老吴 发表于 2013-8-2 10:42:52
ADSP-21369  核心板 PCB文件和原理图共享下载
ADSP-21369:面向通用性应用的高性能32位浮点SHARC处理器
第三代SHARC®处理器提供了更高的性能、以音频和应用为重点的外设和新的存储器配置。ADSP-21369的性能提升至400MHz,同时简化了算法开发并集成了高带宽和非常灵活的外部存储器接口。ADSP-21369基于一个单指令多数据(SIMD)内核,支持32位定点和32-/40位浮点运算格式,与以前的所有SHARC处理器代码完全兼容,可最大化地复用已有代码。ADSP-21369的片上存储器总数增加到2MB的SRAM和6M ROM,同时集成了各种音频专用和通用外设。多种片上外设如一个全数字化S / PDIF发射器/接收器、8通道异步采样率转换器、8个高速串行端口、4个精密时钟发生器以及多种串行接口相结合,可确保ADSP-21369实现最大的系统吞吐量,并将材料成本减至最低。
The third generation of SHARC® Processors offers increased performance, audio and application-focused peripherals, and new memory configurations. The ADSP-21369 increases performance to 400MHz while simplifying algorithm development with the integration of a high-bandwidth and very flexible external memory interface. The ADSP-21369 is based on a single-instruction, multiple-data (SIMD) core which supports both 32-bit fixed-point and 32-/40-bit floating point arithmetic formats and is completely code-compatible with all prior SHARC Processors allowing for maximum reuse of legacy code.
The ADSP-21369 increases the amount of on-chip memory to 2Mb SRAM and 6Mb ROM while integrating a variety of audio-specific and general purpose peripherals. Peripherals such as an all digital S/PDIF transmitter/receiver, 8-channel asynchronous sample rate converter, 8 high-speed serial ports, 4 precision clock generators, and multiple serial interfaces combine to ensure the ADSP-21369 maximizes system throughput while minimizing system bill of materials costs.
技术特性
400MHz SIMD SHARC内核,峰值性能可达2.4 GFLOPS2Mb SRAM、6 Mb客户可定义的ROM高带宽、32位外部存储器接口,支持与SDRAM、SRAM和闪存的无胶合接口数字音频接口(DAI)可实现对于系统外设的用户可定义访问,包括8个串行端口(SPORT)、S/PDIF Tx/Rx、8通道异步采样率转换器、4个精密时钟发生器数字外设接口(DPI)支持用户可定义的系统外设访问,包括2个SPI兼容端口、2个UART、3个全特性定时器和1个两线I2C接口34个零开销(zero-overhead)DMA通道16个PWM通道208引脚LQFP-EP和256焊球SBGA封装商业和工业温度范围对于LQFP封装,最大内核性能有所降低
技术指标
Clock Speed (MHz): 400MHzMMACs: 800On-Chip SRAM (Mbits): 2MbitSerial Ports: 8DAI: XPackage: MQFP,SBGASample Rate Converters: X
应用领域
医疗应用电话工业和仪器仪表
老吴 发表于 2013-8-2 10:44:13
**** Hidden Message *****
PCB文件和原理图一起打包了 PROTEL99格式
ydlxiaolong 发表于 2013-8-2 11:08:58
不错不错。
yigehaoren 发表于 2013-8-2 12:52:11
zj28000 发表于 2013-8-2 14:13:09
好东西啊。
fengyuchengy 发表于 2013-8-3 05:52:10
好多好东西,学习下!
yigehaoren 发表于 2013-8-3 09:14:59
scholler 发表于 2013-8-3 20:58:00
不错的资料,谢谢楼主分享
randy1022 发表于 2013-8-5 16:10:39
好东西!
lim123 发表于 2013-8-7 09:13:15
好东西,,,,
页: [1] 2 3
查看完整版本: ADSP-21369  核心板 PCB文件和原理图共享下载
