2007年经典产品-TCL王牌彩电HD29E64S(IV22机芯) PCB文件原理图固
当时做一个电视真不容易。现在基本上一个芯片搞定。 当时做一个电视,主芯片很弱,比如你要输入你要输入HDMI 信号,要加一个 SII9023 做HDMI 转RGBTTL信号。 要输入视频信号还要加一个 TVP5147 这种模数转换芯片转换。。NamePart TypePCB DecalValueDM1DIO-MELFMELF1N4148DM2BAV99SOT23bav99DM3DIO-MELFMELF1N4148DM4BAV99SOT23bav99DM5DIO-MELFMELF1N4148DM8BAV99SOT23bav99DM54BAV99SOT23bav99DM301DIO-MELFMELF1N4148DM601DIO-MELFMELF1N4148DM602DIO-MELFMELF1N4148DM603DIO-MELFMELF1N4148DM604DIO-MELFMELF1N4148DM701DIO-MELFMELFNCDM702BAV99SOT23bav99DM703BAV99SOT23bav99DM704BAV99SOT23bav99DM708DIO-MELFMELF1N4148DM709DIO-MELFMELF1N4148DM710DIO-MELFMELF1N4148DM711DIO-MELFMELF1N4148DM901D(12.5)D(12.5)1N4001DM902D(12.5)D(12.5)1N4001DM903DIO-MELFMELF1N4148ICM01ENME0509PLCC44-MTV230ICM02ST24C16DIP8ICM03KM432S2030CTSOP86ICM04TVP5147TVP5147ICM05AMS1117AS1117AMS1117-3V3ICM06AS1117AS1117AMS1117-3.3VICM07AMS1117AS1117AMS1117-1V8ICM10IV0302PQFP208ICM11AMS1117AS1117AMS1117-3V3ICM13AMS1117AS1117AMS1117-1V8ICM19ST24C02SO-8ICM20ST24C02SO-8ICM301TB1307FGPQFP48ICM601SII9023TQFP-144SII9023CTUICM602AMS1117AS1117ASM1117-1V8ICM603AMS1117AS1117ASM1117-3V3ICM701FS-TUNER(B)TUNER(B)ICM702TDA9881TSSSOP24TDA9881TSICM703R2S15900SPSOP28R2S15900SPICM7044052SO16MBcd74hc4052ICM801780578057809ICM901TDA7495SSATDA7495SSATDA7495SSAICMARK1ICMARKICMARKICMARK2ICMARKICMARKICMARK3ICMARKICMARKICMARK4ICMARKICMARKICMARK5ICMARKICMARKICMARK6ICMARKICMARKLM01INDU-0805FB0805FBLM1AINDU-06036033.3UHLM2INDU-0805FB0805EMI 100MHZ 100RLM3INDU-06036033.3UHLM03INDU-10051005MIL100UHLM4INDU-10051005MILFBLM5INDU-10051005MIL2.2UHLM6INDU-10051005MILFBLM08INDU-10051005MIL100uHLM10INDU-10051005MILncLM11INDU-0805FB0805EMI 100MHZ 100RLM12INDU-0805FB0805EMI 100MHZ 100RLM13INDU-10051005MIL4.7UHLM14INDU-10051005MIL4.7uHLM15INDU-06036033.3UHLM16INDU-0805FB0805EMI 100MHZ 100RLM32INDU-10051005MIL2.2UHLM33INDU-10051005MIL2.2UHLM35INDU-1210121010UHLM36INDU-0805FB0805EMI 100MHZ 100RLM37INDU-0805FB0805EMI 100MHZ 100RLM38INDU-0805FB0805EMI 100MHZ 100RLM301INDU-10051005MIL100UHLM302INDU-10051005MIL100UHLM303INDU-10051005MIL100UHLM601INDU-10051005MILFBLM602INDU-10051005MILFBLM603INDU-10051005MILFBLM604INDU-10051005MILFBLM701AINDU-10051005MIL100UHLM702AINDU-10051005MIL100UHLM704INDU-10051005MIL100UHLM706INDUL100.82uH or 1uhLM707INDU-10051005MIL100uhLM708INDU-10051005MIL100UHLM709EMI-FILEMI-FILEMI FILTER COIL 17.5T : 17.5TLM710EMI-FILEMI-FILEMI FILTER COIL 17.5T : 17.5TLM711EMI-FILEMI-FILEMI FILTER COIL 17.5T : 17.5TLM716INDU-10051005MIL100UHLM718INDU-10051005MIL100UHLM802PK-L5(10)PK-L5(10)100UHPCBMARK1PADS-TESTPCBMARKPCBMARK2PADS-TESTPCBMARKPCBMARK3PADS-TESTPCBMARKPCBMARK4PADS-TESTPCBMARKPCBMARK5PADS-TESTPCBMARKPCBMARK6PADS-TESTPCBMARKPCBMARK7PADS-TESTPCBMARKQM01SMD_NPNSOT232SC1815QM2SMD_NPNSOT23QM03SMD_NPNSOT23QM04SMD_NPNSOT23QM5PNPSOT232SA1015QM6PNPSOT232SA1015QM7PNPSOT232SA1015QM13SMD_NPNSOT232SC1815QM14SMD_NPNSOT232SC1815QM15SMD_NPNSOT232SC1815QM16SMD_NPNSOT232SC1815QM31PNPSOT232SA1015QM302PNPSOT232SA1015QM303PNPSOT232SA1015QM304PNPSOT232SA1015QM601NDC7002NSOT_6QM602NDC7002NSOT_6QM701SMD_NPNSOT232SC1815QM705SMD_NPNSOT232SC1815QM706NPNQQM708SMD_NPNSOT232SC1815QM709SMD_NPNSOT232SC1815QM710SMD_NPNSOT232SC1815QM717SMD_NPNSOT232SC1815QM718PNPSOT232SA1015QM719PNPSOT232SA1015QM720SMD_NPNSOT232SC1815QM801KTC2026YTO-220ISQM901SMD_NPNSOT232SC1815QM903PNPSOT232SA1015RM801R(12.5-15)1WR(12.5-15)1W3.3KRM802R(10)1/4WR(10)1/4W2KRM901R(10)1/4WR(10)1/4W2.2RRM902R(10)1/4WR(10)1/4W2.2RRM903RCF/40805-15.6KRNM6064RARP8\4R\SMD47R*4S1S1AS1AS2SCREW_4SCREW_01S3S1AS1AS4SCREW_9_4SCREW_9_4S5SCREW_9_4SCREW_9_4S6SCREW_5SCREW_5S7S1AS1AS8SCREW_9_4SCREW_9_4S9S1AS1AS10S1AS1AS11S1AS1AS12S1AS1AS13SCREW_9_4SCREW_9_4S14SCREW_9_4SCREW_9_4S17SCREW_9_4SCREW_9_4S18SCREW_9_4SCREW_9_4SR1SCREW_SRSCREW_SRSR2SCREW_SRSCREW_SRSR3SCREW_SRSCREW_SRSR4SCREW_SRSCREW_SRSR5SCREW_SRSCREW_SRSR6SCREW_SRSCREW_SRSR7SCREW_SRSCREW_SRSR8SCREW_SRSCREW_SRSR9SCREW_SRSCREW_SRSR10SCREW_SRSCREW_SRVRM701VR3RDJ-3PW1H34628AH34628W6H34628AH34628XM1CON3CON\2.5MM\3PIN\AXM2CON9/BCON\2.5MM\9PIN\BXM2ACON9/BCON\2.5MM\9PIN\BXM3CON6CON\2.5MM\6PIN\AXM4CON3CON\2.5MM\3PIN\AXM5CON2\XSIP\2P\XXM8CON5CON\2.5MM\5PIN\AXM09CON9CON\2.5MM\9PIN\AXM11CON5CON\2.5MM\5PIN\AXM13CON15CON\VGAAAAXM601CON\HDMICON_HDMI\SM\RAXM602CON\HDMICON_HDMI\SM\RAXM706CON2\XSIP\2P\XXM712CON2SIP\2PXM714AV-12P12P_AVXM717CON11CON\2.5MM\11PIN\AXM801CON13CON\2.5MM\13PIN\AXM901CON2SIP\2PXM902CON2SIP\2PZDM1DIODEZ-LMLL34L5V1ZDM80603ESDA6030603ESDAZDM90603ESDA6030603ESDAZDM100603ESDA6030603ESDAZDM11DIODEZ-LMLL34L6.2VZDM12DIODEZ-LMLL34L5.6VZDM13DIODEZ-LMLL34L6.2VZDM14DIODEZ-LMLL34L6.2VZDM15DIODEZ-LMLL34L33VZDM300603ESDA6030603ESDAZDM310603ESDA6030603ESDAZDM802KA33VZD10KA33VZM01CRYSTALXTAL5.022.1184MHZZM02CRYSTALXTAL5.014.318MHZZM03CRYSTALXTAL5.014.318MHZZM4CRYSTAL(T)XTAL5.0-T12MHZZM601CRYSTALXTAL5.027MHZZM704CRYSTALXTAL5.04MHZZM706SAW-SIP5SAW-SIP5K9352ZM707SAW-SIP5SAW-SIP5K6274D 整套资料一起打包。回复可见
**** Hidden Message ***** 还是以前的电视好,用个10几年都没有问题,还有很多免费的电视台,现在的电视就相当于一个显示器一样,电视台一个都收不到。 非常感谢楼主大神的分享 非常感谢分享 看起来好复杂 经典内容,学习到了!!!
