RK3588S 10层挂两个LPDDR4 2介盲埋孔PCB和原理图
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBT2000BATT3_2_CON_SMD_CPBC308-0301F_8CON_8P_CPBC308-0301FCON_SMD_CPBC308-0301F_8PD2600DIODEZENER1_1_SOD_123_BZT52C3VBZT52C3V0SOD_123D2601DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D2602DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D2603DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D2604DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D2605DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D2606DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D5600DIODE_SOD_123_B5819WB5819WSOD_123D9200DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402D9202DIODEBI_DIR TRIG_ESD0402_ESD54ESD5451NESD0402D9203DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402ED2200DIODEBI_DIR TRIG_ESD0402_AZ582AZ5825-01FESD0402ED7006DIODEBI_DIR TRIG_ESD0402_ESD_1ESD54031ESD0402ED7007DIODEBI_DIR TRIG_ESD0402_ESD_1ESD54031ESD0402ED7010DIODEBI_DIR TRIG_ESD0402_ESD_1ESD54031ESD0402ED7011DIODEBI_DIR TRIG_ESD0402_ESD_1ESD54031ESD0402ED9300DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402ED9301DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402FB2300BEAD_L0603_120R-100MHZ120R-100MHzL0603FB7000BEAD_L0603_600R-100M600R-100ML0603FB7002BEAD_L0603_600R-100M600R-100ML0603FB7003BEAD_L0603_600R-100M600R-100ML0603FB7006BEAD_L0603_600R-100M600R-100ML0603FB7007BEAD_L0603_600R-100M600R-100ML0603J1CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J3CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J9CON_MHF4_20449-001E_CON_MHF4_20MHF4-20701-001ECON_MHF4_20449-001EJ11CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J12CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J2600USB31_TYPE_C_24P_TYPEC30_24P_SD2012670005TYPEC30_24P_SD-2012670005J4600CMK-CB0077-FV1_6_CON_SMD_BM28B0BM28B0.6-30DS/2-0.35VCON_SMD_BM28B0_6_30DS_2_0_35V_30J4700CMK-CB0077-FV1_6_CON_SMD_BM28B0BM28B0.6-30DS/2-0.35VCON_SMD_BM28B0_6_30DS_2_0_35V_30J5500LCD_HITACHI_TX05D99VM1AAA_1_CONFH35C-61S-0.3SHWCON_SMD_FH35C-61S-0_3SHWJ7001AUDIO_JACK_2P_A_3_CNN2_2R00_6R0Audio_Jack_2P_ACNN2_2R00_6R00X6R10X5R00_HJ7002BATT3_3_CON_SMD_6298-708_8P_0_5CON_8P_6298708 200 883+_0.5mmCON_SMD_6298-708_8P_0_5PITCHJ7003CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J7004CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J7005CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J7006CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J7007CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J7008CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J7009CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J7010CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J7011CONTACT_10123973-004RLF_SMD1_65CONTACT_L0475SMD1_65X1_0J7012BATT3_4_WLCSP-1R7X1R51-12B_SGM3SGM3804WLCSP-1R7X1R51-12BJ7013AUDIO_JACK_2P_A_3_CNN2_2R00_6R0Audio_Jack_2P_ACNN2_2R00_6R00X6R10X5R00_HJ7014CON_24P_WP7A-S024VA1_0_CON_SMD_WP26DK-S024VA3CON_SMD_WP26DK-S024VA3_24P_0_35PL2200INDUCTORSOF FERRITE_IND_2016100.47uHIND_201610L2201INDUCTORSOF FERRITE_IND_4040200.22uHIND_404020L2202INDUCTORSOF FERRITE_IND_2016100.47uHIND_201610L2203INDUCTORSOF FERRITE_IND_2520120.24uHIND_252012L2204INDUCTORSOF FERRITE_IND_2016100.47uHIND_201610L2205INDUCTORSOF FERRITE_IND_2520120.24uHIND_252012L2206INDUCTORSOF FERRITE_IND_2016100.47uHIND_201610L2207INDUCTORSOF FERRITE_IND_2520120.24uHIND_252012L2208INDUCTORSOF FERRITE_IND_2016100.47uHIND_201610L2209INDUCTORSOF FERRITE_IND_2016100.47uHIND_201610L2300INDUCTORSOF FERRITE_IND_2520120.24uHIND_252012L2301INDUCTORSOF FERRITE_IND_2520120.24uHIND_252012L2302INDUCTORSOF FERRITE_IND_2520120.24uHIND_252012L2303INDUCTORSOF FERRITE_IND_2520102.2uHIND_252010L2500INDUCTORSOF FERRITE_IND_5050151.0uHIND_505015L2600INDUCTORCOM_RP2_0504_90R-100M90R-100MRP2_0504L4700INDUCTORSOF FERRITE_IND_2016_13.3uHIND_201610L5600INDUCTORSOF FERRITE_IND_40401210uHIND_404012L6300INDUCTORSOF FERRITE_IND_2520_12.2uHIND_252012L6301INDUCTORSOF FERRITE_IND_2520_12.2uHIND_252012L6302INDUCTORSOF FERRITE_IND_2016_24.7uHIND_201610L6303INDUCTORSOF FERRITE_IND_2016100.47uHIND_201610U1000SOC_RK3588S_BGA1253_17R00X17R00RK3588SBGA1253_17R00X17R00X1R10U2000GAUGE_CW2015_DFN8_3R00X2R50X0R9CW2015CHBDDFN8_3R00X2R50X0R90U2102RTC_HYM8563_TSSOP8_3R10X3R10X1RHYM8563TSTSSOP8_3R10X3R10X1R10U2200PMIC_RK806_QFN68_7R00X7R00X0R80RK806-1QFN68_7R00X7R00X0R80_TU2300DCDC_RK860_WLCSP20_1R65X2R05X0RRK860-2WLCSP20_1R65X2R05X0R63U2301DCDC_RK860_WLCSP20_1R65X2R05X_1RK860-3WLCSP20_1R65X2R05X0R63U2302DCDC_RK860_WLCSP20_1R65X2R05X0RRK860-2WLCSP20_1R65X2R05X0R63U2303DCDC_SY8088_SOT_23_5_ETA3409/SYETA3409/SY8089AACSOT_23_5U2304SWITCH_SGM2576_SOT_23_5_SGM2576SGM2576SOT_23_5U2501BQ25890_0_QFN24_4R00X4R00X0R80_BQ25890QFN24_4R00X4R00X0R80_TU2600USB_HUSB311_MLP14_2R50X2R50X0R8HUSB311MLP14_2R50X2R50X0R80U2602ESD_ESD73034D_SON10_2R50X1R00X0ESD73034DSON10_2R50X1R00X0R50U2603ESD_ESD73034D_SON10_2R50X1R00X0ESD73034DSON10_2R50X1R00X0R50U3800LPDDR4_200P_BGA200_15R00X10R00XLPDDR4_200PBGA200_15R00X10R00X0R90U3801LPDDR4_200P_BGA200_15R00X10R00XLPDDR4_200PBGA200_15R00X10R00X0R90U4000INAND_EMMC_153_2L_BGA153_13R00XEMMC_B153_2LBGA153_13R00X11R50X0R90_2LU4600UM1560DB_DFN4_1R00X1R00X0R40_T_UM1560DB_28DFN4_1R00X1R00X0R40_TU4601UM1560DB_DFN4_1R00X1R00X0R40__1UM1560DB_18DFN4_1R00X1R00X0R40_TU4602LDO_LP3983S_SOT_23_5_LP3983SLP3983SSOT_23_5U4700UM1560DB_DFN4_1R00X1R00X0R40__1UM1560DB_18DFN4_1R00X1R00X0R40_TU4701DCDC_SY8088_SOT_23_5_SY8088AACSY8088AACSOT_23_5U4702UM1560DB_DFN4_1R00X1R00X0R40_T_UM1560DB_28DFN4_1R00X1R00X0R40_TU5602DCDC_MP1488_SOT23-6_SY7200ASY7200ASOT23-6U6300MODULE_AP6XXX_1_MD50_WIFI-AP627AP6275PMD50_WIFI-AP6275PU7000AMPLIFIER_ES8388_QFN28_4R00X4R0ES8388QFN28_4R00X4R00X0R90_TU7003DCDC_SY8088_0_TSOT_23_5_SGM3786SGM37862TSOT_23_5U7004AMPLIFIER_PT1505_1_AW87359FCR_AAW87359FCRAW87359FCRU7005AMPLIFIER_PT1505_1_AW87359FCR_AAW87359FCRAW87359FCRU7006UM1560DB_DFN4_1R00X1R00X0R40__1UM1560DB_18DFN4_1R00X1R00X0R40_TY1100CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzCRY4_3R20X2R50X0R80Y2100CRYSTAL_2P_CRY2_3R20X1R50X0R90_32.768KHzCRY2_3R20X1R50X0R90Y6300CRYSTAL_4P_CRY4_3R20X2R50X0R8_137.4MHzCRY4_3R20X2R50X0R80 PCB 原理图。回复可见下载
**** Hidden Message ***** 谢谢分享!
