xilinx官方zynq开发板
pcb文件CommentDescriptionDesignatorFootprintLibRefQuantity0.1u贴片电容C1, C2, C3, C5, C6,C7, C8, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C23, C24, C64,C66, C69, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C88, C89, C91,C93, C95, C96, C97, C98, C101, C119, C120, C121, C124, C125, C126, C127,C128, C129, C130, C1310402_C0402 100nF (104) 10%16V, 0402 1.0uF (105) 10% 25V5347u贴片电容C4, C26, C30, C33,C38, C41, C44, C50, C53, C56, C941206_C1206 100nF (104) 10%50V1110u贴片电容C9, C100603_C0603 10nF (103) 10%50V210u贴片电容C22, C85, C87, C92,C122, C1230402_C0402 100nF (104) 10%16V, 0402 1.0uF (105) 10% 25V60.47u贴片电容C25, C28, C29, C32,C35, C36, C37, C40, C43, C46, C47, C48, C49, C52, C55, C58, C59, C60, C61,C115, C116, C117, C1180402_C0402 1.0uF (105) 10%25V234.7u贴片电容C27, C31, C34, C39,C42, C45, C51, C54, C57, C86, C90, C1140402_C0402 1.0uF (105) 10%25V1210u贴片电容C62, C630805_C0805 6.8pF (6R8)0.25pF 50V21u贴片电容C650402_C0402 1.0uF (105) 10%25V122p贴片电容C67, C680402_C0402 1.0uF (105) 10%25V222u贴片电容C70, C71, C72, C102,C104, C105, C107, C108, C110, C111, C1130603_C0603 22pF (220) 5%50V, 0603 8.2pF (8R2) 0.25pF 50V1112p贴片电容C83, C84, C99, C1000402_C0402 10nF (103) 10%50V415p贴片电容C103, C106, C109,C1120402_C0402 68pF (680) 5%50V4THD2528-11SD-GF CARD1TF-SMD_THD2528-11SD-GFTHD2528-11SD-GF1蓝灯 0603发光二极管D1, D6, D7, D8, D9,D10, D110603_LED_S10603 蓝灯7PESD15VL1BA,115TVS DIODE 15VWM 44VCSOD323D2FP-SOD323-CA-IPC_CCMP-14432-000007-11MBR0530DIODE SCHOTTKY 30V500MA SOD123D3FP-425-04-MFGCMP-2000-05113-21SS34Silicon Carbide PowerSchottky Diode, 3300 V, - 0.3 A, -55 to 175 degC, 2-Pin SMD, RoHS, Tape andReelD4, D5GESC-GAP3SLT33-214-2_VCMP-2000-05135-22红灯 0603发光二极管D120603_LED_S10603 红灯1MF-MSMF020-2PTC RESET FUSE 30V200MA 1812F1FP-MF-MSMF020-2-MFGCMP-07400-000027-11JD0-0001NLCONN MAGJACK 1PORT1000 BASE-TJ1FP-JD0-0001NL-MFGCMP-16436-000001-111747981-1HDMI Receptacle,Pitch 0.5 mm, 19 Position, Height 6.38 mm, RoHS, Tape and ReelJ2TE-1747981-1_VCMP-1684-00008-1161301621121THT Vertical PinHeader WR-PHD, Pitch 2.54 mm, Dual Row, 16 pinsJ361301621121CMP-1502-01097-11687140149022SMT ZIF ConnectorsHinge Type WR-FPC, Horizontal, Bottom Contact, pitch 0.5 mm, 40 pinsJ4687140149022CMP-1502-01641-1161400826021USB 2.0 Type AReceptacle WR-COM, Stacked Horizontal, THTJ661400826021CMP-1502-03229-11cameraTHT Vertical PinHeader WR-PHD, Pitch 2.54 mm, Dual Row, 18 pinsJ761301821121CMP-1502-01101-11434111050826WS-TASV SMD TactSwitch 6.0X3.5 mmK1, K2, K3, K4, K5,K6434111050826Switch-3.6*6.1*2.568-1437565-1SWITCH TACTILESPST-NO 0.02A 15VK7FP-8-1437565-1-MFGCMP-03407-000016-11120OHM贴片磁珠L20805_L0805 100Ω 25% 100MHz12.2uWire Wound FerriteInductor for Power Lines 1.5μH ±30% 0.0684Ω 1750mA 1210L3FP-LQH32PB_N0-MFGCMP-06042-011622-114.7uSMD Power Inductors15uH ±20% 0.47A 0.612ΩL4, L5, L6, L7FP-NR4010-MFGCMP-14484-001436-14ST-025BHAUDIO MAGNETIC XDCR2-4V SMDLS1FP-ST-025BH-MFGCMP-247804-000002-11TSW-104-08-L-S0.025" SQ PostHeader, Through-hole, Vertical, -55 to 125 degC, 2.54 mm Pitch, 4-Pin, Male,RoHSP1SMTC-TSW-104-08-X-SCMP-1024-00358-112N7002 7002MOS(场效应管)Q1, Q2, Q3SOT-23(SOT-23-3)2N7002 700231k贴片电阻R10402_R0402 0Ω (0R0) 1%110k贴片电阻R2, R5, R6, R7, R26,R27, R28, R29, R30, R66, R71, R72, R83, R86, R87, R100, R101, R102, R103,R104, R1050402_R0402 5.6KΩ (5601) 1%,0402 0Ω (0R0) 1%, 0603 82KΩ (8202) 1%2133贴片电阻R3, R4, R11, R16,R60, R76, R77, R78, R790402_R0402 5.6KΩ (5601) 1%9470贴片电阻R8, R12, R19, R31,R45, R47, R96, R97, R98, R990402_R0402 0Ω (0R0) 1%,0402 5.6KΩ (5601) 1%104.7k贴片电阻R9, R10, R20, R22,R35, R36, R37, R38, R39, R40, R41, R42, R44, R46, R69, R70, R73, R74, R81,R106, R108, R1090402_R0402 0Ω (0R0) 1%,0402 5.6KΩ (5601) 1%2220k贴片电阻R13, R14, R15, R17,R18, R65, R670402_R0402 5.6KΩ (5601) 1%7100贴片电阻R21, R51, R52, R53,R54, R55, R56, R57, R58, R59, R62, R630402_R0402 0Ω (0R0) 1%,0402 5.6KΩ (5601) 1%1280.6贴片电阻R23, R240402_R0402 0Ω (0R0) 1%2240贴片电阻R250402_R0402 0Ω (0R0) 1%168k贴片电阻R320402_R0402 5.6KΩ (5601) 1%1150k贴片电阻R330402_R0402 5.6KΩ (5601) 1%11k贴片电阻R34, R680603_R0603 82Ω (82R0) 1%20贴片电阻R43, R500603_R0603 10KΩ (1002) 1%22.49k贴片电阻R480402_R0402 5.6KΩ (5601) 1%11贴片电阻R490603_R0603 10KΩ (1002) 1%11.5k贴片电阻R610402_R0402 5.6KΩ (5601) 1%18.06k贴片电阻R640402_R0402 5.6KΩ (5601) 1%15.1k贴片电阻R80, R820603_R0603 82KΩ (8202) 1%212k贴片电阻R840603_R0603 82KΩ (8202) 1%110k贴片电阻R850603_R0603 10KΩ (1002) 1%1100k贴片电阻R88, R94, R950402_R0402 5.6KΩ (5601) 1%3120k贴片电阻R890402_R0402 5.6KΩ (5601) 1%1200k贴片电阻R900402_R0402 5.6KΩ (5601) 1%1453k贴片电阻R910402_R0402 5.6KΩ (5601) 1%12k贴片电阻R1070402_R0603 82KΩ (8202) 1%1XC7Z010-1CLG400I667 MHz Zynq™-7000 APSoC, 130 PS I/O, 100 FPGA I/O, 400-Ball BGA, Speed Grade 1, Industrial Grade,Pb-FreeU1CLG400CMP-0363-00008-31W25Q128FVSIG3V 128M-Bit SerialFlash Memory with Dual/Quad SPI & QPI, 2.7 to 3.6 V, -40 to 85 degC,8-Pin SOIC, RoHS, Tape and ReelU2WINB-SOIC-8_MCMP-2000-05005-11MT41K256M16HA-125IT:E4Gb DDR3-1600 SDRAM,256Mb x 16, 1.25 ns, 1.35 V, -40 to 95 degC, 96-Ball FBGAU3MICT-HA-96CMP-2000-04969-11MT3410LB U4, U5, U12, U13SOT-23-5MT3410LB4RTL8211E-VB-CG U6QFN48-6x6RTL8211E-VB-CG1USB3320C-EZKHighly IntegratedFull Featured Hi-Speed USB 2.0 ULPI Transceiver, 1.8 to 3.3 V, -40 to 85degC, 32-Pin QFN (QFN-3304), RoHS, TrayU7MCHP-QFN-32-5x5_V2CMP-0186-00335-11TPS2051BDBVRCurrent-Limited,Power-Distribution Switch, 2.7 to 5.5 V, -40 to 85 degC, 5-Pin SOT-23 (DBV),Green (RoHS & no Sb/Br), Tape and ReelU8DBV0005A_LCMP-2000-07277-11TXB0108PWRTXB01088-Bit Bidirectional Voltage-Level Translator with Auto-Direction Sensingand
+/- 15-kV ESD Protection, 1.2 to 3.6 V, -40 to 85 degC, 20-Pin TSSOP (PW),Green (RoHS & no Sb/Br), Tape and ReelU9PW0020A_LCMP-2000-07337-1193LC56BT-I/OTIC EEPROM 2K SPI 2MHZSOT23-6U10FP-C04-028-MFGCMP-0162-00356-21FT4232HL-REELIC USB HS QUADUART/SYNC 64-LQFPU11FP-LQFP-64-MFGCMP-0078-00021-41SL2.1A U14SOIC-16_150milSL2.1A1AT93C66B-SSHM-TIC EEPROM 4KBIT SPI2MHZ 8SOICU15FP-C04-057-SN-MFGCMP-06313-000039-11U254-051T-4BH83-F1S USB1MICRO-USB-SMD_U254-051T-4BH83-F1SMicro-USB1GT-USB-7010B USB2, USB3USB-C-SMD_GT-USB-7010B- duplicateType-C250MHzXTAL OSC XO25.0000MHZ CMOS SMDY1FP-ASE-MFGCMP-2000-05795-2133.333MHzXTAL OSC XO25.0000MHZ CMOS SMDY2FP-ASE-MFGCMP-2000-05795-2125MCRYSTAL 16.0000MHZ9PF SMDY3FP-TSX-3225-MFGCMP-36405-000014-1112MCRYSTAL 16.0000MHZ9PF SMDY4, Y5, Y6FP-TSX-3225-MFGCMP-36405-000014-13
附件
