RTL8221B(I)-VB_RTL8221B(I)-VM_DataSheet_1.0 -For Magnimage.pdf
RTL8221B(I)-VM-CGINTEGRATED 10/100/1000M/2.5G ETHERNET TRANSCEIVER (SUPPORT MACSEC)
General Description
The Realtek RTL8221B(I)-VM-CG (hereafter referred to as the RTL8221B(I)-VM, except where differences exist) is a highly integrated Ethernet PHY transceiver that is compatible with 10BASE-Te, 100BASE-TX, 1000BASE-T, and 2.5GBASE-T, and is fully compatible with both the IEEE 802.3 standard and the NBASE-T™ Alliance PHY. It provides all the necessary physical layer functions to transmit and receive Ethernet packets over CAT.5e UTP cable.The RTL8221B(I)-VM provides a MACsec feature of IEEE MAC Security Standard protocol. The integrated functionality with MACsec security engines separate egress and ingress traffic and provides data integrity check, confidentiality and replay protect.
The RTL8221B(I)-VM uses state-of-the-art DSP technology and Analog Front End (AFE) to enable high-speed data transmission and reception over UTP cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, MDI swap, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, RFI protection, thermal management, loopback diagnostic capability, and error correction are implemented in the RTL8221B(I)-VM to provide robust transmission and reception capabilities.Data transfer between MAC and PHY is via the SERDES (Serializer-Deserializer) interface, which supports SGMII, HiSGMII, and 2500Base-X. The RTL8221B(I)-VM operates at various digital I/O voltages, including 3.3V and 1.8V.
Features
Compatible with IEEE 802.3, IEEE 802.3u, IEEE 802.3abSupports IEEE 802.3az (Energy Efficient Ethernet)Supports IEEE 802.3bz (2.5GBASE-T)Support MACsec compatible with IEEE 802.1AE, IEEE 802.1AEbn, IEEE 802.1AEbwSupports Full Duplex flow control (IEEE 802.3x)Supports IEEE 802.3 optional ability (Energy Efficient Ethernet and Fast Retrain)Integrated 10M BASE-Te and 100M/1000M/2.5GBASE-T IEEE 802.3 compatible transceiverSupports 2.5G Lite (1G data rate) modeAuto-Negotiation with Extended Next Page capability (XNP)Compatible with NBASE-TTM Alliance PHY SpecificationSupports pair swap/polarity/skew correctionCrossover Detection & Auto-CorrectionConfigurable MDI port ordering (MDI swap) for easy PCB layoutSupports hardware CRC (Cyclic Redundancy Check) functionSupports power down/link down power saving modeSupports clause 22 and Clause 45 MDC/MDIO management interfaceSupports rate adaptor for SerDesSelectable SERDES interface to MAC control (SGMII/HiSGMII/2500 BASE-X)Built-in Wake-on-LAN (WOL) over UTPSupports Interrupt function over UTPSupports Parallel DetectionSupports PHYRSTB core power Turn-OffBaseline Wander CorrectionSelectable 3.3/1.8V signaling for MMD accessSupports 25MHz crystal or external OSCProvides 25MHz clock source for MACProvides 3 network customized LEDs with controllable LED Blinking Frequency and Duty CycleSelf-Loopback diagnostic capabilityThermal management on PHY48-pin QFN Green Package22nm process with ultra-low power consumptionComplete hardware support for Synchronous Ethernet and Precision Time Protocol (PTP) including IEEE 1588v1, v2, and 802.1ASSupports SPI Flash (up to 24MB flash size)Industrial grade manufacturing process (RTL8221BI-VB/ RTL8221BI-VM)
Applications
DTV (Digital TV)MAU (Media Access Unit)CNR (Communication and Network Riser)Game ConsolePrinter and Office MachineDVD Player and RecorderEthernet HubEthernet SwitchBase Stations and ControllersRouters, DSLAMs, PON EquipmentTest and Measurement SystemsIndustrial and Factory Automation EquipmentMultimedia synchronization and Real Time Networking
