NVIDIA HDMI DVI DP 4层挂2个GDDR5 显卡PCB文件 142
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBKT1BRACKET_ATX_2X_ALL-BRKT_2TAB_DVI_HDMI,151-10001-00XX-000-151-10001-00XX-000 BRKT_LP_2TAP_1_DVI_DP_2_HDMI_DPCN1CON_PCI_EXPRESS_NONPHY-X16-CON_PCIEXP_X16_EDGE,EDGEFINGER,1MM,N/A,N/A,N/A,N/A,NO,NO,50V,1.1A,065-00044-0000-000-065-00044-000A CON_FINGER_PEX_164D1D_3PIN_AC_SC70-6_DUAL-BAV99DW,1PAIR - SERIES CONNECTION,100V,0.5A,1V@50MA,0.215A,091-0035-000-091-0035-000 SC70_6D2D_SOT23-1N4148,SINGLE,75V,0.6A,1V@10MA,0.2A,090-0006-000-090-0006-000 SOT23D3D_3PIN_AA_SOT23-BAT54A,1PAIR - COMMON ANODE,30V,0.6A,1V@0.1A,0.2A,091-0003-000-091-0003-000 SOT23D4D_3PIN_AA_SOT23-BAT54A,1PAIR - COMMON ANODE,30V,0.6A,1V@0.1A,0.2A,091-0003-000-091-0003-000 SOT23D501D_3PIN_CC_SOT23-BAT54C,1PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0016-000-091-0016-000 SOT23D502D_3PIN_CC_SOT23-BAT54C,1PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0016-000-091-0016-000 SOT23D503D_3PIN_AC_SC70-6_DUAL-BAV99DW,1PAIR - SERIES CONNECTION,100V,0.5A,1V@50MA,0.215A,091-0035-000-091-0035-000 SC70_6FR1R_1206_F-1.8OHM,5%,0.25W,195-2664-000-1.8OHM,195-2664-0001.8ohm1206G1U_GPU_GB2C_64_BGA595-GP108-300-A1,GPU- DESKTOP,GP108-300-A1-GP108-300-A1 BGA_0595_P080_P084_P085_P090_P100_230X230J1CON_DISPLAYPORT_NORM_4GND-DISPLAYPORT_GASKET,RECEPTACLE,0.5MM,90,YES,NO,YES,YES,YES,N/A,N/A,080-0669-000-080-0669-000 CON_DP_020_SMT_RA_F_CJ2CON_DISPLAYPORT_NORM-DISPLAYPORT_SPRING,RECEPTACLE,0.5MM,90,YES,NO,YES,YES,YES,N/A,N/A,080-0422-000-080-0422-000 CON_DP_020_SMT_RA_F_BJ3CON_HDMI_HDMI_A_SMD-369FA19-0N101D-H,RECEPTACLE,0.5MM,90,YES,NO,YES,YES,YES,500VAC,0.5A,064-0173-000-064-0173-000 CON_HDMI_019_SMT_RA_F_P005_CJ4CON_DVI_D_DVI_D_SHLD-DVI-D_BLACK_SHD_CU,FEMALE,1.905MM,90,NO,YES,NO,YES,YES,N/A,N/A,065-0368-000-065-0368-000 CON_DVID_024_RA_F_SHDJ5HDR_1X4_NORM-HDR_1M4,MALE,2.0MM,VERTICAL,YES,YES,YES,800VAC,1A,074-0098-000-074-0098-000 CON_WAFER232_004_TH_ST_P020J6HDR_1X2_NORM-2503-WS5-02-LF,MALE,2.5MM,0,NO,YES,NO,250.0V,3.0 A,065-0594-000-065-0594-000 CON_HDR_001X002_TH_ST_M_P025_SHR_DL1L_SMD_4_5X4-180UH,FERRITE,20%,0.3A,0.3A,3.2OHM,[]@[ ],[ ],0DECIBEL,130-0133-000-130-0133-000,180UH180uHIND_NONRKO_SMD_045X040_BL2L_TH-0.36UH,[],20%,32A,40A,0.00052OHM,[ ]@[ ],[ ],[ ],131-0678-000-0.36UH,131-0678-0000.36uHIND_NONRKO_TH_105X075L3L_TH-0.36UH,[],20%,32A,40A,0.00052OHM,[ ]@[ ],[ ],[ ],131-0678-000-0.36UH,131-0678-0000.36uHIND_NONRKO_TH_105X075L4L_TH-0.47UH,METALDUST,20%,43A,53A,0.000864OHM,0@0HZ,0HZ,0DECIBEL,130-0917-000-0.47UH,130-0917-0000.47uHIND_NONRKO_TH_117X117_BL5L_TH-1UH,[],20%,15A,20A,0.00363OHM,[ ]@[ ],[ ],[ ],131-0661-000-131-0661-000,1UH1uHIND_NONRKO_TH_082X082L6L_TH-0.36UH,METALDUST,20%,40A,42A,0.00088OHM,0@0HZ,0HZ,0DECIBEL,130-0918-000-0.36UH,130-0918-0000.36uHIND_NONRKO_TH_102X078L7L_TH-0.36UH,METALDUST,20%,40A,42A,0.00088OHM,0@0HZ,0HZ,0DECIBEL,130-0918-000-0.36UH,130-0918-0000.36uHIND_NONRKO_TH_102X078L8L_SMD_5X5-2.2UH,[],20%,3A,3.5A,0.03OHM,[ ]@[ ],[ ],[ ],131-0489-000-131-0489-000,2.2UH2.2uHIND_NONRKO_SMD_058X052_CL9L_SMD_4X4-2.2UH,FERRITE,20%,3.15A,3.42A,0.0585OHM,[]@[ ],[ ],0DECIBEL,130-0838-000-130-0838-000,2.2UH2.2uHIND_NONRKO_SMD_040X040_HLB501L_BEAD_0603-30OHM,FERRITE,25%,5A,5A,0.01OHM,[],N/A,N/A,100-0049-000-100-0049-000,30OHM30ohmIND_SMD_0603LB510L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmIND_SMD_0402M1U_MEM_SD_DDR5_X32_BGA170-1.5GHZ,GDDR5,X32,1.455V,H5GC8H24MJR-T2C,161-0231-100-161-0231-100 BGA_0170_P080_140X120M2U_MEM_SD_DDR5_X32_BGA170_MIRR-1.5GHZ,GDDR5,X32,1.455V,H5GC8H24MJR-T2C,161-0231-100-161-0231-100 BGA_0170_P080_140X120MEC1MEC_SPRNG_SMD-MEC_SPRING_P394,N/A,N/A,0,YES,NO,NO,YES,NO,N/A,N/A,320-0145-000-320-0145-000 EMIPAD_059X035MEC2HEATSINK_4PIN-LP40W,320-0XXX-000-320-0XXX-000 HSA_GPU_LP40W_T_AL_1MEC3MEC_SPRNG_SMD-MEC_SPRING_P394,N/A,N/A,0,YES,NO,NO,YES,NO,N/A,N/A,320-0145-000-320-0145-000 EMIPAD_059X035Q1Q_FET_N_ENH_SOT323_1G1D1S-2N7002W-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4B SOT323Q2Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,[],0.6A,[ ],6V,0.3W,305-0005-000-305-0005-000 SOT23Q3Q_FET_N_ENH_SOT363-2N7002DW,60V,5000MOHM@10V/ 7500MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / []@2.B SC70_6Q4Q_FET_N_ENH_SOT23_1G1D1S-PZD502CMANV,20V,-1000MOHM@10V/ 213MOHM@4.5V / -1000MOHM@2.5V,1A,5A,16V,0.6W,[ ]@10V / [ ]@4.5V / [ ]B SOT23Q5Q_FET_N_ENH_SOT363-2N7002DW,60V,5000MOHM@10V/ 7500MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / []@2.B SC70_6Q6Q_FET_N_ENH_SOT23_1G1D1S-2N7002HG,60V,2000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.3A,0.8A,20V,0.35W,[ ]@10V / [ ]@4.5V / B SOT23Q7Q_FET_P_ENH_SOT323_1G1D1S-RU1C002ZP,-20V,-1000MOHM@10V/ 1200MOHM@4.5V / 1500MOHM@2.5V,-0.2A,-0.8A,10V,0.15W,[ ]@10V / 1.3NC@4B SOT323Q8Q_FET_N_ENH_SOT323_1G1D1S-2N7002W-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4B SOT323Q9Q_FET_N_ENH_SOT23_1G1D1S-PZD502CMANV,20V,-1000MOHM@10V/ 213MOHM@4.5V / -1000MOHM@2.5V,1A,5A,16V,0.6W,[ ]@10V / [ ]@4.5V / [ ]B SOT23Q10Q_FET_P_ENH_SOT323_1G1D1S-RU1C002ZP,-20V,-1000MOHM@10V/ 1200MOHM@4.5V / 1500MOHM@2.5V,-0.2A,-0.8A,10V,0.15W,[ ]@10V / 1.3NC@4B SOT323Q11Q_FET_N_ENH_SOT323_1G1D1S-2N7002W-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4B SOT323Q12Q_FET_N_ENH_SOT363-2N7002DW,60V,5000MOHM@10V/ 7500MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / []@2.B SC70_6Q13Q_FET_N_ENH_LFPAK-SM4507NHKP,30V,5.5MOHM@10V/ 8.7MOHM@4.5V / 0MOHM@2.5V,38A,120A,20V,1.6W,17NC@10V / 5.8NC@4.5V /0NC@2.5V,30B MULTI_SMD_SOT669_LFPAK_BQ14Q_FET_N_ENH_LFPAK-SM4507NHKP,30V,5.5MOHM@10V/ 8.7MOHM@4.5V / 0MOHM@2.5V,38A,120A,20V,1.6W,17NC@10V / 5.8NC@4.5V /0NC@2.5V,30B MULTI_SMD_SOT669_LFPAK_BQ15Q_FET_N_ENH_LFPAK-SM4503NHKPC-TRG,30V,3MOHM@10V/ 5.1MOHM@4.5V / 0MOHM@2.5V,60A,160A,20V,1.6W,30NC@10V / 9.2NC@4.5V /0NC@2.5VB MULTI_SMD_SOT669_LFPAK_BQ16Q_FET_N_ENH_LFPAK-SM4503NHKPC-TRG,30V,3MOHM@10V/ 5.1MOHM@4.5V / 0MOHM@2.5V,60A,160A,20V,1.6W,30NC@10V / 9.2NC@4.5V /0NC@2.5VB MULTI_SMD_SOT669_LFPAK_BQ17Q_FET_N_ENH_LFPAK-SM4503NHKPC-TRG,30V,3MOHM@10V/ 5.1MOHM@4.5V / 0MOHM@2.5V,60A,160A,20V,1.6W,30NC@10V / 9.2NC@4.5V /0NC@2.5VB MULTI_SMD_SOT669_LFPAK_BQ18Q_FET_N_ENH_DFN3X3-PE606BA,30V,18MOHM@10V/ 27MOHM@4.5V / [ ]@2.5V,10.6A,60A,20V,2.2W,7.5NC@10V / 4.3NC@4.5V / []@2.5V,300-09B DFET_SMD_032X033Q19Q_FET_N_ENH_DFN3X3-PE606BA,30V,18MOHM@10V/ 27MOHM@4.5V / [ ]@2.5V,10.6A,60A,20V,2.2W,7.5NC@10V / 4.3NC@4.5V / []@2.5V,300-09B DFET_SMD_032X033Q20Q_FET_N_ENH_SOT323_1G1D1S-2N7002W-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4B SOT323Q21Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 SC70_6Q22Q_FET_N_ENH_SOT323_1G1D1S-RJU003N03,30V,1900MOHM@10V/ 1900MOHM@4.5V / 1900MOHM@2.5V,0.3A,1.2A,12V,0.2W,[ ]@10V / [ ]@4.5V / SOT323Q501Q_FET_N_ENH_SOT323_1G1D1S-RJU003N03,30V,1900MOHM@10V/ 1900MOHM@4.5V / 1900MOHM@2.5V,0.3A,1.2A,12V,0.2W,[ ]@10V / [ ]@4.5V / SOT323Q502Q_FET_N_ENH_SOT323_1G1D1S-RJU003N03,30V,1900MOHM@10V/ 1900MOHM@4.5V / 1900MOHM@2.5V,0.3A,1.2A,12V,0.2W,[ ]@10V / [ ]@4.5V / SOT323Q503Q_FET_N_ENH_SOT363-2N7002DW,60V,5000MOHM@10V/ 7500MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / []@2.B SC70_6Q504Q_FET_N_ENH_SOT23_1G1D1S-2N7002HG,60V,2000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.3A,0.8A,20V,0.35W,[ ]@10V / [ ]@4.5V / B SOT23Q505Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 SC70_6Q506Q_FET_N_ENH_SOT23_1G1D1S-2N7002HG,60V,2000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.3A,0.8A,20V,0.35W,[ ]@10V / [ ]@4.5V / B SOT23Q507Q_FET_N_ENH_SOT323_1G1D1S-RJU003N03,30V,1900MOHM@10V/ 1900MOHM@4.5V / 1900MOHM@2.5V,0.3A,1.2A,12V,0.2W,[ ]@10V / [ ]@4.5V / SOT323Q508Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 SC70_6Q509Q_FET_N_ENH_SOT363-2N7002DW,60V,5000MOHM@10V/ 7500MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / []@2.B SC70_6Q510Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 SC70_6Q511Q_FET_N_ENH_SOT363-2N7002DW,60V,5000MOHM@10V/ 7500MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / []@2.B SC70_6Q512Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,[],0.6A,[ ],6V,0.3W,305-0005-000-305-0005-000 SOT23Q513Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 SC70_6Q514Q_FET_N_ENH_SOT323_1G1D1S-2N7002W-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4B SOT323TP501LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP502LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PU1U_VREG_3PIN_SOT223_GOI-AZ1117CH-ADJTRG1,LOWDROP OUT,1.2V@[ ],[ ]..[ ],1%,1.25V,15V,1A,[],315-0770-000-1.25V,315-0770-0001.25VSOT223U2U_VREG_3PIN_TO92-APL78L05ECTRG,LOWDROP OUT/FIXED,1.9V@[ ],[ ]..[ ],5%,[ ],30V,0.1A,[],315-0525-000-315-0525-000,[ ][]TO92_3_THU3U_SW_PWR_TPS2031_SO8-APL3516CKI,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-0597-000-115-0597-000 SO08_048X038U4U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 SC70_5U5U_OPENVREG_TYPE2PLUS_QFN3X3-UP1666QQKF,BUCK,2PH,1MHZ,DYNAMICVID,0MV..2V,1%,2V,20V,60A,1.47W,316-0467-000-2V,316-0467-0002VQFN020Q_P040_035X035_T017X017_CU6U_SWREG_UP6101_PSOP8-GS72V3SP-R,BUCK,1PH,300KHZ,NONE,-0.3V..18V,1%,0.6V,13.2V,[],1.333W,315-0872-000-0.6V,315-0872-0000.6VSO08_050X040_T035X028U7U_SWREG_SOT23_8HV_SOT23_8-RT7296FGJ8F,BUCK,1PH,500KHZ,NONE,0.807V..6V,1%,0.807V,17V,3A,1W,316-0472-000-0.807V,316-0472-0000.807VSOT23_8U8U_VREG_APL5910_SOP8-GS7133SO-R,ULTRALOW DROP OUT,[ ]@[ ],[ ]..[ ],2%,0.8V,5.5V,3A,[],315-0843-000-0.8V,315-0843-0000.8VSO08_050X040_T035X028U501U_MEM_FL_SER_512KX8_SO_8-50MHZ,1.65V..1.95V,W25Q40EWSNIG,170-0267-000-170-0267-000 SO08_048X038U502U_AND_2IN_SC70-5-NL17SZ08DFT2G,GATES- AND - 2 INPUT,115-1448-000-115-1448-000 SC70_5U503U_AND_2IN_SC70-5-NL17SZ08DFT2G,GATES- AND - 2 INPUT,115-1448-000-115-1448-000 SC70_5U504U_VREG_3PIN_SOT223_GOI-AZ1117CH-ADJTRG1,LOWDROP OUT,1.2V@[ ],[ ]..[ ],1%,1.25V,15V,1A,[],315-0770-000-1.25V,315-0770-0001.25VSOT223Y1XTAL_TH_HC49S-ESA27.0000F18M33FN,27MHZ,30PPM,5PPM,60PPM,18PF,FUNDAMENTAL,085-0178-000-085-0178-000,27MHZ27MHzXTAL_TH_2_110X046
PCB文件。赚15个金币。
