILTER_EXC24CE_1FILTER_EXC24CE_2Filter_EXC24CEU1005TCXO/SMD/2.5X2.0/IT2205BETCXO_RAKON_SMD_4P_3MT6627 QVL TCXO/NCU1006SAW/SMD/1.05X1.35SAFEB1G57KA0F00SAFEB1G57KE0F00U1010XSON6-1X1.45GPS-LNAGPS-LNA/BGU7005U1601SOT23-6/SMDSY7208_2SY7208U1602WLCSP8/SMD/P0.4/B0.25/AK09911_ADXL345_4AK0991U1604LGA12/SMD/P0.5/BMA250EADXL345_5BMA250EU1609QFN24/SMD/P0.4/MPU-6880_74ALVC74PW_2MPU-6880U1901DSBGA4/SMD/P0.4/B0.25/TMP103TMP103AYFFTTMP103AYFFTU1902WLCSP6/SMD/P0.4/B0.23/NB3L03TMP103AYFFT_0NB3L03/NCVBAT1TP/SMD/D0.6TEST_POINT_DIP0.6TEST POINTX302CRYS/SMD/MS3V-T1RCRYSTAL_132K (MS3V-T1R)X601TCXO/SMD/2.5X2.0/IT2205BETCXO_RAKON_SMD_4P_3MT6627 QVL TCXO 加油
