armclub 发表于 2022-10-16 12:08:40
RX580 吃鸡显卡 PCB文件 挂8个GDDR5  RX580P181030HJ
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB35BEAD_SMIND1005_0_5H_120R_505000120RSMIND1005_0_5HB200BEAD_RES1608_2012_1_1H_220R_520220RRES1608_2012_1_1HB202BEAD_SMIND1005_0_5H_120R_505000120RSMIND1005_0_5HBR300RES#3_RES1005_0R_3150000000G0RRES1005BR301RES#3_RES1005_0R_3150000000G0RRES1005D1LED_DUAL_K3A1_K4A2_LED_LITE-ON_LED_RED/BLUELED_LITE-ON_LTST-C195TBJRKTD200SCHOTTKY_DIOSOD_523_BAT54KFILM_BAT54KFILMDIOSOD_523D201SCHOTTKY_DIOSOD_523_BAT54KFILM_BAT54KFILMDIOSOD_523D222DIODE_SERIES_SOT23_1_15H_BAV99_BAV99SOT23_1_15HF1800FUSE_RES3216_1_3H_1.5A_512000311.5ARES3216_1_3HF1900FUSE_RES3216_1_3H_1.5A_512000311.5ARES3216_1_3HF1901FUSE_RES3216_1_3H_200MA_5120003200mARES3216_1_3HHS1HEATSINK_WVIA_HS_7123B00900G_CUCuracao_fansinksHS_7123B00900GJ200CON04_HD2MM1X4_KEY_HEADER_1X4_SHEADER_1X4_SHROUDEDHD2MM1X4_KEYJ10016140052600G_CON_MFITJR_7_CON_8PPOWER_HEADERCON_8P_HDER_TH_1_CN3_0-CJ1700DISPLAY_PORT_CON_DISPLAYPORT_ASDP_W/GASKETCON_DISPLAYPORT_ASTRON_R6890020J1800DISPLAY_PORT_CON_DISPLAYPORT_ASDP_W/GASKETCON_DISPLAYPORT_ASTRON_R6890020J1900DISPLAY_PORT_CON_DISPLAYPORT_ASDP_W/GASKETCON_DISPLAYPORT_ASTRON_R6890020J1950DVI_D_COMPUPACK_CON_COMPUPACK_ADVI-DCON_COMPUPACK_ACNDV210031-001J2501HDMI_CON_HDMI_PLASTRON_HM0D-G-RHDMI_W/TABCON_HDMI_PLASTRON_HM0D-G-R0-LFL900IND#2_IND_6363_4_5H_SUNT_SNR6042.2uHIND_6363_4_5H_SUNT_SNR6045SL1080IND_POL#2_IND_GUORUI_SCD0504T_00.47uHIND_GUORUI_SCD0504TL1506L_IND_NONRKO_TH_63_57_I125X125_0.47UHIND_NONRKO_TH_63_57_I125X125L1507L_IND_NONRKO_TH_63_64_I125X125_1.0UHIND_NONRKO_TH_63_64_I125X125L1880IND_RES1005_100NH_5260101900G100nHRES1005L1895IND_POL_IND_COPPER-FP1007R3_0.10.15uHIND_COPPER-FP1007R3L1897IND_SMIND_IHLP-2525CZ_3_0H_0.470.47uH_17ASMIND_IHLP-2525CZ_3_0HL1898L_IND_NONRKO_TH_63_57_I125X125_0.47UHIND_NONRKO_TH_63_57_I125X125L1899L_IND_NONRKO_TH_63_64_I125X125_1.0UHIND_NONRKO_TH_63_64_I125X125MB200BEAD_RES1608_2012_1_1H_220R_520220RRES1608_2012_1_1HMC141CAP_CAP1608_2012_1_40H_22UF_42122uFCAP1608_2012_1_40HMC148CAP_CAP2012_1_53H_VIA_47UF_421247uFCAP2012_1_53H_VIAMC151CAP_CAP2012_1_40H_10UF_421C010610uFCAP2012_1_40HMC152CAP_CAP2012_1_40H_10UF_421C010610uFCAP2012_1_40HMC154CAP_CAP1608_2012_1_53H_10UF_42110uFCAP1608_2012_1_53HMC155CAP_CAP1608_2012_1_53H_10UF_42110uFCAP1608_2012_1_53HMC209CAP_CAP2012_1_40H_10UF_421C010610uFCAP2012_1_40HMJ10016140029901G_CON_MFITJR_5_CON_6PPOWER_HEADERCON_6P_HDER_TH_1_CN3_0-CML900IND_POL_IND_GUORUI_SCD0504T_2.22.2uHIND_GUORUI_SCD0504TMPCIE1EDGECON_PCIE_164P_EDGECON_PCI_Ex16PCIeEDGECON_PCI_EXPRESS_16MT215MOUNTING_8PINS_MTG3_4_8VIAS_NA_NAMTG3_4_8VIASNS700NET_SHORT_NET_SHORT_NET_SHORT_6NET_SHORTNET_SHORTNS900NET_SHORT#1_NET_SHORT_NS_VIA_62NS_VIANET_SHORTPC900CAP_CAP1608_1000PF_4250010200G1000pFCAP1608PC919CAP_POL_CAPT7343_2_1H_330UF_426330uFCAPT7343_2_1HPR714RES#3_RES1005_32.4K_3160324200G32.4KRES1005PR900RES#3_RES1608_2.2R_323002R200G2.2RRES1608Q7NPN#1_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ14NPN#1_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ15NPN#1_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ100MOS_N#1_SOT23_3PIN_BSH111_20200BSH111SOT23_3PINQ101MOS_N#1_SOT23_3PIN_BSH111_20200BSH111SOT23_3PINQ110MOS_N#1_SOT23_3PIN_BSH111_20200BSH111SOT23_3PINQ203NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363Q206NPN#3_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ209PNP_SOT23_3PIN_1_1H_MMBT3906_20MMBT3906SOT23_3PIN_1_1HQ210NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363Q215NPN#3_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ216NPN#3_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ250NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363Q251NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363Q252MOS_P#1_SOT23_1_15H_AO3415L_202AO3415LSOT23_1_15HQ810MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363Q811MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363Q1009NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363Q1010NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363Q1013NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363Q1016NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363Q1024NPN#2_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ1070MOS_N#1_SOT23_3PIN_1_1H_2N7002_2N7002SOT23_3PIN_1_1HQ1077NPN#2_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ1604NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363Q1700NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363Q1701MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363Q1704MOS_N#1_SOT23_3PIN_2N7002E_20202N7002ESOT23_3PINQ1800NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363Q1801MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363Q1804MOS_N#1_SOT23_3PIN_2N7002E_20202N7002ESOT23_3PINQ1810MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363Q1820MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363Q1823NPN#2_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ1900NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363Q1901MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363Q1902MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363Q1904MOS_N#1_SOT23_3PIN_2N7002E_20202N7002ESOT23_3PINQ1951NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363Q1980MOS_N_SOT363_2N7002DW_2020008502N7002DWSOT363Q2604NPN#1_SOT363_MMDT3904-7_2025390MMDT3904-7SOT363Q2626NPN#2_SOT23_3PIN_MMBT3904_20213MMBT3904SOT23_3PINQ4600MOS_P_SOT23_1_15H_AO3415L_20200AO3415LSOT23_1_15HQ4602NPN_SOT363_MMDT3904-7_202539040MMDT3904-7SOT363Q4613MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALTQ4614MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALTQ4615MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALTQ4616MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALTQ4617MOS_N_1D_3S_SO8_CASE488AA-01_ALNTMFS4983NFSO8_CASE488AA-01_ALTRP1RES_NTWK_RESN2012_33R_32700040033RRESN2012SK1MECH_SOCKET_6GP_SOC_6090055700GELLESMERE_L4_SLT_SOCKETSOC_6090055700GSW1SLIDE_SWITCH_3P_4SH_SW_APEM_MA1SPDTSW_APEM_MA12RTC901CAP_CAP1005_BGA_1000PF_417001021000pFCAP1005_BGAU4NC7SB3157_SOT_SC70-6_1_1H_NC7SBNC7SB3157SOT_SC70-6_1_1HU7U_VREG_3PIN_SOT223_ADV_VR=1.25VADV_VR=1.25VSOT223U11SERIAL_FLASH_SO8_1_78H_PM25LV01PM25LV010A-100SCSO8_1_78HU22SI51214_DFN40P120X140X80-6N_SI5Si51214-A1EAGMDFN40P120X140X80-6NU20074VC1G123_MSOP08_3M0X3M0X1M3_P0SN74LVC1G123DCTMSOP08_3M0X3M0X1M3_P0M65U300GS7103_SO8_THERMAL_1_75H_GS7103GS7103-ASO8_THERMAL_1_75HU506COMPARATOR#1_SOT95P280X145-5N_AAP331AWGSOT95P280X145-5NU507COMPARATOR#1_SOT95P280X145-5N_AAP331AWGSOT95P280X145-5NU701APW7165A_PSOP_8_THERMAL_1_75H_AAPW7165APSOP_8_THERMAL_1_75HU900GS9238_QFN23_4M0X4M0X0M8_P0M50_GS9238-ATQ-RQFN23_4M0X4M0X0M8_P0M50_GS9238U2000170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120U2100170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120U2200170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120U2300170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120U2400170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120U2500170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120U2600170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120U2700170BALL_GDDR5_BGA170C80P_1200X1GDDR5BGA170C80P_1200X1400X120U4003LM96063C_QFN050_10_3X3_LM96063_LM96063QFN050_10_3X3U4503SERIAL_FLASH_SO8_1_78H_PM25LD01Pm25LD010C-SCESO8_1_78HU4506SMD_SC2422_SO16NCP81022QFN52_6M0X6M0X1M0_P0M40_TH8U4507XX08_SOT353_1_1H_NC7SZ08P5X_243NC7SZ08P5XSOT353_1_1HU451014521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3U451114521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3U451214521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3U451314521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3U451414521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3U451514521_2_FDMF3035_PQFN31_REV3_FDFDMF3035FDMF3035_PQFN31_REV3U4517ADP3418_0_QFN16-3X3-0R5P_NCP811NCP81162QFN16-3X3-0R5PU4518ADP3418_0_QFN16-3X3-0R5P_NCP811NCP81162QFN16-3X3-0R5PU4519ADP3418_0_QFN16-3X3-0R5P_NCP811NCP81162QFN16-3X3-0R5PU4520APW7165A_PSOP_8_THERMAL_1_75H_AAPW7165APSOP_8_THERMAL_1_75HU4522XX08_SOT353_1_1H_NC7SZ08P5X_243NC7SZ08P5XSOT353_1_1HY1CRYSTAL_4P_NC_XTAL_NDK_NX3225DA27.000MHzXTAL_NDK_NX3225DAY5CRYSTAL_4P_NC_XTAL_NDK_NX3225DA27.000MHzXTAL_NDK_NX3225DA
armclub 发表于 2022-10-16 12:10:52
PCB文件来了。由于涉及到保密问题。有删掉部分内容。文件不完整,仅供学习参考。
**** Hidden Message *****
huangchang 发表于 2022-10-16 12:15:59
lipen 发表于 2022-10-16 15:29:14
root_2022 发表于 2022-10-16 15:39:51
cat 发表于 2022-10-16 17:12:04
发电机 发表于 2022-10-16 17:43:06
bidezhi7777 发表于 2022-10-16 17:46:07
a6682100 发表于 2022-10-16 20:42:49
oyyp 发表于 2022-10-16 21:52:57
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: RX580 吃鸡显卡 PCB文件 挂8个GDDR5  RX580P181030HJ
