RK3308 做的一个AI智能语音音箱PCB和原理图
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT6001ANT_1P2G_ANT_JACK_ANT_JACKANT_JACKANT_JACKCN2CON3_0.25MM_3P-2R54_3P-2R543P-2R543P-2R54ED802DIODEBI_DIR TRIG_ESD0402_ESD_1ESD5471XESD0402ED803DIODEBI_DIR TRIG_ESD0402_ESD_1ESD5471XESD0402ED804DIODEBI_DIR TRIG_ESD0402_ESD_1ESD5471XESD0402ED805DIODEBI_DIR TRIG_ESD0402_ESD_1ESD5471XESD0402ED2502DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402ED7300DIODEBI_DIR TRIG_ESD0402_ESD9NESD9N12BAESD0402ED7301DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402ED9200DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402ED9600DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402ED9601DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402FB2200BEAD_L0603_180R-100M180R-100ML0603FB2500INDUCTORCOM_L0603D_90R-100M90R-100ML0603DFB7300BEAD_L0603_300R-100M300R-100ML0603FB7301BEAD_L0603_300R-100M300R-100ML0603J7300JACK_1500_1_2P_10T-LT-NA_2P_10T2P_10T-LT-NA2P_10T-LT-NAJ7502USB20_MICRO_0_7P_10T-LT-NA_7P_17P_10T-LT-NA7P_10T-LT-NAL2200INDUCTORSOF FERRITE_IND_2520122.2uHIND_252012L2201INDUCTORSOF FERRITE_IND_2520122.2uHIND_252012L2202INDUCTORSOF FERRITE_IND_3030153.3uHIND_303015L2203INDUCTORSOF FERRITE_IND_3030153.3uHIND_303015L6000INDUCTOR_L0402_DNPDNPL0402L6001INDUCTOR_L0402_DNPDNPL0402L6002INDUCTORSOF FERRITE_IND_3030153.3uHIND_303015L6003RESISTOR_L0603_470NH470nHL0603LED1300RGBLED_2_LED_4P_RGBLEDRGBLEDLED_4PLED1301RGBLED_2_LED_4P_RGBLEDRGBLEDLED_4PMIC802SPH6611LR5H-1_A-MIC5_3R50X2R65XSPH6611LR5H-1A-MIC5_3R50X2R65X0R98MIC803SPH6611LR5H-1_A-MIC5_3R50X2R65XSPH6611LR5H-1A-MIC5_3R50X2R65X0R98MIC804SPH6611LR5H-1_A-MIC5_3R50X2R65XSPH6611LR5H-1A-MIC5_3R50X2R65X0R98MIC805SPH6611LR5H-1_A-MIC5_3R50X2R65XSPH6611LR5H-1A-MIC5_3R50X2R65X0R98Q1800NPN_SOT_23_S8050S8050SOT_23Q5202NPN_SOT_23_S8050S8050SOT_23Q6000NPN_SOT_23_S8050S8050SOT_23Q6001NPN_SOT_23_S8050S8050SOT_23Q6002NPN_SOT_23_S8050S8050SOT_23U1000RK3308_BGA355_52R00X52R00X44R00RK3308BGA355_52R00X52R00X44R00U2200DCDC_SY8088_SOT_23_5_SY8089AACSY8089AACSOT_23_5U2201DCDC_SY8088_SOT_23_5_SY8088AACSY8088AACSOT_23_5U2202LDO_TT2102_SOT_23_5_LP3983SAB5FLP3983SAB5F-08SOT_23_5U2203DCDC_SY8088_SOT_23_5_SY8088AACSY8088AACSOT_23_5U2204DCDC_SY8088_SOT_23_5_SY8088AACSY8088AACSOT_23_5U2205LDO_PT5108_SOT_23_5_PT5108E23E-PT5108E23E-18SOT_23_5U2501ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FSOT_23U3000DDR3_16BIT_FBGA96_14R00X11R00X1K4B2G1646F-BYK0FBGA96_14R00X11R00X1R20U4100NANDFLASH_TSOP48_TSOP48_18R40X1GD9FU1G8F2AMGTSOP48_18R40X12R10X1R20U4201SPI_FLASH_8PIN_SOP8_5R40X5R40X2EN25Q32B-104HIPSOP8_5R40X5R40X2R20U4301NANDFLASH_TSOP48_0_BGA24_8RX6RXPN27G02ABGITGBGA24_8RX6RX1RU6000MODULE_AP6XXX_MD44_AP6XXX_RTL87RTL8723DSMD44_AP6XXXU7300XA8872_ESOP8_4R90X6R00X1R75_XA8XA8872ESOP8_4R90X6R00X1R75U9101LCD_HITACHI_TX05D99VM1AAA_4_QFNAW9163QFN3MMX3MM_20LY1100CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzCRY4_3R20X2R50X0R80Y6000CRYSTAL_4P_CRY4_3R20X2R50X0R8_137.4MHzCRY4_3R20X2R50X0R80 PCB文件和原理图 一起打包。回复可见
**** Hidden Message ***** 感谢分享。 学习一下 学习一下 好好学习。。。
