Lattice LCMXO3LF-4300C-5BG400I +ADG708BRUZ+TPL930ADJ-QF6R
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1N-MOSFET-SOT23_SOT-23_NDS331NNDS331NSOT-23D2N-MOSFET-SOT23_SOT-23_NDS331NNDS331NSOT-23D3N-MOSFET-SOT23_SOT-23_NDS331NNDS331NSOT-23D6N-MOSFET-SOT23_SOT-23_NDS331NNDS331NSOT-23F1UPZ1608U700-4R0TF_F0603_UPZ1608UPZ1608U700-4R0TFF0603F2UPZ1608U700-4R0TF_F0603_UPZ1608UPZ1608U700-4R0TFF0603F3UPZ1608U700-4R0TF_F0603_UPZ1608UPZ1608U700-4R0TFF0603F4UPZ1608U700-4R0TF_F0603_UPZ1608UPZ1608U700-4R0TFF0603F5UPZ1608U700-4R0TF_F0603_UPZ1608UPZ1608U700-4R0TFF0603H1HOLE_1.2_7_P_HOLE_3R0_5R0_HOLEHOLEP_HOLE_3R0_5R0H2HOLE_1.2_7_P_HOLE_3R0_5R0_HOLEHOLEP_HOLE_3R0_5R0H3HOLE_2_0.6_HOLE87_HOLEHOLEHOLE87H4HOLE_2_0.6_HOLE87_HOLEHOLEHOLE87H5HOLE_2_0.6_HOLE87_HOLEHOLEHOLE87H6HOLE_2_0.6_HOLE87_HOLEHOLEHOLE87H7HOLE_2_0.6_HOLE87_HOLEHOLEHOLE87H8HOLE_2_0.6_HOLE87_HOLEHOLEHOLE87HL1LED_SMT_1_LED_SMT_0603_0603603LED_SMT_0603HL2LED_SMT_1_LED_SMT_0603_0603603LED_SMT_0603HL3LED_SMT_1_LED_SMT_0603_0603603LED_SMT_0603HL6LED_SMT_1_LED_SMT_0603_0603603LED_SMT_0603J1SMP-JHD1B_SMP-JHD1B_SMP-JHCD1SMP-JHCD1SMP-JHD1BJ2SMP-JHD1B_SMP-JHD1B_SMP-JHCD1SMP-JHCD1SMP-JHD1BR1R_0402R-N_6K256K250402R-NR2RES_0402R-N_4.7K4.7K0402R-NR3RES_1206R-N_0.0150.0151206R-NR4RES_0402R-N_10K/NC10K/NC0402R-NR5RES_0402R-N_10K10K0402R-NR6R_0402R-N_10K10K0402R-NR7RES_0402R-N_SMD-0402-17.4K-1/16SMD-0402-17.4K-1/16W+/-1%0402R-NR8RES_0402R-N_SMD-0402-17.4K-1/16SMD-0402-17.4K-1/16W+/-1%0402R-NR9RES_0402R-N_SMD-0402-17.4K-1/16SMD-0402-17.4K-1/16W+/-1%0402R-NR125RES_0402R-N_SMD-0402-4.7K-1/16WSMD-0402-4.7K-1/16W+/-1%0402R-NTP1TESTPOINT_TP_SMD_2R0_SYNC_INSYNC_INTP_SMD_2R0TP2TESTPOINT_TP_SMD_2R0_SYNC_INSYNC_INTP_SMD_2R0TP3TESTPOINT_TPS-0R80_VCC_3V3VCC_3V3TPS-0R80U1TPS82130_0_SIL0008D_SMD_MUN12ADMUN12AD03-SE/CyntecSIL0008D_SMDU2TPS7A8400RGRR_0_RGR0020A_TPL930TPL930ADJ-QF6RRGR0020AU3MAX4173TEUT+T_SOT23-6_MAX4173TMAX4173TSOT23-6U4TPS82130_0_SIL0008D_SMD_MUN12ADMUN12AD03-SE/CyntecSIL0008D_SMDU5TPS7A8400RGRR_0_RGR0020A_TPL930TPL930ADJ-QF6RRGR0020AU6MAX4173TEUT+T_SOT23-6_MAX4173TMAX4173TSOT23-6U7TPS82130_0_SIL0008D_SMD_MUN12ADMUN12AD03-SE/CyntecSIL0008D_SMDU8TPS7A8400RGRR_0_RGR0020A_TPL930TPL930ADJ-QF6RRGR0020AU9TPS82130_0_SIL0008D_SMD_TPS8213TPS82130SIL0008D_SMDU10MAX4173TEUT+T_SOT23-6_MAX4173TMAX4173TSOT23-6U11LCMXO3LF-4300C-5BG400I_2_BGA400LCMXO3LF-4300C-5BG400IBGA400_17X17_0_8U122MM_0_CON21VP2R00-6TM-55932_2MM2mm_1x6/NCCON21VP2R00-6TM-55932U137X-25.000MBA-T_CO4P-3R2X2R5-SM-OXETGLJANF-25MHzCO4P-3R2X2R5-SM-NU14SN74LVC1G32QDBVRQ1_0_SOT-23-5_SSN74LVC1G32QDBVRQ1SOT-23-5U15TPS22918_SOT23-6-N_TPS22918DBVRTPS22918DBVR-TISOT23-6-NU16MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU17MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU18MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU19MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU20MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU21MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU22MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU23MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU24MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU25MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU26MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU27MC1B144AIP_MC1B144AIP_MC1B144AIMC1B144AiPMC1B144AIPU28ADG708BRUZ_1_RU_16_ADG708BRUZADG708BRUZRU_16U29TMP75AIDGKT_TSSOP8-0R65-3R00-N_TMP75AIDGKTTSSOP8-0R65-3R00-NU30ADG708BRUZ_1_RU_16_ADG708BRUZADG708BRUZRU_16U31AD7476ARTZ_0_RJ_6_AD7476ARTZAD7476ARTZRJ_6X161083-204009_4_528850874_528850528850874528850874X261083-204009_5_528850874_528850528850874528850874 谢谢分享,学习一下。 谢谢分享
