全志V853 ALLWINNER V853 4层挂一个DDR3 DEMO板PCB 原
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB1FB-0402_L0402_600R/100M600R/100ML0402B2FB-0402_L0402_NC-600R/100MNC-600R/100ML0402B3FB-0402_L0402_600R/100M600R/100ML0402B4FB-0603_L0603_100R-1A100R-1AL0603B5FB-0603_L0603_100R-1A100R-1AL0603B6FB-0603_L0603_100R-1A100R-1AL0603B7FB-0603_L0603_100R-1A100R-1AL0603BAT21CR927CSECM94C-C1206_C1206_1NF/2KV1nF/2KVC1206CON1FPC-SMD-0.3-31P_FPC-SMD-0_3-31PFPC-SMD-0.3-31PFPC-SMD-0_3-31PCON2HR911130A-RJ45_1_RJ45-HR911130AHR911130A-RJ45RJ45-HR911130ACS2C-C0805_C0805_10UF-25V10uF-25VC0805CS3C-EC0806-SMD_CA830H620_NC-220UFNC-220uF-25VCA830H620CS4C-C0402_C0402_47PF47pFC0402D1ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402D2ESD5451X_ESD0402_NC-ESD5451X-2-NC-ESD5451X-2-TRESD0402D3ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402D4ESD9B5VL_ESD0402_NC-ESD5451XNC-ESD5451XESD0402D5ESD9B5VL_ESD0402_NC-ESD5451XNC-ESD5451XESD0402D6ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402D7ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402D12ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402D13ESD5451X_ESD0402_NC-ESD5451X-2-NC-ESD5451X-2-TRESD0402D15ESD9B5VL_ESD0402_NC-ESD5451XNC-ESD5451XESD0402D16ESD9B5VL_ESD0402_NC-ESD5451XNC-ESD5451XESD0402D17ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402D18DIO-B5819W_SOD155_270H118_B5819B5819WSOD155_270H118D19ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402D20ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402DC1ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DC2ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DC3ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DC4ESD5451X_ESD0402_NC-ESD5451X-2-NC-ESD5451X-2-TRESD0402DC5ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402DC6ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DC7ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DC8ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DL1DIO-SS16F_SOD250_380H100_SS16FSS16FSOD250_380H100DM10SPD9103W_SOD323_NC-SPD9103WNC-SPD9103WSOD323DM11SPD9103W_SOD323_NC-SPD9103WNC-SPD9103WSOD323DM12SPD4200B_SMB_NC-SPD4200BNC-SPD4200BSMBDM13SPD4200B_SMB_NC-SPD4200BNC-SPD4200BSMBDP1LED-0603-G_LED0603_LED-0603-GLED-0603-GLED0603DP2LED-0805-R_LED0805_LED-0805-RLED-0805-RLED0805DP3LED-0805_LED0603_BLUEBLUELED0603DU1ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DU2ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DU3ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402DU4ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402DU6DIO-SS24_SOD362_432H229_SS24SS24SOD362_432H229DU7ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DU8ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DU9ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402DU10ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DU11ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402DU12ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402F2FUSE_R1206_FUSE(16V/1.5A)FUSE(16V/1.5A)R1206FB4FB-0603_L0603_100R-1A100R-1AL0603FB10FB-0603_L0603_100R-1A100R-1AL0603FB5903BEAD_L0402_1K-100MHZ1K-100MHzL0402FB5904BEAD_L0402_1K-100MHZ1K-100MHzL0402FB6701BEAD_L0603_120R-100MHZ120R-100MHzL0603H1HOLE_MTH635D320_HOLEHOLEMTH635D320H2HOLE_MTH635D320_HOLEHOLEMTH635D320H3HOLE_MTH635D320_HOLEHOLEMTH635D320H4HOLE_MTH635D320_HOLEHOLEMTH635D320J4JUMPER-2_HDR1_2P254B250_508H254JTAG-SELHDR1_2P254B250_508H254J5CON1X2-2.54-M_HDR1_2P254B250__1CON1X2-2.54-MHDR1_2P254B250_508H254J6CON1X2-2.54-M_HDR1_2P254B250__1CON1X2-2.54-MHDR1_2P254B250_508H254J7CON1X2-2.54-M_HDR1_2P254B250__1CON1X2-2.54-MHDR1_2P254B250_508H254J8CON1X2-2.54-M_HDR1_2P254B250__1CON1X2-2.54-MHDR1_2P254B250_508H254J9CON1X2-2.54-M_HDR1_2P254B250__1CON1X2-2.54-MHDR1_2P254B250_508H254J12DC3-2.0MM-14P_HDR2_7P200B550_21DC3-2.0MM-14PHDR2_7P200B550_2130H560J14CON1X2-2.54-M_HDR1_2P254B250_50NC-CON1X2-2.54-MHDR1_2P254B250_508H254J18PJ-327F_HP5B650_1400H500_PJ-327PJ-327FHP5B650_1400H500J20CON1X6-2.54-M_HDR1_6P254B250_15CON1X6-2.54-MHDR1_6P254B250_1524H254J23FPC-26P-0_0.5MM-B-SDV_FPC24P50BFPC-24P-0.5MM-VFPC24P50B190_1850H300J30CON1X4-2.54-M_HDR1_4P254B250_10CON1X4-2.54-MHDR1_4P254B250_1016H254J52JUMPER-2_HDR1_2P254B250_508H2_1LINEOUTPHDR1_2P254B250_508H254J53JUMPER-2_HDR1_2P254B250_508H2_2LINEOUTNHDR1_2P254B250_508H254J55JUMPER-2_HDR1_2P254B250_508H2_3BOOT-SEL1HDR1_2P254B250_508H254J56JUMPER-2_HDR1_2P254B250_508H2_4BOOT-SEL0HDR1_2P254B250_508H254J57CON2X6-2.54-M_HDR2_6P254B500_15CON2X6-2.54-MHDR2_6P254B500_1524H254J59XH1.25MM-2P-M_CON2-PT1_25-3_2X4XH1.25MM-2P-MCON2-PT1_25-3_2X4_35H4_8B-UPJ65XH1.25MM-7P-M_CON7-PT1_25-3_2X1NC-XH1.25MM-7P-MCON7-PT1_25-3_2X10_6H4_8A-UPJ68CON1X4-2.54-M_HDR1_4P254B250__1NC-CON1X4-2.54-MHDR1_4P254B250_1016H254J69XH2.54MM-5P-M_HDR1_5P250B570_15XH2.54MM-5P-MHDR1_5P250B570_1500H700J70XH1.25MM-4P-M_CON4-PT1_25-3_2X6NC-XH1.25MM-4P-MCON4-PT1_25-3_2X6_85H4_8A-UPJ71JUMPER-2_HDR1_2P254B250_508H2_5DBG-CLKHDR1_2P254B250_508H254J72CON1X2-2.54-M_HDR1_2P254B250_50NC-CON1X2-2.54-MHDR1_2P254B250_508H254J74FPC-26P-0_1.5MM-B-SDV_FPC25P50BFPC-25P-0.5MM-VFPC25P50B190_1850H300J75FPC-26P-0_0.5MM-B-SDV_FPC24P50BFPC-24P-0.5MM-VFPC24P50B190_1850H300J76CON-10X2-P2_54_CON-10X2-P2_54_CCON-10x2-2_54-FCON-10X2-P2_54J77XH1.25MM-7P-M_CON7-PT1_25-3_2X1NC-XH1.25MM-7P-MCON7-PT1_25-3_2X10_6H4_8A-UPJC1TF-SLOT_SDC13B1450_1472H245_TF-TF-SLOTSDC13B1450_1472H245JL5FPC-6P-0.5MM-V_FPC-SMD-6P-P0_5_FPC-6P-0.5MM-VFPC-SMD-6P-P0_5JL6FPC-6P-0.5MM-V_FPC-SMD-6P-P0_5_FPC-6P-0.5MM-VFPC-SMD-6P-P0_5JM6RJ45-LED_RJ14P102B1645_1650H134NC-RJ45-LEDRJ14P102B1645_1650H1346JM7RJ45-LED_1_RJ45-8P-NCLED_RJ45RJ45RJ45-8P-NCLEDJS1DCIN-12V_PWR3B900_1400H1100_DCIDCIN-12VPWR3B900_1400H1100JS3XH2.0MM-3P-M_CON3-PT2_XH2.0MM-3XH2.0MM-3P-MCON3-PT2JU1USB2.0-MICRO-01F_USB9P65B500_69USB2.0-MICRO-01FUSB9P65B500_690H240JU2JUMPER-2_HDR1_2P254B250_508H2_6USB-SELHDR1_2P254B250_508H254JU3XH1.25MM-5P-M_CON5-PT1_25-3_2X8XH1.25MM-5P-MCON5-PT1_25-3_2X8_1H4_8A-UPJU4USB2.0-A-02F_USB8P200B512_1925HNC-USB-A-02FUSB8P200B512_1925H1250JU5XH1.25MM-5P-M_CON5-PT1_25-3_2_1NC-XH1.25MM-5P-MCON5-PT1_25-3_2X8_1H4_8A-UPJW3ANT-IPX_ANT3B300_310H125_ANT-IPANT-IPXANT3B300_310H125K1KEY-04P-SMD-03_KEY4B450_450H380VOL+KEY4B450_450H380K2KEY-04P-SMD-03_KEY4B450_450H3_1VOL-KEY4B450_450H380K3KEY-04P-SMD-03_KEY4B450_450H3_2MENUKEY4B450_450H380K4KEY-04P-SMD-03_KEY4B450_450H3_3ENTERKEY4B450_450H380K5KEY-04P-SMD-03_KEY4B450_450H3_4HOMEKEY4B450_450H380K6KEY-04P-SMD-03_KEY4B450_450H3_5UBOOTKEY4B450_450H380KP1KEY-04P-SMD-03_KEY4B450_450H3_6RESETKEY4B450_450H380KP2KEY-04P-SMD-03_KEY4B450_450H3_7PWRONKEY4B450_450H380L3INDUCTOR_L0806_2.2UH-0.6ADCR<02.2uH-0.6ADCR<0.2RL0806L18INDUCTORSOF FERRITE_IND-SMD-202.2uHIND-SMD-2016LCD2CON25-0.5MM_FPC-SMD-25P-P0_3_COCON25FPC-SMD-25P-P0_3LL1L-L2520_LP200_250H100_10UH-0.9A10uH-0.9A-DCR<0.02RLP200_250H100LP1L-L3225_CD32_1UH-2A1uH-2ACD32LP2L-L3225_CD32_1UH-2A1uH-2ACD32LP3L-L3225_CD32_NC-1UH-2ANC-1uH-2ACD32LP4L-L3225_CD32_1UH-2A1uH-2ACD32LP5L-L3225_CD32_1UH-2A1uH-2ACD32LS1L-L8080_LP800_800H420_6.8UH-DCR6.8uH-DCR<0.1R-4ALP800_800H420MIC1MIC-DGHSEM6050_MIC2B600H500_DGHDGHSEM6050MIC2B600H500MIC2MIC-DGHSEM6050_MIC2B600H500_DGHDGHSEM6050MIC2B600H500MIC10XH1.25MM-2P-M_CON2-PT1_25-3_2X4XH1.25MM-2P-MCON2-PT1_25-3_2X4_35H4_8B-UPMIC20XH1.25MM-2P-M_CON2-PT1_25-3_2X4XH1.25MM-2P-MCON2-PT1_25-3_2X4_35H4_8B-UPP1TVS2_1_2_DIO214_4D_2SP_4D5W2D61TVS2_1_2DIO214_4D_2SP_4D5W2D615L_12P2TVS2_1_2_DIO214_4D_2SP_4D5W2D61TVS2_1_2DIO214_4D_2SP_4D5W2D615L_12Q3NPN-MMBT3904_SOT3P95B130_290H10MMBT3904SOT3P95B130_290H103Q12NMOS-2N7002_SOT3P95B130_290H103NC-2N7002SOT3P95B130_290H103Q13NMOS-2N7002_SOT3P95B130_290H103NC-2N7002SOT3P95B130_290H103Q14NMOS-2N7002_SOT3P95B130_290H103NC-2N7002SOT3P95B130_290H103Q15NMOS-2N7002_SOT3P95B130_290H103NC-2N7002SOT3P95B130_290H103QC1PMOS-STS2301_SOT3P95B130_290H10STS2301SOT3P95B130_290H103TS1TESTPOINT-SMD_TP100_ACINACINTP100U1AW8010CSR_BGA9P50B145_145H65_AWAW8010CSRBGA9P50B145_145H65U3SGM2028_SOT5P95B160_300H130_RT9RT9078-2.8VSOT5P95B160_300H130U4GPR25L005B_0_SOP10-PT05-MMA7660DA380SOP10-PT05-MMA7660FC-H1AU5CS8302_MSOP-8P_NS4890NS4890MSOP-8PU15RS232_SIPEX_SP3232E_TSSOP_D65X5RS232TSSOP_D65X5D775_16SP_5D6LU24SY6280_SOT5P95B160_300H130_SY62SY6280SOT5P95B160_300H130U47SENSOR-BMA250_LGA12P50B200_200HNC-SC7A20TRLGA12P50B200_200H100U4000INAND_EMMC_153_2L_BGA153_13RX11EMMC_B153_2LBGA153_13RX11R5X0R9_2LU4001YT8521S_QFN48-6X6_YT8521SYT8521SQFN48-6X6U6702CRYSTAL4PIN_0_CRY-TSX3225_40MHZ40MHz/24MHzCRY-TSX3225UD1DDR3-FBGA96_BGA96P80B1000_1400HDDR3-FBGA96BGA96P80B1000_1400H120UL1SY7200A_SOT6P95B160_290H145_LP3LP3380B6FSOT6P95B160_290H145UL5SGM2028_SOT5P95B160_300H130_AP2AP2127-2.8VSOT5P95B160_300H130UM4H1601CG_SOP16P127B690_1260H584_NC-H1601CGSOP16P127B690_1260H584UP1AXP2101_0_QFN41P40B500_500H75_AAXP2101QFN41P40B500_500H75UP2SGM2028_SOT5P95B160_300H130_A_1AP2127K-1.8TRG1SOT5P95B160_300H130US1SY8105_SOT6P95B160_290H145_SY81SY8105SOT6P95B160_290H145UU1V853_0621_BGA318P50B1200_1200H1V853BGA318P50B1200_1200H113UU3SGM7227_SOP10P50B300_300H110_NCNC-SGM7227SOP10P50B300_300H110UU4GL850G_SSOP28-5_3X10_2PT0_65H2ANC-GL850G-SSOP28SSOP28-5_3X10_2PT0_65H2AWU2AW1732-NOSOCKET_QFN40P500X500X8XR829QFN40P500X500X80-41NX1CRY-32.768KHZ-3215-SMD_CRYSTAL-ETST00327000JECRYSTAL-2P-3215-H0_85AX4CRYSTAL_SMD_2_SMD_3225_4P_25MHZ25MHzSMD_3225_4PY1CRY-24MHZ-3225-SMD_X4B250_320H124M-16pF-10ppmX4B250_320H120_SMDY4CRY-12MHZ-3225-SMD_X4B250_320H112M-20pF-10ppmX4B250_320H120_SMD PCB是allegro格式,原理图是PDF格式。一起打包。回复可见
**** Hidden Message *****
