全志A133 全志A100_B3_AXP707_LPDDR3_168ball_V1_0_20200312 方案参考PCB
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBAT1CON3_2_WF13_051G1R_5P_1.25MM5P_1.25MMWF13_051G1RBAT2CON3_0_BAT_SMD-3_BATBATBAT_SMD-3BT1T_POINT_R_TP_PAD_TESTTestTP_PADBT2T_POINT_R_TP_PAD_TESTTestTP_PADBT3T_POINT_R_TP_PAD_TESTTestTP_PADCN1FPC_KEY_0_CON6PIN_FPC_863_FPC_KFPC_KEY_0CON6PIN_FPC_863CN2FPC_6P_DC_0_FPC_6P_KEY_FPC_6P_DFPC_6P_DCFPC_6P_KEYCN3FPC_KEY_0_CON6PIN_FPC_863_FPC_KFPC_KEY_0CON6PIN_FPC_863CN4FPC_6P_DC_0_FPC_6P_KEY_FPC_6P_DFPC_6P_DCFPC_6P_KEYCN5CON6PIN_USB1_CON6PIN_FPC_863_COCON6PIN_USB1CON6PIN_FPC_863CON10_0.8T-2PWB_CON-2P-0_8MM_0.8T-20.8T-2PWBCON-2P-0_8MMCON20_0.8T-2PWB_CON-2P-0_8MM_0.8T-20.8T-2PWBCON-2P-0_8MMCON3CON39PIN_0_39PIN_UD_FPC_863_CONCON39PIN39PIN_UD_FPC_863CON4CON45_LCM_45PIN_UD_FPC_863_CON4CON45_LCM45PIN_UD_FPC_863CON5AT070TN93_2_FPC30P-0_5L-1_5H-LR30pin-0.5mm-DOWNFPC30P-0_5L-1_5H-LRCON6CON30PIN_T05-1530-FG01_30PIN-0.30pin-0.5mm-DOWNT05-1530-FG01CON7CON50PIN_51PIN_UD_FPC_863_CON51CON51_PIN51PIN_UD_FPC_863CON8RT9293B_9_SHIELD-N_ICSRC6508SFRICSRC6508SFRSHIELD-NCON9RT9293B_9_SHIELD-N_ICSRC6508SFRICSRC6508SFRSHIELD-NCON10RT9293B_9_SHIELD-N_ICSRC6508SFRICSRC6508SFRSHIELD-NCON11RT9293B_9_SHIELD-N_ICSRC6508SFRICSRC6508SFRSHIELD-NCON12RT9293B_9_SHIELD-N_ICSRC6508SFRICSRC6508SFRSHIELD-NCON14RT9293B_9_SHIELD-N_ICSRC6508SFRICSRC6508SFRSHIELD-NCON150_0.8T-2PWB_CON-2P-0_8MM_0.8T-20.8T-2PWBCON-2P-0_8MMCON16TP_4P4_RF_0_RF_TP_FAN_TP_4P4_RFTP_4p4_RFRF_TP_FAND1DIO-SS16F_SOD250_380H100_SS24SS24SOD250_380H100D2ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D3ESD9B5VL_ESD0402_NC/PT2C051NNC/PT2C051NESD0402D4ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D5ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D6ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D7ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D8ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D9ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D10ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D11ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D12ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D13D_0_SOD123_SS14SS14SOD123D14D_0_SOD123_SS14/1N5819SS14/1N5819SOD123D15DIODE_DUAL_3_SOT23-132_BAT54SBAT54SSOT23-132D16DIODESCHOTTKY_SOD123_NC/16VNC/16VSOD123D17DIODE_DUAL_3_SOT23-132_BAT54SBAT54SSOT23-132D18DIODESCHOTTKY_SOD123_NC/6.8VNC/6.8VSOD123D19ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D20ESD9B5VL_ESD0402_NC/PT2C051NNC/PT2C051NESD0402D21ESD9B5VL_ESD0402_NC/PT2C051NNC/PT2C051NESD0402D22ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D23ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402D24DIODE_SCHOTTKY_SOD123_XBS104S14XBS104S14SOD123DC1ESD9B5VL_ESD0402_PT2C051LPT2C051LESD0402DC2ESD9B5VL_ESD0402_PT2C051LPT2C051LESD0402DC3ESD9B5VL_ESD0402_PT2C051LPT2C051LESD0402DC4ESD9B5VL_ESD0402_NC/PT2C051NNC/PT2C051NESD0402DC5ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402DC6ESD9B5VL_ESD0402_PT2C051NPT2C051NESD0402DC7ESD9B5VL_ESD0402_PT2C051LPT2C051LESD0402DC8ESD9B5VL_ESD0402_PT2C051LPT2C051LESD0402DP1LED-0805-G_LED0603_LEDLEDLED0603DP2ESD9B5VL_ESD0402_NC/PT2C051NNC/PT2C051NESD0402DU1ESD5451X_ESD0402_PT2C051NPT2C051NESD0402DU2ESD9B5VL_ESD0402_PT2C051LPT2C051LESD0402DU3ESD9B5VL_ESD0402_PT2C051LPT2C051LESD0402DU4ESD5451X_ESD0402_PT2C051NPT2C051NESD0402DU5ESD5451X_ESD0402_NC/PT2C051NNC/PT2C051NESD0402DU6ESD9B5VL_ESD0402_NC/PT2C051LNC/PT2C051LESD0402DU7ESD9B5VL_ESD0402_NC/PT2C051LNC/PT2C051LESD0402DU8ESD9B5VL_ESD0402_NC/PT2C051NNC/PT2C051NESD0402FB1INDUCTOR_0_L0603_600R/100M600R/100ML0603FC1C-C0402_C0201_NC/104NC/104C0201FC2C-C0402_C0201_NC/104NC/104C0201FID1TPOINT R_2_MARK_PADE_MARK_MARKMARK_PADEFID2TPOINT R_2_MARK_PADE_MARK_MARKMARK_PADEFID3TPOINT R_2_MARK_PADE_MARK_MARKMARK_PADEFID4TPOINT R_2_MARK_PADE_MARK_MARKMARK_PADEFQ1MOSFETN_SOT23_NC/SI2300NC/SI2300SOT23FR1R_R0603_NC/4.7R_NC/4.7RR0603FR2RES1B_R0201_NC/10KNC/10KR0201FR4R_R0201_NC/10KNC/10KR0201H1TPOINT R_2_MARK_PADE_HOLE_HOLEMARK_PADEH2TPOINT R_2_MARK_PADE_HOLE_HOLEMARK_PADEJ30_0.8T-2PWB_CON-2P-0_8MM_0.8T-20.8T-2PWBCON-2P-0_8MMJ4SDMMCSLOT_2_TF_07_MRK-TF09-190MRK-TF09-190-0015TF_07J5CON6PIN_USB1_CON6PIN_FPC_863_COCON6PIN_USB1CON6PIN_FPC_863J6PAD2PIN_PAD2PIN0833_PAD2PINPAD2PINPAD2PIN0833J7CON6_WTB_MTG2_2_CD-ARF004-P01A_CON6_WTB_MTG2CD-ARF004-P01AJP1PJ381-2_0_ADJ-312-P32-39X_ADJ-3ADJ-312-P32-39XADJ-312-P32-39XL1INDUCTOR_IND-3X3_10UH_1A10uH_1AIND-3X3L2INDUCTOR_IND-3X3_10UH_1A10uH_1AIND-3X3LP1INDUCTOR_0_SML2520_1P2H_1.0UH/21.0uH/2.7A/DCR<0.049RSML2520_1P2HLP2INDUCTOR_0_SML2520_1P2H_1.0UH/21.0uH/2.7A/DCR<0.049RSML2520_1P2HLP3INDUCTOR_0_SML2520_1P2H_1.0UH/21.0uH/2.7A/DCR<0.049RSML2520_1P2HLP4INDUCTOR_0_IND-3X3_2.2UH-DCR<0.2.2uH-DCR<0.1R-2AIND-3X3LP5INDUCTOR_0_SML2520_1P2H_1.0UH/21.0uH/2.7A/DCR<0.049RSML2520_1P2HLP6INDUCTOR_0_SML2520_1P2H_1.0UH/21.0uH/2.7A/DCR<0.049RSML2520_1P2HLP7INDUCTOR_0_SML2520_1P2H_1.0UH/21.0uH/2.7A/DCR<0.049RSML2520_1P2HLW1INDUCTOR_0_L0806_NC/2.2UH-0.6ANC/2.2uH-0.6AL0806P9T_POINT_R_TP30_SMD_TESTTestTP30_SMDQ1WPM4005_11_DFN8P0_65B2_00X2_00HWPM1481DFN8P0_65B2_00X2_00H0_75T25TESTPOINT-SMD_TP_PAD_AP-I2S-DOUAP-I2S-DOUTTP_PADU1A100-BGA_BGA346P50B1200_1200H11A100-BGABGA346P50B1200_1200H114U2LY8006_0_MSOP8_LPA4890MSFLPA4890MSFMSOP8U3LY8006_0_MSOP8_LPA4890MSFLPA4890MSFMSOP8U4RT9266PE_2_SOT23-5_NC/LPW5206NC/LPW5206SOT23-5U5AP3019_0_SOT23-6_LP3315LP3315SOT23-6U6AP3031_0_SOT23-6_AP3127BAP3127BSOT23-6U7GSL1680_0_QFN40_NC/GSL1680NC/GSL1680QFN40U8FT5306DE4_0_GSL3675-7X7_GSL3676GSL3676GSL3675-7X7U9HAL3144_1_QFN2020_3_MH248ESQMH248ESQQFN2020_3U10STK3310_STK3310_STK3310STK3310STK3310U13SENSOR-BMA250_MC3433_MC3433MC3433MC3433U14AXP22X_24_QFN40P0_40B5_00X5_00HAC101QFN40P0_40B5_00X5_00H0_75UD1LPDDR3-POP168_1_BGA168P50B1200_LPDDR3_POP168BALLBGA168P50B1200_1200H72UM1EMMC5.0-BGA169_BGA169P50B1200_1EMMCBGA169P50B1200_1600H100UM2NAND-FLASH-TSOP48_SOP48P50B1200NANDSOP48P50B1200_1840H120UP1AXP803_QFN69P0_4B8X8_AXP707AXP707QFN69P0_4B8X8UP2RT9266PE_3_SOT23-6_LP6226CB6FLP6226CB6FSOT23-6USB1USB_MINI_SOCKET_0_CMUS-06505-09CMUS-06505-097-03CMUS-06505-097-03UU1SY6280_SOT5P95B160_300H130_SOT2SOT23-5SOT5P95B160_300H130WU1AW1732-NOSOCKET_QFN40P500X500X8XR829QFN40P500X500X80-41NXW1CRYSTAL-4_0_X4B250_320H80_SMD_224M-16pF-10PPMX4B250_320H80_SMDY1CRY-24MHZ-3225-SMD_X4B250_320H124M-16pF-10ppmX4B250_320H120_SMDY2CRY-32_0.768KHZ-2X6-DIP_SC-32S-32.768K-12.5pF-20ppmSC-32S-32K 这个文件是挂了LPDDR3 ,看这个估计是从4个DDR3 上,修改成单个LPDDR3 的。不过LPDDR3 部分画的非常一般,
文件包含PCB 和原理图, 收1RMB
