[/free]
DRC错误标记由带有两个字母的“领结”符号组成。字母代码指示违反了哪种约束类型。
Net-to-Net Spacing DRC错误标记代码为大写;相反,Same Net Spacing代码是小写的。
DRC错误标记代码定义
下表列出了每种DRC错误标记代码组合及其关联的约束违例。该列表根据DRC错误标记中的字母按字母顺序排列。
[free]
本主题需向作者支付 1 枚金币 才能浏览 购买主题
DRC错误标记代码定义
Code | ConstraintViolation |
A – A | Acuteangle to cavity edge |
B – B | BondPad to Bond Pad |
B – L | BondPad to Line |
B – S | BondPad to Shape |
C – C | Componentto cavity edge |
Package to package | |
Soldermask to soldermask | |
D – C | DFAPackage to package |
D – D | MechanicalDrill Hole to Mechanical Drill Hole |
Mechanical Drill Hole to Drill Hole | |
D – I | Negativeplane islands |
D – L | MechanicalDrill Hole to Cline |
Drill Hole to Cline | |
D – P | PhaseTolerance Tolerance |
Mechanical Drill Hole to Pin | |
D – S | MechanicalDrill Hole to Shape |
Drill Hole to Shape | |
D – V | MechanicalDrill Hole to Via |
Drill Hole to Via | |
E – D | MaxFinal Settle Max |
Min First Switch Min | |
Noise Margin Min | |
Overshoot Max | |
Propagation Delay Max | |
Propagation Delay Min | |
Propagation Delay Path Type | |
Relative Propagation Delay Delta | |
Relative Propagation Delay Path Type | |
Relative Propagation Delay Scope | |
E – L | LayerSets |
Max Exposed Length | |
Total Etch Length Max | |
Total Etch Length Min | |
E – P | Parallelism |
E – S | MaxStub Length |
E – T | VerifySchedule |
E – V | MaxVia Count |
E – X | ActiveWindow |
Max Xtalk | |
Max Peak Xtalk | |
Sensitive Window | |
Maximum Inter Crosstalk | |
Maximum Intra Crosstalk | |
F – C | Bondfinger to component |
Bond Pad to Component Edge | |
Bond Finger to cavity edge | |
F – F | BondPad to Bond Pad (same net) |
Bond Pad to Bond Pad (different net) | |
I – M | Single-lineImpedance Target and Tolerance |
J – N | AllowTs |
K – B | BondPad to Route Keepin |
Bond Pad to Route Keepout | |
Bond Pad to Via Keepout | |
K – C | Packageto place keepin |
Package to place keepout | |
K – L | Lineto Route Keepin |
Line to Route Keepout | |
K – P | ThruPin to Route Keepin |
Thru Pin to Route Keepout | |
SMD to Route Keepin | |
SMD to Route Keepout | |
Test Pin to Route Keepin | |
Test Pin to Route Keepout | |
Test Pin to No Probe | |
K – S | Shapeto Route Keepin |
Shape to Route Keepout | |
K – V | Viato Route Keepin |
Via to Route Keepout | |
Via to Via Keepout | |
BB Via to Route Keepin | |
BB Via to Route Keepout | |
BB Via to Via Keepout | |
Test Via to Route Keepin | |
Test Via to Route Keepout | |
Test Via to Via Keepout | |
Test Via to No Probe | |
L – L | Lineto Line |
L – S | Shapeto Line |
L – W | LineWidth Max |
Line Width Min | |
Neck Max Length | |
Neck Min Width | |
M – A | Soldermaskalignment |
Pad Soldermask Alignment | |
Symbol Soldermask Alignment | |
M – C | SymbolSoldermask to Pad Soldermask |
Minimum Cavity Size | |
M – L | Soldermaskto pad and cline |
M – M | PadSoldermask to Pad Soldermask |
Any Metal to Any Metal Spacing | |
M – P | Soldermaskto Pin |
M – S | Soldermaskto shape |
M – V | Soldermaskto Via |
Matched Via count violation | |
N – S | NegativePlane to Sliver |
O – C | Objectexposure to cavity |
P – B | BondPad to SMD Pin |
Bond Pad to Test Pin | |
Bond Pad to Thru Pin | |
P – D | MechanicalPin Antipad to Drill Hole |
P – L | Lineto SMD Pin |
Line to Test Pin | |
Line to Thru Pin | |
Mechanical Pin Antipad to Cline | |
P – M | Pastemaskpad to pastemask pad |
Pastemask to package pastemask | |
P – P | SMDPin to SMD Pin |
SMD Pin to Test Pin | |
Test Pin to Test Pin | |
Thru Pin to SMD Pin | |
Thru Pin to Test Pin | |
Thru Pin to Thru Pin | |
Mechanical Pin Antipad to Pin | |
P – S | Shapeto SMD Pin |
Shape to Test Pin | |
Shape to Thru Pin | |
Mechanical Pin Antipad to Shape | |
P – V | SMDPin to BB Via |
SMD Pin to Test Via | |
SMD Pin to Thru Via | |
Test Pin to BB Via | |
Test Pin to Test Via | |
Test Pin to Thru Via | |
Thru Pin to BB Via | |
Thru Pin to Test Via | |
Thru Pin to Thru Via | |
Mechanical Pin Antipad to Via | |
R – C | Packageto room |
S – N | AllowEtch |
S – S | Shapeto Shape |
T – C | Testpointloc. to component |
Testpoint pad to component | |
Testpoint under component | |
V – B | BondPad to BB Via |
Bond Pad to Test Via | |
Bond Pad to Thru Via | |
V – G | AllowPad-Pad Connect |
BB Via Stagger Max | |
BB Via Stagger Min | |
Min BB Via Gap | |
V – L | Lineto BB Via |
Line to Test Via | |
Line to Thru Via | |
V – N | Vias |
Vialist constraint violation | |
V – S | Shapeto BB Via |
Shape to Test Via | |
Shape to Thru Via | |
V – V | BBVia to BB Via |
BB Via to Test Via | |
Test Via to Test Via | |
Thru Via to BB Via | |
Thru Via to Test Via | |
Thru Via to Thru Via | |
W – A | Min.bonding wire length |
Wire to die edge angle | |
W – D | Bondingwire diameter |
W – C | Wireto Cavity Edge Spacing |
Wire End to Cavity Edge Spacing | |
W – E | Wireend to wire end |
W – F | Wireto bond finger |
W – I | Max.bonding wire length |
W – P | Wireto pin |
W – W | Wireto wire (same profile) |
W – X | Wireto wire (different profile) |
X – D | ExternallyDetermined Violation |
[free]
回 tz小智 的帖子
tz小智: (2024-01-23 09:15) images/back.gif回 tz小智 的帖子
