28层 XCVP1802-2MSELSVC4072 PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB1BATTERY_BAT_TS518_TS621_DUAL_TS621E-FL11ETS621E-FL11EBAT_TS518_TS621_DUALD1BAS40-04_SOT_23_BAS40-04BAS40-04SOT_23D2DIODE_ZENER_DO_214AC_SMAJ16ASMAJ16ADO_214ACDS1LED_LED_0603_LED-GRN-SMTLED-GRN-SMTLED_0603J12147334000_CON_MOLEX_2147334000_21473340002147334000CON_MOLEX_2147334000J22147334000_CON_MOLEX_2147334000_21473340002147334000CON_MOLEX_2147334000J3QSFPDD_CAGE_AMPHENOL_UE36-B16200-06A2A_QSFPDDCAGE + HEATSINKQSFPDDCage + HeatsinkAMPHENOL_UE36-B16200-06A2AJ4QSFPDD_CAGE_AMPHENOL_UE36-B16200-06A2A_QSFPDDCAGE + HEATSINKQSFPDDCage + HeatsinkAMPHENOL_UE36-B16200-06A2AJ6TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ7692622030100_CON_WURTH_MICRO_USB_HOZ_B_6926220301006.92622E+11CON_WURTH_MICRO_USB_HOZ_BJ8TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ10TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ11HDR_2X6_HDR_2X6_HDR_2X6HDR_2X6HDR_2X6J12HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J1612V_RT_ANGLE_MINI_FIT_JACK_CON_MOL_5569_6P_39-30-106039-30-1060CON_MOL_5569_6PJ17TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ26HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J29TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ34HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J36HDR_2X7_87832_1420_87832-142087832-142087832_1420J37HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J51ASP_184329_01_ASP_184329_01_ASP_184329_01ASP_184329_01ASP_184329_01J63TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ64TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ72TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ117TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ202HDR_2X7_87832_1420_87832-142087832-142087832_1420J203HDR_1X2_HDR_1X2_HDR_1X2HDR_1X2HDR_1X2J209TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINIJ233FANHDR4_HDR_1X4_LOCK_MOLEX_0470533000470533000HDR_1X4_LOCK_MOLEXJ249TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINIJ250TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINIJ252TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINIJ256TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ257TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ259TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ262TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ263TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ268TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ272TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ273TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ274TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ295TP-HOOK_TP_KEY_MINI_REDREDTP_KEY_MINIJ296TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ297TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ300HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J301HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J3025025700893_CON_MOL_10P_5025700893_CON_MOL_10P_5025700893CON_MOL_10P_5025700893CON_MOL_10P_5025700893J307HFJ11_1G01E_L12RL_CON_ETH_HFJ111G01E_L12RL_RJ45RJ45CON_ETH_HFJ111G01E_L12RLJ308629104190121_WURTH_629104190121_6291041901216.29104E+11WURTH_629104190121J310HDR_2X9_HDR_MOLEX_87832_1820_0878321820878321820HDR_MOLEX_87832_1820J313HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J324TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ325HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J326HDR_2X3_HDR_2X3_HDR_2X3HDR_2X3HDR_2X3J328SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ329SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ330SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ331SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ332MICTOR-38_CONN_TE_38POS_VERT_SMD_ CONN_TE_38POS_VERT_SMDJ338SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ339SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ340TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ341TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ342TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ343TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ345HDR_1X2_HDR_1X2_HDR_1X2HDR_1X2HDR_1X2J346HDR_1X2_HDR_1X2_HDR_1X2HDR_1X2HDR_1X2J347HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J348HDR_1X3_HDR_1X3_HDR_1X3HDR_1X3HDR_1X3J349HFJ11_1G01E_L12RL_CON_ETH_HFJ111G01E_L12RL_RJ45RJ45CON_ETH_HFJ111G01E_L12RLJ350SFP-DD_SFP-DD_SFP-DDSFP-DDSFP-DDJ351SFP-DD-CAGE_SFP-DD-CAGE-NOPIPE_20482360072048236007SFP-DD-CAGE-NOPIPEJ352SFP-DD_SFP-DD_SFP-DDSFP-DDSFP-DDJ353SFP-DD-CAGE_SFP-DD-CAGE-NOPIPE_20482360072048236007SFP-DD-CAGE-NOPIPEJ3542147334000_CON_MOLEX_2147334000_21473340002147334000CON_MOLEX_2147334000J3552147334000_CON_MOLEX_2147334000_21473340002147334000CON_MOLEX_2147334000J356QSFPDD_CAGE_AMPHENOL_UE36-B16200-06A2A_QSFPDDCAGE + HEATSINKQSFPDDCage + HeatsinkAMPHENOL_UE36-B16200-06A2AJ357QSFPDD_CAGE_AMPHENOL_UE36-B16200-06A2A_QSFPDDCAGE + HEATSINKQSFPDDCage + HeatsinkAMPHENOL_UE36-B16200-06A2AJ3582147334000_CON_MOLEX_2147334000_21473340002147334000CON_MOLEX_2147334000J3592147334000_CON_MOLEX_2147334000_21473340002147334000CON_MOLEX_2147334000J360QSFPDD_CAGE_AMPHENOL_UE36-B16200-06A2A_QSFPDDCAGE + HEATSINKQSFPDDCage + HeatsinkAMPHENOL_UE36-B16200-06A2AJ361QSFPDD_CAGE_AMPHENOL_UE36-B16200-06A2A_QSFPDDCAGE + HEATSINKQSFPDDCage + HeatsinkAMPHENOL_UE36-B16200-06A2AJ3622344064-4_CON_TE_2344064-4_2344064-42344064-4CON_TE_2344064-4J363UE62-B1620-020112317416-1CAGE_TE_2317416-1J364TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ366TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ368TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ369CONN_USB_C_CON_AMP_12401598E4_2A_12401598E4#2A12401598E4#2ACON_AMP_12401598E4_2AJ370HDR_2X9_HDR_MOLEX_87832_1820_0878321820878321820HDR_MOLEX_87832_1820J371HDR_2X9_HDR_MOLEX_87832_1820_0878321820878321820HDR_MOLEX_87832_1820J372TP-HOOK_TP_KEY_MINI_BLACK_TP_KEY_MINI_DNPBLACKTP_KEY_MINIJ373SMA-SCREW-ON_SMA_3P_MOLEX_732513481_CON_SMA_SCREW_ON_32K10K_400_3M_73251_DUALCON_SMA_SCREW_ONSMA_3P_MOLEX_732513481J374SMA-SCREW-ON_SMA_3P_MOLEX_732513481_CON_SMA_SCREW_ON_32K10K_400_3M_73251_DUALCON_SMA_SCREW_ONSMA_3P_MOLEX_732513481J375SMA-SCREW-ON_SMA_3P_MOLEX_732513481_CON_SMA_SCREW_ON_32K10K_400_3M_73251_DUALCON_SMA_SCREW_ONSMA_3P_MOLEX_732513481J376SMA-SCREW-ON_SMA_3P_MOLEX_732513481_CON_SMA_SCREW_ON_32K10K_400_3M_73251_DUALCON_SMA_SCREW_ONSMA_3P_MOLEX_732513481J385SFP-DD_SFP-DD_SFP-DDSFP-DDSFP-DDJ386SFP-DD-CAGE_SFP-DD-CAGE-NOPIPE_20482360072048236007SFP-DD-CAGE-NOPIPEJ387SFP-DD_SFP-DD_SFP-DDSFP-DDSFP-DDJ388SFP-DD-CAGE_SFP-DD-CAGE-NOPIPE_20482360072048236007SFP-DD-CAGE-NOPIPEJ389SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ390SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ391SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ392SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ393SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ394SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ395SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJ396SMA-5PIN_32K10K_400_NEW_32K10K-400L5_32K10K_400_3M_73251_DUAL32K10K-400L532K10K_400_NEWJP1PCIE_PWR_2X4_ASTRON_6652208-T0003T-H_A_6652208-T0003T-H6652208-T0003T-HASTRON_6652208-T0003T-H_AJP2PCIE_PWR_2X4_ASTRON_6652208-T0003T-H_A_6652208-T0003T-H6652208-T0003T-HASTRON_6652208-T0003T-H_AJP3PCIE_PWR_2X4_ASTRON_6652208-T0003T-H_A_6652208-T0003T-H6652208-T0003T-HASTRON_6652208-T0003T-H_AJP4PCIE_PWR_2X4_ASTRON_6652208-T0003T-H_A_6652208-T0003T-H6652208-T0003T-HASTRON_6652208-T0003T-H_AL1IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110L2IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110L3IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110L4IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110L5IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95L6IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95L7IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL8IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL9IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L10IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L11IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L12IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L13IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L14IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L16IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95L17IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95L24IND_IND_COIL_SCL7649_36NH36NHIND_COIL_SCL7649L31IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL32IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL54IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110L55IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110L56IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110L57IND_INDC200X125X110_FERRITE-600FERRITE-600INDC200X125X110L58IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L65IND_IND_MUR_2520_470NH470NHIND_MUR_2520L66IND_IND_MUR_2520_470NH470NHIND_MUR_2520L67IND_IND_MUR_2520_1.0UH1.0UHIND_MUR_2520L68IND_IND_MUR_2520_1.0UH1.0UHIND_MUR_2520L69IND_IND_MUR_2520_1.0UH1.0UHIND_MUR_2520L72IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L73IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L75IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L77IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L78IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL79IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL82IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL93IND_IND_SRP7050TA_680NH680NHIND_SRP7050TAL94IND_IND_SRP7050TA_680NH680NHIND_SRP7050TAL108IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95L109IND_INDC160X80X95_FERRITE-220FERRITE-220INDC160X80X95L112IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL113IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL114IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL115IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL118IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL127IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL132IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL133IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL134IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL135IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL136IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL137IND_IND_COIL_1008AF_5.8UH5.8UHIND_COIL_1008AFL138IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL139IND_IND_COIL_1008AF_6.8UH6.8uHIND_COIL_1008AFL140IND_IND_COIL_1008AF_6.8UH6.8uHIND_COIL_1008AFL141IND_IND_COIL_1008AF_6.8UH6.8uHIND_COIL_1008AFL142IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL143IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL144IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL145IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL146IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL147IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL148IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL149IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL150IND_IND_COIL_1008AF_3.9UH3.9uHIND_COIL_1008AFL151IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL153IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL154IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL157IND_INDC250X200X80_1.0UH1.0UHINDC250X200X80L158IND_INDC250X200X80_1.0UH1.0UHINDC250X200X80L159IND_INDC250X200X80_1.0UH1.0UHINDC250X200X80L160IND_INDC250X200X80_1.0UH1.0UHINDC250X200X80L161IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L162IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L163IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L164IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L165IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L166IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L167IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L168IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L169IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L170IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L171IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L172IND_INDC160X80X65_FERRITE-120FERRITE-120INDC160X80X65L173FERRITE-22_0603FERRITE-22BEAD_160X80X75L174IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L175IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L176IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L177IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L178IND_IND_MUR_2520_470NH470NHIND_MUR_2520L179IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L180IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L181IND_IND_COIL_SCL7649_36NH36NHIND_COIL_SCL7649L184IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L185IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL187IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL188IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL189IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L190BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL191BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL192BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL193BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL194BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL195BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL196BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL197BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL198BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL199BLM15PX121SN1D_FB_BLM15PX121SN1D_DISCRETE_120OHMS @ 100MHZ120Ohms @ 100MHzFB_BLM15PX121SN1DL200IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL201IND_IND_SRP7050TA_680NH680NHIND_SRP7050TAL202IND_IND_SRP7050TA_680NH680NHIND_SRP7050TAL203IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L204IND_IND_SRP7050TA_680NH680NHIND_SRP7050TAL205IND_IND_SRP4020TA_1.5UH1.5UHIND_SRP4020TAL206IND_IND_EATON_FP10007R3_150NH150nHIND_EATON_FP10007R3L207IND_INDC250X200X80_1.0UH1.0UHINDC250X200X80L208IND_INDC250X200X80_1.0UH1.0UHINDC250X200X80L209IND_INDC250X200X80_1.0UH1.0UHINDC250X200X80L210IND_INDC250X200X80_1.0UH1.0UHINDC250X200X80MH11HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH12HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH14HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH27HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH28HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH29HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH30HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH31HOLE_FIDCUT_FIDCUTFIDCUTFIDCUTMH32HOLE_FIDCUT_FIDCUTFIDCUTFIDCUTMH33HOLE_FIDCUT_FIDCUTFIDCUTFIDCUTMH34HOLE_FIDCUT_FIDCUTFIDCUTFIDCUTMH35HOLE_FIDCUT_FIDCUTFIDCUTFIDCUTMH36HOLE_FIDCUT_FIDCUTFIDCUTFIDCUTMH37HOLE_FIDCUT_FIDCUTFIDCUTFIDCUTMH38HOLE_FIDCUT_FIDCUTFIDCUTFIDCUTMH39HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH40HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH41HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125MH42HOLE_MH_250H125_MH_125_250MH_125_250MH_250H125Q1FET-3PIN_SOT_23_NDS331NNDS331NSOT_23Q2FET-3PIN_SOT_23_NDS331NNDS331NSOT_23Q3DMN26D0UFB4_DFN_105X65X40_3_DMN26D0UFB4-7DMN26D0UFB4-7DFN_105X65X40_3Q4DMN26D0UFB4_DFN_105X65X40_3_DMN26D0UFB4-7DMN26D0UFB4-7DFN_105X65X40_3Q13FET-3PIN_SOT_23_NDS331NNDS331NSOT_23Q33FET-3PIN_SOT_23_NDS331NNDS331NSOT_23Q39SI7157DP_PWR_56_V02_SI7157DPSI7157DPPWR_56_V02Q40SI7157DP_PWR_56_V02_SI7157DPSI7157DPPWR_56_V02Q41RUM001L02T2CL_SOT_723_RUM001L02T2CLRUM001L02T2CLSOT_723Q42NDS336P_SOT_23_FDN336PFDN336PSOT_23Q43FET-3PIN_SOT_23_NDS331NNDS331NSOT_23Q44FET-3PIN_SOT_23_NDS331NNDS331NSOT_23Q46FET-3PIN_SOT_23_2N7002_2152N7002_215SOT_23Q48FET-3PIN_SOT_23_NDS331NNDS331NSOT_23Q49DMN26D0UFB4_DFN_105X65X40_3_DMN26D0UFB4-7DMN26D0UFB4-7DFN_105X65X40_3Q50DMN26D0UFB4_DFN_105X65X40_3_DMN26D0UFB4-7DMN26D0UFB4-7DFN_105X65X40_3Q51DMN26D0UFB4_DFN_105X65X40_3_DMN26D0UFB4-7DMN26D0UFB4-7DFN_105X65X40_3RP1RPACK_10K_X4_RP_EXB_0603X4_10.0K10.0KRP_EXB_0603X4RP2RPACK_10K_X4_RP_EXB_0603X4_10.0K10.0KRP_EXB_0603X4RP3RPACK_10K_X4_RP_EXB_0603X4_10.0K10.0KRP_EXB_0603X4RP4RPACK_10K_X4_RP_EXB_0603X4_10.0K10.0KRP_EXB_0603X4RP5RPACK_10K_X4_RP_EXB_0603X4_10.0K10.0KRP_EXB_0603X4RP6RPACK_10K_X4_RP_EXB_0603X4_10.0K10.0KRP_EXB_0603X4SHIELD1FF-VCK190-1588-SHIELD_FF-VCK190-1588-SHIELD_FF-VCK190-1588-SHIELDFF-VCK190-1588-SHIELDFF-VCK190-1588-SHIELDSW1SW_DIP_4_SW_SDA_8P_SDA04H1SBDSDA04H1SBDSW_SDA_8PSW2PUSHBUTTON-4_SW_TL3301_G_4P_TL3301EF100QGTL3301EF100QGSW_TL3301_G_4PSW3SW_DIP_2_SW_SDA_4P_SDA02H1SBDSDA02H1SBDSW_SDA_4PSW4PUSHBUTTON-4_SW_TL3301_G_4P_TL3301EF100QGTL3301EF100QGSW_TL3301_G_4PSW5PUSHBUTTON-4_SW_TL3301_G_4P_TL3301EF100QGTL3301EF100QGSW_TL3301_G_4PSW6SW_DIP_4_SW_SDA_8P_SDA04H1SBDSDA04H1SBDSW_SDA_8PSW11SW_DIP_4_SW_SDA_8P_SDA04H1SBDSDA04H1SBDSW_SDA_8PSW12PUSHBUTTON-4_SW_TL3301_G_4P_TL3301EF100QGTL3301EF100QGSW_TL3301_G_4PSW13SW_SLIDE_SPDT_SW_102_1261_EV_1101M2S3AQE21101M2S3AQE2SW_102_1261_EVSW14PUSHBUTTON-4_SW_TL3301_G_4P_TL3301EF100QGTL3301EF100QGSW_TL3301_G_4PSW15PUSHBUTTON-4_SW_TL3301_G_4P_TL3301EF100QGTL3301EF100QGSW_TL3301_G_4PSW16PUSHBUTTON-4_SW_TL3301_G_4P_TL3301EF100QGTL3301EF100QGSW_TL3301_G_4PU1XCVP1802LSVC4072_A_SOC_4072_1P0MM_IRON_CHAMP_HEADXCVP1802-2MSELSVC4072SOC_4072_1P0MM_IRON_CHAMP_HEADU2TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U3SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570U4SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570U5INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U6REF3012_SOT23_3_ISL60002DIH310Z-TKISL60002DIH310Z-TKSOT23_3U7SN74LVC07A_TSSOP_14_SN74LVC07ASN74LVC07ATSSOP_14U8LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U9TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U10TPS3890_WSON_6_155X155X80_TPS389001DSERTPS389001DSERWSON_6_155X155X80U11MT25QU01GBBB8E12-0SIT_BGA24C100P5X5_800X600X120_MT25QU01GBBB8E12-0SITMT25QU01GBBB8E12-0SITBGA24C100P5X5_800X600X120U12MT25QU01GBBB8E12-0SIT_BGA24C100P5X5_800X600X120_MT25QU01GBBB8E12-0SITMT25QU01GBBB8E12-0SITBGA24C100P5X5_800X600X120U14SN74CB3Q3253_TSSOP065P620X120_16_SN74CB3Q3253PWRSN74CB3Q3253PWRTSSOP065P620X120_16U15SN74CB3Q3253_TSSOP065P620X120_16_SN74CB3Q3253PWRSN74CB3Q3253PWRTSSOP065P620X120_16U16SN74AVC4T245_QFN_RSV_16_SN74AVC4T245SN74AVC4T245QFN_RSV_16U17TL1963A_33DCYR_DCY_R_DPSO_G4_TL1963A_33DCYRTL1963A_33DCYRDCY_R_DPSO_G4U18SN74AVC2T245_QFN40P140X180X55-10_SN74AVC2T245SN74AVC2T245QFN40P140X180X55-10U19USB3320_QFN32_QFN05P500X500X100_32P_330EP_USB3320USB3320QFN05P500X500X100_32P_330EPU20FT4232HL_LQFP_64_FT4232HL_LQFP64FT4232HL_LQFP64LQFP_64U2293LC56B_SOIC8P127W390_93LC56B93LC56BSOIC8P127W390U23SN74AVC2T245_QFN40P140X180X55-10_SN74AVC2T245SN74AVC2T245QFN40P140X180X55-10U24MAX9100_SOP095P280X145_5_MAX9100MAX9100SOP095P280X145_5U25K4F8E304HA_R044_WFBGA_200_10X14_5MM_MT53D512M32D2DS-046MT53D512M32D2DS-046WFBGA_200_10X14_5MMU26K4F8E304HA_R044_WFBGA_200_10X14_5MM_MT53D512M32D2DS-046MT53D512M32D2DS-046WFBGA_200_10X14_5MMU27SBSMC_FILTER_SYFER_SBSM_2220_0.33UF0.33UFFILTER_SYFER_SBSM_2220U28TPD4E05U06DQAR_DQA_R_PSON_N10_TPD4E05U06DQARTPD4E05U06DQARDQA_R_PSON_N10U29AND_GATE_SINGLE_SC70_5_SN74LVC1G08SN74LVC1G08SC70_5U32SI570_SINGLE_SI570_10MHZ-160MHZ10MHZ-160MHZSI570U33TCA9548A_TSSOP_24_TCA9548APWRTCA9548APWRTSSOP_24U34M24128-BR_TSSOP65P640X120_8_M24128-BRM24128-BRTSSOP65P640X120_8U35TCA9548A_TSSOP_24_TCA9548APWRTCA9548APWRTSSOP_24U36DP83867CRRGZ_VQFN05P700X700X100_48_408EP_DP83867CRRGZRDP83867CRRGZRVQFN05P700X700X100_48_408EPU63SN74AVC4T245_QFN_RSV_16_SN74AVC4T245SN74AVC4T245QFN_RSV_16U65INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U99USB3320_QFN32_QFN05P500X500X100_32P_330EP_USB3320USB3320QFN05P500X500X100_32P_330EPU100MIC2544A_1YM_SOIC_8_MIC2544A-1YMMIC2544A-1YMSOIC_8U101TPD2EUSB30_DRT_R_PDSO_N3_TPD2EUSB30DRTRTPD2EUSB30DRTRDRT_R_PDSO_N3U103SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6U104X-SDM-01_IP4856CX25_SHIFTER_ADAPTER_X-SDM-01X-SDM-01IP4856CX25_SHIFTER_ADAPTERU105SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6U122SN74AVC8T245_TSSOP_24_SN74AVC8T245SN74AVC8T245TSSOP_24U123SN74AVC8T245_TSSOP_24_SN74AVC8T245SN74AVC8T245TSSOP_24U124SN74AVC8T245_TSSOP_24_SN74AVC8T245SN74AVC8T245TSSOP_24U125XCZU4EGSFVC784_BGA784C08P28X8_230X230X312_XCZU4-SFVC784XCZU4-SFVC784BGA784C08P28X8_230X230X312U128SN74AVC1T45_SC70_6_SN74AVC1T45SN74AVC1T45SC70_6U129TPS3890_WSON_6_155X155X80_TPS389001DSERTPS389001DSERWSON_6_155X155X80U130AND_GATE_SINGLE_SC70_5_SN74LVC1G08SN74LVC1G08SC70_5U132K4F8E304HA_R044_WFBGA_200_10X14_5MM_MT53D512M32D2DS-046MT53D512M32D2DS-046WFBGA_200_10X14_5MMU133MTFC8GAKAJCN-1M_BGA153C50P14X14_1300X1150X100_(S1+S2)_MTFC32GAZAQHD-ITMTFC32GAZAQHD-ITBGA153C50P14X14_1300X1150X100U143TPS62480_VQFN05P260X310X100_16_TPS62480RNCRTPS62480RNCRVQFN05P260X310X100_16U144TPS62097_VQFN05P210X210X100_11_TPS62097RWKRTPS62097RWKRVQFN05P210X210X100_11U145TPS7A83A_PVQFN05P365X365X100_20_200EP_TPS7A8300ARGRRTPS7A8300ARGRRPVQFN05P365X365X100_20_200EPU146TPS62097_VQFN05P210X210X100_11_TPS62097RWKRTPS62097RWKRVQFN05P210X210X100_11U147TPS62097_VQFN05P210X210X100_11_TPS62097RWKRTPS62097RWKRVQFN05P210X210X100_11U150K4F8E304HA_R044_WFBGA_200_10X14_5MM_MT53D512M32D2DS-046MT53D512M32D2DS-046WFBGA_200_10X14_5MMU151K4F8E304HA_R044_WFBGA_200_10X14_5MM_MT53D512M32D2DS-046MT53D512M32D2DS-046WFBGA_200_10X14_5MMU152IR35215_QFN04P500X500X85_40_370_IR35215IR35215QFN04P500X500X85_40_370U154TDA21490_PQFN_45_500X600X100_41_TDA21490TDA21490PQFN_45_500X600X100_41U155TDA21490_PQFN_45_500X600X100_41_TDA21490TDA21490PQFN_45_500X600X100_41U157TDA21490_PQFN_45_500X600X100_41_TDA21490TDA21490PQFN_45_500X600X100_41U159TDA21490_PQFN_45_500X600X100_41_TDA21490TDA21490PQFN_45_500X600X100_41U160IRPS5401_IRPS5401MTRPBF_IRPS5401IRPS5401IRPS5401MTRPBFU161INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U163INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U164INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U165INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U166INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U167IRPS5401_IRPS5401MTRPBF_IRPS5401IRPS5401IRPS5401MTRPBFU168INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U172INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U174INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U175IRPS5401_IRPS5401MTRPBF_IRPS5401IRPS5401IRPS5401MTRPBFU176INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U177INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U184INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U185IR38164_QFN_IR38164_26_IR38164IR38164QFN_IR38164_26U186INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U187IR38164_QFN_IR38164_26_IR38164IR38164QFN_IR38164_26U188INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U189IR38164_QFN_IR38164_26_IR38164IR38164QFN_IR38164_26U191IR3889_QFN_IR3889_36_IR3889IR3889QFN_IR3889_36U198DP83867CRRGZ_VQFN05P700X700X100_48_408EP_DP83867CRRGZRDP83867CRRGZRVQFN05P700X700X100_48_408EPU199SN74LVC1G11_SC70_6_SN74LVC1G11SN74LVC1G11SC70_6U201MAX8869EUE18_TSSOP_16_EP_MAX8869EUE18+MAX8869EUE18+TSSOP_16_EPU210PCA9306DCTR_DCT_R_PDSO_G8_PCA9306DCTRPCA9306DCTRDCT_R_PDSO_G8U211PCA9306DCTR_DCT_R_PDSO_G8_PCA9306DCTRPCA9306DCTRDCT_R_PDSO_G8U212PCA9306DCTR_DCT_R_PDSO_G8_PCA9306DCTRPCA9306DCTRDCT_R_PDSO_G8U213PCA9306DCTR_DCT_R_PDSO_G8_PCA9306DCTRPCA9306DCTRDCT_R_PDSO_G8U217U7836LF_OSC_RAKON_U7836LF_38.4MHZ38.4MHZOSC_RAKON_U7836LFU218TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U2198A34001_CABGA_144P80_(S1+S2+S3)_8A340018A34001CABGA_144P80U220TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U221AND_GATE_SINGLE_SC70_5_SN74LVC1G08SN74LVC1G08SC70_5U22224LC64_SOIC127P600X175_8_24FC1025T-I/SN24FC1025T-I/SNSOIC127P600X175_8U223LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U225LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U226LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U227LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U228LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U229LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U230LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U231LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U232LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U233TCA6416A_TSSOP_24_TCA6416ATCA6416ATSSOP_24U234INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U235SN74LVC07A_TSSOP_14_SN74LVC07ASN74LVC07ATSSOP_14U236LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U238SN74AVC4T245_QFN_RSV_16_SN74AVC4T245SN74AVC4T245QFN_RSV_16U239SN74AVC4T245_QFN_RSV_16_SN74AVC4T245SN74AVC4T245QFN_RSV_16U240NC7SZ66_SC70_5_SC70_5_NC7SZ66P5XNC7SZ66P5XSC70_5U243LP38798_WSON05PX400X400X100_12_260X300_LP38798SD-ADJ/NOPBLP38798SD-ADJ/NOPBWSON05PX400X400X100_12_260X300U244SIT5358AN-FR-33E0_OSC_SIT5358_500X320X095_54.000000MHZ54.000000MHzOSC_SIT5358_500X320X095U246K4F8E304HA_R044_WFBGA_200_10X14_5MM_MT53D512M32D2DS-046MT53D512M32D2DS-046WFBGA_200_10X14_5MMU247K4F8E304HA_R044_WFBGA_200_10X14_5MM_MT53D512M32D2DS-046MT53D512M32D2DS-046WFBGA_200_10X14_5MMU248SI570_SI570_10MHZ_TO_810MHZ10MHZ_TO_810MHZSI570U2518P34S1204NLGI_VQFN05P_310X310X100_16_180EP_8P34S1204NLGI8P34S1204NLGIVQFN05P_310X310X100_16_180EPU2528P34S1204NLGI_VQFN05P_310X310X100_16_180EP_8P34S1204NLGI8P34S1204NLGIVQFN05P_310X310X100_16_180EPU254SN74LVC07A_TSSOP_14_SN74LVC07ASN74LVC07ATSSOP_14U255SN74AVC2T245_QFN40P140X180X55-10_SN74AVC2T245SN74AVC2T245QFN40P140X180X55-10U256SN74AVC2T245_QFN40P140X180X55-10_SN74AVC2T245SN74AVC2T245QFN40P140X180X55-10U2578P34S1204NLGI_VQFN05P_310X310X100_16_180EP_8P34S1204NLGI8P34S1204NLGIVQFN05P_310X310X100_16_180EPU259IR38060_PQFN_35_5X6_IR38060IR38060PQFN_35_5X6U260INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U263MT25QU512ABB8E12_BGA24C100P5X5_800X600X120_MT25QU512ABB8E12-0SITMT25QU512ABB8E12-0SITBGA24C100P5X5_800X600X120U264INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U265INA226_DGS_MSOP_10_INA226INA226DGS_MSOP_10U267SN74LVC07A_TSSOP_14_SN74LVC07ASN74LVC07ATSSOP_14U268SN74LVC1G07DCK_SC70_5_SN74LVC1G07SN74LVC1G07SC70_5U269SN74LVC1G07DCK_SC70_5_SN74LVC1G07SN74LVC1G07SC70_5U270SN74LVC1G07DCK_SC70_5_SN74LVC1G07SN74LVC1G07SC70_5U271SN74AVC2T245_QFN40P140X180X55-10_SN74AVC2T245SN74AVC2T245QFN40P140X180X55-10U272SN74AVC2T245_QFN40P140X180X55-10_SN74AVC2T245SN74AVC2T245QFN40P140X180X55-10U273SN74AVC2T245_QFN40P140X180X55-10_SN74AVC2T245SN74AVC2T245QFN40P140X180X55-10U274SN74LVC07A_TSSOP_14_SN74LVC07ASN74LVC07ATSSOP_14U276TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U277TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U278TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U279TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U280NC7SV125_SC70_SC70_5_NC7SV125NC7SV125SC70_5U281MAX9100_SOP095P280X145_5_MAX9100MAX9100SOP095P280X145_5U282MAX9100_SOP095P280X145_5_MAX9100MAX9100SOP095P280X145_5U283NC7SV125_SC70_SC70_5_NC7SV125NC7SV125SC70_5U284TDA21490_PQFN_45_500X600X100_41_TDA21490TDA21490PQFN_45_500X600X100_41U285TDA21490_PQFN_45_500X600X100_41_TDA21490TDA21490PQFN_45_500X600X100_41U286TDA21490_PQFN_45_500X600X100_41_TDA21490TDA21490PQFN_45_500X600X100_41U287TDA21490_PQFN_45_500X600X100_41_TDA21490TDA21490PQFN_45_500X600X100_41U288IR3899A_PQFN_50_400X500X110_17_IR3899AIR3899APQFN_50_400X500X110_17U289TDA21472_PQFN_TDA21472_41_TDA21472TDA21472PQFN_TDA21472_41U290TDA21472_PQFN_TDA21472_41_TDA21472TDA21472PQFN_TDA21472_41U291IR35215_QFN04P500X500X85_40_370_IR35215IR35215QFN04P500X500X85_40_370U293TDA21472_PQFN_TDA21472_41_TDA21472TDA21472PQFN_TDA21472_41U294TDA21472_PQFN_TDA21472_41_TDA21472TDA21472PQFN_TDA21472_41U295IRPS5401_IRPS5401MTRPBF_IRPS5401IRPS5401IRPS5401MTRPBFU296TDA21472_PQFN_TDA21472_41_TDA21472TDA21472PQFN_TDA21472_41U297TPD4E05U06DQAR_DQA_R_PSON_N10_TPD4E05U06DQARTPD4E05U06DQARDQA_R_PSON_N10U298RC21008A_QFN40P500X500X100-40TP_RC21008A065GND#BB0RC21008A065GND#BB0QFN40P500X500X100-40TPU299RC21008A_QFN40P500X500X100-40TP_RC21008A065GND#BB0RC21008A065GND#BB0QFN40P500X500X100-40TPU300XUM736_OSC_254_700X500X145_6_200MHZ_SI570200MHzOSC_254_700X500X145_6U302XUM736_OSC_254_700X500X145_6_200MHZ_SI570200MHzOSC_254_700X500X145_6U304XUM736_OSC_254_700X500X145_6_200MHZ_SI570200MHzOSC_254_700X500X145_6U306XUJ716_OSC_254_700X500X145_6_33.333333MHZ_SI57033.333333MHZOSC_254_700X500X145_6U307TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U308TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U309TDA21472_PQFN_TDA21472_41_TDA21472TDA21472PQFN_TDA21472_41U312626L15625I3T_OSC_105_250X200X110_4_156.25MHZ156.25MHZOSC_105_250X200X110_4U313626L15625I3T_OSC_105_250X200X110_4_156.25MHZ156.25MHZOSC_105_250X200X110_4U314TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U315TXS0108E_TSSOP_20_TXS0108ETXS0108ETSSOP_20U316MC74VHC1G03_SOT65P_220X135X110_5_MC74VHC1G03MC74VHC1G03SOT65P_220X135X110_5U317XUJ716_OSC_254_700X500X145_6_33.333333MHZ_SI57033.333333MHZOSC_254_700X500X145_6U318LMK1C1102_TSSOP8_65P450X310X120_LMK1C1102PWRLMK1C1102PWRTSSOP8_65P450X310X120U319SI5332F_PQFN05P500X500X100_32P_220EP_SI5332FD14199-GM1Si5332FD14199-GM1PQFN05P500X500X100_32P_220EPU320626L15625I3T_OSC_105_250X200X110_4_156.25MHZ156.25MHZOSC_105_250X200X110_4U321XFL336_OSC_127_500X320X95_8_26MHZ26MHzOSC_127_500X320X95_8U322TCA9548A_TSSOP_24_TCA9548APWRTCA9548APWRTSSOP_24U323SBSMC_FILTER_SYFER_SBSM_2220_0.33UF0.33UFFILTER_SYFER_SBSM_2220U324SBSMC_FILTER_SYFER_SBSM_2220_0.33UF0.33UFFILTER_SYFER_SBSM_2220U326MC74VHC1G03_SOT65P_220X135X110_5_MC74VHC1G03MC74VHC1G03SOT65P_220X135X110_5U327MC74VHC1G03_SOT65P_220X135X110_5_MC74VHC1G03MC74VHC1G03SOT65P_220X135X110_5U328MC74VHC1G03_SOT65P_220X135X110_5_MC74VHC1G03MC74VHC1G03SOT65P_220X135X110_5X1FC-13A_XTAL_XTAL_FC13A_32.768KHZ32.768KHZXTAL_FC13AX2TPD4S012_DRY_6_SON_TPD4S012TPD4S012DRY_6_SONX3FA238_XTAL_EPSON_FA238_12.00MHZ12.00MHZXTAL_EPSON_FA238X4CRYS_2_XTAL250X200X80_24MHZ24MHzXTAL250X200X80X8CRYS_2_XTAL_HCM49_24.000MHZ24.000MHZXTAL_HCM49X9ABM8_XTAL_XTAL_ABM8_25.00MHZ25.00MHZXTAL_ABM8X10ABM8_XTAL_XTAL_ABM8_25.00MHZ25.00MHZXTAL_ABM8X11XTAL_50MHZ_XTAL_320X250X80_TXC7M_50MHZ50MHzXTAL_320X250X80_TXC7MX12XTAL_50MHZ_XTAL_320X250X80_TXC7M_50MHZ50MHzXTAL_320X250X80_TXC7MX13ABM8_XTAL_XTAL_ABM3_ABM3B-25.000MHZABM3B-25.000MHZXTAL_ABM3 PCB文件共享。回复可见下载
**** Hidden Message ***** 好好学习哦
回 armclub 的帖子
armclub:PCB文件共享。回复可见下载[内容隐藏]
(2023-10-11 11:35) images/back.gif
