armclub 发表于 2024-3-24 21:03:40
富瀚微FH8626V100 demo 板开发板PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBT1BATTERY_CR1220_DISCRETE_CR1220CR1220CR1220BT2BATTERY_IV01E_DISCRETE_NC/XH414NC/XH414HG-IV01EIV01ECN1HEADER10X2_JTAG_10X2PIN 2.54MM10X2Pin2.54mmJTAGCN2PHONE_JACK,3.5MM,90D,DIP_5P_PHOPHONE_JACKPHONE_JACKCN4PHONE_JACK,3.5MM,90D,DIP_5P_PHOPHONE_JACKPHONE_JACKCON1RJ45_LED_RJ45_LED-1_RJ45_LEDRJ45_LEDRJ45_LED-1D1BV03CESD73031ND0402D2BV03CESD73031ND0402D3BV03CESD73031ND0402D41N6265/TO_0_RGL55_GL5537-1GL5537-1RGL55D5DIODE_2_DO-214AC_B250A-13FB250A-13FDO-214ACD6TVS_DO-214AA_SMBJ15CASMBJ15CADO-214AAD7LED_0_D0603_LEDREDLEDREDD0603D8BV03CESD73031ND0402D9BV03CESD73031ND0402D12SBD_SOT23_LBAT54CLT1GLBAT54CLT1GSOT23D13DIODE_1_SOD-323_IN4148WSIN4148WSSOD-323D14TVS_D0402_ESD5431NESD5431ND0402D15TVS_D0402_ESD73011NESD73011ND0402D16TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD17TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD18TVS_D0402_ESD5431NESD5431ND0402D19TVS_D0402_ESD5431NESD5431ND0402D20TVS_D0402_ESD5431NESD5431ND0402D23LED_LED0603_LEDGREENLEDGREENLED0603D24LED_LED0603_LEDGREENLEDGREENLED0603D25TVS_D0402_ESD73011NESD73011ND0402D26TVS_D0402_ESD73011NESD73011ND0402D27TVS_D0402_ESD73011NESD73011ND0402D28TVS_D0402_ESD5431NESD5431ND0402J1CON2_GMI6027P-2C_CON2-MICCON2-MICGMI6027P-2CJ2POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MMJ3DCJACK_DC-3_DC-JACKDC-JackDC-3J4CONNECT2_125MM_HEADER2_125MM_SM1.25T-2-2AHEADER2_125MM_SMDJ5MEC1-120-02-F-D-LC_HEADER20X2_1MEC1-120-02-F-D-LCHEADER20X2_1MM_SMDJ6CON3_SIP3_254MM_SIP3_254MMSIP3_254MMSIP3_254MMJ7CON4_HEADER4_125MM_UARTUartHEADER4_125MMJ8CONNECT2_125MM_HEADER2_125MM_SM1.25T-2-2AHEADER2_125MM_SMDJ9POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MMJ10POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MMJ11CON7_0_SIP4_254MM_SIP4_254MMSIP4_254MMSIP4_254MMJ12JUMP_SIP2_254MM_JUMPJumpSIP2_254MMJ13JUMP_SIP2_254MM_JUMPJumpSIP2_254MMJ14MIC_USB_MICRO_5P_OTG_USB/C91467OTG_USB/C91467MICRO_5PJ16POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MMJ17POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MMJ27SD_0_PROCONN_SD_SDCARDSDCardPROCONN_SDJ31POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MMJ39POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MMJ90USB-A_USBX1_SMD_USB-AUSB-AUSBX1_SMDJ111POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MMJ112POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MMJ114POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MML1INDUCTOR_L3X3H15_SWPA3015S4R7MTSWPA3015S4R7MTL3X3H15L2INDUCTOR_L3X3H15_SWPA3015S2R2NTSWPA3015S2R2NTL3X3H15L3INDUCTOR_L3X3H15_SWPA3015S2R2NTSWPA3015S2R2NTL3X3H15L4INDUCTOR_L4X4H3_SWPA4030S2R2NTSWPA4030S2R2NTL4X4H3LED17LED_G_1_LED0603_DISCRETE_LED_RLED_RLED0603MQ2AF2301P_SOT_23_AF2301PAF2301PSOT_23Q1NPN_SOT23_2_MMBT3904MMBT3904SOT23_2Q3MQ_AF2301P_0_SOT_23_AF2301PAF2301PSOT_23Q4NPNBCE_0_SOT23_2_MMBT3904MMBT3904SOT23_2Q5NPNBCE_0_SOT23_2_MMBT3904MMBT3904SOT23_2S1PUSH_BUTTON_1_KEY_2PIN_KEY_2PINkey_2pinKEY_2PINS2PUSH_BUTTON_1_KEY_2PIN_KEY_2PINkey_2pinKEY_2PINSW1POWERSWITCH_0_PS_3PIN_POWER SWPOWERSWITCHPS_3PINT1TESTPOINT_TP30_NC/TEST POINTNC/TestPointTP30T2TESTPOINT_TP30_NC/TEST POINTNC/TestPointTP30T3TEST_POINT_TP_TESTCOLLARTestCollarTPT4TEST_POINT_TP_TESTCOLLARTestCollarTPT5TESTPOINT_TP30_NC/TEST POINTNC/TestPointTP30T6TESTPOINT_TP30_NC/TEST POINTNC/TestPointTP30T7TEST_POINT_TP_TESTCOLLARTestCollarTPT8TEST_POINT_TP_TESTCOLLARTestCollarTPT9TEST_POINT_TP_TESTCOLLARTestCollarTPT10TEST_POINT_TP_TESTCOLLARTestCollarTPT11TEST_POINT_TP_TESTCOLLARTestCollarTPT12TEST_POINT_TP_TESTCOLLARTestCollarTPT13TEST_POINT_TP_TESTCOLLARTestCollarTPT14TESTPOINT_TP30_NC/TEST POINTNC/TestPointTP30T15TEST_POINT_TP_TESTCOLLARTestCollarTPT16TEST_POINT_TP_TESTCOLLARTestCollarTPT17TEST_POINT_TP_TESTCOLLARTestCollarTPT18TESTPOINT_MARK_NC/MARKNC/MARKMARKT19TEST_POINT_TP_TESTCOLLARTestCollarTPT20TESTPOINT_MARK_NC/MARKNC/MARKMARKT21TEST_POINT_TP_TESTCOLLARTestCollarTPT22TESTPOINT_TP30_NC/TEST POINTNC/TestPointTP30T23TESTPOINT_MARK_NC/MARKNC/MARKMARKT24TESTPOINT_MARK_NC/MARKNC/MARKMARKT25TEST_POINT_TP_TESTCOLLARTestCollarTPT26TEST_POINT_TP_TESTCOLLARTestCollarTPT27TEST_POINT_TP_TESTCOLLARTestCollarTPT28TEST_POINT_TP_TESTCOLLARTestCollarTPT29TEST_POINT_TP_TESTCOLLARTestCollarTPT30TEST_POINT_TP_TESTCOLLARTestCollarTPU1DC-DC-SY8088AAC_2_QFN10-SGM7229SGM7229YUWQ10G/TRQFN10-SGM7229U2QFN88_ZT_0_QFN88-ZT-SOCKET_QFN8QFN88_ZTQFN88-ZT-SOCKETU3A52815_4_SOT23_5_TPS79333DBVRTPS79333DBVRSOT23_5U4NORFLASH_SO8_200MIL_GD25Q127CSGD25Q127CSIG/W25Q128JVSIQSO8_200MILU5W25N01GV_SOP8_127_TH2_GD5F1GQ4UGD5F1GQ4UCYIG/W25N01GVZEIGSOP8_127_TH2U6DC-DC-SY8120B_SOT23_6_SY8120BSY8120BSOT23_6U7DC-DC-SY8088AAC_SOT23_5_SY8088ASY8088AACSOT23_5U8TSX-3225_CRSTALY_3225_SX32Y0240SX32Y024000B91T-U_24MHz9PF 10ppmCRSTALY_3225U9DC-DC-SY8088AAC_SOT23_5_SY8088ASY8088AACSOT23_5U10DC-DC-SY8088AAC_SOT23_5_SY8088ASY8088AACSOT23_5U12A52815_4_SOT23_SGM809-SXN3L/TRSGM809-SXN3L/TRSOT23U13CON2X4_2_UART_27_5MM_UART_FIX_HUART_FIX_HOLEUART_27_5MMU14PCF85163T/I_SOP8_PCF85163T/IPCF85163T/ISOP8U15MC146_MC-146_Q13MC1462000200/32Q13MC1462000200/32.768KhzMC-146U16AZ6208BM_SOP8_127-620X500_AZ620AZ6208BMSOP8_127-620X500U18MC146_MC-146_Q13MC1461000600_3Q13MC1461000600_32.768kHz 6pF 20ppmMC-146U19USR-TCP232-E2_USR-TCP232-E2_USRUSR-TCP232-E2USR-TCP232-E2U21SWDIP8_3_SW_6X2_127_SMD_SW_6X2SW_6X2_127_SMDSW_6X2_127_SMDU56PE-68515_1_SOP16_270_50_PPT44-1PPT44-11BPSOP16_270_50U57IP101GR_QFN32_04_TH_IP101GRIP101GRQFN32_04_TH
armclub 发表于 2024-3-24 21:04:43
PCB文件。回复可见
**** Hidden Message *****
sassa 发表于 2024-3-24 22:45:52
cat 发表于 2024-3-24 23:07:53
317 发表于 2024-3-25 00:04:38
谢谢分享!
旧尔一 发表于 2024-3-25 00:04:50
谢谢分享!
晕哥 发表于 2024-3-25 00:08:16
谢谢分享!
lf2k2022 发表于 2024-3-25 00:30:38
767955407 发表于 2024-3-25 07:21:33
bidezhi7777 发表于 2024-3-25 07:43:58
页: [1] 2 3 4 5 6 7 8
查看完整版本: 富瀚微FH8626V100 demo 板开发板PCB文件共享
