armclub 发表于 2023-6-16 18:43:58
雷蛇音响 ACM8625+PCM9211PTR+ETA1188 方案PCB 原理图 datasheet等
CommentPatternQuantityComponents0Ω DNP0603_R1R520603WAF0000T5E0Ω0603_R3R4, R12, R510603WAF0000T5E1.5KΩ0603_R1R270603WAF1501T5E
C22843100nF0603_C16C3, C6, C11, C24, C35, C38, C40, C41, C43, C44, C47, C58, C78,C83, C85, C87CL10B104KO8NFNC100uFCAP_AL_SMT_100uF2C1, C26EEEHA1V101P
JLC C336419100Ω0603_R1R20603WAF1000T5E
JLC C2277510KΩ0603_R8R6, R15, R24, R33, R35, R44, R45, R570603WAF1002T5E
JLC C2580410nF0402_C2C19, C88GRM155R71H103KA88D10nF0603_C1C68GRM155R71H103KA88D10pF0603_C5C63, C64, C65, C66, C67CL10C100JB8NNNC10uF0603_C10C2, C36, C37, C39, C42, C46, C54, C56, C59, C77CL10A106KP8NNNC10uFCAP_SMT_AL_10uF_DC2C29, C30EMVE160ADA100MD55G10uHINDUCTOR 4.7_10 TOGETHER4L1, L2, L3, L41274AS-H-100M=P3, Murate110pF0603_C2C21, C22CC0603JRNPO9BN11116.2KΩ0603_R2R13, R14AC0603FR-0716K2L1KΩ0603_R2R11, R420603WAF1001T5E
C211901nF0603_C4C31, C32, C33, C34CL10B102KB8NNNC
JLC C15881uF0603_C5C7, C18, C55, C79, C86CL10A105KB8NNNC2.2KΩ0603_R4R7, R8, R53, R540603WAF2201T5E2.2uF0603_C2C81, C82CL10A225KO8NNNC
JLC C236302.2uHINDUCTOR_SLO0630H2R2MTT1L6SLO0630H2R2MTT200KΩ0603_R2R25, R260603WAF2003T5E
JLC C25811200Ω0603_R1R410603WAF2000T5E
JLC C821820pF0402_C2C51, C53GRM1555C1H200JA01D210KΩ0603_R1R320603WAF2103T5E
JLC C22952220nF0603_C1C50CL10B224KB8NNNC
JLC C6470522pF0603_C1C52CL10C220JB8NNNC
JLC C165322uF0805_C12C4, C23, C45, C62, C69, C70, C71, C72, C73, C74, C75, C76C2012X5R1V226M125AC
JLC C217940923.2KΩ ±1%0603_R1R9RC0603FR-0723K2L27pF0603_C2C60, C61CL10C270JB8NNNC
JLC C16562KΩ0603_R1R5AC0603FR-072KL2N7002-7-FMOSFET, N-CH, 2N7002-7-F1Q12N7002-7-F
JLC C8504933Ω0603_R3R20, R21, R220603WAF330JT5E
JLC C231404.7KΩ0603_R7R1, R3, R10, R47, R48, R50, R550603WAF4701T5E
JLC C231624.7nF0603_C1C270603B472K500NT
JLC C539874.7uF0603_C7C5, C8, C15, C25, C48, C49, C84GRM188R6YA475KE15D4.7uHINDUCTOR_SWPA60 series1L5SWPA6045S4R7NT470KΩ0603_R1R290603WAF4703T5E
JLC C23178470nF0603_C4C10, C13, C14, C16CL10B474KA8NNNC
JLC C162349.9Ω0603_R6R30, R36, R37, R38, R39, R400603WAF499JT5E5.1KΩ0603_R1R28RC0603JR-075K1L51KΩ0603_R1R460603WAF5102T5E
JLC C231965A, 4.5-30V Sync BuckConverterSO8E1U14SY8205FCC, 5A, 4.5-30V Sync Buck Converter5V_EXTtestpoint_SMD1TP5Testpoint SMT5V_LDOTie_point1T12680nF1206_C4C9, C12, C17, C20CL31B684KBHNNNE
JLC C307578680Ω0603_R1R230603WAF6800T5E
JLC C2322868KΩ0603_R1R430603WAF6802T5E
JLC C2323168nF0603_C1C28CL10B683KB8NNNC
C3165868Ω0603_R4R16, R17, R18, R190603WAF680JT5E
JLC C2759273.2K0603_R1R31AC0603FR-0773K2L8K2 ±1%0603_R1R56AC0603FR-078K2LACM8625TSSOP28PP ACM3128 BIG LF1U1ACM8625; TSSOP 28ADR/GPIO2Header, 100mil, 2pins1J3PZ254V-11-02PAnalog Input3.5mm_Audio_Jack_35RASMT4BHNTRX1J735RASMT4BHNTRXBATTerminal_R2.31T9BCLK_TPtestpoint_SMD1TP7Testpoint SMTBCLKHeader, 100MIL, 3PINS1J4PZ254V-11-03PCH341TCH3411U11CH341TCLASSHHeader, 100mil, 2pins1J8PZ254V-11-02PClassHtestpoint_SMD1TP17Testpoint SMTCP2112 F03 GMRCP21121U13CP2112-F03-GM, QFN24
C2678020 JLCDVDDHeader, 100MIL, 3PINS1J13PZ254V-11-03PETA1188QFN3X3FC_20P1U12ETA1188Fault0603_R1D1XL-1608SURC-04FSYNC_TPtestpoint_SMD1TP8Testpoint SMTFSYNCHeader, 100MIL, 3PINS1J5PZ254V-11-03PGNDTerminal_R2.31T6GNDtestpoint_SMD3TP10, TP11, TP18Testpoint SMTGPIO1/SDOUTHeader, 100mil, 2pins1J12PZ254V-11-02Pheatsink_bottomHeatsink_bottom1H1Keystone 5102Jumper Link surface1J2Keystone 5102LDO, 1A, DFN3x3-6, VIN1.6-5.5VDFN3x3-62U9, U10NA0603_C1C800603CG220G500NTNA0603_R1R49OUT_L-Terminal_R2.31T2OUT_L+Terminal_R2.31T1OUT_R-Terminal_R2.31T3OUT_R+Terminal_R2.31T4OUTA-_PWMtestpoint_SMD1TP2Testpoint SMTOUTA+_PWMtestpoint_SMD1TP1Testpoint SMTOUTB-_PWMtestpoint_SMD1TP3Testpoint SMTOUTB+_PWMtestpoint_SMD1TP4Testpoint SMTPCM9211PTRLQFP48_PCM92111U5digikey part number:296-27688-2-ND
PCM9211PTR
JLC C181660PDNzSwitch Button - Small1S1TL3365AF180QG, E-SwitchPower ON0603_R1D4BL-HGE36G-AV-TRBPVDD_BSTTie_point1T8PVDD_EXTTie_point1T7PVDDTerminal_R2.31T5SCLHeader, 100MIL, 3PINS1J9PZ254V-11-03PSCLtestpoint_SMD1TP12Testpoint SMTSDAHeader, 100MIL, 3PINS1J10PZ254V-11-03PSDAtestpoint_SMD1TP13Testpoint SMTSDIN_TPtestpoint_SMD1TP6Testpoint SMTSDINHeader, 100MIL, 3PINS1J6PZ254V-11-03PSN74AVC4T774RSVSN74AVC4T774RSV (UQFN16)1U3SN74AVC4T774RSVSN74LVC1G14DCKRSN74LVC1G14DCKT1U6JLC C35740SP0503BAHTGSP0503BAHTG-SOT143-4_V1D3JLC C7074
TVS Diode Array, 30 pF, 30 KV, -40 to 85 degC, 4-Pin SOT143, RoHS, Tape andReelSPDIF-INPLR135_T101U4PLR135/T10SPDIF-LOCK0603_R1D2XL-1608BGWC-06SPDIF-OUTEAPLTAA41U7EAPLTAA4TCA9406DCURTCA9406DCUR (DCR R-PDS0-G8)1U2Voltage Level TranslatorBidirectional 1 Circuit 2 Channel 24Mbps 8-VSSOP
A 1.65V~3.6V; B 2.3V~5.5VTYPECtype c_type21J11KH-TYPE-C-16PVR_DIGtestpoint_SMD1TP9Testpoint SMTVREG_AVDDtestpoint_SMD1TP16Testpoint SMTXTALXTAL-5x3.21Y2TXM12.000M2503LDCE-O00TXTALXTAL-ABM101Y1ABM10-24.576MHZ-E20-T
armclub 发表于 2023-6-16 18:45:29
全部资料都上传了。
调试相关工具软件
AudioTuningSetup_1.3.1 调试工具和授权license
分包压缩,必须要所有都下载到同一个文件夹,如果下载过程中文件名变了必须要改成论坛显示的文件名才能解压。
yyddny 发表于 2023-6-16 19:02:38
leslie_aqiang 发表于 2023-6-16 19:35:16
rockchips 发表于 2023-6-16 19:39:39
zspdeyc 发表于 2023-6-16 20:49:35
995823615 发表于 2023-6-16 23:20:48
xiaobaitu 发表于 2023-6-17 00:11:49
nj20044 发表于 2023-6-17 00:17:37
kanxue_nmg 发表于 2023-6-17 05:57:06
页: [1] 2 3 4 5 6
查看完整版本: 雷蛇音响 ACM8625+PCM9211PTR+ETA1188 方案PCB 原理图 datasheet等
