RK3328 TVBOX 安卓智能电视盒PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT2700ANT_1P2G_ANT_JACK_ANT_JACKANT_JACKANT_JACKANT2702ANT_1P2G_ANT_JACK_ANT_JACKANT_JACKANT_JACKCM700CM_C_MTM-C_100UF/25V100uF/25VMTM-CCM701CM_C_MTM-B_100UF/10V100uF/10VMTM-BCM2500CM_C_MTM-B_100UF/10V100uF/10VMTM-BCM2501CM_C_MTM-B_100UF/10V100uF/10VMTM-BD705DIODEZENER1_SOD_323_ESD5621W-2ESD5621W-2/TRSOD_323D900DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402D2600DIODE_0_SOD_123_B5819WB5819WSOD_123D2800DIODEBI_DIR TRIG_ESD0402_ESD_1ESD5471XESD0402D2801DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402D2900DIODEDOUBLE F_SOT_23_BAT54SBAT54SSOT_23D2901DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402D2902DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402D2903DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402D3000DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D3001DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D3002DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D3003DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D3500DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402D3501DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402ED700DIODEBI_DIR TRIG_ESD0402_AZ582AZ5825-01FESD0402ED2600DIODEBI_DIR TRIG_ESD0402_ESD_1ESD5471XESD0402ED2601DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402ED2602DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402ED2603DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402F700FUSE_0_R1206_NCNCR1206HOLE11TEST_2_HOLE_C4R50_C8R00_STRUCTUStructure_HoleHOLE_C4R50_C8R00HOLE12TEST_2_HOLE_C4R50_C8R00_STRUCTUStructure_HoleHOLE_C4R50_C8R00HOLE13TEST_2_HOLE_C4R50_C8R00_STRUCTUStructure_HoleHOLE_C4R50_C8R00HOLE14TEST_2_HOLE_C4R50_C8R00_STRUCTUStructure_HoleHOLE_C4R50_C8R00IR700IR_RECEIVE_0_IRM-2638_OQSS-R12OQSS-R12IRM-2638J14USBA_0_USB3D0_AF_9P_USB3D0_AF_9USB3D0_AF_9PUSB3D0_AF_9PJ700DC_2_JACK-9_5X11_6-3PA_JACK_POWJACK_POWERJACK-9_5X11_6-3PAJ2100TF_SD_SOCKET_0_TF-CARD-PUSH_TF_TF_SD_SOCKETTF-CARD-PUSHJ2600HDMI_A_0_HDMI-14_5X11_55-23P_HDHDMI_AHDMI-14_5X11_55-23PJ2800GP1FD310TP1_3_DLT2160A_APL_3Papl_3pDLT2160AJ2900PHONEJACKSTEREO SW_2_PJ-320D-5SMT-PJPJ-320D-5_SMTAJ3500HEADER4_0_DIP4_2R54MM_4PIN-2R54PIN-2R54DIP4_2R54MMJP3001RJ45_6_RJ45_47-RJ4522-XX047-RJ4522-XX0RJ45L700INDUCTORSOF FERRITE_IND_6060286.8uHIND_606028L701INDUCTORSOF FERRITE_IND_2520121.0uHIND_252012L702INDUCTORSOF FERRITE_IND_2520121.0uHIND_252012L703INDUCTORSOF FERRITE_IND_2520121.0uHIND_252012L704INDUCTORSOF FERRITE_IND_2520121.0uHIND_252012L900INDUCTOR_L0603_180R-100M180R-100ML0603L901INDUCTOR_L0603_180R-100M180R-100ML0603L1201INDUCTOR_L0603_180R-100M180R-100ML0603L1401INDUCTOR_L0603_180R-100M180R-100ML0603L1403INDUCTORCOM_RP2_0405_NC/MCZ121NC/MCZ1210DH900L2TA0GRP2_0405L1501INDUCTOR_L0603_180R-100M180R-100ML0603L1601INDUCTOR_L0603_180R-100M180R-100ML0603L1602INDUCTOR_L0603_180R-100M180R-100ML0603L2500INDUCTORCOM_RP2_0405_NCNCRP2_0405L2501INDUCTORCOM_RP2_0405_NCNCRP2_0405L2502INDUCTORCOM_RP2_0405_NCNCRP2_0405L2503INDUCTORCOM_RP2_0405_NCNCRP2_0405L2900INDUCTOR_L0603_1.8UH1.8uHL0603L2909INDUCTOR_L0603_180R-100M180R-100ML0603L3800INDUCTORSOF FERRITE_IND_3030124.7uHIND_303012LED701LED_LED0603_LED_GREENLED_GREENLED0603LED702LED_LED0603_LED_REDLED_REDLED0603LED703LED_LED0603_LED_REDLED_REDLED0603LED704LED_LED0603_LED_GREENLED_GREENLED0603LED705LED_LED0603_LED_REDLED_REDLED0603M700MARK_MARK_MARKMARKMARKM701MARK_MARK_MARKMARKMARKM702MARK_MARK_MARKMARKMARKM703MARK_MARK_MARKMARKMARKM704MARK_MARK_MARKMARKMARKM705MARK_MARK_MARKMARKMARKQ2100MOSFETP_SOT_23_WPM2015-3/TRWPM2015-3/TRSOT_23Q2601NPN_SOT_23_90149014SOT_23Q2603MOSFETN_SOT_323_2SK30182SK3018SOT_323SW701SWITCH_4_KCD117-2P-S_POWER_SWPOWER_SWKCD117-2P-SSW900SWKEY-SPST_0_TS-3220S_RECOVER_RECOVER_keyTS-3220SSW1301SWKEY-SPST_0_TS-3220S_RESET_KERESET_keyTS-3220STP2300TP_TP_0R70_TP_0.7TP_0.7TP_0R70TP2301TP_TP_0R70_TP_0.7TP_0.7TP_0R70U701PMIC_RK805_QFN32_4R00X4R00X0R90RK805-1QFN32_4R00X4R00X0R90_TU702DCDC_FR9881_SOT_23_6_SY8120/ETASY8120/ETA8120SOT_23_6U800DSP_RK3328_BGA395_14R00X14R00X1RK3328BGA395_14R00X14R00X1R24U1900DDR4X16_1_FBGA96_14R00X11R00X1RDDR4X16FBGA96_14R00X11R00X1R20U1901DDR4X16_1_FBGA96_14R00X11R00X1RDDR4X16FBGA96_14R00X11R00X1R20U1902LDO_PT5108_SOT_23_5_PT5108E23E-PT5108E23E-25SOT_23_5U2300INAND_EMMC_169_BGA169_18R00X14RKLM8G1GEAC-B031BGA169_18R00X14R00X1R20U2500SWITCH_SY6280_SOT_23_5_SY6280AASY6280AACSOT_23_5U2502SWITCH_SY6280_SOT_23_5_SY6280AASY6280AACSOT_23_5U2600ESD_ESD5304D_SON10_2R50X1R00X0RESD5304DSON10_2R50X1R00X0R50U2601ESD_ESD5304D_SON10_2R50X1R00X0RESD5304DSON10_2R50X1R00X0R50U2900AMPLIFIER_TPF632_TSSOP14_4R96X4SGM89000YTS14GTSSOP14_4R96X4R40X1R20U3000ETHERNET_10M100M_SOIC16_12R70X9HR601680SOIC16_12R70X9R40X6R22U3003ESD_UCLAMP2512T_SON8_2R00X1R00XuClamp2512TSON8_2R00X1R00X0R43U3800MODULE_AP6354_MD44_AP6XXX_13RX1AP6356MD44_AP6XXX_13RX15RX1R5USB1JP_USB2_1.0_USB_A_USB-AF90USB-AF90USB_AY700CRYSTAL_2P_1G_CRY2_6R90X1R40X1R32.768KHzCRY2_6R90X1R40X1R30Y900CRYSTAL_4P_CRY4_3R20X2R50X0R8_124MHzCRY4_3R20X2R50X0R80Y3800CRYSTAL_4P_CRY4_3R20X2R50X0R80_37.4MHzCRY4_3R20X2R50X0R80 PCB文件来了。回复可见
**** Hidden Message ***** 谢谢分享RK3328 TVBOX 安卓智能电视盒PCB文件 谢谢分享,学习 谢谢分享,学习一下。
