TYX-ADC0804芯片资料-一款可代替ADC0804的国产芯片
技有限公司推出的一款ADC芯片,与美国国家半导体公司(national semiconductor)的ADC0804芯片功能相似,多数情况下可以平替,无需更改程序,一次AD转换时间不超过1mS。TYX-ADC0804提供SOP16封装,可通过PCB转换成与ADC0804引脚对应的DIP20封装。TYX-ADC0804的功能引脚图如下:file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.png序号引脚名称引脚功能1VCC电源正极,3.3V-5.5V2D6数字信号输出第6位3D7数字信号输出第7位(最高位)4D5数字信号输出第5位5INTRAD转换结束信号,低电平表示本次转换已完成6Vin模拟信号输入端,电压不能超过VCC7Vref/2参考电平输入,电压不能超过VCC8CS片选信号,低电平有效9RD读信号,低电平有效10WR写信号,低电平启动AD转换11D0数字信号输出第0位(最低位)12D1数字信号输出第1位13D2数字信号输出第2位14D3数字信号输出第3位15D4数字信号输出第4位16GND电源负极
参考应用电路如下图file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image004.png转为ADC0804引脚对应的DIP20封装的原理图如下:file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image006.png参考程序如下(主控STC89C52RC,晶振11.0592M。如用高速单片机,可在操作时序加延时)#include <reg51.h>#include <intrins.h>#define LED_DATAP1#define AD_DATAP0sbit DIG1= P3^4;//数码管第1位sbit DIG2= P3^5;//数码管第2位sbit DIG3= P3^6;//数码管第3位sbit DIG4= P3^7;//数码管第4位sbit ADC_CS= P2^0;sbit ADC_RD= P2^1;sbit ADC_WR= P2^2;sbit INTR= P2^3; unsigned charLED_data={0xff,0xff,0xff,0xff}; unsigned char consttable[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; //0 1 2 3 4 5 6 7 8 9 void tm0_isr()interrupt 1{ static unsigned char i=0; TH0 = (65536 - 2000) / 256; TL0 = (65536 - 2000) % 256; switch(i) { case 0x01 : { DIG4 = 1; LED_DATA = LED_data; DIG1 = 0; break; } case 0x02 : { DIG1 = 1; LED_DATA = LED_data; DIG2 = 0; break; } case 0x03 : { DIG2 = 1; LED_DATA = LED_data; DIG3 = 0; break; } case 0x04 : { DIG3 = 1; LED_DATA = LED_data; DIG4 = 0; break; } } i++; if(i>4)i=1;} void main(){ unsigned char temp; //定时器0初始化 TMOD = TMOD & 0xf0; TMOD = TMOD | 0x01; TH0 = (65536 - 2000) / 256; TL0 = (65536 - 2000) % 256; TR0 = 1; ET0 = 1; EA=1; while(1){ ADC_CS = 0; _nop_(); ADC_WR = 0; //启动AD转换 _nop_(); ADC_WR = 1; AD_DATA=0xff; //读取P1口之前先给其写全1 while(INTR);//等待转换完成 ADC_RD = 0; //AD读使能 temp = AD_DATA; //AD数据读取赋给P1口 ADC_RD = 1; ADC_CS = 1; //关闭ADCS ADC_WR = 0; LED_data = table; LED_data = table; LED_data = table; LED_data = 0xff; } }
