layout 发表于 2022-10-29 23:39:27
南芯SC8701+CH32V303CBT6 做的快充板PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1DIODE1N4004_D604_0_D0603_1N4141N4148D0603D2DIODE1N4004_D604_0_D0603_1N4141N4148D0603D3DIODE1N4004_D604_0_D0603_1N4141N4148D0603D4DIODE1N4004_D604_0_D0603_1N4141N4148D0603D5DIODE1N4004_D604_0_D0603_1N4141N4148D0603D6DIODE1N4004_D604_0_D0603_1N4141N4148D0603D7DIODE1N4004_D604_0_SOD323_NCNCSOD323D8DIODE1N4004_D604_0_SMA_SS34SS34SMAD9DIODE1N4004_D604_0_SMC_SL42SL42SMCD10DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D11DIODE1N4004_D604_0_SMA_SS34SS34SMAD12DIODE1N4004_D604_0_SMA_SS12SS12SMAD14DIODE_D0603_IN4148IN4148D0603D15DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D16DIODE_D0603_IN4148IN4148D0603D17DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D18DIODE_D0603_IN4148IN4148D0603D19DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D20DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D21DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D22DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D23DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D24DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D25DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D26DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D27DIODEBI_DIR TRIG_SOD323_SPD911SPD9112WSOD323D28DIODEBI_DIR TRIG_SOD323_SPD911SPD9112WSOD323D29DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D30DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D31DIODEBI_DIR TRIG_R0402_ESD5451ESD5451NR0402D32DIODE_D0603_1N41481N4148D0603D33DIODE_D0603_1N41481N4148D0603D34DIODE_D0603_1N41481N4148D0603D35DIODE_D0603_1N41481N4148D0603D36DIODE_D0603_1N41481N4148D0603D37DIODE_D0603_1N41481N4148D0603D38DIODE_D0603_NCNCD0603D39DIODE_D0603_NCNCD0603D40DIODE_D0603_1N41481N4148D0603D41DIODE_D0603_1N41481N4148D0603D42DIODE_D0603_1N41481N4148D0603D43DIODE_D0603_1N41481N4148D0603D44DIODE_D0603_1N41481N4148D0603D45DIODE_D0603_1N41481N4148D0603D46DIODE_D0603_1N41481N4148D0603D47DIODE_D0603_1N41481N4148D0603D48DIODE_D0603_1N41481N4148D0603D49DIODE_D0603_1N41481N4148D0603D50DIODE_D0603_1N41481N4148D0603D51DIODE_D0603_1N41481N4148D0603D52DIODE_D0603_1N41481N4148D0603D53DIODE_D0603_1N41481N4148D0603D54DIODE_D0603_1N41481N4148D0603D55DIODE_D0603_1N41481N4148D0603D56DIODE_SOD323_IN4148IN4148SOD323J1JAMP_FB0_2_JAMP_5MMJAMP_5mmFB0_2J2JAMP_FB0_2_JAMP_5MMJAMP_5mmFB0_2J3JAMP_FB0_2_JAMP_5MMJAMP_5mmFB0_2J4HEADER4_CON1X4_3R96_H10_VM_VH-VH-4PCON1X4_3R96_H10_VMJ5HEADER4_CON1X4_3R96_H10_VM_VH-VH-4PCON1X4_3R96_H10_VMJ6HEADER12_GY_B01M_A_12PIN_R1_A_GY-B01M-A-12PIN-R1GY_B01M_A_12PIN_R1_AJ9HEADER6_GY_B01M_A_6P_R1_GY-B01GY-B01M-A-6P-R1GY_B01M_A_6P_R1J10HEADER7_1_CON1X7_2_H6_VM_SH-7PSH-7PCON1X7_2_H6_VMJ13CON7_3_CON1X5_2_H6_VM_PH-5PPH-5PCON1X5_2_H6_VMJ14CON7_4_PH-1_0_5P_WT_CON7CON7PH-1_0_5P_WTJ15HEADER15_CON1X15_2_H6_VM_PH-15PH-15PCON1X15_2_H6_VML1INDUCTOR_L_13R8X12R8_H7R3_SM_CSCSBL1275-150ML_13R8X12R8_H7R3_SML2INDUCTOR_L_13R8X12R8_H7R3_SM__1CSBL1275-560ML_13R8X12R8_H7R3_SML3INDUCTORSOF FERRITE_0_L_3X3_H1SWPA3015S220MTL_3X3_H1R5_SML4INDUCTOR_R0805_BLM21PG2218N1BLM21PG2218N1R0805L5INDUCTOR_R0805_BLM21PG2218N1BLM21PG2218N1R0805L6INDUCTOR_L0805_BLM21PG2218N1BLM21PG2218N1L0805L7INDUCTOR_L0805_BLM21PG2218N1BLM21PG2218N1L0805L8INDUCTOR_L0805_BLM21PG2218N1BLM21PG2218N1L0805LED1LED_0_LED0603_REDREDLED0603LED2LED_0_LED0603_REDREDLED0603Q1EMB09N03V_1_DFN8_1R27_6X5_H1R1_D120N10ESDFN8_1R27_6X5_H1R1_MOSQ2EMB09N03V_1_DFN8_1R27_6X5_H1R1_D120N10ESDFN8_1R27_6X5_H1R1_MOSQ3EMB09N03V_1_DFN8_1R27_6X5_H1R1_D120N10ESDFN8_1R27_6X5_H1R1_MOSQ4EMB09N03V_1_DFN8_1R27_6X5_H1R1_D120N10ESDFN8_1R27_6X5_H1R1_MOSQ52N3904_Q601_0_SOT23_90149014SOT23Q62N3904_Q601_0_SOT23_90149014SOT23Q7PDGS_1_SOT23_SI2301SI2301SOT23Q8NPN_0_SOT23_90149014SOT23Q9FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q10FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q11FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q12FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q13FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q14FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q15MOSFETN_SOT23_2SK30182SK3018SOT23Q16MOSFETN_SOT23_2SK30182SK3018SOT23Q17MOSFETN_SOT23_2SK30182SK3018SOT23Q18MOSFETN_SOT23_2SK30182SK3018SOT23Q19MOSFETN_SOT23_2SK30182SK3018SOT23Q20FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q21FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q22FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q23FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q24FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q25FDS4435A_SOP8_YJS4407AYJS4407ASOP8Q26PNP_SOT23_90159015SOT23Q27PNP_SOT23_90159015SOT23Q28MOSFETN_SOT23_2SK30182SK3018SOT23Q29MOSFETN_SOT23_2SK30182SK3018SOT23Q30MOSFETN_SOT23_2SK30182SK3018SOT23Q312N6788_0_SOT23_AO3400AO3400SOT23Q322N6788_0_SOT23_AO3400AO3400SOT23Q33NPN_SOT23_90149014SOT23Q342N6788_0_SOT23_AO3400AO3400SOT23Q35NPN_SOT23_90149014SOT23Q36NPN_SOT23_90149014SOT23TP9TPOINT R_TP_1R3_0R9_3.3V3.3VTP_1R3_0R9TP10TPOINT R_TP_TOPLAYER_5V5VTP_TOPLAYERTP11TP_TP_1R3_0R9_IRIRTP_1R3_0R9U1SC8701_1_QFN32_0R4_4X4_H0R8_SC8SC8701QFN32_0R4_4X4_H0R8U2RT8289_SOP8_PAD_RT8279RT8279SOP8_PADU3DCDC_SY8113_SOT_23_6_TMI3253SHTMI3253SHSOT_23_6U4REG1117A-1.8_U606_TI-DCY4_L_LM1LM1117S-3.3TI-DCY4_LU5REG1117A-1.8_U606_TI-DCY4_L_L_1LM1117S-5TI-DCY4_LU6SI8621BC-B-IS_U301_SOP8_1R27_3RNSI8122SSOP8_1R27_3R9_H1R8U7MAX232ECD_U308_SOP16_1R27_3R9_MMAX3232ExPWSOP16_1R27_3R9U8ISO1541_U805_0_SOP8_NSI8100NNSi8100NSOP8U9STM32F103_48P_QFP48_0R5_7X7_H1RCH32V303CBT6QFP48_0R5_7X7_H1R6Y1CRYSTAL_OSC2_5R0X3R2_H1R3_SM_8M8MOSC2_5R0X3R2_H1R3_SM
layout 发表于 2022-10-29 23:40:12
PCB文件回复可见
**** Hidden Message *****
cityhu 发表于 2022-10-30 00:03:41
tomhi 发表于 2022-10-30 07:17:30
kanxue_nmg 发表于 2022-10-30 07:37:41
清心如水 发表于 2022-10-30 07:53:15
单枪舞九州 发表于 2022-10-30 08:34:31
支持
huangchang 发表于 2022-10-30 08:36:04
支持一下!
mester 发表于 2022-10-30 08:46:13
kualong05 发表于 2022-10-30 08:47:24
南芯的外围器件也太多了
页: [1] 2 3 4 5 6 7 8 9
查看完整版本: 南芯SC8701+CH32V303CBT6 做的快充板PCB文件
