GC4663+君正 ingenic T41 做的摄像头PCB文件 MARK_C90_MAIN_V2_0-2022110
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1ESD_ESD0402_ESD5451XESD5451XESD0402FB1BEAD_FB0402_1000OHM/250MA1000ohm/250mAFB0402FB7BEAD_FB0402_1000OHM/250MA1000ohm/250mAFB0402H1MHOLE1_MHOLE_4D8P_3D2H_MH_4.8MMMH_4.8mmP_3.2mmDMHOLE_4D8P_3D2HHOLE1TPOINT R_H3D5MM_2D2MM_T POINTTPOINT RH3D5MM_2D2MMHOLE2TPOINT R_H3D5MM_2D2MM_T POINTTPOINT RH3D5MM_2D2MMHOLE3TPOINT R_H3D5MM_2D2MM_T POINTTPOINT RH3D5MM_2D2MMHOLE4TPOINT R_H3D5MM_2D2MM_T POINTTPOINT RH3D5MM_2D2MMJ1CON_2X1_CON2-1D25-LT_CON21.25MCON21.25mm LTCON2-1D25-LTJ2CON_2X1_CON2-1D25-LT_CON21.25MCON21.25mm LTCON2-1D25-LTJ3FPCCON_7X2_FPC-CON14-0D5-LT_CONCON140.5mm LTFPC-CON14-0D5-LTJ4CON_2X1_CON2-1D25-LT_CON21.25MCON21.25mm LTCON2-1D25-LTJ5SENSOR_IRCUT-32X28-16_8X14_9_SESensorIRCUT-32X28-16_8X14_9J6CON_5X1_CON5-1D5-LT_CON51.5MMCON51.5mm LTCON5-1D5-LTJ7CON_5X1_CON5-1D5-LT_CON51.5MMCON51.5mm LTCON5-1D5-LTJ8HEADER_4X2_HEADER4X2FM_1D27_SMDCON81.27mm FemaleHEADER4X2FM_1D27_SMDJ9IPEX_ANT3_U_FL_R_SMD_IPEXIPEXANT3_U_FL_R_SMDJ32MMC_SD_TFCARD_MICROSD_TFMICROSD_TFTFCARDL1INDUCTOR_L2016_1UH/2.7A1uH/2.7AL2016L2INDUCTOR_L2016_2.2UH/1.3A-20162.2uH/1.3A-2016L2016L3INDUCTOR_L2016_2.2UH/1.3A-20162.2uH/1.3A-2016L2016L4INDUCTOR_L2016_2.2UH/1.3A-20162.2uH/1.3A-2016L2016L5INDUCTOR_L0402_1NH-04021nH-0402L0402Q1P_MOS_SOT23_WPM3401WPM3401SOT23Q2P_MOS_SOT23_WPM3401WPM3401SOT23Q3NPN_SOT23_SST3904SST3904SOT23SW2SW2_C_SW2_SMD_ST1112A_ST1112AST1112ASW2_SMD_ST1112AU1SY8088_SOT23-5_LN5058LN5058SOT23-5U2SY8088_SOT23-5_ETA3409ETA3409SOT23-5U3SY8088_SOT23-5_LN5058LN5058SOT23-5U4T41_QFN96_QFN96_0D35_T41_T41QFT41QFN96QFN96_0D35_T41U5SY8088_SOT23-5_LN5058LN5058SOT23-5U6CS8302_MSOP8_0D65_CS8302MCS8302MMSOP8_0D65U7GC4663_BGA41_0D73X0D65_GC4663_GGC4663BGA41_0D73X0D65_GC4663U8SZ18201_QFN32_0D5_SZ18201_SZ182SZ18201QFN32_0D5_SZ18201U9BA6208_SOP8_1D27_BA6208BA6208SOP8_1D27U10LN5010_SOT23-5_LN5010B282MR-GLN5010B282MR-GSOT23-5U11SGM2019_SOT23-5_S-1339D13S-1339D13SOT23-5U12ULN2803A-QFN203PDB3_QFN20L_0D5_ULN2803AQFN20L_0D5_ULN2803U13SPI_NAND_WSON8_1D27_8X6_GD5F1GQGD5F1GQ5UEYIGRWSON8_1D27_8X6U14USBWIFI_T_LCC6_BLM8188FU3_BL-M8BL-M8188FU3-BLCC6_BLM8188FU3Y1XTAL_P4_CRY_2D5X2D0_24M201624M2016CRY_2D5X2D0 PCB文件。回复可见
**** Hidden Message *****
