intel CPU NODE COMPACT 服务器板PCB 志强bga1667 H34774-002
REFDESCOMP_DEVICE_TYPESYM_NAMEC4J3CAP_0402LF-0.1UF,16V,10%,X7R,AASMC0402ACR2DIODE_SMLF-MBRA130LT3,IC,C7922ASCR1811ADS2LED_A1-GREEN,EMPTY,D14725-008SLEDR0603ADS3LED_A1-GREEN,IC,D14725-008SLEDR0603ADS4LED_A1-GREEN,IC,D14725-008SLEDR0603ADS5LED_A1-GREEN,IC,D14725-008SLEDR0603ADS6LED_A1-GREEN,IC,D14725-008SLEDR0603ADS7LED_A1-GREEN,IC,D14725-008SLEDR0603ADS8LED_A1-GREEN,IC,D14725-008SLEDR0603AEU1IR3899_SM-IC,G28504-001LCC17_20_16_5MAEU2TPS74801_A_SMLF-IC,D80648-001MLF10_12_50MBEU5TPS74801_A_SMLF-IC,D80648-001MLF10_12_50MBEU9TPS51200_SM-IC,E17764-001LCC10_12_5MBEU10ISL6353_B_SM2-IC,E98996-003LCC40_19_4MAEU12NCP5368_SM-IC,G91363-001QFN32_20_5MEEU14INA230_SM-IC,G98751-001LCC16_12_5MBEU15MOSFETN_1D3S_SO8-NFET,E99929-0ATDSON8_24_50IBEU17MOSFETN_1D3S_SO8-NFET,E99927-0ATDSON8_24_50IBEU18MAX34409_LCC-IC,H12741-001LCC16_16_65MAEU19NCP81111_QFN-IC,G91366-001QFN32_20_5MDEU20EN5367_QFN-IC,G58531-001QFN54_40_22_5MAEU25EN6337_QFN-IC,G17893-001QFN38_28_16_5MBEU28MOSFETN_1D3S_SOT5-IC,H16715-001SOT669AEU29NCP81111_QFN-IC,G91366-001QFN32_20_5MDEU30NCP5368_SM-IC,G91363-001QFN32_20_5MEF6FUSE_SMLF-IC,C94311-001SFU1812AF7FUSE_SMLF-IC,C94311-001SFU1812AF8FUSE_SMLF-IC,C94311-001SFU1812AFB1INDUCTOR_SM-100NH,IND,D92183-0ASMI1516AFB2FERRITE_SM-30,FB,656554-058SFB0805AFB3FERRITE_SMLF-30,FB,656554-032SFB0805AFB7FERRITE_SMLF-30,FB,656554-032SFB0805AFB12FERRITE_SMLF-30,FB,656554-032SFB0805AISO1GND_ISOLATION_SM-EMPTY,NAGND_ISOLATIONISO2GND_ISOLATION_SM-EMPTY,NAGND_ISOLATIONISO3GND_ISOLATION_SM-EMPTY,NAGND_ISOLATIONISO4GND_ISOLATION_SM-EMPTY,NAGND_ISOLATIONISO5GND_ISOLATION_SM-EMPTY,NAGND_ISOLATIONISO6GND_ISOLATION_SM-EMPTY,NAGND_ISOLATIONJ4J2SCONN260_H26868001_SMTCONN-CONASCONN260_H26868001J4J3SCONN260_H26871001_SMTCONN-CONASCONN260_H26871001J5E2SCONN60_C21100002_SMLF-CONN,C2ASCONN60_C21100002J5J2SCONN260_H26871001_SMTCONN-CONASCONN260_H26871001J5J3SCONN260_H26872001_SMTCONN-CONASCONN260_H26872001J1FCONN164K_A96883004A_UNB-EMPTYAFCONN164K_A96883004BJ2SCONN75K_H17033001_SMT2-SCONN,ASCONN75K_H17033001J3CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J6CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J9CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J18CONN2_A91829004_THLF-CONN,A918ACONN2_A91829004J19CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001J22CONN3_A91829001_THLF-CONN,A918ACONN3_A91829001L1INDUCTOR_SM-100NH,IND,D92183-0ASMI1516AL2INDUCTOR_SM-0.05UH,IND,H16948-ASMI2020EL4INDUCTOR_SM-3.3UH,IND,E13358-0ASMI2927EL7INDUCTOR_SMLF-230NH,IND,E16521ASMI4740AL8INDUCTOR_SM-100NH,IND,D92183-0ASMI1516AL9INDUCTOR_SMT-10UH,IND,721891-0ASMI0805DL12INDUCTOR_SM-0.22UH,IND,E98761-ASMI1919AMH1MTG_SPOKE_N125_TH4-EMPTY,N_AMTG_SPOKE_N125DMH2MTG_SPOKE_N125_TH4-EMPTY,N_AMTG_SPOKE_N125DMH3MTG_SPOKE_N125_TH4-EMPTY,N_AMTG_SPOKE_N125DMH4MTG_SPOKE_N125_TH4-EMPTY,N_AMTG_SPOKE_N125DQ1FET_N_SOT23LF-2N7002,EMPTY,C76ASOT23BQ3MOSFET_N_SOT323-IRLML6244,FET,ASOT23DQ5FET_N_DUAL_SMLF-2N7002DW,FET,DASSOP6_53_65MAQ6FET_N_DUAL_SMLF-2N7002DW,FET,DASSOP6_53_65MAQ7TTL1T45_SMT-IC,G44167-001SSOP6_53_65MBQ8NPN_SM-MMBT3904,IC,C52245-001SOT23BQ9NPN_DUAL_TMP_SSOPLF-MBT3904,XSASSOP6_53_65MAQ10NPN_DUAL_TMP_SSOPLF-MBT3904,XSASSOP6_53_65MARM1STANDOFF_TH1-SO,H18839-001STANDOFF169RT1THERMISTOR_SM-IC,220K,C14407-0ASTR0603BRT4THERMISTOR_SMLF-IC,100.0K,C144ASTR0603ART5THERMISTOR_SM-IC,220K,C14407-0ASTR0603BRT8THERMISTOR_SMLF-IC,10.0K,C1440ASTR0603ATH1CONN2_A13494008_THLF-TH,A13494ACONN2_A13494008TH2CONN2_A13494008_THLF-TH,A13494ACONN2_A13494008U5F1W25Q128_SOIC-IC,E62303-001SOI16_30_50IBU1MPC03DEF00_QFN-IC,G68599-001QFN25_25_8MAU2TTL4T245_TSSOP-74AVCH4T245,IC,ATSSOP16_18_65MDU3TTL4T245_TSSOP-74AVCH4T245,IC,ATSSOP16_18_65MDU4EPM570_FBGA100-IC,G77227-001BGA100_1_1MCU5PCA9555_SMLF-IC,C90179-001-VDDATSSOP24_18_65MAU6AT24C02_SOIC-IC,C82789-001-GNDASOI8_15_50IAU7PCA9617_SSOP-IC,G81764-001-GNDASSOP8_12_65MCU8FDMB3800_LCC-FDMB3800,FET,G419ALCC8_8_65MBU9MAX803X_SMT-MAX803S,IC,E15926-ASOT323AU10TTL4T245_TSSOP-74AVCH4T245,IC,ATSSOP16_18_65MDU11TTL4T245_TSSOP-74AVCH4T245,IC,ATSSOP16_18_65MDU13TTL1T45_SMT-IC,G44167-001SSOP6_53_65MBU15BDX_DE_EXT_B_BGA-IC,H31563-001BGA1667_5_BDXU17PCA9617_SSOP-IC,G81764-001-GNDASSOP8_12_65MCU18TTL1T45_SMT-IC,G44167-001SSOP6_53_65MBU19AT24C02_SOIC-IC,C82789-001-GNDASOI8_15_50IAU20PCA9617_SSOP-IC,G81764-001-GNDASSOP8_12_65MCU21TTL4T245_TSSOP-74AVCH4T245,IC,ATSSOP16_18_65MDU22TTL1G08_SOTLF-74LVC1G08,IC,C88BSSOP5_67_95MAU23TTL1G07_A_SOP-74LVC1G07,IC,C88BSSOP5_53_65MAU25ICS553_SOILF-IC,D10272-001-GNDASOI8_15_50ICU26TTL1T45_SMT-IC,G44167-001SSOP6_53_65MBU27TTL1T45_SMT-IC,G44167-001SSOP6_53_65MBU28TTL4T245_TSSOP-74AVCH4T245,IC,ATSSOP16_18_65MDU29SLB9660_SM-IC,H19115-001TSSOP28_18_65MCU30TTL1G07_A_SOP-74LVC1G07,IC,C88BSSOP5_53_65MAU31TTL1G07_A_SOP-74LVC1G07,IC,C88BSSOP5_53_65MAU32TPM_TSOP1-IC,H25979-001TSSOP28_18_65MCU33TTL1G07_A_SOP-74LVC1G07,IC,C88BSSOP5_53_65MAU34TTL1G07_A_SOP-74LVC1G07,IC,C88BSSOP5_53_65MAU35TTL1G07_A_SOP-74LVC1G07,IC,C88CSSOP5_53_65MAU59W25Q32_SOI8-IC,G98328-001SOI8_20_50IBY1D7CRYSTAL_2013-25.000MHZ,IC,H196ASMY1310AY2CRYSTAL_2013-25.000MHZ,IC,H196ASMY1310AY3CRYSTAL_SM-32.768KHZ,IC,C13544ASMY1306A PCB文件,没原理图。回复可见
**** Hidden Message ***** 强 谢谢分享
