TI OMAP4440 8层两介盲埋孔设计PCB(LAN9514+TFP410
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT1ANTENNA2_4GHZCHIP_SMD_16X44_2_42_4GHzAntennaSMD_16X44C23747UFCAPACITOR6.3V20%0805_SM-73547uFSM-7351-CAP-0805D1LED_LTST-C150GKT_GRNGRNLTST-C150GKTD2LED_LTST-C150GKT_GRNGRNLTST-C150GKTD3LED_RED_SML-LX0603IW_OCT0107_SMSML-LX0603IW-TRSM-LED-LX0603D4PGB0010603MR_0_F603-41X39_PGB00PGB0010603MRF603-41X39D5PGB0010603MR_0_F603-41X39_PGB00PGB0010603MRF603-41X39D6PGB0010603MR_0_F603-41X39_PGB00PGB0010603MRF603-41X39D7PGB0010603MR_0_F603-41X39_PGB00PGB0010603MRF603-41X39D8111-1004104_POWERDI-123_DISCRETDFLS130L-7POWERDI-123F1111-1004093_SM_LITTELFUSE_0435_1.5A_QuickBlowSM_LITTELFUSE_0435GND1CONN_TP_HOOP_SMT_SM-TP-5016_IO_SMT_CON_5016SM-TP-5016J1HEADER10X2PIN_1_27MM_CONN2X10-4HEADER10x2CONN2X10-4028J2111-1003411_1_JUMP2X5-6040-MIR_SLW-105-01-L-DJUMP2X5-6040-MIRJ3EXP_HDR_28_JUMP2X14-6040-1_EXP_EXP_HDR_28JUMP2X14-6040-1J4HEADER10X2PIN_1_27MM_CONN2X10-4HEADER10x2CONN2X10-4028J5UMCC_VERT_SMT_UMCCVERT_UMCC_VERUMCC_VERTSMT_UMCCVERTJ6EXP_HDR_28_JUMP2X14-6040-1_EXP_EXP_HDR_28JUMP2X14-6040-1J7111-1003780_0_SM_CON_FX6A-40P_0FX6A-40P-0.8SV91SM_CON_FX6A-40P_0_8SV91J8EHDR_SM_14PHDR2x7JUMP2X7-6040-K6J9USBAX2_RJ45_10_100_TH_STKUSBX2RUSBAx2_RJ-45TH_STKUSBX2RJ45J10HEADER_0_JUMP2-6040_104350-1104350-1JUMP2-6040J11HEADER_0_JUMP2-6040_104350-1104350-1JUMP2-6040J13HEADER_0_JUMP2-6040_104350-1104350-1JUMP2-6040J14KINGCONN_SDMM-X0-0011_0_KINGCOMSDMM-X0-0011KINGCOMM_SDMM-X0-0011J15HEADER_0_JUMP2-6040_104350-1104350-1JUMP2-6040J16DUAL3_5MMSTACKEDCONNECTOR_TH_DUDual_3.5mmConnectorStackedTH_DUAL3_5MMSTKJ17CONNECTORSAMTECTFM_0_TFM-115-A_TFM_30TFM-115-AJ18111-1002717_MOLEX-56579-0576_5656579-0567MOLEX-56579-0576J19HEADER_0_JUMP2-6040_104350-1104350-1JUMP2-6040L1111-1002735_SM-7351-IND-0603_DIBLM18KG221SN1DSM-7351-IND-0603L2111-1001207_SM-CAP-0402_5.1NH5.1nHSM-CAP-0402L3111-1002735_SM-7351-IND-0603_DIBLM18KG221SN1DSM-7351-IND-0603L4111-1002735_SM-7351-IND-0603_DIBLM18KG221SN1DSM-7351-IND-0603L5LQM21PN1R0MC0_0_SM_IND_LQM21P_D1uHSM_IND_LQM21PL6111-1002735_SM-7351-IND-0603_DIBLM18KG221SN1DSM-7351-IND-0603L7111-1002671_1_SM-7351-IND-0402_BLM15PD121SN1DSM-7351-IND-0402L8111-1002666_L805-35X60_1.0UH_+/1.0uHL805-35X60L9111-1002666_L805-35X60_1.0UH_+/1.0uHL805-35X60L10111-1002671_1_SM-7351-IND-0402_BLM15PD121SN1DSM-7351-IND-0402L11111-1002735_SM-7351-IND-0603_DIBLM18KG221SN1DSM-7351-IND-0603L12111-1003359_L2010-41X87_0.68UH_0.68uHL2010-41X87L13111-1002735_SM-7351-IND-0603_DIBLM18KG221SN1DSM-7351-IND-0603L14IND_1210_1.0UH_3A_20%_X_L1210-71.0uHL1210-70X102L15111-1002735_SM-7351-IND-0603_DIBLM18KG221SN1DSM-7351-IND-0603L16111-1003740_IND0806_1.0UH_+/-301.0uHIND0806L17111-1002671_1_SM-7351-IND-0402_BLM15PD121SN1DSM-7351-IND-0402L18111-1002735_SM-7351-IND-0603_DIBLM18KG221SN1DSM-7351-IND-0603L19111-1002671_1_SM-7351-IND-0402_BLM15PD121SN1DSM-7351-IND-0402L20111-1002671_1_SM-7351-IND-0402_BLM15PD121SN1DSM-7351-IND-0402L21111-1003801_TBD_VLP8040_6.8UH_+6.8uHTBD_VLP8040L22111-1002735_SM-7351-IND-0603_DIBLM18KG221SN1DSM-7351-IND-0603L23IND_1210_1.0UH_3A_20%_X_SM-IND-1.0uHSM-IND-1210P1CONN_HDMI_0_HDMI-SMT-W-FLANGE_CCONN_HDMI_1HDMI-SMT-W-FLANGEP2CONN_HDMI_0_HDMI-SMT-W-FLANGE_CCONN_HDMI_1HDMI-SMT-W-FLANGEP3CONN_PWR1_2.5MM_CONN3-PWR-PJ102PJ-002ACONN3-PWR-PJ102AP4DSUB_FEMALE_SHORT_0_CONN9-SMT-R190-009-263R001CONN9-SMT-RT-190-009-263Q1TRANS_IRLML2402_SM-SOT-23_DISCRPMV56XNSM-SOT-23Q2TRANS_IRLML2402_SM-SOT-23_DISCRPMV56XNSM-SOT-23R187RES_272-0065-000_SMD_0402_DISCR0SMD_0402S1B3S-1000P_2_SM-SW-BS3-1000P_BS3BS3-1000PSM-SW-BS3-1000PS2B3S-1000P_2_SM-SW-BS3-1000P_BS3BS3-1000PSM-SW-BS3-1000PSW1111-1003783_SM_SW_CHS-01TA_DISCCHS-01TASM_SW_CHS-01TAU1TFP410_1_PAP64-12X70_TFP410TFP410PAP64-12X70U2TXS0102DCUR_1_SM-SO-8-DCU_IC_TXTXS0102DCURSM-SO-8-DCUU3111-1003817_LS240-WI-01-A20_LSRLSR-TiWi-BLELS240-WI-01-A20_LSRU4SN74AVC1T45DCKR_SC70-6_IC_SN74ASN74AVC1T45DCKRSC70-6U5IC_TPD12S015_0_SM_BGA_P4_4X7_28TPD12S015ASM_BGA_P4_4X7_28U6TPS2054BD_0_SO16-25X75_TPS2054BTPS2054BDSO16-25X75U7IC_USB3321C-GL-TR_1_QFN32_5X5_UUSB3320C-EZKQFN32_5X5U8LAN9514_QFN64_QFN64-11X27-SMSC_LAN9514_QFN64QFN64-11X27-SMSCU9TPS73633DBVT_0_SOT23-27X39-5_TPTPS73633DBVTSOT23-27X39-5U10IC_OMAP4440_SDC_SKT_PO0_4.42_X_OMAP4460OMAP4440_SDC_SKTU11TMP_0_PHOENIX-POWER_PHOENIXPMIPhoenixPMIC ES2PHOENIX-POWERU12111-1003550_BGA3X4-ZXU_TXB0104ZTXB0104ZXURBGA3X4-ZXUU13SN74LVC1G07DCKR_0_SM-SO-SC70-5_SN74LVC1G07DCKRSM-SO-SC70-5U14FDC6330L_1_SM-SOT-6-P95-1P5_IC_FDC6330LSM-SOT-6-P95-1P5U15TPD6E001RSER_SM-QFN-10-P5-RSE_TTPD6E001RSERSM-QFN-10-P5-RSEU16FDC6330L_1_SM-SOT-6-P95-1P5_IC_FDC6330LSM-SOT-6-P95-1P5U17TPD6E001RSER_SM-QFN-10-P5-RSE_TTPD6E001RSERSM-QFN-10-P5-RSEU18PHOENIX_AUDIO_0_0_SM-BGA-121-P5Phoenix_audio_1_1SM-BGA-121-P5-6X6U19TPS3803G15_0_DCK5_TPS3803G15TPS3803G15DCK5U20111-1003204_0_BGA3X4-ZXU_TXS010TXS0104EZXURBGA3X4-ZXUU21TPS2141PWP_0_PWP14-12X70_TPS214TPS2141PWPPWP14-12X70U22111-1003800_TBD_TPS54320_TPS543TPS54320RHLTBD_TPS54320U23111-1003389_0_SO16-25X75_IC_SN7SN75C3232EDRSO16-25X75U24TPD4S012DRYR_0_U_6_DRY_TPD4S012TPD4S012DRYRU_6_DRYU25111-1003570_BGA16_YZH_TPS62361TPS62361BGA16_YZHY1XTAL25MHZ_HC49U_0_XTAL2-NX8045G25.000MHzXTAL2-NX8045GBY2111-1002526_0_SM_XTAL_CM315_32.32.768kHzSM_XTAL_CM315Y3111-1003454_1_OSC_CSXO_5X3P2_7C7C38470004OSC_CSXO_5X3P2 2023年7月28日打卡
