6层盲埋孔 intel Bay trail(Z3735G) WIN平板PCB
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT6401ANT_WFL-R-SMT_ANT-IPEX-SMALL_WFWFL-R-SMTANT-IPEX-SMALLD2001DIODE_0_SOD123_1N58191N5819SOD123D8201D_1N5819HW_SOD123_1N5819HW1N5819HWSOD123D9201LED_6_IR-IR234C-D3_IR12-21C-TR8IR12-21C-TR8IR-IR234C-D3FB6201INDUCTOR_L0402_600R/100MHZ600R/100MHzL0402FB6202INDUCTOR_L0402_600R/100MHZ600R/100MHzL0402FB6401FB0402_SMR0402_600R@100MHZ600R@100MHzSMR0402FB7000FERRITE_ALTSIZE_SMR0402_FERRITEFERRITE_ALTSIZESMR0402FB7001FERRITE_ALTSIZE_SMR0402_FERRITEFERRITE_ALTSIZESMR0402FB7005FERRITE_ALTSIZE_SMF0402_1P15XP6FERRITE_ALTSIZESMF0402_1P15XP65_P65HFB7006FERRITE_ALTSIZE_SMF0402_1P15XP6FERRITE_ALTSIZESMF0402_1P15XP65_P65HFB7007FERRITE_ALTSIZE_SMF0402_1P15XP6FERRITE_ALTSIZESMF0402_1P15XP65_P65HFB7008FERRITE_ALTSIZE_SMF0402_1P15XP6FERRITE_ALTSIZESMF0402_1P15XP65_P65HFB7009FERRITE_ALTSIZE_SMF0402_1P15XP6FERRITE_ALTSIZESMF0402_1P15XP65_P65HFB7010FERRITE_ALTSIZE_SMF0402_1P15XP6FERRITE_ALTSIZESMF0402_1P15XP65_P65HFB7011FERRITE_ALTSIZE_SMR0402_FERRITEFERRITE_ALTSIZESMR0402FB7012FERRITE_ALTSIZE_SMR0402_FERRITEFERRITE_ALTSIZESMR0402FIL6401FIL_SAW-856561_DFN5_B9482(1575MB9482(1575MHz)DFN5FIL6402FIL_SAW-856561_DFN5_B9482(1575MB9482(1575MHz)DFN5J2001BATTERY_0_CON-SMT-1_25-5P_LI_3.LI_3.7VCON-SMT-1_25-5PJ3501CON12_MICROSD_MTG4_0_TF-PUSH-WACON12_MICROSD_MTG4TF-PUSH-WAIJ6201ANT-2_0.2_ANT-IPEX-SMALL_ANT-2.ANT-2.2ANT-IPEX-SMALLJ7001CON-SMT-1_0_CON-PAD-2_5-2P_CON-con-pad-2_5-2pCON-PAD-2_5-2PJ7003PJ381-2_0_PJ5P-SK1_35-JHP3016-JPJ-B2318s-bellPJ5P-SK1_35-JHP3016-JXTJ7004TOUCH_SCREEN_0_CON-FPC-P0_5H1_0FPC_6PIN_0.5MMCON-FPC-P0_5H1_0-6P-OPJ8401CON34_3_CON-FPC-P0_5H2_0-40P-OPT070BWS141TCON-FPC-P0_5H2_0-40P-OPJ8402CON34_5_CON-FPC-P0_5H2_0-30P_RKRK070AWXI30CON-FPC-P0_5H2_0-30PJ8504CON24_RCPT_CAM_BYT_CR_CON-BTB-PCON24_RCPT_CAM_BYT_CRCON-BTB-P0_4H1_5W4_1F-24P-OPJ8505CON24_RCPT_CAM_BYT_CR_CON-BTB-PCON24_RCPT_CAM_BYT_CRCON-BTB-P0_4H1_5W4_1F-24P-OPJ9201CON45P_0_CON-FH26-P0_3H1_2-45P-CON45CON-FH26-P0_3H1_2-45P-OPJ9400FH55-22S-0_6.5SH_CON-FH26-P0_3HFH55-22S-0.5SHCON-FH26-P0_3H1_0-25P-OPL2007IND_ALTSIZE_SML2520_1P2H_1.0UH_1.0UHSML2520_1P2HL2008INDUCTOR_1_IND-4X4_4.7UH/1.5A4.7uH/1.5AIND-4X4L6201INDUCTOR_0_L0201_4.7NH4.7nHL0201L6202INDUCTOR_0_L0201_NC/4.7NHNC/4.7nHL0201L6203INDUCTOR_IND-3X3_NC/3.3UH/0.7ANC/3.3uH/0.7AIND-3X3L6401L0402_SMR0402_0R0RSMR0402L6402L0402_SMR0402_6.8NH6.8nHSMR0402L6403L0402_SMR0402_6.8NH6.8nHSMR0402L8201L_LVS404018_IND-4X4_10UH10uHIND-4X4L8401CHOKE_4PIN_ALT_MCZ0806AH_80OHM_80OHM_100MHZMCZ0806AHL8402CHOKE_4PIN_ALT_MCZ0806AH_80OHM_80OHM_100MHZMCZ0806AHL8403CHOKE_4PIN_ALT_MCZ0806AH_80OHM_80OHM_100MHZMCZ0806AHL8404CHOKE_4PIN_ALT_MCZ0806AH_80OHM_80OHM_100MHZMCZ0806AHL8405CHOKE_4PIN_ALT_MCZ0806AH_80OHM_80OHM_100MHZMCZ0806AHL9000CHOKE_4PIN_ALT_MCZ0806AH_80OHM_80OHM_100MHZMCZ0806AHMOD2AMPAK_SIPAP6476MODULE-WIFI-AP6476-U3PQ2000WPM1481_0_LCC6_P65MM_SQ2P05MM_NWPM1481LCC6_P65MM_SQ2P05MM_NSQ8401MOSFET_N_SOT523_2SK30192SK3019SOT523Q8402MOSFETP_SOT23_VIC1121VIC1121SOT23Q8403MOSFETN_SOT523_2SK30192SK3019SOT523Q8404MOSFETN_SOT523_2SK30192SK3019SOT523Q9201MOSFETN_SOT23_VIC1221DIVIC1221DISOT23RT2000THERMISTOR_SMRT0402_27X47_10K_D10KSMRT0402_27X47RT2001THERMISTOR#1_SMRT0402_27X47_NC/NC/10KSMRT0402_27X47U1000SOC_VLV2_CR_CONCEPT_CUST_WW3_BGSOC_VLV2_CR_CONCEPT_CUST_WW3BGA592_P65MM_17X17U2003AXP288_1P04_LCC76_P4MM_SQ9P1MM_AXP288_1P04LCC76_P4MM_SQ9P1MM_EP5P5U2006G5121_1_SOT26_MT3608MT3608SOT26U2010LPW5206H_SOT25_MT9700MT9700SOT25U3005MT41K256M16_BGA96_P8MM_9P1X14P1MT41K256M16BGA96_P8MM_9P1X14P1U3006MT41K256M16_BGA96_P8MM_9P1X14P1MT41K256M16BGA96_P8MM_9P1X14P1U3500U_W25Q64FWSSIG_0_SOP8_LCC8_MX25MX25U6435FM2I-10GSOP8_LCC8U3501KLM8G1WEMB_B031_0_BGA153_11P5X1KLM8G1WEMB_B031BGA153_11P5X13_12MILPADU6201BCM43438_0_BCM43438_BCM43438BCM43438BCM43438U6202LFB212G45CG7D227_1_LFB212G45CG7LFB212G45CG7D227LFB212G45CG7D227U6203LM1086_2_SOT26_SOT363_NC/NL27WZNC/NL27WZU04SOT26_SOT363U6401MAX2659_0_AFN_MAX2659_MAX2659MAX2659AFN_MAX2659U6402U_BCM4752IFBG_BGA49_P65_5SQ_1P3BCM4752IFBGBGA49_P65_5SQ_1P3H_PAD12MILU7001ALC5640_VB_LCC48_P4MM_SQ6MM_1P0ALC5640_VBLCC48_P4MM_SQ6MM_1P0HU700274LVC1G126_SOT23_5_74LVC1G126_G74LVC1G126SOT23_5U7003MIC_AMS_O40S42_EC1_1_CON-PAD-2_MIC_AMS_O40S42_EC1CON-PAD-2_5-2PU8001KXCJK_1013_LCC16_NS_P5MM_SQ3MM_KXCJK_1013LCC16_NS_P5MM_SQ3MM_1P01HU8002AK09911C_12MILPAD_BGA8_P4MM_1P1AK09911C_12MILPADBGA8_P4MM_1P19SQ_P57H_12MILPADU8003BMC150_LCC14_P4MM_2P2SQ_BMC150_BMC150LCC14_P4MM_2P2SQ_BMC150U8004KXCJ9-1008_LGA10_0_65_3X3MM_KXCKXCJ9-1008LGA10_0_65_3X3MMU8005BMG160_LCC12_NS_P5MM_SQ3MM_1P0HBMG160LCC12_NS_P5MM_SQ3MM_1P0HU8201U_MP3202_SOT26_MT9201MT9201SOT26U8401CE71XXMM_SOT23_ME6206A-1V8ME6206A-1V8SOT23U9001TUSB1210_LCC32_P5MM_5SQ_EP3P45_TUSB1210LCC32_P5MM_5SQ_EP3P45U900974AVC1T45YZP_BGA6_5MM_1P4_P9_7474AVC1T45YZPBGA6_5MM_1P4_P9U9010AOZ6184_DPDT_LCC10_P4MM_1P8X1P4AOZ6184_DPDTLCC10_P4MM_1P8X1P4U9201GT911_0_QFN52-0_4-6X6-GT911_GT9GT911QFN52-0_4-6X6-GT911Y1000XTAL_4PIN_SMY_4P_79X98_PAD37X3925.0MHZSMY_4P_79X98_PAD37X39_24HY1001XTAL_0_CRY-MC146_32.768KHZ_G41032.768KHZCRY-MC146Y6201CRYSTAL-4_0_CRY-D3225_NC/26M-20NC/26M-20ppmCRY-D3225Y6202CRYSTAL-4_0_CRY-D3225_26M-20PPM26M-20ppmCRY-D3225Y6401KT2016A26000ACW18TLG_BRCM_0_TCXKT2016A26000ACW18NANTCXO_KT2016_2X1D6_0D8 PCB文件。回复可见下载。
**** Hidden Message ***** 等级不够,没有显示的权力 谢谢分享!
