Intel Xeon FCBGA1440 十六层至强服务器主板PCB 文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEAP1AP11-1469492-9KEY_1469942AP2AP21-1469492-9KEY_1469942AP3AP31-1469492-9KEY_1469942CN1CN1BH1X3HS-1.25PITCH_WHITE53261_03CPU1CPU1SKL_HBGA1440D1D1S-MBR230LSFT1G_SOD123FLDIODE_SOD123D2D2S-RB551V-30_SOD323DIODE_SOD323D3D3TPD4E02B04DQARDFN10_0D5_2D5X1D0D4D4TPD4E02B04DQARDFN10_0D5_2D5X1D0D5D5TPD4E02B04DQARDFN10_0D5_2D5X1D0D6D6TPD4E02B04DQARDFN10_0D5_2D5X1D0D7D7MMBD4148_NL_100VSOT23_1DD8D8MMBD4148_NL_100VSOT23_1DD9D9RB521S30DIODE_SOD523D10D10SCS521S-CSDIO_SOD523_SCS521S_1D11D11LBAT54ALT1GSOT23_3P_U1D12D12LBAT54ALT1GSOT23_3P_U1D13D13SCS521S-CSDIO_SOD523_SCS521S_1D15D15LBAT54ALT1GSOT23_3P_U1D16D16BAV99,215SOT_23AD17D17SCS521S-CSDIO_SOD523_SCS521S_1D18D18RB521S30DIODE_SOD523D19D19LBAT54CLT1GSOT23_3D20D20LMBR130T1GSOD123D21D21S-RB551V-30_SOD323DIODE_SOD323DA1DA1LBAT54CLT1GSOT23_3P_U1DA2DA21SS355_SOD323DIODE_SOD323DA3DA3LBAT54CLT1GSOT23_3P_U1DIMM1DIMM1DDR4SODIMM-260PS_BLACK-HF-31DDR4_SODIMM260P_H9_2_4EC1EC110pF_50VC0402ESD1ESD1ESD-AOZ8231ADI-05DFN10X06ESD2ESD2ESD-AOZ8829DI-03-HFESD_2_5X1ESD3ESD3ESD-AOZ8829DI-03-HFESD_2_5X1F1F1MINISMDC110F-16-2SPLSW_MINIH1H1MINIPCI-E52PIN H=4.0STANDOFF_C52MM_D34MM-PASDH2H2MINIPCI-E52PIN H=4.0STANDOFF_C52MM_D34MM-PASDH7H7HOLEHOLE_C7D2R8H8H8HOLEHOLE_C200D112H10H10HOLEHOLE_C200D112H12H12HOLEHOLE_C7D2R8H13H13HOLEHOLE_C7D2R8H14H14HOLEHOLE_C7D2R8H16H16HOLEHOLE_C200D112H17H17HOLEHOLE_C200D112H18H18HOLEHOLE_C200D112H25H25HOLEHOLE_C200D112JLPC1JLPC1H2X5SF-1.27PITCH_BLACKHEADSMD2X5_1_27MM_3HJNC1JNC1NC_93519_2NC_93519_2JNC2JNC2NC_93519_2NC_93519_2L1L1180L1500mL0603L11L11ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL12L12DLP11TB800UL2LSCKE_TDK_ACM2012-900-2PL13L13DLP11TB800UL2LSCKE_TDK_ACM2012-900-2PL14L14ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL15L15DLP11TB800UL2LSCKE_TDK_ACM2012-900-2PL16L16DLP11TB800UL2LSCKE_TDK_ACM2012-900-2PL17L17ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL18L18DLP11TB800UL2LSCKE_TDK_ACM2012-900-2PL19L19DLP11TB800UL2LSCKE_TDK_ACM2012-900-2PL20L20ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL21L21DLP11TB800UL2LSCKE_TDK_ACM2012-900-2PL22L22DLP11TB800UL2LSCKE_TDK_ACM2012-900-2PL23L23180L1500mL0603L24L24ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL25L25ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL26L26ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL27L27ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL28L28ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL29L29ACM2012H-900-2P-T05SCKE_TDK_ACM2012-900-2PL30L30CH-1.0u22A10mS-RHCHK_IHLP2525CZ01L31L3180_100MHz_6AL080504L46L461.0uH15A 7.4mRLS2_6530LAN1LAN1RJA5-08F1-KNR1-0ARJ45_JM3711LD1LD1TPD4E02B04DQARDFN10_0D5_2D5X1D0LD3LD3TPD4E02B04DQARDFN10_0D5_2D5X1D0LD4LD4TPD4E02B04DQARDFN10_0D5_2D5X1D0LD5LD5TPD4E02B04DQARDFN10_0D5_2D5X1D0LD7LD7TPD4E02B04DQARDFN10_0D5_2D5X1D0LD9LD9TPD4E02B04DQARDFN10_0D5_2D5X1D0LD10LD10TPD4E02B04DQARDFN10_0D5_2D5X1D0LED1LED1LEDS-L-S110KGCTSLED_PARALIGHT_L-S110XXLED2LED2LEDS-L-S110KYCT-FX-TSLED_PARALIGHT_L-S110XXOSC1OSC1OSC-48MHZ25_S-RHOSC4P_2_2X2_5MMOSC2OSC248MHz_15pFSCRY4_7X5X1D4OSC3OSC3OSC-25M-30-3225SOSC4_3D2X2D5X1P0P01410189-3DCNN_TYCO_1410189PCH1PCH1SKL_PCH_HBGA837PCHOKE1PCHOKE1CH-1.0u22A10mS-RHCHK_IHLP2525CZ01PCI1PCI11000PF_50VC0402PCP1PCP1NC_93519_2NC_93519_2PL5PL5CH-0.22u68A0.875mSCHK_S2_11_3X10PL6PL6CH-1u11A12.6mS-HFCHK_S2_5_49X5_18PL7PL72.2uH8A 15mRLS2_6530PL8PL82.2uH_12ASCKE_CYNTEC_PCMC104T-2R2MNPL9PL92.2uH_12ASCKE_CYNTEC_PCMC104T-2R2MNPL10PL102.2uH10A 15mRLS2_6530PL11PL111.0uH15A 7.4mRLS2_6530PL70PL700.1uH_32.5ASIND_GOTREND_GSTC063PPQ1PQ1L2N7002LT1GSOT_23APQ2PQ2FDMF3035_PQFN31-HFPQFN31PQ3PQ3FDMF3035_PQFN31-HFPQFN31PQ4PQ4FDMF3035_PQFN31-HFPQFN31PQ5PQ5CSD87350Q5DSON8_3PQ6PQ6FDMF3035_PQFN31-HFPQFN31PQ7PQ7FDMF3035_PQFN31-HFPQFN31PQ8PQ8NN-FDMS3604S_POWER56-8-RHPOWER56_S8PQ9PQ9NN-FDMS3604S_POWER56-8-RHPOWER56_S8PQ10PQ10AON6414ALDFN5_4D98X6D02X1D17PQ11PQ11AON6414ALDFN5_4D98X6D02X1D17PQ12PQ12AON6414ALDFN5_4D98X6D02X1D17PQ13PQ13AON6414ALDFN5_4D98X6D02X1D17PQ14PQ14AON6354DFN5_4D98X6D02X1D17PRI1PRI12.2R_3FR0603PRT1PRT1470KRT3%0402-HFR0402PS1PS10805L075WRPOLYSW2_P2_2PS2PS20805L075WRPOLYSW2_P2_2PSP1PSP1R0402_SHT_PADR0402_SHT_PAD_NPMPU1PU1ISL95808IRZ-TTDFN8_TSMD59X29PU2PU2NB681GD-Z_QFN13-HFQFN13_2X3PU3PU3TPS51218DSCRSON10PU4PU4TPS51216RUKRWQFN20_TSMDQ63PU5PU5TPS53319DQPRDFN22_6X5X1D5_P5D48X3D24PU6PU6TPS53319DQPRDFN22_6X5X1D5_P5D48X3D24PU7PU7TPS51218DSCRSON10Q1Q1L2N7002LT1GSOT_23AQ2Q2L2N7002LT1GSOT_23AQ3Q3L2N7002LT1GSOT_23AQ4Q4L2N7002LT1GSOT_23AQ5Q5L2N7002LT1GSOT_23AQ6Q6MMBT3906LT1GSOT23EBC_TQ7Q7MMBT3906LT1GSOT23EBC_TQ8Q8BSS138LT1GSOT23SGD_TQ9Q9L2N7002LT1GSOT_23AQ10Q10L2N7002LT1GSOT_23AQ11Q11L2N7002LT1GSOT_23AQ12Q12L2N7002LT1GSOT_23AQ13Q13L2N7002LT1GSOT_23AQ14Q14MMBT3904LT1GSOT23EBC_TQ15Q15MMBT3904LT1GSOT23EBC_TQ16Q16L2N7002LT1GSOT_23AQ17Q17L2N7002LT1GSOT_23AQ18Q18L2N7002LT1GSOT_23AQ19Q19L2N7002LT1GSOT_23AQ20Q20L2N7002LT1GSOT_23AQ21Q21L2N7002LT1GSOT_23AQ22Q22L2N7002LT1GSOT_23AQ23Q23L2N7002DW1T1GSOT_363Q24Q24L2N7002LT1GSOT_23AQ25Q25L2N7002LT1GSOT_23AQ26Q26MMBT3904LT1GSOT23EBC_TQ27Q27MMBT3904LT1GSOT23EBC_TQ28Q28L2N7002DW1T1GSOT_363Q29Q29L2N7002LT1GSOT_23AQ30Q30L2N7002LT1GSOT_23AQ31Q31L2N7002LT1GSOT_23AQ32Q32LMBT3904LT1GSOT23_BJTQ33Q33LMBT3904LT1GSOT23_BJTQ34Q34LMBT3904LT1GSOT23_BJTQ35Q35L2N7002LT1GSOT_23AQ36Q36L2N7002LT1GSOT_23AQ37Q37LMBT3904LT1GSOT23_BJTQ38Q38IRFH8318TRPBFDFN5_4D98X6D02X1D17Q39Q39IRFH8318TRPBFDFN5_4D98X6D02X1D17Q53Q53L2N7002LT1GSOT_23AQ54Q54LMBT3904LT1GSOT23_BJTQ67Q67L2N7002LT1GSOT_23AQ69Q69SI7461DPDFN5_4D98X6D02X1D17Q70Q70L2N7002LT1GSOT_23AQ71Q71L2N7002DW1T1GSOT_363QA1QA1L2N7002DW1T1GSOT_363QA2QA2BSS138LT1GSOT23SGD_TRT1RT110KRTR0402RT2RT2470KRT3%0402-HFR0402RT3RT310KRTR0402RT4RT410KRTR0402SATA1SATA1TFM-107-21-L-D-ATFM-107-X3-XXX-D-ASATA2SATA2MINIPCIE-H6D75mmMINI_PCIE_40MM_C52_D34SP1SP1NC_93519_2NC_93519_2SW1SW1RESET-SMD-5PSSW_PT-036-B2FSW2SW2RESET-SMD-5PSSW_PT-036-B2FSW3SW3RESET-SMD-5PSSW_PT-036-B2FT1T1TPTESTPIN24T2T2TPTESTPIN24T3T3TPTESTPIN24T4T4TPTESTPIN24T5T5TPTESTPIN24TCX1TCX1220uF_10VC_D_7343TCX2TCX2220uF_10VC_D_7343TCX3TCX3220uF_10VC_D_7343TCX4TCX4220uF_10VC_D_7343TF1TF1GSC-2401T-RTRAN_24PIN_1MMTF2TF2GSC-2401T-RTRAN_24PIN_1MMTF3TF3GSC-2401T-RTRAN_24PIN_1MMTF4TF4GSC-2401T-RTRAN_24PIN_1MMTF5TF5GSC-2401T-RTRAN_24PIN_1MMTPJNC5TPJNC5TPTESTPIN24TZRB1TZRB1LMBR130T1GSOD123TZRB2TZRB2LMBR130T1GSOD123U1-1U1-1MT40A2G8JC-062EIT:EBGA78_8X12U1-2U1-2MT40A2G8JC-062EIT:EBGA78_8X12U1-3U1-3MT40A2G8JC-062EIT:EBGA78_8X12U1-4U1-4MT40A2G8JC-062EIT:EBGA78_8X12U1-5U1-5MT40A2G8JC-062EIT:EBGA78_8X12U1-6U1-6MT40A2G8JC-062EIT:EBGA78_8X12U1-7U1-7MT40A2G8JC-062EIT:EBGA78_8X12U1-8U1-8MT40A2G8JC-062EIT:EBGA78_8X12U1U1553MILFSOIC8U2U2AT24C02D-SSHM-TSOP8_1D27X6X1D75U3U3CH7517A-BFIQFN40_TSMDQ138AU4U4APL5930KAI-TRGSOP8P_APL5912U5U574AHCT1G125SOT353_5PU6U674AHCT1G125SOT353_5PU7U7CH7517A-BFIQFN40_TSMDQ138AU8U8APL5930KAI-TRGSOP8P_APL5912U9U974AHCT1G125SOT353_5PU10U1074AHCT1G125SOT353_5PU11U11SRV05-4.TCTSOT23-6_1D45_SRV05-4U12U12SRV05-4.TCTSOT23-6_1D45_SRV05-4U13U13TPS2561DRCRLCC10_P5MM_65X98_4FINGERDIE_40HU14U14TPS2561DRCRLCC10_P5MM_65X98_4FINGERDIE_40HU15U15ALC898-GRLQFP48U16U16F81866D-RHPQFP128AU17U17PTN3360DBS-RHQFN48P_7X7MMAU18U18TPS2561DRCRLCC10_P5MM_65X98_4FINGERDIE_40HU19U19TPS2561DRCRLCC10_P5MM_65X98_4FINGERDIE_40HU20U20TPS2561DRCRLCC10_P5MM_65X98_4FINGERDIE_40HU21U21SP339EER1-LQFN40_6X6X1_P4D65U22U22SP339EER1-LQFN40_6X6X1_P4D65U23U23SP339EER1-LQFN40_6X6X1_P4D65U24U24SP339EER1-LQFN40_6X6X1_P4D65U25U25SP339EER1-LQFN40_6X6X1_P4D65U26U26SN74AHC1G08DCKRSC70_5U27U27SN74LVC2G14DCK3SC70_6U28U28SN74AUP1G07DCKRSC70_5U29U29SN74LVC2G14DCK3SC70_6U30U30NC7S08P5XSC70_5U32U32NC7S08P5XSC70_5U33U33SN74AHC1G08DBVSOT23-5U34U34SN74AHC1G08DBVSOT23-5U35U35SN74AHC1G08DBVSOT23-5U36U36SN74AHC1G08DBVSOT23-5U37U37SN74AHC1G08DBVSOT23-5U38U38SN74AHC1G08DBVSOT23-5U39U39SN74LVC2G14DCK3SC70_6U40U40MAX809RTRG_SOT23-3-RHSOT23_3P_U1U41U41NCP45520IMNTWG-HDFN8_2X2_T39X67U42U42NC7S08P5XSC70_5U43U43NCP45520IMNTWG-HDFN8_2X2_T39X67U44U44SN74LVC1G08DCKRSC70_5U45U45ISL95855IRTZVQFN48_SMDQ171U46U46SN74AUP1G07DCKRSC70_5U47U47TPS54426PWPRHTSSOP14SPQU48U48EN5337QI-TQFN38_7X4X1D85U49U49LTC4245IUHFQFN_39U50U50LTC4365IDDB#TRMDFN8_3X2XD8U51U51SC1565IS-2.5TRTSOP8_1D27X6X1D75U52U52AST2400A1-GP408PIN_TFBGAU53U53ADC128D818CIMTSOP16_D65X6D4X1D1U54U54LM73CIMK-0/NOPBSOT23_6U55U55LM73CIMK-0/NOPBSOT23_6U56U56LM73CIMK-0/NOPBSOT23_6U57U57LM73CIMK-0/NOPBSOT23_6U58U58LM73CIMK-0/NOPBSOT23_6U59U59MACRONIX_MX25L12845EMI-10G16_SOPU60U60W25Q16JVSSIQSOP8_1D27X7D9X2D16U61U61ADM3202ARUZ-REEL7TSSOP16_0R65_5X6R4U62U62IMP811REUS-TE-004-SOT143U63U63MT41K256M16TW-107IT:P96BALL_FBGAU64U64EN5337QI-TQFN38_7X4X1D85U65U65EN5337QI-TQFN38_7X4X1D85U66U66W25Q16JVSSIQSOP8_1D27X7D9X2D16U67U67GSC-2401T-RTRAN_24PIN_1MMU68U68NH82580EBBGA256_1_17X17X2D01U69U69OSC-50MSOSC4_3D2X2D5X1U71U71AT25256B-SSHL-TSOP8_1D27X6X1D75U72U72TPS62130RGTRPVQFN16_PT05-TPS53321U73U73TPS3803-01DCKRDCK5_0R65_2X2R1U74U74TSI721A1-16GILYFCBGA143U75U75TSI721A1-16GILYFCBGA143U76U7674LVC1G125GWSOT23_5U77U77AT24C64B-10UT-18SO8U78U78SC1565IS-2.5TRTSOP8_1D27X6X1D75U79U79SC1565IS-2.5TRTSOP8_1D27X6X1D75U80U80841N254BKILFVFQFN32U81U8174LVC1G125GWSOT23_5U82U82AT24C64B-10UT-18SO8U83U83SC1565IS-2.5TRTSOP8_1D27X6X1D75U84U84IR3842MTRPBFQFN15_5X6X1_1U85U85LTC4300A-1SOP8_D65X4D9X1D2U86U86SN65MLVD201SOP8_1D27X6X1D75U87U87LTC4300A-1SOP8_D65X4D9X1D2U88U88SN74LVC1G125DBVTSOT23_5U89U89SN74LVC1G125DBVTSOT23_5U90U90SRV05-4.TCTSOT23-6_1D45_SRV05-4U91U91SRV05-4.TCTSOT23-6_1D45_SRV05-4U92U92841N254BKILFVFQFN32U93U93SN74AHC1G08DBVSOT23-5U94U94NB3N5573NB3N5573TSSOP16UA1UA1RTL8211E-VB-CGQFN48_0R4_6X6_P4R4UART1UART11x2P_2MM1X2_2UL1UL1WGI210ITQFN64_TSMDQ142UL2UL2ICS557G08TSSOP16AUR1UR1ICS557G08TSSOP16AUSB2_1USB2_1USB5-A4F1-KNA0-02USB_L_A4FUSB2_2USB2_2USB5-A4F1-KNA0-02USB_L_A4FUSB1USB1UEA1112C-4ET2-7HDCNN_FOXCONN_UEA1112C-4ET2_7HVGA1VGA1DSUB-VGAF_BLUE-RH-2CON_DB15VPFB1VPFB1120ohm@100MHz,5000mAFB0805VPFB3VPFB3120ohm@100MHz,5000mAFB0805VPFB4VPFB4120ohm@100MHz,5000mAFB0805X1X125.000MHzY_4P_SMD3225XT1XT1XTAL-25M-20P-30PPM-5032SCRY4_5X3D2X1XT2XT2XTAL-25M-20P-30PPM-5032SCRY4_5X3D2X1Y1Y132.768KHZ12.5p_S-25OSC_3_2X1_5_1Y2Y224MHZ16p_SXTL4P_3_2X2_5Y3Y327MHz_18pFXTL4P_3_2X2_5Y4Y427MHz_18pFXTL4P_3_2X2_5Y5Y5XTAL-25M-20P-30PPM-5032SOSC4_5X3D2X1Y6Y625.000MHzY_4P_SMD3225 PCB文件。赚几个金币。
非常感谢楼主大神分享 学习,谢谢分享! 谢谢分享! NIUYA 非常感谢楼主
