STM32F407VGT6/STM32F4XXVX+FD6288Q+SM4480PRL 做得控制板PCB
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED4BAS70-04/SOT_SOT-23B_BAS21SLT1BAS21SLT1SOT-23BD6TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60ND7TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60ND8TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60ND9TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60ND10TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60ND17DIO_5_SMA_SS34SS34SMAD18DIO_5_SMA_SS34SS34SMAD19DIO_5_SMA_SS34SS34SMAD23MOS_SOT-23_PMOSPMOSSOT-23D24MOS_SOT-23_PMOSPMOSSOT-23D31DI-TVS-D_SMA_DO-214AC_SMAJ12CASMAJ12CASMA_DO-214ACD32DI-TVS-D_SMA_DO-214AC_SMAJ12CASMAJ12CASMA_DO-214ACD92DIO_5_SMA_SS34SS34SMAD93DIO_5_SMA_SS34SS34SMAD94DIO_5_SMA_SS34SS34SMAD98BZX84C16/SOT_5_SMA_SMAJ28CASMAJ28CASMAD99BZX84C16/SOT_5_SMA_SMAJ28CASMAJ28CASMAD104BAS70-04/SOT_SOT-23B_BAS21SLT1BAS21SLT1SOT-23BD105DIO-TVS-BIPOLAR-2_DIOS2_SOD323_3.3VDIOS2_SOD323_BIQD108DI-XI-S_SMA_DO-214AC_IC_SMAJ28CSMAJ28CASMA_DO-214ACD112BAS70-04/SOT_SOT-23B_BAS21SLT1BAS21SLT1SOT-23BD115DIO-TVS-BIPOLAR-2_DIOS2_SOD323_3.3VDIOS2_SOD323_BIQD116BAS70-04/SOT_SOT-23B_BAS21SLT1BAS21SLT1SOT-23BD353DIODE_DIOS2_SOD323_BIQ_LRB751V-LRB751V-40T1GDIOS2_SOD323_BIQD354DIODE_DIOS2_SOD323_BIQ_LRB751V-LRB751V-40T1GDIOS2_SOD323_BIQD355DIO-TVS-BIPOLAR-2_DIOS2_SOD32_112VDIOS2_SOD323_BIQD356DIODE_DIOS2_SOD323_BIQ_LRB751V-LRB751V-40T1GDIOS2_SOD323_BIQD357DIODE_DIOS2_SOD323_BIQ_LRB751V-LRB751V-40T1GDIOS2_SOD323_BIQD358DIO-TVS-BIPOLAR-2_DIOS2_SOD32_112VDIOS2_SOD323_BIQD359DIODE_SCHTKY_SMA_IC_SMAJ28CASMAJ28CASMAD360DIODE_SCHTKY_SMA_IC_SMAJ28CASMAJ28CASMAD361DIO-TVS-BIPOLAR-2_DIOS2_SOD32_25VDIOS2_SOD323_BIQD362DIO-TVS-BIPOLAR-2_DIOS2_SOD32_25VDIOS2_SOD323_BIQD363DIO-TVS-BIPOLAR-2_DIOS2_SOD32_25VDIOS2_SOD323_BIQD364DIO-TVS-BIPOLAR-2_DIOS2_SOD32_25VDIOS2_SOD323_BIQF1FUSE-SMD1206_SMD1206_FUSE_60V/0FUSE_60V/0.1ASMD1206F2FUSE-SMD1206_SMD1206_FUSE_60V/0FUSE_60V/0.1ASMD1206J4RT9167A-28CB,SOT23_19_MR30_PB-FMR30_PB-F_M_3_5MR30_PB-FG_M_3_5J7RT9167A-28CB,SOT23_66_SMD-5-2MMsmd-3-2mm-lSMD-5-2MM-LJ9RT9167A-28CB,SOT23_63_SMD-5-2MMsmd-3-2mm-lSMD-5-2MM-LJ16J-HDR-5_HDR254MA-1X5_HDR254MA-1HDR254MA-1X5HDR254MA-1X5J22RT9167A-28CB,SOT23_40_SMD-3-2MM2mm3pinsSMD-3-2MM-LJ33RT9167A-28CB,SOT23_53_SMD-2-2MMSMD-2-2MM-LSMD-2-2MM-LJ364HEADER_1_DIP-3-2_54MM_SIP-2.5sip-2.54mm-3pinsDIP-3-2_54MMJ374HEADER_1_DIP-3-2_54MM_SIP-2.5sip-2.54mm-3pinsDIP-3-2_54MMJ384HEADER_1_DIP-3-2_54MM_SIP-2.5sip-2.54mm-3pinsDIP-3-2_54MMJ39RT9167A-28CB,SOT23_19_MR30_PB-FMR30_PB-F_M_3_5MR30_PB-FG_M_3_5J414HEADER_1_DIP-3-2_54MM_SIP-2.5sip-2.54mm-3pinsDIP-3-2_54MMJ444HEADER_2_DIP-4-2_54MM_SIP-2.5sip-2.54mm-4pinsDIP-4-2_54MMJ46RT9167A-28CB,SOT23_60_XT30U-M_XXT30U-MXT30U-MJ47RT9167A-28CB,SOT23_86_SMD-GH-2PSMD-2-2MM-LSMD-GH-2P-125MM-LJ48J-A-4P_SMD-GH-4P-125MM-L_SMD-GHSMD-GH-4P-125MM-LSMD-GH-4P-125MM-LL1L_0_SLO1040H6R8MTT_33UH33uHSLO1040H6R8MTTL2L_0_SPL0404B_4.7UH4.7UHSPL0404BL4L-CMLS-ACM2012_CMLS-ACM2012_WCMWCM2012F2SF-900T04CMLS-ACM2012L7L-IND_SLO1040H6R8MTT_22UH/2A22uH/2ASLO1040H6R8MTTL9L-IND_L2520_NC/2.2UH/2.1ANC/2.2uH/2.1AL2520L10BEAD_R0603_BEAD/600R/500MABEAD/600R/500mAR0603LB4LB_L0402_LBLBL0402LB6LB_22_INDC1005X60N_CBG100505U60CBG100505U601/NCINDC1005X60NLB8LB_22_INDC1005X60N_CBG100505U_1CBG100505U601INDC1005X60NM9U-B0505S-1WR2_0_B0505S-1WR2-SIPNC/b0303s-1wr2B0505S-1WR2-SIP4PHA2TP_0_TEST_1_5MM_NCNCTEST_1_5MMQ26NPN-BEC_0_SOT-23_NPNNPNSOT-23Q49RT9167A-28CB,SOT23_72_SOP-8_CC6CC6902SO-30ASOP-8Q73RT9167A-28CB,SOT23_47_SOIC-8N_SSM4480PRLSOIC-8NQ85RT9167A-28CB,SOT23_77_LGA-8_WF2WF282ALGA-8TP26TESTPOINT_1_TEST_MINI_TESTPOINTTESTPOINTTEST_MINIU1RT9167A-28CB,SOT23_80_RT2808AGSRT7272BRT2808AGSPU4SY8120SY8120BSOT23-6U6RT9193_3_LGA14_ICM-62407-CICM-62407-CLGA14U8W25Q128JV/NC0RWSON8-50-0806LU9RT9167A-28CB,SOT23_6_LQFP100_STSTM32F407VGT6/STM32F4XXVXLQFP100U10RT9167A-28CB,SOT23_8_SOIC-8N_FMFM25V02/NCSOIC-8NU12RT9167A-28CB,SOT23_7_SOP-8_ADUMADuM1250/NCSOP-8U16EFM8BB21F16G-C-QFN20_EFM8BB21F1EFM8BB21F16G-C-QFN20EFM8BB21F16G-C-QFN20U17FD6288Q_QFN24-EP_FD6288Q-QFN25FD6288Q-QFN25QFN24-EPU24RT9167A-28CB,SOT23_82_LPCC16_QMQMC5883L/HMC5883L/NCLPCC16U25RT9167A-28CB,SOT23_80_RT2808AGSRT7272BRT2808AGSPU29U-TJA1057GT-3J_SOP8-P127-390X49SIT1040TSOP8-P127-390X490U34EFM8BB21F16G-C-QFN20_EFM8BB21F1EFM8BB21F16G-C-QFN20EFM8BB21F16G-C-QFN20U35FD6288Q_QFN24-EP_FD6288Q-QFN25FD6288Q-QFN25QFN24-EPU39RT9167A-28CB,SOT23_7_SOP-8_AD_1ADuM1250SOP-8U40RT9167A-28CB,SOT23_84_SOP-8_BL2BL24C256A-PARCSOP-8Y127MHZ_SMD3225_4P_XTAL_3225_24MH24MHzXTAL_3225
