18层英特尔® Agilex™ 7 FPGA I 系列开发套件 INT
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB1MOLEX_QSFPDD_CAGE_MOLEX_QSFPDD_CAGE_MOLEX_QSFPDD_CAGEMolex_QSFPDD_CageMOLEX_QSFPDD_CAGEB2MOLEX_QSFPDD_CAGE_MOLEX_QSFPDD_CAGE_MOLEX_QSFPDD_CAGEMolex_QSFPDD_CageMOLEX_QSFPDD_CAGECN1CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206CN2CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206CN3CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206CN4CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206CN5CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206CN6CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206D1LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D2APHB1608CGKSYKC_LED0603_4PIN_APHB1608_APHB1608CGKSYKCAPHB1608CGKSYKCLED0603_4PIN_APHB1608D3LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D4APHB1608CGKSYKC_LED0603_4PIN_APHB1608_APHB1608CGKSYKCAPHB1608CGKSYKCLED0603_4PIN_APHB1608D5LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D6LED_0_LED_0603_BLUELEDBLUELEDLED_0603D7LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D8LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D9LED_WURTH_LED_0603_RED_LEDRED_LEDLED_0603D10LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D11LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603D12TVS_5P0SMDJ12A_TVS_5P0SMDJ12A_5P0SMDJ12A5p0SMDJ12ATVS_5P0SMDJ12AD13TVS_5P0SMDJ12A_TVS_5P0SMDJ12A_5P0SMDJ12A5p0SMDJ12ATVS_5P0SMDJ12AEU1MAX31730ATC_LCC12_S30_50DF25X17MA_MAX31730ATC+MAX31730ATC+LCC12_S30_50DF25X17MAEU2MAX31730ATC_LCC12_S30_50DF25X17MA_MAX31730ATC+MAX31730ATC+LCC12_S30_50DF25X17MAFB1BEAD_FERRITE_SM_0402_220OHM220ohm402FB5BEAD_FERRITE_SM_0402_220OHM220ohm402FB6BEAD_FERRITE_SM_0402_220OHM220ohm402FB7BEAD_FERRITE_SM_0402_220OHM220ohm402FB8BEAD_FERRITE_SM_0402_220OHM220ohm402FB9BEAD_FERRITE_SM_0402_220OHM220ohm402FB10BEAD_FERRITE_SM_0402_220OHM220ohm402FB13BEAD_FERRITE_SM_0402_220OHM220ohm402FB16BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR600Ohm, 0.5A, 0.35DCR603FB17FERRITEBEAD_1_0402_220OHM220ohm402FB18FERRITEBEAD_1_0402_220OHM220ohm402FB19FERRITEBEAD_1_0402_220OHM220ohm402FB20FERRITEBEAD_1_0402_220OHM220ohm402FB21FERRITEBEAD_1_0402_220OHM220ohm402FB24R2_0402_742792780742792780402FB25BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR600Ohm, 0.5A, 0.35DCR603FB26INDUCTOR_SL1616A-R10MHF_0.1UH,19A0.1uH,19ASL1616A-R10MHFFB27BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR600Ohm, 0.5A, 0.35DCR603FB28BEAD_FERRITE_SM_0603_600OHM, 0.5A, 0.35DCR600Ohm, 0.5A, 0.35DCR603FB29INDUCTOR_805_120OHM,800MA120ohm,800mA805FB30BEAD_FERRITE_SM_0603_22OHM@100MHZ8A22ohm@100Mhz8A603FB31BEAD_FERRITE_SM_0603_22OHM@100MHZ8A22ohm@100Mhz8A603FB32BEAD_FERRITE_SM_0603_22OHM@100MHZ8A22ohm@100Mhz8A603FB33BEAD_FERRITE_SM_0603_22OHM@100MHZ8A22ohm@100Mhz8A603FB40BEAD_FERRITE_SM_0402_220OHM220ohm402FB41BEAD_FERRITE_SM_0603_22OHM@100MHZ8A22ohm@100Mhz8A603HW1LIGHTPIPE_P-U90-1101-T00A-BP_2_LIGHTPIPE_P-U90-1101-T00A-BP_LIGHTPIPE_P-U90-1101-T00A-BPLIGHTPIPE_P-U90-1101-T00A-BPLIGHTPIPE_P-U90-1101-T00A-BPJ1DDR4X72X288_1_DDR4DIMM_SMT_DDR4X72X288DDR4x72x288DDR4DIMM_SMTJ2DDR4X72X288_1_DDR4DIMM_SMT_DDR4X72X288DDR4x72x288DDR4DIMM_SMTJ32027180100_2027180100_202718010020271801002027180100J42027180100_2027180100_202718010020271801002027180100J5PCIE_BRACKET_X16_1_PCIX-16PORT_PCIE_SLOTPCIE_SlotPCIX-16PORTJ6CON_MCIO_74P_G42V12312HR_SCONN74_K64129002_PIP_MCIO_74P_G97V22312HRMCIO_74P_G97V22312HRSCONN74_K64129002_PIPJ7CON_MCIO_74P_G42V12312HR_SCONN74_K64129002_PIP_MCIO_74P_G97V22312HRMCIO_74P_G97V22312HRSCONN74_K64129002_PIPJ8MICRO_USB_CONN_MOLEX-MICRO-USB-47589-001_MICRO_USB_CONNMICRO_USB_CONNMOLEX-MICRO-USB-47589-001J9FAN_CONN_0_MOLEX_0470533000_FAN_CONNFAN_ConnMOLEX_0470533000J10J2370247-1051MOLEX_70247-1051J112X4_PCIE_ATX_1_MLX_SD-5569_8POS_RA_PCIE2X4 ATXPCIe2x4 ATXMLX_SD-5569_8POS_RAJ121X3_HDR_TH_1X3_HDR_TH_TSW-103-08-G-STSW-103-08-G-S1X3_HDR_THJ131X3_HDR_TH_1X3_HDR_TH_TSW-103-08-G-STSW-103-08-G-S1X3_HDR_THL1INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L2INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L3INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L4INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L5INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L6INDUCTORIRON_IFSC1008ABER1R0M01_1UH1uHIFSC1008ABER1R0M01L11BEAD_FERRITE_SM_0402_BLM15AG221SN1BLM15AG221SN1402L12BEAD_FERRITE_SM_0402_BLM15AG221SN1BLM15AG221SN1402L13BEAD_FERRITE_SM_0402_BLM15AG221SN1BLM15AG221SN1402L14BEAD_FERRITE_SM_0402_BLM15AG221SN1BLM15AG221SN1402L15INDUCTOR,DISCRETE_IND_AH3740_ITG_120NH120nHIND_AH3740_ITGL16INDUCTOR,DISCRETE_IND_AH3740_ITG_120NH120nHIND_AH3740_ITGL17INDUCTOR,DISCRETE_IND_AH3740_ITG_120NH120nHIND_AH3740_ITGL18INDUCTOR_IND_BRC2518_22UH__22uHIND_BRC2518L19INDUCTOR,DISCRETE_IND_AH3740_ITG_120NH120nHIND_AH3740_ITGL20INDUCTOR,DISCRETE_XEL4020-821_0.82UH0.82uHXEL4020-821L21INDUCTOR,DISCRETE_XEL4020-821_0.82UH0.82uHXEL4020-821L22INDUCTOR,DISCRETE_XEL4030-201ME_0.20UH0.20uHXEL4030-201MEMTH1MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GNDMT_HOLE_GNDMH_D125C175T_TB315MTH2MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GNDMT_HOLE_GNDMH_D125C175T_TB315MTH4MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GNDMT_HOLE_GNDMH_D125C175T_TB315MTH5MNTHOLE_1_MH_D125C175T_TB315_MT_HOLE_GNDMT_HOLE_GNDMH_D125C175T_TB315Q1PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q2PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q3PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q4PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q5PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q6PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q7PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q8PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q9PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q10PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q11PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q12PWRMOSFET_EN_GSD_0_SOT23_FDV305NFDV305NSOT23Q13PSMN1R0-30YLD_0_NFET_PSMN1R0-30YLD_PSMN1R0-30YLDPSMN1R0-30YLDNFET_PSMN1R0-30YLDQ14PWRMOSFET_EN_GSD_1_SOT23_SI2302CDS-T1-GE3SI2302CDS-T1-GE3SOT23S1S7PBSwitchWURTH_6X3P5_TACT_SWITCHS2S7PBSwitchWURTH_6X3P5_TACT_SWITCHS3S7PBSwitchWURTH_6X3P5_TACT_SWITCHS4S7PBSwitchWURTH_6X3P5_TACT_SWITCHS5S7PBSwitchWURTH_6X3P5_TACT_SWITCHST32SHORT_SHORT_SHORTSHORTSHORTSW1SPST4_DIPSWITCH_SMT_QUAD_TDA04H0SB1TDA04H0SB1DIPSWITCH_SMT_QUADSW2SPST4_DIPSWITCH_SMT_QUAD_TDA04H0SB1TDA04H0SB1DIPSWITCH_SMT_QUADSW3SPST4_DIPSWITCH_SMT_QUAD_DIPSWITCH4DIPSWITCH4DIPSWITCH_SMT_QUADSW4SPST4_DIPSWITCH_SMT_QUAD_DIPSWITCH4DIPSWITCH4DIPSWITCH_SMT_QUADSW5SPST4_DIPSWITCH_SMT_QUAD_TDA04H0SB1TDA04H0SB1DIPSWITCH_SMT_QUADSW6SW_SLIDE_DPDT_EG2207_SW_SLIDE_DPDTSW_SLIDE_DPDTEG2207TP1TESTPOINT_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP2TP,0.016", THRU HOLE_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP3TP,0.016", THRU HOLE_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP4TP,0.016", THRU HOLE_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP8TP,0.016", THRU HOLE_0D016_THRU_HOLE_TP, 0.016", THRU HOLETP,0.016", Thru Hole0D016_THRU_HOLETP9TP,0.016", THRU HOLE_0D016_THRU_HOLE_TP, 0.016", THRU HOLETP,0.016", Thru Hole0D016_THRU_HOLETP10TESTPOINT_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP11TESTPOINT_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP14TP,0.016", THRU HOLE_0D016_THRU_HOLE_TP, 0.016", THRU HOLETP,0.016", Thru Hole0D016_THRU_HOLETP15TP,0.016", THRU HOLE_0D016_THRU_HOLE_TP, 0.016", THRU HOLETP,0.016", Thru Hole0D016_THRU_HOLETP16TESTPOINT_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP17TESTPOINT_30MIL_TP_TESTPOINTTESTPOINT30MIL_TPTP18TP,0.016", THRU HOLE_0D016_THRU_HOLE_TP, 0.016", THRU HOLETP,0.016", Thru Hole0D016_THRU_HOLETP19PAD_STYLE_C_PADSTYLE1_IO_TESTPAD_PCBPADS-1TESTPADPADSTYLE1TP20PAD_STYLE_C_PADSTYLE1_IO_TESTPAD_PCBPADS-1TESTPADPADSTYLE1TP21PAD_STYLE_C_PADSTYLE1_IO_TESTPAD_PCBPADS-1TESTPADPADSTYLE1TP22PAD_STYLE_C_PADSTYLE1_IO_TESTPAD_PCBPADS-1TESTPADPADSTYLE1U1MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U2MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U3MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U4MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U5MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U6AGILEX-I_2957A_FBGA2957A_HEX_P56X45_AGILEX-I_2957AAgileX-I_2957AFBGA2957A_HEX_P56X45U7MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U8MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U9MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U10MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U11MT40A1G16HBA-083E_0_FBGA96_MT40A1G16KNR-075:EMT40A1G16KNR-075:EFBGA96U12MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U13MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U14FPC202_QFN-56_FPC202RHURFPC202RHURQFN-56U15MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U1624AA024_SOIC-8_24AA024-I/SN24AA024-I/SNSOIC-8U17SN74LVC1G08_0_DCK_SN74AUP1G08DCKRSN74AUP1G08DCKRDCKU18MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U19SN74AUP1G126DCK_SC70_TI_SN74AUP1G126DCKSN74AUP1G126DCKSC70_TIU20MT25QU01GBBB_T-PBGA24_MT25QL02GCBB8E12-0SITMT25QL02GCBB8E12-0SITT-PBGA24U21REF1112_SOT23-3_REF1112AIDBZRREF1112AIDBZRSOT23-3U22SI5341A-A-GM_0_QFN64_9X9_SI5391_SI5391A-A12892-GMSi5391A-A12892-GMQFN64_9X9_SI5391U23SI52204_QFN32L_SI52204-A01BGMSi52204-A01BGMQFN32LU24SI53254A-D02AM_SI53254_QFN40_SI53254A-D02AMSi53254A-D02AMSI53254_QFN40U25SI53254A-D02AM_SI53254_QFN40_SI53254A-D02AMSi53254A-D02AMSI53254_QFN40U26FXMA2102UMX_UMLP_FXMA2102UMXFXMA2102UMXUMLPU27FXMA2102UMX_UMLP_FXMA2102UMXFXMA2102UMXUMLPU28MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U29MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U30MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U31MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U32MAX3378E_0_TSSOP-14_MAX3378EMAX3378ETSSOP-14U33MAX811_SOT-143_MAX811MAX811SOT-143U3410M50DAF256_256FBGA_(S1+S2+S3+S4+S5+S6+S7+S8+S9+S10+S11+S12)_10M50DAF256C7G10M50DAF256C7G256FBGAU35TPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30DRTU36CY7C68013A_56QFN_QFN56_CY7C68013A_QFNCY7C68013A_QFNQFN56U37W25Q64JVSSIM_WSOIC-8_W25Q64JVSSIMW25Q64JVSSIMWSOIC-8U38TS3A5018RSVR_0_UQFN-16_TS3A5018RSVRTS3A5018RSVRUQFN-16U39SN74LVC2G17DCKR_SC70-6_SN74LVC2G17DCKRSN74LVC2G17DCKRSC70-6U40MAX3002EUP+T_20-TSSOP_TXS0108EPWRTXS0108EPWR20-TSSOPU41SN74LVC2G17DCKR_SC70-6_SN74LVC2G17DCKRSN74LVC2G17DCKRSC70-6U42MAX3002EUP+T_20-TSSOP_TXS0108EPWRTXS0108EPWR20-TSSOPU43M24128_SO8_M24128-BWMN6TPM24128-BWMN6TPSO8U44FDMC8878_VER2_FDMC8878_VER2_FDMC2514SDCFDMC2514SDCFDMC8878_VER2U45FDMC8878_VER2_FDMC8878_VER2_FDMC2514SDCFDMC2514SDCFDMC8878_VER2U46LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPADU47LTC4365_DFN_DFN8-EPAD_3X2_LTC4365-1LTC4365-1DFN8-EPAD_3X2U48LTC4359_MSOP-8_LTC4359LTC4359MSOP-8U49FDMC8878_VER2_FDMC8878_VER2_FDMC2514SDCFDMC2514SDCFDMC8878_VER2U50FDMC8878_VER2_FDMC8878_VER2_FDMC2514SDCFDMC2514SDCFDMC8878_VER2U51LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPADU52LTC4365_DFN_DFN8-EPAD_3X2_LTC4365-1LTC4365-1DFN8-EPAD_3X2U53TPS3700_DDC_TPS3700TPS3700DDCU54ED8401_1_ED8401_QFN40_ED8401ED8401ED8401_QFN40U55LMV321_SOT23-5_LMV321LMV321SOT23-5U56FDMF31XX_3_LGA41_ET6160LIET6160LILGA41U57FDMF31XX_3_LGA41_ET6160LIET6160LILGA41U58FDMF31XX_3_LGA41_ET6160LIET6160LILGA41U59ER3105QI_0_12LD_DFN_ER3105DIER3105DI12LD_DFNU60FDMF31XX_3_LGA41_ET6160LIET6160LILGA41U61LTC4625EY_BGA25_LTM4625LTM4625BGA25U62EP53F8QI_2_EP53F8QI_EP53F8QIEP53F8QIEP53F8QIU63EP53F8QI_2_EP53F8QI_EP53F8QIEP53F8QIEP53F8QIU64EM2130_MODULE_1_EM2130_EM2130HEM2130HEM2130U65EM2130_MODULE_1_EM2120_EM2120L01QIEM2120L01QIEM2120U66LTM4657-BGA_0_LTC-BGA-49-1518_IC_LTM4657EY_LTM4657EY#PBFLTM4657EYLTC-BGA-49-1518U67LTM4657-BGA_0_LTC-BGA-49-1518_IC_LTM4657EY_LTM4657EY#PBFLTM4657EYLTC-BGA-49-1518U68LTC3543EDCB_0_LQFN_28_5MMX4MM_LTC7151SEVLTC7151SEVLQFN_28_5MMX4MMU69LTC3543EDCB_0_LQFN_28_5MMX4MM_LTC7151SEVLTC7151SEVLQFN_28_5MMX4MMU70EM2130_MODULE_1_EM2120_EM2140P01QIEM2140P01QIEM2120U71LTC3543EDCB_0_LQFN_28_5MMX4MM_LTC7151SEVLTC7151SEVLQFN_28_5MMX4MMU72EM2130_MODULE_1_EM2120_EM2120L01QIEM2120L01QIEM2120U73EN63A0QI_QFN-76_EN63A0QIEN63A0QIQFN-76U75EN5337Q_2_QFN38_EN6347QIEN6347QIQFN38U77EP53F8QI_2_EP53F8QI_EP53F8QIEP53F8QIEP53F8QIU79EP53F8QI_2_EP53F8QI_EP53F8QIEP53F8QIEP53F8QIU80EP53F8QI_2_EP53F8QI_EP53F8QIEP53F8QIEP53F8QIU81LT3042IDD#PBF_0_LT3042IDD_LT3042IDD#PBFLT3042IDD#PBFLT3042IDDU82EN63A0QI_QFN-76_EN63A0QIEN63A0QIQFN-76U83EN63A0QI_QFN-76_EN63A0QIEN63A0QIQFN-76U84TPS51200_VSON-11_TPS51200DRCRTPS51200DRCRVSON-11U85TPS51200_VSON-11_TPS51200DRCRTPS51200DRCRVSON-11U86EN5337Q_2_QFN38_EN6337QIEN6337QIQFN38U87FDMC8878_VER2_FDMC8878_VER2_FDMC2514FDMC2514FDMC8878_VER2U88LTC4365_DFN_DFN8-EPAD_3X2_LTC4365-1LTC4365-1DFN8-EPAD_3X2U89EZ6301QI_1_NEWEZ6301_QFN_EZ6301QIEZ6301QINEWEZ6301_QFNX1OSC_ALT_0_ECS3525_50MHZ50MHzECS3525Y1CRYSTAL_SM_13_XTAL_3MMX2MM_48MHZ48MHzXTAL_3MMX2MMY2CRYSTAL_SM_13_XTAL_FA-128_25.00MHZ25.00MHzXTAL_FA-128Y3CRYSTAL_SM_13_XTAL_FA-128_24.00MHZ24.00MHzXTAL_FA-128 PCB文件。回复可见。没原理图
**** Hidden Message ***** 看看
